8 Pages V  « < 4 5 6 7 8 >
Ogg Vorbis acceleration project, Is it dead?
LigH
post Apr 29 2012, 06:13
Post #126
@ john33 & lvqcl:
Would you be able to release DLLs as well (both the one and the four)? There are people who still use e.g. BeSweet based tools.
http://forum.gleitz.info - das deutsche doom9/Gleitz-Forum
lvqcl
post Jun 9 2012, 20:24
Post #127
I don't know how to do them, especially 4-dlls version... I managed to compile libvorbis.dll but it just crashes.
punkrockdude
post Jun 10 2012, 00:32
Post #128
Is it possible to compile this in Linux/Ubuntu? I have used the following successfully in Ubuntu and is there a modification to include these optimizations?
sudo apt-get build-dep libvorbis
mkdir ogg_build && cd ogg_build
wget http://www.geocities.jp/aoyoume/aotuv/source_code/libvorbis-aotuv_b6.03.tar.bz2
tar -xvjf libvorbis-aotuv_b6.03.tar.bz2
cd ~/ogg_build/aotuv-b6.03_20110424 && chmod +x configure
./configure --disable-shared && make
sudo make install
Regards.
This post has been edited by punkrockdude: Jun 10 2012, 00:36
john33
post Jul 1 2012, 12:15
Post #129
xcLame and OggDropXPd Developer
Three sets of 'Lancer' builds of the various dlls - aoTuVb6.03. The '4' dlls, SSE3 version has been tested with CDex and appears to be OK but all the remainder are untested. Try at your own risk and while I would be interested in feedback from the point of view of generally making these available at Rarewares, I won't pretend to know where to look to fix any problem that may exist. blink.gif
OggVorbils dlls:
SSE: http://www.rarewares.org/files/ogg/oggvorb...3_LancerSSE.zip
SSE2: http://www.rarewares.org/files/ogg/oggvorb..._LancerSSE2.zip
SSE3: http://www.rarewares.org/files/ogg/oggvorb..._LancerSSE3.zip
Libvorbis.dll:
SSE: http://www.rarewares.org/files/ogg/libvorb...3_LancerSSE.zip
SSE2: http://www.rarewares.org/files/ogg/libvorb..._LancerSSE2.zip
SSE3: http://www.rarewares.org/files/ogg/libvorb..._LancerSSE3.zip
Vorbis.dll (for HeadAC3he)
SSE: http://www.rarewares.org/files/ogg/vorbis_...3_LancerSSE.zip
SSE2: http://www.rarewares.org/files/ogg/vorbis_..._LancerSSE2.zip
SSE3: http://www.rarewares.org/files/ogg/vorbis_..._LancerSSE3.zip
John
LigH
post Jul 1 2012, 14:04
Post #130
Thank you, I will report them privately to the interested person and reply soon...
I believe those versions "for HeadAC3he" are for a HeadAC3he version so outdated that noone still has it, the last "current" versions I have (0.24a8, 0.24a13, 0.25a3) should be compatible to either of the default builds...
This post has been edited by LigH: Jul 1 2012, 14:39
john33
post Jul 1 2012, 14:19
Post #131
QUOTE (LigH @ Jul 1 2012, 14:04) *
Ah, OK, perhaps it's time to consign them to history, then?
John
LigH
post Jul 1 2012, 14:39
Post #132
Ah, no, this "vorbis.dll" is compatible to HeadAC3he 0.24a8. All three variants are working well on a Phenom-II X6.
HeadAC3he 0.24a13 uses a "bridge" library (hVorbis.dll) to be compatible to the usual builds. It uses the "quartet". The SSE variant seems to work; the SSE2 variant doesn't start correctly due to a missing "svml_dispmd.dll" - same for the SSE3 variant. This DLL appears to be related to libmmd.
Same for HeadAC3he 0.25a3 (password to unpack = 'nodelay') - SSE works, SSE2 and SSE3 miss "svml_dispmd.dll".
This post has been edited by LigH: Jul 1 2012, 14:43
lvqcl
post Jul 1 2012, 14:56
Post #133
Not only SVML_DISPMD.DLL but also LIBMMD.DLL.
BTW, 4-DLL version works with CDex correctly here. Also, libvorbis.dll works with AIMP (after renaming to aimp_libvorbis.dll)
LigH
post Jul 1 2012, 15:00
Post #134
BeSweet 1.5b31 supports both libvorbis.dll and the Ogg Vorbis quartet.
