foo_random_pools, Select random groups from the media library
fbuser
post Jan 2 2010, 18:15
foo_random_pools is a foobar2000 component for creating random playlist entries selected and grouped by various pool definitions.
Mainly you can define titleformat expressions for selecting random groups like albums including sorting and filtering from the media library.
Download the latest version: here
This post has been edited by fbuser: Sep 16 2011, 22:50
TakuSkan
post Oct 8 2010, 10:10
Could you just lay out a brief abstract of what needs to be done here? I'm not at all clear on why changing the group and filter as we did here changed the whole dynamic of what's going on. This thread is about the only source of information on this component... si/no?
fbuser
post Oct 8 2010, 19:02
QUOTE (TakuSkan @ Oct 8 2010, 10:10) *
Mainly you need to find a title format expression for grouping, which matches your root folders. Something like $puts(Remainder,$stripprefix(%path%,<your base path>))$left($get(Remainder),$sub($strchr($get(Remainder),\),1)) could be a starting point, maybe it already works.
The filter is used to restrict the tracks of the media library before building the groups. For each track of the media library, which is not filtered out by the filter expression, the group expression is evaluated. All evaluations with the same value are building one group. Normally one such complete group will be randomly picked, but this behaviour can be customized by several attributes, e.g. you can limit the picking to only one track per group. So, for your described cases it should be obvious, that using %artist% as group leads to a different result than using $directory(%path%) as a group.
Besides the help file, most probably yes.
- fbuser   foo_random_pools   Jan 2 2010, 18:15
- - Black_Over_Bills_Mothers   Thanks for this plugin. I'm finding it really ...   Jan 3 2010, 10:01
- - Chris Norman   Looks like a great idea - going to test it.   Jan 3 2010, 13:08
- - xbullethammer   BRILLIANT! Finally a way to add random albums...   Jan 3 2010, 20:57
- - realhaiy   great plugin! only one requset: option for pre...   Feb 13 2010, 10:25
- - NullString   THis is goddamn great! If I want to select 7 r...   Feb 13 2010, 18:03
- - Xezzy   Yes, limit the playlist by filesize would be great...   Feb 13 2010, 21:03
- - fbuser   A limiting by duration or filesize will be probabl...   Feb 14 2010, 01:11
- - mrinferno   just noticed this last night and had a chance to t...   Feb 14 2010, 15:24
- - foosion   Nice idea. I've tried to make it crash, but I ...   Feb 14 2010, 15:37
|- - fbuser   QUOTE (foosion @ Feb 14 2010, 15:37) Nice...   Feb 14 2010, 16:45
- - exxecutor   Thank you for this component! However, why is...   Feb 14 2010, 17:14
- - fbuser   Will be fixed with the next version.   Feb 14 2010, 18:10
- - Fractal_Mortality   Anyone have any idea how I could rig a script for ...   Feb 14 2010, 21:05
- - exxecutor   So, I have been using this component for some days...   Feb 23 2010, 13:54
- - Xezzy   Great component. Is it still under development? Ca...   Mar 29 2010, 23:48
- - fbuser   Thanks for the hint. I'm already using a newer...   Mar 30 2010, 18:51
|- - mrinferno   QUOTE (fbuser @ Mar 30 2010, 13:51) Thank...   Mar 30 2010, 19:00
- - NullString   haven't gotten any crashes yet. this plugin so...   Mar 30 2010, 19:19
