M4B to MP3 (chapter separation), Converting M4B to multiple MP3s taking into account the M4B chapters
jaime11
post Sep 23 2009, 00:23
Hello
I have been searching on the forum but haven't found anything. Basicly what I'm looking for is a program that will input a M4B file and output several MP3 files (1 MP3 per chapter in the M4B file).
I have been using Free M4B to MP3 Converter, but unfortunately, all it does is extract a single MP3 from the M4B.
Anyone knows any other programs for this job?
Thank you
ertdredge
post Oct 16 2011, 03:57
As with everyone who's posted, major props to valekhz for building and maintaining this.
I got this working on Mac (Snow Leopard 10.6) with some fiddling:
  • OS 10.6 comes with python 2.6 pre-installed, I had to upgrade python to 2.7.x
  • I used macports to install all the requirements
  • The check for 'darwin' compatibility was removed from libmp4v2.py sometime between v0.2 and v0.5, I added it back to get around the "NotImplementedError: O/S 'darwin' not supported":
    elif sys.platform.startswith('darwin'):
        dll = ctypes.CDLL('libmp4v2.dylib')
  • LAME 3.98.2, the default version with macports was broken, I got "lame: output buffer too small" I had to downgrade to v3.98.0
  • I needed to manually add the mp4v2 location to DYLD_LIBRARY_PATH
Which all sums up to something like this:
  • Download Python 2.7.2 from python.org and install it
  • Add the code snippet, above, at line 16 to libmp4v2.py
...and then, open a fresh Terminal window (to pick up the new Python version that the Python installer adds to your path), and
sudo port install ffmpeg
sudo port install mp4v2
export DYLD_LIBRARY_PATH=/opt/local/lib
cd /tmp
curl -O http://trac.macports.org/export/38059/trunk/dports/audio/lame/Portfile
sudo port install
Then cd back to where you downloaded and unzipped valekhz-m4b-converter and do the expected
python m4b.py filename.m4a
Voila. You can add the export DYLD_LIBRARY_PATH=/opt/local/lib into your ~/.bash_profile for future convenience. Possibly you don't need to do all of this in OS 10.7 but I'm dragging my feet on the upgrade.
Thanks again, valekhz!
- jaime11   M4B to MP3 (chapter separation)   Sep 23 2009, 00:23
- - DVDdoug   NOTE - I've never seen an M4B file, so maybe s...   Sep 23 2009, 00:53
- - MostlyHarmless   Would you point me to a link with such file (m4b w...   Sep 23 2009, 09:17
- - tedgo   Have you tried foobar2000? It can handle m4a/m4b w...   Sep 23 2009, 10:06
- - jaime11   Hello Thanks to everyone with their fast replies.....   Sep 23 2009, 23:21
- - Zarggg   Is there any particular reason you need to transco...   Sep 24 2009, 16:10
|- - jaime11   QUOTE (Zarggg @ Sep 24 2009, 17:10) Is th...   Sep 24 2009, 16:56
|- - uberwolf   QUOTE (jaime11 @ Sep 24 2009, 15:56) QUOT...   Oct 29 2009, 01:03
- - Zarggg   If you don't have (lossless) sources, and you...   Nov 2 2009, 20:26
|- - uberwolf   My idea was to first convert the complete M4b file...   Nov 3 2009, 19:21
- - Zarggg   Have you tried using Audacity? I've had pretty...   Nov 4 2009, 16:56
- - HydrogenNoobie   Jamie11, Did you ever find a solution? I am looki...   Sep 20 2010, 05:22
