8 Pages V  « < 6 7 8
Ogg Vorbis acceleration project, Is it dead?
lvqcl
post Jul 8 2012, 17:56
Post #176
I took my old compiles and also compiled the sources with SSE4.1 instruction set. Then I took an album (57m 37s) and encoded it. Results (encoding time, in seconds):
32 bit:
SSE - 89.5 s
SSE2 - 72.2 s
SSE3 - 73.2 s
SSE4.1 - 72.1 s
64 bit:
SSE2 - 67.1 s
SSE3 - 66.5 s
SSE4.1 - 66.1 s
BTW, I also tested original Lancer from http://homepage3.nifty.com/blacksword/index.htm
SSE - 57.7 s
SSE2 - 53.2 s
SSE3 - 53.1 s
SSE2 MT - 35.9 s (71.6 s total process time)
SSE3 MT - 36.2 s (72.3 s total process time)
eahm
post Jul 12 2012, 00:22
Post #177
Pink Floyd - The Wall 1:21:09 (CPU specs: http://i46.tinypic.com/110lytc.png)
(q5.0)
oggenc2.87-1.3.3-generic: Total encoding time: 0:29.874, 162.99x realtime
oggenc2.87-1.3.3-x64: Total encoding time: 0:17.067, 285.30x realtime
oggenc2.87-aoTuVb6.03-generic: Total encoding time: 0:31.949, 152.40x realtime
oggenc2.87-aoTuVb6.03-x64: Total encoding time: 0:18.236, 267.01x realtime
oggenc2.87-aoTuVb6.03-LancerSSE: Total encoding time: 0:18.330, 265.64x realtime
oggenc2.87-aoTuVb6.03-LancerSSE2: Total encoding time: 0:18.096, 269.07x realtime
oggenc2.87-aoTuVb6.03-LancerSSE3: Total encoding time: 0:18.439, 264.07x realtime
oggenc2.87-aoTuVb6.03-LancerSSE3_x64: Total encoding time: 0:13.994, 347.95x realtime
qaac_1.38 (V82): Total encoding time: 0:20.374, 238.99x realtime
NeroAACCodec-1.5.1 (Q0.48): Total encoding time: 0:19.313, 252.12x realtime
lame3.99.5 (V2): Total encoding time: 0:19.344, 251.71x realtime
lame3.99.5-64 (V2): Total encoding time: 0:17.643, 275.98x realtime
This post has been edited by eahm: Jul 12 2012, 00:56
lvqcl
post Jul 14 2012, 12:47
Post #178
It seems that older versions (that require Intel DLLs) were faster than current. Also, SSE2_OLD version is as fast as before. (misconfigured compiler?..)
john33
post Jul 14 2012, 14:06
Post #179
xcLame and OggDropXPd Developer
QUOTE (lvqcl @ Jul 14 2012, 12:47) *
The SSE2_OLD is actually configured in the same way as the SSE2 compile. Both are ICL 12.1 compiles. The only difference is that the OLD was compiled within VS2008 and the other within VS2010.
John
Brazil2
post Jul 15 2012, 11:20
Post #180
QUOTE (john33 @ Jul 14 2012, 15:06) *
Destroid
post Jul 22 2012, 10:07
Post #181
After finally getting the 64-bit machine operational, I have some benches to add here (running i5-2600K [OC], 8GB, WinXP x64 SP2):
OggEnc 2.87 aoTuV b6.03 Lancer builds (-q 3 [126.2 kbps])
SSE2 ........ 74.13x
SSE2 old ... 98.84x
SSE3 ........ 74.13x
SSE3 x64 .. 107.83x
lvqcl
post Jul 22 2012, 12:31
Post #182
Could you test also SSE version?
This post has been edited by lvqcl: Jul 22 2012, 12:47
IgorC
post Jul 22 2012, 14:58
Post #183
QUOTE (Destroid @ Jul 22 2012, 06:07) *
i5 2500k or i7 2600k?
http://listening-test.coresv.net/results.htm
Destroid
post Jul 22 2012, 18:23
Post #184
Ok, the results using Vorbis -q3 running on i5-2500K (OC'ed), 8GB, WinXP x64 SP2.
