fpMP3Enc: a multi-core MP3 encoder based upon LAME 3.98.2
GeorgeFP
post Aug 2 2009, 12:58
Hello,
I'd like to introduce my project "fpMP3Enc" - a multicore MP3 encoder based on LAME 3.98.2. It is a sample application/case study for my multicore library "Fiber Pool".
The source code can be downloaded here: http://www.fiberpool.de/en/downloads.html
The current version is still mostly single-threaded for single-file encoding but scales for multiple-files encoding.
The multicore tweaks used in this version are:
- parallel/asynchronous conversion/scaling of PCM data to float samples
- parallel/asynchronous computation of replay gain
- I/O ordering (WAV files are read into memory first before MP3 files are written to disk)
With the following test system
- Intel Q9450@2.66GHz (Quad Core)
- 8 GiB RAM
- Windows Vista x64 (Superfetch disabled)
- 61 WAV files (2.99 GiB, about 5 hours play time)
I've got the following results:
LAME 3.98.2 (x32; rarewares): 24.6x
LAME64 3.98 (x64; mp3tech): 20.8x
fpMP3Enc (x64; single): 23.3x
fpMP3Enc (x64; multi): 80.2x
Single-file encoding is slower than the original LAME because I haven't SSE-optimized the code.
The scale factor in multiple-files encoding is 3.3 compared to LAME and 3.4 compared to "fpMP3Enc single", which is quite good for a first version.
The next steps will be to perform the psycho acoustics computation for each frame in parallel, then the MDCT, and so on.
Compile and usage:
- You need Visual Studio 2008 (and obviously Windows) to compile the project.
- SSE4 is enabled by default. To disable: #undef USE_SSE4
- Memory control is disabled by default in this version. This can lead to pagefile swapping if too many files are to be encoded. You can enable memory control by using a different 'MEMORY_MODE' macro (experimental).
- Win32 version: The total WAV file size sum must not exceed 400MiB.
- Win64 version: The total WAV file size sum must not exceed 400GiB.
- Input: WAV 16-bit stereo, 44.1kHz
- Output: MP3 Stereo/Joint-Stereo, 44.1kHz
I'd like to know what you think about this project so contact me if you have any comments or feedback.
George
hlloyge
post Sep 30 2009, 07:48
I am sorry, but where are compiled binaries? I don't really want to compile the code myself.
GeorgeFP
post Sep 30 2009, 08:44
QUOTE (hlloyge @ Sep 30 2009, 08:48) *
The main reason for not providing the binaries is that MP3 is not free and you have to pay for it. See here.
PatchWorKs
post Sep 30 2009, 10:51
QUOTE (GeorgeFP @ Sep 30 2009, 09:44) *
Why not Vorbis (or even better Theora) then ?
GeorgeFP
post Sep 30 2009, 13:31
QUOTE (PatchWorKs @ Sep 30 2009, 11:51) *
I'm thinking of making Theora multicore-capable but have not decided yet. Other projects are also very interesting, e.g. FLAC.
You should know that I'm neither an audio nor an video codec developer. And to be honest, my knowledge about MP3 is very poor.
What I wanted to show with these case studies was how algorithms can be parallelized even if everybody thinks it's too difficult or impossible. MP3 encoding was a good example for this... so I took that.
