HOW TO: synchronise your last.fm playback stats with foobar, ...works with CUI and DUI
marc2003
post Dec 7 2009, 14:47
this isn't a proper component but a script which utilises 2 other components (WSH panel mod & foo_customdb) to do the following:
-it can import the playcount/loved tracks from your entire last.fm library into foobar. it uses foo_customdb so your files are not touched.
-after doing the library import it will automatically update in the background as you listen.
-it can love/unlove tracks on last.fm via a button.
-it can automatically love tracks when they are played based on title formatting (for example, it can be set to automatically love tracks with a RATING of 5)
-you can display/filter the data in any custom columns, library viewers, display panels, etc using these simple tags:
%LASTFM_PLAYCOUNT_DB%
%LASTFM_LOVED_DB% //has a value of 1 for loved tracks
full instructions can be found here: https://dl.dropboxusercontent.com/u/2280132...ount%20sync.zip
changelog: https://dl.dropboxusercontent.com/u/2280132...e/changelog.txt
updated 30/04/13: no longer requires foo_softplaylists meaning artist field remapping is supported for loving tracks and background updates.
This post has been edited by db1989: May 2 2013, 12:03
Reason for edit: updated by request
http://marc2003.x10host.com/updates
marc2003
post Dec 9 2009, 02:24
there is also the last.fm TOS to consider. i've just added this information to the readme as well.
QUOTE (http://www.last.fm/api/tos)
You will not make more than 5 requests per originating IP address per second, averaged over a 5 minute period, without prior written consent.
it hasn't really needed to be mentioned before because there's absolutely no chance of breaking it with this script.
Fractal_Mortalit...
post Dec 9 2009, 04:28
QUOTE (marc2003 @ Dec 8 2009, 20:24) *
Hm I see... Well an automated script could still be used, correct? It would just take awhile (and 5 requests per second isn't too bad).
http://www.last.fm/user/magnumforce2006
- marc2003   HOW TO: synchronise your last.fm playback stats with foobar   Dec 7 2009, 14:47
- - bob12   This is amazing. Thank you.   Dec 7 2009, 16:01
- - dreadroach   Works like a charm, thank you.   Dec 7 2009, 16:13
|- - dreadroach   I can't sync some tracks. Instead of number of...   Dec 7 2009, 17:07
- - marc2003   my script parses 2 values found in the xml respons...   Dec 7 2009, 17:32
- - marc2003   new version uploaded. same link as first post. ch...   Dec 8 2009, 10:54
|- - dreadroach   Thanks for new version. Anyway, i fixed my ...   Dec 8 2009, 11:47
- - marc2003   glad you sorted it. also, i've just found out...   Dec 8 2009, 12:33
- - carmenm   Now i found a pretty big bug, you MUST prevent you...   Dec 8 2009, 14:43
- - marc2003   ah yes my mistake. as i don't use streams very...   Dec 8 2009, 15:00
- - carmenm   Still happens. I dont see the difference in the sc...   Dec 8 2009, 15:27
- - marc2003   maybe your browser was caching the file?? i did ac...   Dec 8 2009, 15:38
- - T.P Wang   @marc2003: I think it's better to use somethin...   Dec 8 2009, 15:55
- - marc2003   thanks. post above edited to reflect changes.   Dec 8 2009, 16:07
- - carmenm   Thanks a lot, works perfectly now! Just thoug...   Dec 8 2009, 16:32
- - marc2003   i need to play around a bit and see what is possib...   Dec 8 2009, 20:24
- - marc2003   i did some experimenting and it seems there is onl...   Dec 8 2009, 22:48
- - Fractal_Mortality   edit: nevermind, the default works   Dec 9 2009, 00:19