The encode rate and bitrate numbers come from the binaries themselves. To help make sense of which version I was running I included the binaries' date-stamps.
john33 (OggEnc 2.87 aoTuV b6.03, average bitrate 126.2 kbps, all builds Lancer except *)
Generic* 40.2072 05/04/2011
P4* 65.8952 05/04/2011
SSE 71.8857 07/04/2012
SSE2 74.1321 07/04/2012
SSE2 (old) 98.8428 07/04/2012
SSE3 74.1321 07/04/2012
SSE3 x64 107.8285 07/04/2012
lvqcl Lancer (OggEnc 2.87 aoTuV b5.7, average bitrate 118.6 kbps)
SSE 87.8602 02/20/2012
SSE2 118.6113 02/20/2012
SSE2 x64 131.7904 02/20/2012
SSE3 112.9632 02/20/2012
SSE3 x64 124.8540 02/20/2012
Blacksword Lancer (OggEnc 2.83, aoTuV b5, average bitrate 118.0 kbps)
SSE 120.112743 11/09/2006
SSE2 131.673327 11/09/2006
SSE2 MT 200.035978 11/09/2006
SSE3 131.330713 11/09/2006
SSE3 MT 199.766456 11/09/2006
This post has been edited by Destroid: Jul 22 2012, 18:46
lvqcl
post Jul 22 2012, 18:33
Post #185
oggenc "02/20/2012" is based on aoTuV 5.7, not 6.03 wink.gif
Destroid
post Jul 22 2012, 18:47
Post #186
blink.gif Fixed.
I got pretty confused with this many binaries.
Destroid
post Jul 22 2012, 20:02
Post #187
(Time expired editing above post while typing...)
FYI, I noticed the SSE binary in the aoTuV b5.7 bundle (post #121) declared itself b6.03. Because the bitrate is consistent with the other compiles in the bundle I'm guessing it's just a typo.
It's worth mentioning that Vorbis doesn't have drastic bitrate variance when compiler options change. When I posted the average bitrate in the above table it really means each individual file had the same bitrate, respective of the builder+compiler.
lvqcl
post Jul 22 2012, 20:27
Post #188
...That's strange. Thank you for the info.
AshenTech
post Oct 15 2012, 19:50
Post #189
I was wondering if somebody whos got gcc could give us a compile with AVX or AVX+sse4/4.2a to test on bulldozer based chips.
apparently they fixed the AVX support with newer gcc versions http://www.primegrid.com/forum_thread.php?id=3912
would be interesting if it where possible to see how AVX would effect encode speeds if at all smile.gif (cant wait for them to also have FMA support)
sheh
post Oct 21 2012, 06:09
Post #190
Are the AoTuV b6.03 sources from post #117 mixed with Lancer?
For decoding only, are there major quality/bugfix differences between the current libvorbis/vorbisfile and what the latest "original" Lancer was based on (from late 2006)?
lvqcl
post Oct 21 2012, 08:07
Post #191
QUOTE (sheh @ Oct 21 2012, 09:09) *
Yes, but I tested only encoding part of these sources, and I'm not sure that decoding works properly.
See http://svn.xiph.org/trunk/vorbis/CHANGES (original Lancer is based on libvorbis 1.1.2).
sheh
post Oct 21 2012, 17:32
Post #192
It seems there are decoding related changes since then. Also things like "Corrections to the specification" or "Fix a numerical instability in the edge extrapolation filter" which I don't know if are relevant or not. smile.gif So staying with an old version isn't a good idea.
How did you do the merge? Comparing Lancer against AoTuV 5, then AoTuV 5 to 6, or libvorbis (and co.) 1.1.2 to 1.3.3, and patching in in unchanged parts?
Did you try creating new SSE code? If there are clear cases of calculations done on arrays, is it necessarily difficult?
AshenTech
post May 28 2013, 06:49
Post #193
any chance of a compile with FMA support?
we cant get an intel compiler build with AVX support because intels compiler blocks non-intel chips from getting AVX code paths sadly, but FMA could have a beneficial effect on encode performance I would think smile.gif
Steve Forte Rio
post Jun 1 2014, 12:33
Post #194
Can we hope to see Oggenc Lancer Build based on aoTuV beta6.03 unified with Xiph.Org's libvorbis1.3.4?
hidn
post Jun 1 2014, 14:49
Post #195
Yes. As vorbis himself. Xiph developing another codec "opus". Welcome, new abandonware. For people who support vorbis nothing remains except "thanks". Fate of many open source projects, lack of interest.
Tuning is boring? Start new project.
This post has been edited by hidn: Jun 1 2014, 14:53
Steve Forte Rio
post Jun 1 2014, 18:56
Post #196
QUOTE (hidn @ Jun 1 2014, 11:49) *
How about wide hardware support? I'm not sure if the opus will get it even in next 2 years. That's nonsense (to close Vorbis project). Also AFAIK Opus has more targeting onto low latency and low bitrate (of course not without a cost of quality loses for simple file encoding at medium bitrates).
This post has been edited by Steve Forte Rio: Jun 1 2014, 18:59
skamp
post Jun 1 2014, 19:42
Post #197
1) Ogg Vorbis works very well in its current iteration;
2) Codec support these days is probably more software than "hardware".
8 Pages V  « < 6 7 8
RSS Lo-Fi Version Time is now: 4th May 2015 - 01:06