- GeorgeFP   fpMP3Enc: a multi-core MP3 encoder based upon LAME 3.98.2   Aug 2 2009, 12:58
- - Fandango   QUOTE (GeorgeFP @ Aug 2 2009, 13:58) I...   Aug 2 2009, 14:51
- - Kitsuned   Doesn't foobar2000 already do this if you have...   Aug 2 2009, 15:49
- - nazgulord   I'm not sure, but isn't it that foobar2000...   Aug 2 2009, 15:55
|- - Mike Giacomelli   QUOTE (nazgulord @ Aug 2 2009, 10:55) Out...   Aug 2 2009, 17:21
|- - Fandango   QUOTE (Mike Giacomelli @ Aug 2 2009, 18:2...   Aug 2 2009, 17:23
|- - Mike Giacomelli   QUOTE (Fandango @ Aug 2 2009, 12:23) QUOT...   Aug 2 2009, 17:38
|- - GeorgeFP   QUOTE (Kitsuned @ Aug 2 2009, 16:49) Does...   Aug 2 2009, 19:18
|- - Mike Giacomelli   QUOTE (GeorgeFP @ Aug 2 2009, 14:18) QUOT...   Aug 2 2009, 19:23
||- - GeorgeFP   QUOTE (Mike Giacomelli @ Aug 2 2009, 20:2...   Aug 2 2009, 20:04
|- - q_b6   QUOTE (GeorgeFP @ Aug 3 2009, 02:18) QUOT...   Jan 24 2010, 02:12
|- - GeorgeFP   QUOTE (q_b6 @ Jan 24 2010, 02:12) I think...   Jan 24 2010, 19:11
- - Fandango   foobar2000 does not use multi-threading encoders, ...   Aug 2 2009, 16:56
- - Mike Giacomelli   So you're getting a huge speed up by essential...   Aug 2 2009, 20:40
|- - GeorgeFP   QUOTE (Mike Giacomelli @ Aug 2 2009, 21:4...   Aug 2 2009, 21:28
- - Axon   Yeah, that was probably a bad example. In the mo...   Aug 2 2009, 21:15
|- - GeorgeFP   QUOTE (Axon @ Aug 2 2009, 22:15) In the m...   Aug 2 2009, 22:13
|- - Fandango   QUOTE (GeorgeFP @ Aug 2 2009, 23:13) In ...   Aug 2 2009, 22:50
|- - GeorgeFP   QUOTE (Fandango @ Aug 2 2009, 23:50) Will...   Aug 3 2009, 07:00
|- - GeorgeFP   Hi again, I've updated the application and ad...   Aug 5 2009, 19:53
- - GeorgeFP   Hello, it's me again... The last three weeks ...   Aug 26 2009, 22:03
|- - Alexxander   QUOTE (GeorgeFP @ Aug 26 2009, 23:03) The...   Aug 27 2009, 08:41
|- - GeorgeFP   QUOTE (Alexxander @ Aug 27 2009, 09:41) H...   Aug 27 2009, 10:12
- - spoon   x80 encoding speed equates to 14MB a second read (...   Aug 26 2009, 23:09
|- - GeorgeFP   QUOTE (spoon @ Aug 27 2009, 00:09) x80 en...   Aug 27 2009, 09:45
|- - GeorgeFP   Hello, the "final" version of fpMP3Enc ...   Sep 30 2009, 07:04
- - hlloyge   I am sorry, but where are compiled binaries? I don...   Sep 30 2009, 07:48
|- - GeorgeFP   QUOTE (hlloyge @ Sep 30 2009, 08:48) I am...   Sep 30 2009, 08:44
|- - PatchWorKs   QUOTE (GeorgeFP @ Sep 30 2009, 09:44) The...   Sep 30 2009, 10:51
|- - skamp   QUOTE (PatchWorKs @ Sep 30 2009, 11:51) W...   Sep 30 2009, 13:15
|- - GeorgeFP   QUOTE (PatchWorKs @ Sep 30 2009, 11:51) W...   Sep 30 2009, 13:31
- - twist3d   Any chance getting a compile to rarewares?   Oct 2 2009, 12:27
- - GeorgeFP   Hi again, meanwhile, I've added ID3 tagging s...   Oct 28 2009, 10:02
- - punkrockdude   Anyone who has compiled this encoder that could se...   Oct 28 2009, 11:43
|- - GeorgeFP   QUOTE (punkrockdude @ Oct 28 2009, 12:43)...   Oct 28 2009, 20:02
|- - GeorgeFP   QUOTE (GeorgeFP @ Oct 28 2009, 21:02) I a...   Oct 29 2009, 10:53
|- - jamesbaud   QUOTE (GeorgeFP @ Oct 29 2009, 01:53) QUO...   Dec 3 2009, 08:29
- - GeorgeFP   The download link is: http://www.rarewares.org/mp3...   Nov 3 2009, 06:39
- - Cokemonkey11   Any chance in a GUI frontend? I'm interested i...   Nov 3 2009, 07:08
