Can $if() or TF be used in "Automatically fill values"?, TF = title formattings :)
2E7AH
post Nov 10 2009, 09:38
Group: Validating
here is example:
source: %tmp%
pattern: $if($strstr(%tmp%,Genre),%genre%)
I wanted to check if string 'Genre' exist in tag %tmp%, and if exist than write %tmp% value to %genre% tag
What am I doing wrong?
Zarkon
post Nov 10 2009, 09:43
The pattern field is what it says it is - No titleformatting, you just specify what the pattern of the source is.
The source accepts titleformatting. Set source to $if($strstr(%tmp%,Genre),%tmp%,%genre%) and pattern to %genre%.
This post has been edited by Zarkon: Nov 10 2009, 09:51
2E7AH
post Nov 10 2009, 09:58
Group: Validating
OK, here is real example: I have custom tag AMG which might have genre, style, mood and theme words in it. They indicate if that tag exist (should be written) - it's like that last.fm script for MusicBrainz tagger if one knows about it:
%amg% = Genres: rock // Styles: Thrash // Moods: Epic // Themes: Victory
Now I use pattern: Genres: %genre% // Styles: %style% // Moods: %mood% // Themes: %theme%
which is OK, but if some "inner" tag doesn't exist than this pattern fails, (i.e. style is missing it indicator):
%amg% = Genres: rock // Moods: Epic // Themes: Victory
Now using the pattern doesn't results correctly
I'm quite sure there is way to do this but right now I don't know about it
This post has been edited by 2E7AH: Nov 10 2009, 10:07
2E7AH
post Nov 10 2009, 11:04
Group: Validating
Here is shortest solution that I run to:
source:
\\$if($strstr(%amg%,Genres: ),$substr(%amg%,9,$sub($strstr(%amg%,' \\ '),1)))\\$if($strstr(%amg%,Styles: ),$substr($substr(%amg%,$strstr(%amg%,Styles: ),$len(%amg%)),8,$sub($strstr($substr(%amg%,$strstr(%amg%,Styles: ),$len(%amg%)),' \\ '),1)))\\$if($strstr(%amg%,Moods: ),$substr($substr(%amg%,$strstr(%amg%,Moods: ),$len(%amg%)),8,$sub($strstr($substr(%amg%,$strstr(%amg%,Moods: ),$len(%amg%)),' \\ '),1)))\\$if($strstr(%amg%,Themes: ),$substr(%amg%,$add($strstr(%amg%,Themes: ),8),$len(%amg%)))
pattern:
\\%genre%\\%style%\\%mood%\\%theme%
This post has been edited by 2E7AH: Nov 10 2009, 11:13
Yirkha
post Nov 10 2009, 11:38
Group: FB2K Moderator
You could use Masstagger with multiple "Guess value from other fields..." actions like "Genres: %genre% \\", "\\ Styles: %style% \\", "\\ Moods: %mood% \\", "\\ Themes: %theme%".
Or shorten a bit that thing of yours using variables:
$if($put(a,$strstr(%amg%,Genres: )),$substr(%amg%,$get(a),8),$sub($strstr(%amg%,' \\ '),1)))\\
$if($put(a,$strstr(%amg%,Styles: )),$substr($substr(%amg%,$get(a),$len(%amg%)),8,$sub($strstr($substr(%amg%,$get(a),$len(%amg%)),' \\ '),1)))\\
$if($put(a,$strstr(%amg%,Moods: )),$substr($substr(%amg%,$get(a),$len(%amg%)),8,$sub($strstr($substr(%amg%,$get(a),$len(%amg%)),' \\ '),1)))\\
$if($put(a,$strstr(%amg%,Themes: )),$substr(%amg%,$add($get(a),8),$len(%amg%)))
2E7AH
post Nov 10 2009, 11:56
Group: Validating
Thanks for reply, it's shorten a bit, but again too long for "normal" usage, so I changed the script for which it was intended.
I used mentioned lastfm script for MusicBrainz tagger in the past and don't remember how I splited their values which were written similarly in %comment% tag. Or maybe I didn't - don't know, anyway it seems strange to me that foobar needs such a long pattern for the example
2E7AH
post Nov 10 2009, 15:47
Group: Validating
QUOTE (Yirkha @ Nov 10 2009, 12:38) *
I wanted to create masstagger script as it's good idea and save it for future use but it's not good solution:
- "\\ Themes: %theme%" won't work, but there must be added some temp tag in front, i.e. "%temp% \\ Themes: %theme%"
- "\\ Styles: %style% \\" won't work if Styles: is missing - %style% will be assigned with wrong value
- masstagger actions aren't sequenced: when using properties you can use "Automatically fill values" then use other actions in properties dialog in one step without affecting previous action - masstagger can't do this, i.e. you can't assign value from some tag field and then in later action remove that field
[edit] corrected
This post has been edited by 2E7AH: Nov 10 2009, 16:08
Yirkha
post Nov 10 2009, 15:52
OK, never mind then. I didn't really try it, just thought it could be a better automation than going through "Automatically Fill Values..." multiple times with different patterns manually in Properties, but with those limitations, it's really not possible.
Canar
post Nov 10 2009, 16:20
Just made it work with Masstagger. You need 4 "Guess value from other fields" actions, each like this:
Source format: %amg% //
Guessing pattern: %%Style: %style% //%%
Next one:
Guessing pattern: %%Mood: %mood% //%%
etc.
This post has been edited by Canar: Nov 10 2009, 16:24
Reason for edit: damn edge cases
2. Assume good faith.
2E7AH
post Nov 10 2009, 16:25
Group: Validating
Thanks smile.gif Done already: http://www.hydrogenaudio.org/forums/index....st&p=667009
I fill a bit silly now. I didn't had to literally follow Yirkha's suggestion + masstagger actions ARE sequenced
[edit] Those double percentages works great, although I don't understand them (something like dummy tags?)
thanks
[v] yeah, I'll update the script
This post has been edited by 2E7AH: Nov 10 2009, 16:38
Canar
post Nov 10 2009, 16:27
My version degrades properly if any information is missing and does not need to be executed in sequence.
RSS Lo-Fi Version Time is now: 2nd August 2015 - 04:02
