3 Pages V   1 2 3 >
Issues with ASX streams, Split from: "foobar2000 v1.0 beta 2a"
Cutter
post Nov 27 2009, 20:31
QUOTE (yandexx @ Nov 27 2009, 18:38) *
  • Bug: Certain ASX playlist files are not parsed properly.
Thanks for the release.
This ASX stream isn't played by foobar2000: http://www.polskieradio.pl/sluchaj/play.aspx?p=r1
Peter
post Nov 27 2009, 20:35
foobar2000 developer
Group: Admin
QUOTE (Cutter @ Nov 27 2009, 20:31) *
Their ASX file is broken:
<ref href = "mms://stream.polskieradio.pl/program1">
Should be:
<ref href = "mms://stream.polskieradio.pl/program1" />
Cutter
post Nov 27 2009, 20:44
QUOTE (Peter @ Nov 27 2009, 20:35) *
Oh, this can be corrected manually. Thanks.
This post has been edited by Cutter: Nov 27 2009, 21:04
Cutter
post Nov 27 2009, 21:04
ASX files containing accented characters aren't handled correctly.
Example: http://www.polskieradio.pl/st/program3M.asx
The "ˇ" in the Title tag makes the file unplayable.
Yirkha
post Nov 27 2009, 21:27
Group: FB2K Moderator
That's not a valid UTF-8, I guess.
alwaysdub
post Nov 27 2009, 22:22
BBC asx streams are not working, eg
http://www.bbc.co.uk/radio/listen/live/r4.asx
or
http://www.bbc.co.uk/radio/listen/live/r5lsp.asx
Errors :-
Unable to open item for playback (IWMReader::Open failed : Unknown error code (0xC00D0026)):
"http://www.bbc.co.uk/radio/listen/live/r4.asx"
"http://www.bbc.co.uk/radio/listen/live/r5lsp.asx"
Can you confirm if these are also broken asx or if this is a bug, please?
They work in WMP/VLC.
Ritsl
post Nov 27 2009, 23:48
QUOTE (alwaysdub @ Nov 27 2009, 22:22) *
If a stream works without errors in common players, it should be considered as a bug if it doesn't work in foobar. These are web resources, Postel's law applies (within limits). This is utterly annoying for the developers, but the feature is much less useful if it only works on perfectly valid asx files.
Peter
post Nov 28 2009, 09:30
Group: Admin
BBC asx streams are not working...
Problem triggered by server not returning content-length, fixed for the next update, thanks for reporting.
You can download the ASX file using your web browser, save it then open the saved copy in foobar2000.
oMikR0n
post Nov 28 2009, 11:04
"http://tvradio.ert.gr/radio/liveradio/asx/erasport.asx"
In WMP works with no problems
This post has been edited by oMikR0n: Nov 28 2009, 11:07
The Link
post Nov 28 2009, 11:24
QUOTE (oMikR0n @ Nov 28 2009, 11:04) *
Works fine here in beta2a.
hechacker1
post Nov 29 2009, 23:56
Thanks for the update.
There is one problem with recommending removing support for the mslive plugin. Foobar2000 only works on this stream with the mslive plugin:
http://ordorica.org/tune.pl?station=kfi640
The stream is in asx format (wma/mms:). The link is to my script that generates a stream for ClearChannel websites (they want you to use flash).
For now I will just continue to use the mslive plugin.
saivert
post Nov 30 2009, 00:05
@hechacker1: Your script doesn't set the proper Content-Type HTTP header.
here is a list of MIME types for Windows Media stuff: http://support.microsoft.com/kb/288102
http://foobar2000.saivert.com - foobar2000 component repository
Yirkha
post Nov 30 2009, 00:18
QUOTE (hechacker1 @ Nov 29 2009, 23:56) *
ASX is supposed to be an XML document, therefore you ought to escape ampersands to &amp;.
This post has been edited by Yirkha: Nov 30 2009, 00:18
hechacker1
post Nov 30 2009, 00:39
I added the content type to my script:
Content-type: audio/x-ms-wma
But it made no difference for foobar.
As far as changing the ampersands, I just use a perl script to take clear channel's randomly generated strings and pass it as a simple asx file.
I guess I can regex replace their generated content.. but it works fine with other players and mslive.
I'll do it later, hopefully with a simple regex.
This post has been edited by hechacker1: Nov 30 2009, 00:39
Zao
post Nov 30 2009, 02:30
Post #15
Group: Members (Donating)
XML::Writer or XML::Generator.
Peter
post Nov 30 2009, 10:34
Post #16
Group: Admin
QUOTE (hechacker1 @ Nov 30 2009, 00:39) *
From http://en.wikipedia.org/wiki/Advanced_Stream_Redirector:
ASX files have MIME type video/x-ms-asf (as do ASF files).
