48 Pages V  « < 4 5 6 7 8 > »
Closed TopicStart new topic
HOW TO: synchronise your last.fm playback stats with foobar, ...works with CUI and DUI
marc2003
post Jan 22 2010, 12:16
Post #126
1) thanks for spotting. i'll get a corrected version uploaded. but only people with over 9000 plays for a track will have been affected so far. tongue.gif
and i don't see how your LFM_U can show 55. the action for the "Customdb U" should be set to 5. if there was a typo, it would have been spotted long before now. try playing the song for 10 seconds so it updates again and see what happens.
EDIT: updated version uploaded. all foo_customdb users should overwrite their foo_customdb.dll.cfg file with the new one in this upload.
http://cid-649d3bfeaf541fbb.skydrive.live....ount%20sync.zip
This post has been edited by marc2003: Jan 22 2010, 12:27
puserp
post Jan 22 2010, 12:28
Post #127
QUOTE (marc2003 @ Jan 22 2010, 12:16) *
"never underestimate the stupidity"
I was able to spot your mistake in foo_customdb config, but made one myself. There was value 55 for CustomdbU 5 action. Shame on me laugh.gif
marc2003
post Jan 22 2010, 12:44
Post #128
currently, this script only supports play counts upto 9999 when using foo_customdb - i'm just wondering, is there anybody on here who is likely to run into this limitation any time soon? laugh.gif
Jack Schmaltz
post Jan 22 2010, 15:30
Post #129
iv had my eye on this for a while but didnt fancy it due to it originally updating files.
now that its in customdb iv give it a whirl & i must say im very impressed.
managed to fit it into my cui very easily & even make a few mods through customdb.
thanks for your efforts marc2003, greatly appreciated
http://www.discogs.com/user/jackschmaltz
marc2003
post Jan 26 2010, 02:08
Post #130
minor update of config.
-nothing new except the user credentials are now set in an external file. this means i can make future last.fm related panels but the end user only has to set their username in one place.
-contains some other sample WSH scripts
Fractal_Mortalit...
post Jan 26 2010, 07:52
Post #131
Hey Marc, this is a really nitpicky thing, but is there any way to add padding to the top of the love "heart button" in order for it to line up with other buttons better?
http://www.last.fm/user/magnumforce2006
marc2003
post Jan 26 2010, 07:57
Post #132
sure, just find this line in the panel (it's near the top)
top_margin = dui ? 2 : 0;
2 is the default top margin for DUI, 0 is the default for CUI. modify these however you like.
Fractal_Mortalit...
post Jan 26 2010, 09:37
Post #133
Sorry, one more question... How do I set the newer version to use file tagging instead of custom_db?
marc2003
post Jan 26 2010, 11:43
Post #134
you need to edit the file \scripts\marc2003\lastfm.js
it's the first option after entering your username/api key. i don't see how you can miss it. tongue.gif
Fractal_Mortalit...
post Jan 26 2010, 17:07
Post #135
Sorry, I'm a slow one, lol.
Fractal_Mortalit...
post Jan 28 2010, 05:33
Post #136
Hey Marc, in which part of which script do we set custom colors? Thanks.
marc2003
post Jan 28 2010, 06:25
Post #137
QUOTE (marc2003 @ Jan 26 2010, 10:43) *
again... tongue.gif admittedly it's further on down the page but it's all commented. use the context menu to switch to it once you've set it.
Fractal_Mortalit...
post Jan 28 2010, 06:45
Post #138
QUOTE (marc2003 @ Jan 28 2010, 00:25) *
Dawgoneit! I kept looking through fonts_colours_flags.js, lol
marc2003
post Feb 1 2010, 14:09
Post #139
New version
Updated 01/02/2010
This new version has some major changes from the previous version. It uses foo_customdb exclusively – no more file tagging support. If you require this, you can get the old version here.
New version features:
- No more script editing. Everything is set via the context menu.
- Removal of superfluous options. See above link if you want “auto love” and “add one” features from previous versions.
- Storage of settings is now completely independent of the script so any future script updates means you can simply overwrite the files without having to backup/restore your settings manually.
no real reason for existing users to upgrade. i've just been playing around making it easier to use for new users.
This post has been edited by marc2003: Feb 1 2010, 14:22
MB.
post Feb 1 2010, 19:25
Post #140
unclean
post Feb 2 2010, 06:05
Post #141
Has anyone else not able been to get the autoplaylist method working with the standard installation on Vista or 7?
I have everything set up properly in my config, and copied foo_customdb.dll.cfg to %appdata%\foobar2000\configuration, but [%LFM_TH%][%LFM_H%][%LFM_T%][%LFM_U%] returns nothing. The console isn't showing errors, and other customdb actions like %PLAY_COUNT_CD% work.
