75 Pages V  « < 5 6 7 8 9 > »
foo_wave_seekbar, pretty accelerated seekbar
Zao
post Jan 8 2010, 16:16
Post #151
Group: Members (Donating)
QUOTE (Devocalypse @ Jan 8 2010, 14:22) *
However when the computer is Locked (Win+L) and the Foobar window is NOT minimized I get constant 100% cpu usage on my C2D.
Reported in early 0.0.x series, I lose the device and do probably not do the re-acquire test properly.
QUOTE (TomBarlow @ Jan 8 2010, 16:04) *
I think this component is causing problems for me when I listen to radio streams.
Remove the component and see what happens? Also, what protocol; it should completely ignore MMS etc.
QUOTE (LarsK @ Jan 8 2010, 16:12) *
is it possible to start playing with double click in the waveform?
Requested already.
TomBarlow
post Jan 8 2010, 17:53
Post #152
If I set the panel to hidden (in columns UI layout prefs) everything is fine. The bad things only happen after listening to the stream for about 5 minutes or more. It's an m3u stream. From what I could see of the console it said it was skipping the stream. It also happens with mms streams. It seems to happen every time I listen to one, but only after a while.
Zao
post Jan 8 2010, 20:06
Post #153
As the GDI+ mode is an overnight hack, it may very well be horribly broken.
A quick inspection with Process Explorer tells me I'm leaking GDI handles like crazy. Yay.
(Sly)
post Jan 8 2010, 20:55
Post #154
Major bug: I was playing Heroes Might & Magic III in fullscreen when i discovered this bug.
On track change (one track ended other started) the playback stopped until i Alt-Tab-ed out from the game, after that playback continued normally. This happened on every tack change. Everybody knows that this is not a CPU speed problem, Heroes III uses very few resources. I'm running Windows XP SP3, DX9C latest, T2390 1.86GHz, 2GB RAM, Intel Mobile 965 Express @ Laptop.
LAME 3.99.5 -V0
Zao
post Jan 9 2010, 08:04
Post #155
0.1.8 is out, improving greatly on performance, especially the high load when listening to streams. See changelog for all the changes.
(Sly)
post Jan 9 2010, 09:49
Post #156
QUOTE ((Sly) @ Jan 8 2010, 21:55) *
Bug is gone with 0.1.8. I was using 0.1.4.
Keep up the good work. Waiting for embended data in tags, or datatbase in root of music library. I hope that Peter releases the SDK for writing Default UI elements, for you to be able to create this greate addon as pure toolbar element.
This post has been edited by (Sly): Jan 9 2010, 09:50
LAME 3.99.5 -V0
kode54
post Jan 9 2010, 10:49
Post #157
Group: Admin
QUOTE ((Sly) @ Jan 9 2010, 00:49) *
It already is a UI Element. There is no way for components to add to the toolbar.
Hamallainen
post Jan 9 2010, 12:34
Post #158
No more flickering with gdi. Thanks
fuflo
post Jan 9 2010, 16:30
Post #159
regarding the effects:
i have some general knowledge in programming, but not graphical.
how would i go about changing the bar() function to make the bar smaller in vertical size? the reason i'm asking is i'm trying out some designs for foobar with this component and it would look much less blockier if the bar was a little smaller vertically.
i tried hacking the default effect a little to no avail...
Zao
post Jan 9 2010, 17:54
Post #160
QUOTE (fuflo @ Jan 9 2010, 16:30) *
The following code may be acceptable and will available for use in the default effect in next release. Tweak the last two parameters to the function to indicate from what amplitude the bar should start fading and which amplitude it's fully gone. For fun, also try reversing the order of them, which would give a bar that's hollow towards zero.
float4 fade_bar( float pos, float2 tc, float4 fg, float4 bg, float width, bool show, float vert_from, float vert_to )
    float dist = abs(pos - tc.x);
    float vertical = smoothstep(vert_from, vert_to, abs(tc.y));
    float4 c = show
        ? lerp(fg, bg, max(vertical, smoothstep(0, width, dist)))
        : bg;
    return c;
For example, to fade from solid at amplitude 0.3 to 0.8:
c0 = faded_bar(cursorPos, input.tc, selectionColor, c0, positionWidth, cursorVisible, 0.3, 0.8);
This post has been edited by Zao: Jan 11 2010, 06:35
fuflo
post Jan 9 2010, 22:24
Post #161
hmm.. either i'm doing it wrong or i have no idea..
it doesn't seem to have any effect. i added that function to default seekbar.fx and replaced bar() references with fade_bar() with added values 0.3 and 0.8 where you mentioned and it doesn't seem to have any effect.
also from your description of that function it doesn't seem to be what i actually want..
ps. although as i'm writing this, i had a couple or more beers so i'll check back tommorow with a clear mind smile.gif
Gapkiller
post Jan 9 2010, 22:45
Post #162
feature request:
Please add function to temporarily turn off wave analyzing.
When i make playlists I scroll and click tracks pretty fast so it gets very high on cpu usage...
It would be perfect if it would display only the scrollbar without analyzing!
Thx
Zao
post Jan 9 2010, 22:59
Post #163
QUOTE (fuflo @ Jan 9 2010, 22:24) *
Left to right is (0.3, 0.7), (0.3, 0.35), (0.7, 0.3).
If you've got a seekbar.fx in both your profile and foobar dir, it prefers the profile one. Also, note that .fx files only affect the Direct3D mode, not GDI or Direct2D.
