TAK DirectShow Filter, a filter to enable any DirectShow Player (i.e. WMP) to play .tak files
HorsePower73
post Sep 21 2009, 14:59
I hope this is the right place for this post.
I wrote a DirectShow filter for TAK, called dsfTAKSource.
You can download it here: http://home.tele2.it/LivioCavallo/
It's the first version, so please warn me of any problem.
This filter should allow any directshow player to open, decode and play .tak audio files.
Well, I hope you'll like it.
HorsePower73
zombiewerewolf
post Sep 21 2009, 18:03
There's only one problem I encountered. It doesn't play tak files with unicode filename.
HorsePower73
post Sep 22 2009, 12:20
Yes, I know.
The problem here is that tac_deco_lib does not accept UNICODE filenames.
<brainstorming mode on>
I could try to work around this problem rewriting part of the filter to use tac-deco_lib streaming interface instead of file functions.
But now I'm considering rewriting my filter as a parser filter with support to IAsyncReader, in next major version.
<brainstorming mode off>
Maybe I'll work on it.
twistedddx
post Sep 22 2009, 15:45
QUOTE (HorsePower73 @ Sep 22 2009, 20:50) *
You can convert widechar to multibyte, I think TAK accept multibyte filenames? I never checked tongue.gif
If you use Visual Studio:
char mbMultiByteFilename[_MAX_PATH];
WideCharToMultiByte(CP_UTF8, 0, szWideCharFilename, -1, mbMultiByteFilename, _MAX_PATH, 0, 0);
tak_SSD_Create_FromFile (mbMultiByteFilename, &Options, NULL, NULL);
HorsePower73
post Sep 23 2009, 00:54
[Are these programming details in topic?]
<Programming details START>
WideCharToMultiByte is a system function accessible using Kernel32.lib starting from WinNT, it's not a VisualStudio exclusive.
Filename string conversion in dsfTAKSource is already done using WideCharToMultiByte.
Some unicode characters does not have any MB equivalent (this is a reason unicode exists!), so conversion is sometimes impossible.
Also using best_fit_conversion on conversion exception (with system default character, the '?' wilcard used in place of not convertible characters) tak_SSD_Create_FromFile cannot open the file.
<Programming details END>
I compiled a new dsfTAKSource build which returns a better error code on filename conversion error.
Now players should detect and report it in a better way.
I'll put last build on dsfTAKSource site.
P.S.: as some of you may have noticed, site has moved. Now it is here:
http://liviocavallo.altervista.org/
- HorsePower73   TAK DirectShow Filter   Sep 21 2009, 14:59
- - Destroid   On installation I get the error message:CODERegSvr...   Sep 21 2009, 15:35
|- - HorsePower73   Thanks for testing the filter. effectively it is b...   Sep 21 2009, 17:22
- - Destroid   Nice! Works without those .DLL's. (I can...   Sep 21 2009, 17:49
|- - HorsePower73   Well, really that FLT filter is ready and working:...   Sep 21 2009, 18:01
|- - Destroid   QUOTE (HorsePower73 @ Sep 21 2009, 17:01)...   Sep 21 2009, 22:19
- - zombiewerewolf   There's only one problem I encountered. It doe...   Sep 21 2009, 18:03
|- - HorsePower73   Yes, I know. The problem here is that tac_deco_lib...   Sep 22 2009, 12:20
|- - twistedddx   QUOTE (HorsePower73 @ Sep 22 2009, 20:50)...   Sep 22 2009, 15:45
|- - HorsePower73   [Are these programming details in topic?] <Pro...   Sep 23 2009, 00:54
|- - twistedddx   QUOTE (HorsePower73 @ Sep 23 2009, 09:24)...   Sep 27 2009, 14:47
|- - HorsePower73   First: Tks for commenting. <short answer begin...   Sep 27 2009, 23:14
- - TBeck   QUOTE (HorsePower73 @ Sep 21 2009, 15:59)...   Sep 23 2009, 22:32
- - Zarggg   Ah, was that the problem? I'll be so happy onc...   Sep 24 2009, 16:08
|- - HorsePower73   dsfTAKSource v 0.0.1.2 is out (http://liviocavallo...   Sep 25 2009, 16:35
- - HorsePower73   Code has been updated (http://liviocavallo.altervi...   Sep 26 2009, 15:42
- - zombiewerewolf   It works great Thank you very much for adding uni...   Sep 26 2009, 17:18
- - johnsonlam   Thanks HorsePower73, though I didn't convert a...   Oct 1 2009, 15:55
- - watercolor   Can I use this on Windows 7 x64? I try Install.bat...   May 2 2010, 08:27
|- - HorsePower73   As lvqcl already said, it should work running inst...   May 2 2010, 11:17
- - lvqcl   Run 32-bit command line and type Install.bat there...   May 2 2010, 09:47
- - watercolor   QUOTE (lvqcl @ May 2 2010, 17:47) Run 32-...   May 2 2010, 12:55
- - Spiridon   TAK Sampling rate: 96Khz Resolution: 24bits Inco...   May 10 2010, 20:53
|- - HorsePower73   Thanks for signaling. Now ver 0.0.1.5 is online, f...   May 11 2010, 10:25
|- - Spiridon   QUOTE (HorsePower73 @ May 11 2010, 12:25)...   May 11 2010, 23:26
- - Spiridon   Sample rate: 192 Khz Can't start playback.   May 12 2010, 10:56
|- - HorsePower73   Well. this seems a deeper (or wider) problem. It d...   May 15 2010, 11:12
|- - Spiridon   QUOTE (Spiridon @ May 12 2010, 12:56) Sam...   May 25 2010, 14:19
- - betaking   To:HorsePower73 TAK 2.1.0 Final is out,but I found...   Mar 7 2011, 13:57
- - Destroid   I'm not sure any format changes occurred betwe...   Mar 7 2011, 22:18
|- - HorsePower73   Yes Destroid, you are right. I'm busy, but I...   Mar 18 2011, 09:39
- - HorsePower73   TAK DirectShow filter has been updated. Now it...   Dec 1 2011, 12:34
- - Nowings69   I want to ask you one why dont you make a splitter...   Dec 1 2011, 14:18
|- - HorsePower73   I think I have not understood you question. I coul...   Dec 2 2011, 00:06
- - Destroid   I had error using install.bat with registry entry ...   May 20 2012, 21:26
- - TBeck   Better late than never... Thank you for the fi...   Jun 18 2013, 08:47
RSS Lo-Fi Version Time is now: 30th May 2015 - 20:25