Yet the exact same setup on a portable installation works perfectly. I have no idea what is happening.
QUOTE (MB. @ Feb 1 2010, 10:25) *
marc2003
post Feb 2 2010, 06:19
Post #142
if you copied over the file while foobar was running, closing it probably over wrote it with the default settings? close foobar and copy over the file again. other than that, i have no idea. i've tested this on standard and portable installs.
look in the foo_customdb preferences at the "fields" and "action" tabs. that should tell you if my file is installed properly or not.
This post has been edited by marc2003: Feb 2 2010, 06:20
Sparanoid
post Feb 5 2010, 05:14
Post #143
hi marc2003, somebody got error message while using my skin MonoLite Plus, I don't know why, I try to translate the messege to English:
when he try to enter his last.fm account via context menu, he got input.wsf error:
char: 1
error: VBScript
code: 8007007E
source: Windows Script Host
This post has been edited by Sparanoid: Feb 5 2010, 05:14
marc2003
post Feb 5 2010, 06:57
Post #144
i have no idea but a quick google suggests trying this - start>search/run
regsvr32 scrrun.dll
also make sure windows is up to date.
i've tested my script on XP SP3 and windows 7 x64 with administrator and limited accounts and it all works fine.
Kuraj
post Feb 6 2010, 23:37
Post #145
This isn't working well for me. Although the panel does show whether my track is loved or not, it doesn't show up on NG Playlist. Additionally, i get an error upon leaving the application:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program C:\Program Files (x86)\foobar2000\foobar2000.exe
R6025
- pure virtual function call
I'm running Windows 7 Ultimate x64.
Kuraj
post Feb 7 2010, 00:52
Post #146
Also, I tried the old version of plugin, with tag mode - which partially solved the problem since i was able to see the playcounts and love status - but I still get the mentioned error. Even disabling the foo_softplaylists and foo_customdb plugins didn't solve the issue, so I take it's foo_uie_wsh_panel_mod's fault.
maximillan
post Feb 7 2010, 01:10
Post #147
sorry foobar noob here, how make this work with DUI ?, i cant figure out how to add wsh panel. for clarification dui = default ui?
marc2003
post Feb 7 2010, 01:41
Post #148
QUOTE (Kuraj @ Feb 6 2010, 23:52) *
no. i assume you're using one of those mono lite mod themes on DA? i've seen that error mentioned as a known issue and it has nothing to with this script or the components it uses. WSH panel mod,soft playlists and foo_customdb have been rock solid for me. and no one else has mentioned that error in the 2 months since i put this together.
QUOTE (maximillan @ Feb 7 2010, 00:10) *
you have to use layout editing mode found on the view menu to add a panel to your layout.
Kuraj
post Feb 7 2010, 03:03
Post #149
QUOTE (marc2003 @ Feb 6 2010, 18:41) *
No, I'm not using any more off DA; here's my list of components:
Core (2010-01-09 12:47:00)
    foobar2000 core 1.0
foo_albumlist.dll (2010-01-09 12:44:46)
    Album List 4.4
foo_audioscrobbler.dll (2010-02-06 21:14:04)
    Audioscrobbler 1.4.5
foo_cdda.dll (2010-01-09 12:44:42)
    CD Audio Decoder 3.0
foo_converter.dll (2010-01-09 12:44:32)
    Converter 1.4
foo_dsp_std.dll (2010-01-09 12:44:48)
    Standard DSP Array 1.0
foo_input_std.dll (2010-01-09 12:44:24)
    Standard Input Array 1.0
foo_mlt.dll (2007-10-27 21:35:30)
    Miranda ListeningTo foobar2000 Plugin 1.0
foo_musicbrainz.dll (2009-04-10 21:27:28)
    MusicBrainz Tagger 0.2
foo_rgscan.dll (2010-01-09 12:44:24)
    ReplayGain Scanner 2.0.9
foo_ui_columns.dll (2010-01-09 15:40:28)
    Columns UI 0.3.8.3
foo_ui_std.dll (2010-01-09 12:44:52)
    Default User Interface 0.9.5
foo_uie_albumlist.dll (2009-06-13 23:49:19)
    Album list panel 0.3.5
foo_uie_lyrics2.dll (2010-02-03 00:35:08)
    Lyric Show Panel 2 0.4.6.12
foo_w7shell.dll (2010-01-17 04:09:20)
    Windows 7 integration 0.2.9.1
Now that I think about it, it might be one of those; I'll play with them tomorrow, and see if it works.
marc2003
post Feb 7 2010, 04:08
Post #150
could be lyrics. that's pretty unstable by all accounts.
RSS Lo-Fi Version Time is now: 1st April 2015 - 10:42