|- - GeorgeFP   QUOTE (Cokemonkey11 @ Nov 3 2009, 08:08) ...   Nov 3 2009, 07:46
||- - Cokemonkey11   QUOTE (GeorgeFP @ Nov 2 2009, 23:46) QUOT...   Nov 6 2009, 02:45
||- - GeorgeFP   QUOTE (Cokemonkey11 @ Nov 6 2009, 03:45) ...   Nov 6 2009, 10:30
|- - punkrockdude   QUOTE (Cokemonkey11 @ Nov 3 2009, 08:08) ...   Nov 3 2009, 08:10
- - sld   The figures thrown around here are fantastic. Many...   Nov 3 2009, 07:43
- - Brent   Have you thought about using .net/mono with gtk#? ...   Nov 6 2009, 13:32
|- - Xire   Any plans to support STDIN/STDOUT?   Nov 6 2009, 13:58
||- - GeorgeFP   QUOTE (Xire @ Nov 6 2009, 14:58) Any plan...   Nov 6 2009, 15:08
|- - GeorgeFP   QUOTE (Brent @ Nov 6 2009, 14:32) Have yo...   Nov 6 2009, 14:57
- - hlloyge   C2Q, 32 bit encoder, 32 bit windows 7, i know it s...   Nov 6 2009, 17:58
|- - GeorgeFP   QUOTE (hlloyge @ Nov 6 2009, 17:58) C2Q, ...   Nov 6 2009, 18:22
||- - hlloyge   QUOTE (GeorgeFP @ Nov 6 2009, 19:22) From...   Nov 6 2009, 22:11
|- - Alexxander   QUOTE (hlloyge @ Nov 6 2009, 17:58) It wo...   Nov 6 2009, 18:58
|- - GeorgeFP   QUOTE (Alexxander @ Nov 6 2009, 18:58) Ex...   Nov 6 2009, 20:57
- - smeargol   Very good work! I would like to try it out, bu...   Nov 10 2009, 00:34
|- - GeorgeFP   QUOTE (smeargol @ Nov 10 2009, 00:34) So,...   Nov 10 2009, 07:08
|- - smeargol   QUOTE (GeorgeFP @ Nov 10 2009, 08:08) I m...   Nov 10 2009, 14:01
|- - GeorgeFP   QUOTE (smeargol @ Nov 10 2009, 14:01) It ...   Nov 18 2009, 18:01
|- - smeargol   QUOTE (GeorgeFP @ Nov 18 2009, 19:01) Bad...   Nov 20 2009, 22:58
- - sandhuatha   Thanks a lot for this utility. I am very happy to ...   Dec 5 2009, 21:59
|- - GeorgeFP   QUOTE (sandhuatha @ Dec 5 2009, 21:59) Ho...   Dec 5 2009, 23:51
- - edwardar   Any chance someone could give a foobar2000 command...   Dec 30 2009, 17:16
|- - GeorgeFP   QUOTE (edwardar @ Dec 30 2009, 17:16) Any...   Dec 31 2009, 10:08
- - -sanb-   how can i use them with winamp?   Jan 2 2010, 15:06
- - flapane   Will you add mp3 transcoding (mp3 to mp3) support?   Jan 18 2010, 22:00
|- - GeorgeFP   QUOTE (flapane @ Jan 18 2010, 22:00) Will...   Jan 18 2010, 22:41
- - LordCorvin   Sorry if that've been asked already, but is th...   Jan 23 2010, 20:06
|- - GeorgeFP   QUOTE (LordCorvin @ Jan 23 2010, 20:06) S...   Jan 23 2010, 20:46
|- - LordCorvin   QUOTE (GeorgeFP @ Jan 23 2010, 20:46) QUO...   Jan 23 2010, 22:27
|- - GeorgeFP   QUOTE (LordCorvin @ Jan 23 2010, 22:27) S...   Jan 23 2010, 23:04
- - flapane   Hi, could you explain me why it runs single thread...   Jun 18 2011, 17:55
- - GeorgeFP   By design, the encoder will run with at least thre...   Jun 18 2011, 20:14
- - JJZolx   Any thoughts to updating this to make it based on ...   May 21 2012, 02:10
|- - GeorgeFP   QUOTE (JJZolx @ May 21 2012, 03:10) Any t...   May 21 2012, 19:17
|- - lar1r   QUOTE (GeorgeFP @ May 21 2012, 19:17) QUO...   Aug 10 2012, 21:48
|- - GeorgeFP   QUOTE (lar1r @ Aug 10 2012, 22:48) Intere...   Aug 11 2012, 11:33
|- - lar1r   QUOTE (GeorgeFP @ Aug 11 2012, 11:33) QUO...   Aug 13 2012, 15:24
- - JJZolx   George, has there been any progress on an update t...   Jan 17 2014, 16:25
- - goa pride   George, has there been any progress on an update t...   Jan 17 2014, 22:48
RSS Lo-Fi Version Time is now: 30th August 2015 - 03:50