See also: http://support.microsoft.com/kb/288102
Squeller
post Nov 30 2009, 20:24
Post #17
Thanks for the MS streaming support! As we know from experience (foo_input_mslive) this is a hard task, often due to not standard compliant xml files. From the philosophy of fb2k I know you won't workaround things. Anyway, this one also doesn't work, I think the xml is alright:
http://radiodresden.stream.green.ch/radiodresden.wax
contents:
<ASX version = "3.0">
<title>Radio Dresden</title>
<Entry>
    <Ref href = "mms://stream.green.ch/RadioDresden"/>
</Entry>
</ASX>
fb2k output:
Unable to open item for playback (Unsupported file format):
"http://radiodresden.stream.green.ch/radiodresden.wax"
Peter, are you thinking about Realaudio support? Unfortunately there's quite a few real-stuff around, BBC for instance...
This post has been edited by Squeller: Nov 30 2009, 20:28
Peter
post Nov 30 2009, 20:33
Post #18
Group: Admin
Fixed, thanks for reporting.
Temporary workaround: download the .WAX file, rename to .ASX, open.
TomBarlow
post Nov 30 2009, 20:59
Post #19
QUOTE (Squeller @ Nov 30 2009, 19:24) *
BBC for instance...
Try here: http://iplayerhelp.external.bbc.co.uk/help...eal_wma_streams
Dvvarf
post Nov 30 2009, 21:17
Post #20
Tags for MMS streams are not displayed. mslive (or WMP): displayed; foobar: not displayed. Should it be that way?
Peter
post Nov 30 2009, 23:28
Post #21
Group: Admin
QUOTE (Dvvarf @ Nov 30 2009, 21:17) *
What kind of tags and not displayed where? Any specific stations where I can see this behavior?
Dvvarf
post Dec 1 2009, 00:17
Post #22
QUOTE (Peter @ Dec 1 2009, 01:28) *
Metadata in mms-streamed wma. Unfortunately, its our local radio, so its impossible for me to give its url to you (only screenshots - it is not really helpful, is it?).
But for example mms://fr1.101.ru/v1_1_128 (mslive at least shows NRJ as artist/title like WMP does, foobar shows nothing). And those on local server in mslive info has that string:
<HASSCRIPT> : Yes
P.S. Sorry, if I'm being dense or non-clearly understandable - my English is not too good. unsure.gif
This post has been edited by Dvvarf: Dec 1 2009, 00:17
tpijag
post Dec 1 2009, 01:07
Post #23
Have no idea if this is helpful.
Plays for me while showing:
NRJ as %Artist%
NRJ as %Title%.
Current beta
OS: XP
terry [in dallas, tx.]
This post has been edited by tpijag: Dec 1 2009, 01:07
Peter
post Dec 1 2009, 09:56
Post #24
Group: Admin
Shows artist/title as "NRJ" and copyright as "NRJ FM" here.
_oao
post Dec 1 2009, 10:25
Post #25
QUOTE (tpijag @ Dec 1 2009, 01:07) *
NRJ as %Artist%
NRJ as %Title%.
Current beta
OS: XP
it doesn't show anything for me in foobar2000 v1.0 beta 2a, works in WMP...
OS: windows 7 64bit
list of components:
Core (2009-11-27 18:56:00)
foobar2000 core 1.0 beta 2a
foo_abx.dll (2009-06-07 12:25:26)
ABX Comparator 1.3.4
foo_albumlist.dll (2009-11-27 16:59:38)
Album List 4.4
foo_audioscrobbler.dll (2008-05-13 15:36:16)
Audioscrobbler 2.3.1
foo_binpack.dll (2008-10-25 16:42:42)
BinPack Playlist Generator 1.1.0
foo_bitcompare.dll (2008-12-05 15:08:02)
Binary Comparator 1.2
foo_burninate.dll (2009-06-24 19:14:28)
Audio CD Writer 3.0.1
foo_cdda.dll (2009-11-27 16:59:28)
CD Audio Decoder 3.0
foo_chacon.dll (2008-10-05 14:28:50)
Chacon 0.0.1
foo_chronflow.dll (2008-04-14 00:16:00)
Chronial's Coverflow 0.3.0
foo_converter.dll (2009-11-27 16:59:22)
Converter 1.4
foo_discogs.dll (2009-11-20 20:07:46)
Discogs Tagger 1.22
foo_dockable_panels.dll (2007-03-28 08:19:02)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]
foo_dsp_std.dll (2009-11-27 16:59:36)
Standard DSP Array 1.0
foo_facets.dll (2008-04-09 19:29:14)
Facets 2008-02-25