All three libvorbis variants work well with BeSweet. The SSE quartet works too, missing MD DLLs are complained three times for the SSE2 and SSE3 quartets.
lvqcl
post Jul 1 2012, 15:31
Post #135
I just noticed that Vorbis DLLs optimized for P4/Athlon64 (they are available at http://www.rarewares.org/ogg-libraries.php) also require libmmd.dll
This post has been edited by lvqcl: Jul 1 2012, 15:32
LigH
post Jul 1 2012, 15:38
Post #136
The requirement of libmmd.dll is rather common for several builds on RareWares which are compiled with one of the Intel C++ compilers.
john33
post Jul 1 2012, 15:49
Post #137
Thanks for the feedback. I've just recompiled the HeadAC3he and libvorbis dlls to include the correct svml_dispmd.lib. I've uploaded on the same links. smile.gif
Edit: Just recompiled and uploaded again.
This post has been edited by john33: Jul 1 2012, 16:29
John
LigH
post Jul 1 2012, 16:42
Post #138
Are you certain that you did not just do the opposite of the wanted? What worked before, does not anymore.
In contrast to the "libmmd.dll", I don't have this "svml_dispmd.dll" anywhere. RareWares doesn't offer it for download on the "Others" page.
john33
post Jul 1 2012, 16:57
Post #139
QUOTE (LigH @ Jul 1 2012, 16:42) *
You may be right! rolleyes.gif But, while I sort that out, the 32 bit ICL dlls required are here:
http://www.rarewares.org/files/ICL_dlls.zip
EDIT: OK, I've recompiled and uploaded yet again!! Hopefully got it right this time. wink.gif All on the original links.
This post has been edited by john33: Jul 1 2012, 17:51
John
LigH
post Jul 1 2012, 20:23
Post #140
SSE DLLs require the libmmd.dll, SSE2 and SSE3 DLLs require the svml_dispmd.dll in addition.
If they are in system32, everything works well.
Raimu
post Jul 2 2012, 19:05
Post #141
I can confirm that SSE3 DLLs work fine but require svml_dispmd.dll!
john33
post Jul 2 2012, 19:15
Post #142
That seems to be as a consequence of the optimisations used. If someone knows better, I'm more than willing to listen. wink.gif
John
lvqcl
post Jul 2 2012, 20:13
Post #143
Try "Multi-threaded (/MT)" option instead of "Multi-threaded DLL (/MD)" -- for all projects in your solution, of course. Then msvcr100, libmmd, and svml_disp libraries should be linked statically.
john33
post Jul 2 2012, 21:44
Post #144
QUOTE (lvqcl @ Jul 2 2012, 20:13) *
John
john33
post Jul 2 2012, 22:14
Post #145
OK, thanks to lvqcl, all new compiles of the dlls are now on the links above with the dependencies removed. smile.gif
John
akapuma
post Jul 2 2012, 23:40
Post #146
Thank you very much.
Time for transcoding 1h30min (movie soundtrack) on my PC:
old libvorvis.dll: 4min57sec
new libvorvis.dll: 2min53sec
Best regards
akapuma
Raimu
post Jul 3 2012, 13:00
Post #147
Yes, thank you, everyone. For myself I confirm an encoding speed increase from rate 24.1x to 29.97x on my old AMD CPU when facing off the new x64/SSE3 builds against Rarewares' latest AoTuV6 x64 build encoding a longish film soundtrack. Speed increase for dll versions is in the same ballpark, though lower for my CPU.
john33
post Jul 3 2012, 14:28
Post #148
Thanks for all the feedback and assistance, I'll post these over at Rarewares in the next few hours. smile.gif
John
Raimu
post Jul 3 2012, 19:55
Post #149
QUOTE (john33 @ Jul 3 2012, 16:28) *
@john33, any interest in also posting the cli encoder binary at Rarewares?
This post has been edited by Raimu: Jul 3 2012, 19:55
AshenTech
post Jul 4 2012, 02:45
Post #150
I was just wondering if we could get a compile using
the Open64 compiler found at http://developer.amd.com/tools/open64/pages/default.aspx for testing.
there is also another version at
http://www.open64.net/download/open64-4x-releases.html
some reports put the code it produces as being on par with ICC.
I would try and compile with it, but, to be very honest.....I really really suck with programming and compiling....couldnt keep GCC working on windows to save my life(kept breaking on me)
I would just like to see what a more cpu agnostic compiler(thats rated pretty high by its users) would give us vs ICC's results.
thanks for your efforts, its good to see vorbis still getting some love smile.gif
RSS Lo-Fi Version Time is now: 21st April 2015 - 11:37