- - Fractal_Mortality   How does this "weighted randomness" work...   Mar 31 2010, 07:35
- - exxecutor   QUOTE (Fractal_Mortality @ Mar 31 2010, 07...   Mar 31 2010, 08:31
- - Fractal_Mortality   Gotcha, thanks for the explanation   Mar 31 2010, 08:48
- - fbuser   Version 0.0.2 is available. See first post for DL ...   Apr 4 2010, 22:28
- - exxecutor   Thank you very much! Works great so far.   Apr 4 2010, 23:33
- - mrinferno   awesome thanks! looking forward to trying out ...   Apr 5 2010, 03:28
|- - fbuser   QUOTE (mrinferno @ Apr 5 2010, 03:28) jus...   Apr 5 2010, 08:40
|- - mrinferno   QUOTE (fbuser @ Apr 5 2010, 03:40) Edit: ...   Apr 5 2010, 14:49
- - Fractal_Mortality   So does this mean we can now perform filters like ...   Apr 5 2010, 06:46
|- - fbuser   QUOTE (Fractal_Mortality @ Apr 5 2010, 06...   Apr 5 2010, 08:41
- - Fractal_Mortality   Ahhh, it appears this isn't working for me bec...   Apr 5 2010, 09:02
|- - fbuser   QUOTE (Fractal_Mortality @ Apr 5 2010, 09...   Apr 5 2010, 09:17
- - Fractal_Mortality   Hmm, ok... Any idea how I'd go about that in m...   Apr 5 2010, 09:20
- - fbuser   "Format from other field" with the desti...   Apr 5 2010, 09:36
- - q-stankovic   Since the component offers the limitation by time,...   Apr 17 2010, 15:10
- - fbuser   You don't need weird expressions to achieve th...   Apr 17 2010, 15:56
- - q-stankovic   QUOTE (fbuser @ Apr 17 2010, 16:56) You d...   Apr 17 2010, 16:05
- - fbuser   I don't see a need to do anything here. To get...   Apr 17 2010, 21:22
- - q-stankovic   QUOTE (fbuser @ Apr 17 2010, 22:22) I don...   Apr 18 2010, 21:29
|- - fbuser   QUOTE (q-stankovic @ Apr 18 2010, 21...   Apr 18 2010, 22:04
- - carpman   Hi all, Great component fbuser. Looking forward t...   May 5 2010, 03:27
- - carpman   Forget it. Seems like a freak occurence of randomn...   May 5 2010, 06:30
- - carpman   Okay, after some more testing of this component I...   May 6 2010, 02:32
|- - fbuser   QUOTE (carpman @ May 6 2010, 02:32) Again...   May 6 2010, 21:08
- - Wooops   There´s no option to run "all pools" sim...   May 6 2010, 08:25
- - carpman   Thanks for the reply. I got it now. So basically ...   May 7 2010, 09:27
|- - NullString   QUOTE (carpman @ May 7 2010, 05:27) In wh...   May 7 2010, 14:31
|- - Fractal_Mortality   QUOTE (carpman @ May 7 2010, 04:27) Becau...   May 8 2010, 00:31
|- - e11   QUOTE (carpman @ May 7 2010, 09:27) Thank...   May 10 2011, 22:53
- - laite   Hi, it seems that if same album is on random playl...   Jun 21 2010, 18:22
- - fbuser   Thanks for reporting. Fixed with version 0.0.2.2.   Jun 21 2010, 21:18
- - hesher   Could someone give an example for usage of the plu...   Jul 8 2010, 14:29
|- - mrinferno   one of my favorite ways to use it is as a virtual ...   Jul 8 2010, 15:51
|- - hesher   QUOTE (mrinferno @ Jul 8 2010, 08:51) one...   Jul 10 2010, 00:08
- - Bodhi   fbuser a billion thanks, I was looking for that fo...   Sep 5 2010, 22:04
- - Sixth Street   Just started playing around with this component, i...   Sep 6 2010, 17:29
- - q-stankovic   Not possible because that would require not only o...   Sep 6 2010, 17:39
|- - Sixth Street   QUOTE (q-stankovic @ Sep 6 2010, 11...   Sep 6 2010, 17:55
- - q-stankovic   I remember that the @limit function inside playlis...   Sep 6 2010, 18:51
- - Bodhi   Hi, Is there a limitation in MBs? It works fine u...   Sep 7 2010, 10:29
|- - fbuser   QUOTE (Bodhi @ Sep 7 2010, 10:29) Is ther...   Sep 11 2010, 12:28