foo_fileops.dll (2009-11-27 16:58:42)
File Operations 2.1.2
foo_freedb2.dll (2009-11-27 16:58:44)
freedb Tagger 0.6.2
foo_grabber_python.dll (2009-02-06 12:40:15)
Lyrics Grabber Dances With Python 0.1.12 Alpha
foo_imgburner.dll (2008-10-30 16:18:15)
ImgBurner 0.3.1
foo_infospect.dll (2008-02-01 20:02:58)
Infospect 1.0.3
foo_input_alac.dll (2009-03-22 14:15:46)
ALAC Decoder 1.0.3
foo_input_monkey.dll (2009-05-01 13:40:52)
Monkey's Audio Decoder 2.1.4
foo_input_std.dll (2009-11-27 16:59:22)
Standard Input Array 1.0
foo_jesus.dll (2009-11-20 22:41:02)
Autosave & Autobackup 6
foo_lastfm_radio.dll (2009-02-25 21:05:24)
Last.fm Radio 0.5.6b
foo_lyricsgrabber.dll (2009-02-07 06:12:47)
Lyrics Grabber 0.3.0.7 Alpha
foo_masstag.dll (2009-09-18 09:01:36)
Masstagger 1.8.4
foo_musicbrainz.dll (2009-04-10 20:27:28)
MusicBrainz Tagger 0.2
foo_navigator.dll (2007-08-04 11:36:46)
Navigator 0.63
foo_out_wasapi.dll (2009-05-19 22:45:18)
WASAPI output support 2.1
foo_playcount.dll (2009-04-29 19:09:32)
Playback Statistics 2.1.9
foo_playlist_manager.dll (2007-01-22 12:05:12)
Playlist Manager 1.0.2
foo_playlist_playback_attributes.dll (2009-08-01 13:20:06)
Playlist Playback Attributes 0.1.0 [Aug 1 2009 - 15:15:00]
foo_queuecontents.dll (2009-07-27 10:47:56)
Queue Contents Editor 0.1
foo_quicktag.dll (2008-05-01 19:39:02)
Quick Tagger 1.0.1
foo_random.dll (2009-06-30 22:06:58)
Randomized Playlist Entry 1.3.0
foo_rgscan.dll (2009-11-27 16:59:10)
ReplayGain Scanner 2.0.9
foo_run.dll (2009-06-07 14:15:18)
Run services 0.3.7
foo_scrobblecharts.dll (2007-03-31 16:36:48)
Last.fm Chart Player 0.2.3
foo_sendtodevice.dll (2008-03-14 18:37:38)
Send to Device 1.1.2 [Nov 28 2007 - 10:13:31]
foo_skip.dll (2009-01-03 17:04:18)
Skip Track 0.4
foo_softplaylists.dll (2009-11-30 23:00:00)
Soft Playlists 2009-12-01
foo_stopaftercuralbum.dll (2009-06-01 08:50:42)
foo_stopaftercuralbum 0.2
foo_textdisplay.dll (2008-07-08 18:45:26)
Text Display UI Element 1.0 RC 3
foo_texttools.dll (2009-01-17 15:00:52)
Text Tools 1.0.2
foo_ui_columns.dll (2009-08-30 15:21:36)
Columns UI 0.3.8.0
foo_ui_std.dll (2009-11-27 16:59:48)
Default User Interface 0.9.5
foo_uie_albumlist.dll (2009-06-13 22:49:19)
Album list panel 0.3.5
foo_uie_biography.dll (2009-11-26 00:26:10)
Biography View 0.3.4.1
foo_uie_console.dll (2009-08-29 16:06:24)
Console panel 0.4
foo_uie_elplaylist.dll (2009-06-05 21:01:32)
ELPlaylist 0.6.5.3.3(beta)
foo_uie_graphical_browser.dll (2008-04-19 19:37:53)
Graphical Browser rev015
foo_uie_library_tree.dll (2009-07-25 01:18:14)
Library Tree 0.3.2.5b
foo_uie_lyrics.dll (2008-12-12 09:39:20)
Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01]
foo_uie_panel_splitter.dll (2009-11-26 01:03:32)
Panel Stack Splitter 0.3.8.2(alpha)
foo_uie_playlists_dropdown.dll (2009-09-23 23:44:46)
Playlists Dropdown 0.7.6
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
Quick Search Toolbar 2.8l
foo_uie_typefind.dll (2007-10-22 21:30:44)
Typefind 0.2 beta 2
foo_uie_wsh_panel_mod.dll (2009-11-13 12:15:35)
WSH Panel Mod 1.1.11
foo_unpack.dll (2009-11-27 16:58:28)
RAR reader 1.3
ZIP/GZIP reader 1.0
foo_utils.dll (2008-02-08 23:26:58)
Playlist Tools 0.6.2 beta 6
foo_verifier.dll (2009-10-05 10:39:20)
File Integrity Verifier 1.1
foo_vis_shpeck.dll (2009-09-24 18:07:44)
Shpeck - Winamp vis plugins wrapper 0.3.6
foo_w7shell.dll (2009-09-05 01:22:36)
Windows 7 integration 0.2.8.1
foo_whatsnew.dll (2008-08-30 14:45:00)
Feature Watcher 1.0.6
foo_wlm.dll (2009-06-21 20:30:22)
Windows Live Messenger Notifier 1.0.8
This post has been edited by Frank Bicking: Dec 1 2009, 10:31
Reason for edit: Added codebox.
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 27th March 2015 - 09:56