- - valekhz   If anyone is still interested I wrote a little pyt...   Dec 4 2010, 01:22
|- - nbarzgar   QUOTE (valekhz @ Dec 4 2010, 02:22) If an...   Dec 4 2010, 08:06
|- - valekhz   Thank you for writing the guide, nbarzgar. QUOTE ...   Dec 4 2010, 13:25
- - nbarzgar   QUOTE (valekhz @ Dec 4 2010, 14:25) Thank...   Dec 5 2010, 06:02
|- - valekhz   QUOTE (nbarzgar @ Dec 5 2010, 06:02) I pu...   Dec 5 2010, 16:11
- - nbarzgar   VLC shows the chapters!! So now what would...   Dec 5 2010, 20:30
|- - valekhz   QUOTE (nbarzgar @ Dec 5 2010, 20:30) VLC ...   Dec 6 2010, 00:45
|- - nbarzgar   QUOTE (valekhz @ Dec 6 2010, 01:45) Aweso...   Dec 8 2010, 06:59
- - valekhz   I finally got the time to finish the script. Unfor...   Dec 10 2010, 22:42
|- - nbarzgar   QUOTE (valekhz @ Dec 10 2010, 23:42) I fi...   Dec 11 2010, 11:58
- - HydrogenNoobie   valekhz, Thank you so much for writing this scrip...   Dec 11 2010, 23:47
|- - valekhz   Unfortunately there's no Unicode support right...   Dec 12 2010, 19:02
- - daleybox   I ran into a couple of problems: 1) It was sayin...   Dec 13 2010, 03:36
|- - valekhz   Had some time to figure out the Unicode problem to...   Dec 13 2010, 22:59
|- - brian2090   QUOTE (daleybox @ Dec 12 2010, 21:36) ......   Feb 24 2011, 04:52
|- - alexf   thanks to valekhz for creating this script   Aug 23 2011, 22:40
- - HydrogenNoobie   Valekhz - I prefer no pre-pending of "Chapter...   Dec 13 2010, 23:37
- - HydrogenNoobie   valekhz, I hadn't seen your latest post when I...   Dec 13 2010, 23:50
- - HydrogenNoobie   Wow! I am both impressed and happy. Not only ...   Dec 14 2010, 06:33
|- - daleybox   Thanks so much for the chapter naming support, and...   Dec 14 2010, 14:19
|- - valekhz   QUOTE (HydrogenNoobie @ Dec 14 2010, 06:3...   Dec 14 2010, 20:37
- - HydrogenNoobie   Valekhz, 2. Ahh. I suspected that might be the c...   Dec 17 2010, 05:43
|- - valekhz   QUOTE (HydrogenNoobie @ Dec 17 2010, 05:4...   Dec 17 2010, 19:53
- - HydrogenNoobie   Valekhz, I just wanted to say thank you one last ...   Dec 27 2010, 20:08
- - valekhz   No problem, I'm glad it worked. I needed a fe...   Jan 3 2011, 16:55
|- - swavek   First off, many thanks to valekhz for building thi...   Oct 15 2011, 18:58
|- - cynepnaxa   Many thanks to valekhz! Note for customers. Va...   Jul 15 2012, 02:35
|- - cynepnaxa   QUOTE (cynepnaxa @ Jul 15 2012, 02:35) Va...   Jul 17 2012, 01:08
- - js2002   QUOTE (valekhz @ Dec 4 2010, 01:22) If an...   Jul 28 2011, 12:57
|- - js2002   fixed 1 problem in line 44: proc = subprocess...   Jul 28 2011, 14:55
- - ertdredge   As with everyone who's posted, major props to ...   Oct 16 2011, 03:57
|- - vitos   QUOTE (ertdredge @ Oct 16 2011, 04:57) As...   Aug 22 2012, 11:29
- - fyrebender360   Absolutely brilliant!!!! Thanks f...   Nov 9 2011, 23:23
|- - Jaantat   I tried all different versions but still it makes ...   Jun 16 2012, 15:30
|- - nmallears   QUOTE (Jaantat @ Jun 16 2012, 07:30) I tr...   Jun 18 2013, 17:15
|- - bitbanger   QUOTE (nmallears @ Jun 18 2013, 11:15) I ...   Oct 30 2014, 19:06
- - theviki   If this is still relevant, I found an easier way. ...   Aug 31 2012, 12:48
RSS Lo-Fi Version Time is now: 3rd August 2015 - 19:21