- - Bodhi   Great, thanks!   Sep 11 2010, 12:35
- - laite   First of all, let me say that I really like this c...   Sep 21 2010, 15:08
- - TakuSkan   I'm terrible at figuring out code to get FB2K ...   Oct 5 2010, 09:25
- - fbuser   Just create only one pool with using %artist% as y...   Oct 5 2010, 20:38
- - TakuSkan   Wow... this is closing in on something I've be...   Oct 6 2010, 06:48
|- - fbuser   QUOTE (TakuSkan @ Oct 6 2010, 06:48) Wow....   Oct 6 2010, 19:02
|- - TakuSkan   QUOTE (fbuser @ Oct 6 2010, 11:02) ...you...   Oct 6 2010, 20:08
|- - fbuser   QUOTE (TakuSkan @ Oct 6 2010, 20:08) Woul...   Oct 7 2010, 20:32
- - TakuSkan   Could you just lay out a brief abstract of what ne...   Oct 8 2010, 10:10
|- - fbuser   QUOTE (TakuSkan @ Oct 8 2010, 10:10) Coul...   Oct 8 2010, 19:02
|- - TakuSkan   QUOTE (fbuser @ Oct 8 2010, 11:02) Someth...   Oct 9 2010, 23:08
|- - fbuser   QUOTE (TakuSkan @ Oct 9 2010, 23:08) the ...   Oct 10 2010, 09:00
|- - TakuSkan   QUOTE (fbuser @ Oct 10 2010, 01:00) If yo...   Oct 12 2010, 04:22
|- - carpman   QUOTE (TakuSkan @ Oct 12 2010, 04:22) For...   Oct 12 2010, 05:01
|- - TakuSkan   QUOTE (carpman @ Oct 11 2010, 21:01) Sure...   Oct 12 2010, 12:05
- - tempman   Thanks for this great plug in! I use it with ...   Oct 13 2010, 17:42
|- - fbuser   QUOTE (tempman @ Oct 13 2010, 17:42) I wo...   Oct 15 2010, 16:59
- - carpman   Hi fbuser I don't know how hard this would be...   Oct 20 2010, 00:50
- - Yaris   Nice plugin, thanks I want to random select indi...   Oct 21 2010, 22:43
|- - mrinferno   try %filename% as the group. set limit number of t...   Oct 21 2010, 23:51
- - スラッシ   I totally love this component, it's great...   Nov 22 2010, 17:23
|- - fbuser   QUOTE (スラッシ @ Nov...   Nov 22 2010, 18:36
- - スラッシ   That's what I get for reading the first few pa...   Nov 22 2010, 18:54
- - Ephoras   hell, i think i m rly dumb, because i don't ge...   Mar 11 2011, 01:54
|- - carpman   QUOTE (Ephoras @ Mar 11 2011, 00:54) Grou...   Mar 11 2011, 09:04
- - Ephoras   thanks, it works now;) My main problem was that i...   Mar 11 2011, 12:04
- - prashantv   Is it possible to sort in descending order?   Mar 18 2011, 00:27
- - Ephoras   Hell it still does not work the way i want it to. ...   Mar 22 2011, 12:43
- - fbuser   Which size have the files you are going to add to ...   Mar 22 2011, 22:04
- - Ephoras   thank you, i had 1 loosless album in the filter, t...   Mar 23 2011, 00:12
- - mrinferno   hi fbuser, I was just rereading through the thread...   Apr 2 2011, 13:02
- - Ephoras   Hi, anyone here who wants to help me? I currentl...   Apr 20 2011, 08:11
- - trebordean   I have my random pools selecting from an autoplayl...   Apr 21 2011, 12:28
|- - fbuser   QUOTE (trebordean @ Apr 21 2011, 12:28) I...   Apr 21 2011, 16:10
- - trebordean   fbuser, Under the playlist patterns section, a dr...   Apr 22 2011, 17:57
|- - tpijag   Tracks are selected by whatever definition you pro...   Apr 22 2011, 18:20
- - carpman   I'm pretty much satisfied with foo_random pool...   May 11 2011, 11:09
- - e11   Mabey im miss understanding the settings but, i wa...   May 11 2011, 11:40
|- - fbuser   QUOTE (e11 @ May 11 2011, 11:40) Mabey im...   May 11 2011, 21:41
- - e11   Ha that works thankyou very much   May 12 2011, 06:59
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 30th May 2015 - 02:04