QUOTE (Gapkiller @ Jan 9 2010, 22:45) *
The processing threads run at idle priority, so it should not be horribly noticeable, responsivity-wise.
But yes, an "inhibit enqueueing of new tracks" command might be doable. It'd be tricky to get it to affect work items previously enqueued though.
Gapkiller
post Jan 9 2010, 23:13
Post #164
Thank you for considering this. Would be a very helpful feature to me!
This post has been edited by Gapkiller: Jan 9 2010, 23:13
Hancoque
post Jan 10 2010, 01:12
Post #165
How is the waveform calculated? Is it just a sum of all channels? I noticed that the channels of a 5.1 file are treated differently. The LFE channel, for example, receives a boost. I'd like to be able to limit the calculation to certain channels or even use only one channel. As most music is in stereo, a two-channel view would also be great. The main reason for me to use this component would be to examine the material as accurately as possible, especially in terms of dynamics compression. That possibility is greatly reduced when viewing only a mono sum as it makes the material look better than it really is.
boombaard
post Jan 10 2010, 01:53
Post #166
QUOTE (Hancoque @ Jan 10 2010, 02:12) *
Actually, my girlfriend will love this visualizer. I acquainted her with the Loudness War a while back, and it's helped her identify why she didn't care for some music without really knowing why. Still, it would be nice to have 2 channels, or at least know if the single-wave output is RMSed or summed.
In any case: Thanks Zao smile.gif
Zao
post Jan 10 2010, 03:24
Post #167
The mixdown algorithm is very unscientific.
switch (channelCount)
case 8:
    frame[0] += frame[6] * sqrt_half;
    frame[1] += frame[7] * sqrt_half;
case 6:
    frame[0] += frame[2] * sqrt_half + frame[4] * sqrt_half + frame[3];
    frame[1] += frame[2] * sqrt_half + frame[5] * sqrt_half + frame[3];
case 2:
    frame[0] += frame[1];
    frame[0] /= 2.0;
    break;
case 4:
    frame[0] += frame[1] + frame[2] + frame[3];
    frame[0] /= 4.0;
That is, 7.1ch is mixed to 5.1ch.
5.1ch is mixed to stereo.
Stereo is averaged to mono (which will mislead with phase-skewed channels).
4ch is similarily averaged to mono.
fuflo
post Jan 10 2010, 12:41
Post #168
finally found why fade_bar didn't work for me.
from your example:
float4 fade_bar( float pos, float2 tc, float4 fg, float4 bg, float width, bool show, float vert_from, vert_to )
should be:
This post has been edited by fuflo: Jan 10 2010, 12:41
TomBarlow
post Jan 10 2010, 15:40
Post #169
Thanks for the latest version, it works well and looks great.
Would a transparent background be possible at all? Or maybe the ability to define a background image? I realise the foreground colour is calculated using the background colour, so maybe not, just thought I'd suggest it smile.gif
boombaard
post Jan 10 2010, 17:13
Post #170
Something quite problematic my gf pointed out:
Background: Black
foreground: Red
(hl: darkgreen selection:yellow
Now, if I disable the fg color, the fg (that is, the waveform) becomes white, but it also grows by a significant %age. What's happening there? wink.gif
(The same thing applies when you change the bg color, btw)
This post has been edited by boombaard: Jan 10 2010, 17:15
aphasia
post Jan 10 2010, 17:33
Post #171
Thanks for a very cool component. Kudos Zao!
fuflo
post Jan 10 2010, 17:44
Post #172
hmm.. i don't know if this is a bug but with d3d, making foobar's window transparent, wave seekbar's bg is black ( and not transparent ). gdi is fine
This post has been edited by fuflo: Jan 10 2010, 17:45
Zao
post Jan 11 2010, 03:18
Post #173
QUOTE (fuflo @ Jan 10 2010, 12:41) *
I'm fairly sure that the console should log any effect compilation errors with line and column.
QUOTE (TomBarlow @ Jan 10 2010, 15:40) *
Since early on, I have intended to load any textures referenced by annotations in the effect file, but sadly enough I have not implemented it yet.
An example of such an annotation is line 2 of the default seekbar.fx.
QUOTE (boombaard @ Jan 10 2010, 17:13) *
Background: Black
foreground: Red
At the edge of the waveform, the color is bg. To a certain distance inside the waveform, the color is linearly interpolated to fg. Inside of that distance, color continues the interpolation, depending on how b and fg relate to each other.
If bg.r is redder than fg.r, the center will go towards a color without red.
If bg.r is less red than fg.r, it will go towards a full red component.
Likewise for green and blue.
The more similiar bg and fg are, the softer the edge will seem and the less extreme the interior will be.
Note that what you disable is the override of the global colors, not the color itself. It will use whatever you have set in the DUI/CUI global preferences.
QUOTE (fuflo @ Jan 10 2010, 17:44) *
That's expected, and I do not believe that it's solvable, not even with Direct3D9Ex.
Similarily, it will most probably not do the right thing in the unholy Panel Stack of Columns.
This post has been edited by Zao: Jan 11 2010, 03:19
eke
post Jan 12 2010, 11:40
Post #174
is it possible to display 2 wavebars at once for 2 files, in order to compare them to each other?
Zao
post Jan 12 2010, 12:28
Post #175
QUOTE (eke @ Jan 12 2010, 11:40) *
No. At least not currently. Maybe when I get around implementing displaying the selected song I can implement a setting to not track the currently playing one.
RSS Lo-Fi Version Time is now: 31st August 2015 - 20:56
