2 Pages V  < 1 2
TAK DirectShow Filter, a filter to enable any DirectShow Player (i.e. WMP) to play .tak files
Spiridon
post May 12 2010, 10:56
Post #26
Sample rate: 192 Khz
Can't start playback.
HorsePower73
post May 15 2010, 11:12
Post #27
Well. this seems a deeper (or wider) problem.
It does not seem to be a bug; it seems that freq above 96KHz require a different approach.
I should investigate, but really now I do not have time.
I hope next month.
Thanks for testing.
Spiridon
post May 25 2010, 14:19
Post #28
QUOTE (Spiridon @ May 12 2010, 12:56) *
I don't have problem anymore.
To play these files (192 Khz), AC3Filter is needed.
AC3Filter -> System -> Use AC3Filter for -> Check PCM
This post has been edited by Spiridon: May 25 2010, 14:30
betaking
post Mar 7 2011, 13:57
Post #29
To:HorsePower73
TAK 2.1.0 Final is out,but I found that you made TAK DirectShow Source Filter based on TAK 2.0.0,can you make a new version base on TAK 2.1.0? Thanks!
Destroid
post Mar 7 2011, 22:18
Post #30
I'm not sure any format changes occurred between version 2.0.0 and 2.1.0 that would interfere with decoding, you shouldn't have problems. However, if you do have issues you'll simply need to replace the tak_deco_lib.dll installed by the TAK DirectShow filter found in your "...\system32" folder with the updated DLL included with TAK 2.1.0.
HorsePower73
post Mar 18 2011, 09:39
Post #31
Yes Destroid, you are right. I'm busy, but I'll update the installation package.
HorsePower73
post Dec 1 2011, 12:34
Post #32
TAK DirectShow filter has been updated.
Now it's up to TAK version 2.2.0.
Now it installs and works correctly in Windows 64bit (tested with Windows7 64bit).
You can find it here:
dstTAKSource (0.0.1.6): http://liviocavallo.altervista.org/
Nowings69
post Dec 1 2011, 14:18
Post #33
I want to ask you one why dont you make a splitter?
I already replace tak_deco_lib.dll and try it
HorsePower73
post Dec 2 2011, 00:06
Post #34
I think I have not understood you question.
I could write a parser, but this requires a TAK file to have a shure sequnce of bytes at the beginning; I think this is not assured as TB can change file format in the future.
Please explain me your idea about the splitter.
Replace tak_deco_lib? To try what?
Destroid
post May 20 2012, 21:26
Post #35
I had error using install.bat with registry entry http://www.hydrogenaudio.org/forums/index....st&p=796016
I had success with minor modification:
%systemroot%/system32/regedit.exe TAKRegistration.reg -> %systemroot%/regedit.exe TAKRegistration.reg
TBeck
post Jun 18 2013, 08:47
Post #36
TAK Developer
Thank you for the filter!
I was very glad about your (first) release. But i thought, i had to test the filter before adding it to my list of software with TAK support. Unfortunately i had no time and deceided to wait for user responses. Then i lost sight of it.
But finally i have managed to add it to the software list in TAK 2.3.0's readme.
Thomas
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 30th August 2015 - 08:01