- - Fractal_Mortality   New question: How can we forced the script to look...   Dec 9 2009, 00:46
- - marc2003   see my changelog 2 posts above. the context menu i...   Dec 9 2009, 00:53
- - Fractal_Mortality   I see. So is there a way to update an entire libra...   Dec 9 2009, 01:20
- - marc2003   not possible. i already explained this earlier in ...   Dec 9 2009, 01:45
- - Fractal_Mortality   Hm, that's ashame... Although it seems like us...   Dec 9 2009, 02:04
- - marc2003   there is also the last.fm TOS to consider. i'v...   Dec 9 2009, 02:24
|- - Fractal_Mortality   QUOTE (marc2003 @ Dec 8 2009, 20:24) ther...   Dec 9 2009, 04:28
- - carmenm   Last version works very well. I have 2 question: -...   Dec 9 2009, 09:48
- - marc2003   as for the 10 second rule, you're more than we...   Dec 9 2009, 11:31
- - carmenm   I am ok with you 10sec, i am just trying to unders...   Dec 9 2009, 11:39
- - marc2003   one of the reasons i set 10 seconds is because i q...   Dec 9 2009, 15:12
|- - carmenm   QUOTE (marc2003 @ Dec 9 2009, 16:12) one ...   Dec 9 2009, 15:21
- - T.P Wang   Just curious: Why not use on_item_played() callbac...   Dec 9 2009, 15:21
- - marc2003   on_item_played doesn't work for tracks less th...   Dec 9 2009, 15:39
- - marc2003   i'm too late to edit my last post, so carmenm,...   Dec 9 2009, 17:15
|- - carmenm   QUOTE (marc2003 @ Dec 9 2009, 18:15) i...   Dec 9 2009, 17:29
- - marc2003   oh i know mine is an absolute mess with zillions o...   Dec 9 2009, 17:39
- - carmenm   Ok fine with me by the way one question about glo...   Dec 9 2009, 18:13
- - marc2003   using the editor dialog will reset any variable th...   Dec 9 2009, 19:05
- - marc2003   yet another new version uploaded. added features f...   Dec 9 2009, 19:46
- - TsukasaX   Any good way to put the information collected into...   Dec 9 2009, 23:00
- - marc2003   i did experiment with a component called foo_custo...   Dec 9 2009, 23:25
- - marc2003   right, here's my latest experiment - a new ve...   Dec 10 2009, 11:20
- - TsukasaX   Unfortunately I use NG Playlist instead of ELplay...   Dec 10 2009, 16:49
- - marc2003   new experimental ELplaylist version uploaded. this...   Dec 10 2009, 18:26
|- - marc2003   QUOTE (marc2003 @ Dec 10 2009, 17:26) new...   Dec 11 2009, 01:32
- - Fractal_Mortality   marc, How would I edit your script in order for it...   Dec 10 2009, 21:11
- - marc2003   CODEIn a lot of cases, I'll love a track durin...   Dec 10 2009, 21:26
|- - Fractal_Mortality   QUOTE (marc2003 @ Dec 10 2009, 15:26) COD...   Dec 11 2009, 00:17
- - carmenm   Hi marc, i have a question, could you share your C...   Dec 11 2009, 10:58
- - marc2003   here you go. just import.fcl and play around. i ca...   Dec 11 2009, 16:32
|- - carmenm   QUOTE (marc2003 @ Dec 11 2009, 17:32) her...   Dec 11 2009, 16:43
- - carmenm   I tested your last script, i like a lot. 2 things ...   Dec 11 2009, 18:22
|- - marc2003   QUOTE (carmenm @ Dec 11 2009, 17:22) - yo...   Dec 11 2009, 18:29
|- - jimbothigpen   QUOTE (carmenm @ Dec 11 2009, 12:22) I te...   Dec 14 2009, 17:11
|- - carmenm   QUOTE (jimbothigpen @ Dec 14 2009, 18:11)...   Dec 14 2009, 17:53
|- - jimbothigpen   QUOTE in the code look for CODE} else if (ok...   Dec 14 2009, 20:16
- - marc2003   a new version has been uploaded which supports foo...   Dec 12 2009, 07:39
- - loft   How about making this script a true component or i...   Dec 12 2009, 23:26
- - Hitchhiker427   I really hope the developer considers making this ...   Dec 13 2009, 00:31
- - marc2003   @ loft & Hitchhiker427, i couldn't agree m...   Dec 14 2009, 18:48
- - marc2003   replace CODEg_metadb.UpdateFileInfoSimple(...   Dec 14 2009, 20:21
- - jimbothigpen   OK... I use what I think is the most recent versio...   Dec 14 2009, 22:53
- - marc2003   as you're using the customdb version, undo any...   Dec 14 2009, 23:29
- - jimbothigpen   thanks so much to both marc2003 and carmenm! -...   Dec 14 2009, 23:57
- - carmenm   Thanks for helping marc2003.   Dec 15 2009, 09:08
- - スラッシ   This is great! I've been looking for this ...   Dec 15 2009, 10:46
- - marc2003   the sync is a one way thing. if there is nothing f...   Dec 15 2009, 13:32
- - スラッシ   Brilliant, works a charm. Thanks again!   Dec 15 2009, 13:41
- - marc2003   the link for the customdb version is now dead. thi...   Dec 15 2009, 20:35
- - i like sleeping   Thanks for this! I wondered a while ago if som...   Dec 17 2009, 02:14
- - marc2003   well i'm just using artist/title to query the ...   Dec 17 2009, 03:27
- - スラッシ   One more suggestion, although I'm not sure if ...   Dec 17 2009, 07:01
- - marc2003   it would seem that is exclusive to their own web p...   Dec 17 2009, 07:41
- - スラッシ   Yeah, I was afraid of that. It's a shame they ...   Dec 17 2009, 07:54
- - rafib   Thank you so much for this plugin! I've be...   Dec 20 2009, 11:24
|- - marc2003   QUOTE (rafib @ Dec 20 2009, 10:24) I had ...   Dec 20 2009, 17:19
- - Keesface   How can i prevent this script from trying to submi...   Jan 4 2010, 10:24
- - marc2003   the reasons it still runs for streams are... -you...   Jan 4 2010, 11:14
- - u-neeks   hi, please, how i can set the tracks with any ra...   Jan 11 2010, 22:48
- - marc2003   QUOTE rating(0,1,2,3,4,5) you want it to automati...   Jan 11 2010, 23:34
|- - u-neeks   QUOTE (marc2003 @ Jan 11 2010, 19:34) QUO...   Jan 12 2010, 01:58
- - marc2003   well it is already documented what you need to do....   Jan 12 2010, 02:16
|- - u-neeks   working fine now, thanks! i needed to ch...   Jan 12 2010, 05:06
- - marc2003   sorry about that. at least you figured it out.   Jan 12 2010, 10:35
- - marc2003   T.P Wang has made a new version of WSH panel mod t...   Jan 12 2010, 16:39
- - スラッシ   Hi marc, Again I come with a suggestion that may ...   Jan 15 2010, 00:09
- - marc2003   i'm kind of lost for words.....what exactly ca...   Jan 15 2010, 00:58
|- - スラッシ   QUOTE (marc2003 @ Jan 15 2010, 00:58) i...   Jan 15 2010, 01:28
- - Andreasvb   I had some problem updating to the new WSH Panel M...   Jan 15 2010, 01:19
|- - marc2003   QUOTE (Andreasvb @ Jan 15 2010, 00:19) I ...   Jan 15 2010, 01:44
|- - Andreasvb   QUOTE (marc2003 @ Jan 15 2010, 01:44) QUO...   Jan 15 2010, 01:51
|- - marc2003   QUOTE (marc2003 @ Jan 15 2010, 00:44) the...   Jan 16 2010, 10:23
- - marc2003   i take the artist and title and try and directly a...   Jan 15 2010, 01:38
- - スラッシ   Yeah... I kinda expected that, but I figured there...   Jan 15 2010, 01:45
- - Hitchhiker427   I had the same problem as スラ...   Jan 15 2010, 01:45
- - Sparanoid   I got an error when updated to wsh panel mod beta ...   Jan 16 2010, 04:43
- - Sparanoid   Thanks a lot I get it works, now I'm working o...   Jan 19 2010, 23:13
- - marc2003   if you check the readme file again, you'll see...   Jan 19 2010, 23:17
- - Sparanoid   Oh, that works! I'm not very good at codin...   Jan 19 2010, 23:29
- - Sparanoid   Well this may be a bug: when I enable Spelling Cor...   Jan 20 2010, 00:51
- - marc2003   if last.fm is wrong, you can turn off spelling cor...   Jan 20 2010, 01:30
12 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 3rd March 2015 - 04:25
