IPB
9 Pages V   1 2 3 > »
foo_playlist_attributes, Assign relevant attributes to a playlist
fbuser
post Aug 1 2009, 22:48
Post #1
Group: Developer
This component lets you assign various attributes to a playlist. The component also reimplements two options which are already provided by foo_removeplayed, to make them useable on a per playlist basis.
Download the latest version: here
This post has been edited by fbuser: Sep 16 2011, 22:52
Go to the top of the page
+Quote Post
Mar2zz
post Aug 2 2009, 00:18
Post #2
Group: Members
Very nice. some options that are on the featurelist also in here. thank you.
http://www.youtube.com/watch?v=whoj6BOSfE4 (foob.fm)
+Quote Post
Mar2zz
post Aug 2 2009, 10:17
Post #3
Group: Members
Hmm can't edit my post?
obviously remove played and skipped tracks don't work with autoplaylists.
What is the difference between remove played and skipped tracks with the checkbox, and the same option that can be set for a playlist?
very nice to see that the playback order in toolbar changes with the setting made with this component.
great work.
+Quote Post
wojtek
post Aug 2 2009, 10:42
Post #4
Group: Members
Brilliant component!
One small question/request - would it be possible to (option?) change playback order on playlist change rather than on playback?
http://foobar2000.pl/ :: unofficial polish forum
+Quote Post
fbuser
post Aug 2 2009, 10:49
Post #5
Group: Developer
QUOTE (Mar2zz @ Aug 2 2009, 10:17) *
It's by design. You can't edit an autoplaylist manually either.
The checkboxes are for the global settings for all playlists.
+Quote Post
fbuser
post Aug 2 2009, 10:52
Post #6
Group: Developer
QUOTE (lwiczek @ Aug 2 2009, 10:42) *
That doesn't make any sense to me. The playback order is related to the current playing playlist. Why should it be changed, when you switch to another playlist?
+Quote Post
wojtek
post Aug 2 2009, 11:02
Post #7
Group: Members
QUOTE (fbuser @ Aug 2 2009, 11:52) *
Good point... i've just thought of it like i do usually - switch to playlist, choose playback order, play something. My suggestion was more of informative type - you switch to a playlist and you can imediatelly see the playback order for the selected playlist, but that would be hard / impossible to implement because it would collide with the real playing order. Ergo - never mind (;
+Quote Post
fbuser
post Aug 2 2009, 11:23
Post #8
Group: Developer
QUOTE (lwiczek @ Aug 2 2009, 11:02) *
For playlists with specific settings you will need a few mouse clicks, but you can see it in the main menu: Playback -> Playlist playback attributes -> Playback order
+Quote Post
Black_Over_Bills...
post Aug 2 2009, 11:25
Post #9
Group: Members
@fbuser
Great component - thanks. And now the usual 'but it would be better if...'!
Would it be possible to;
1) Implement a context menu for each playlist so that only it's attributes could be changed/viewed from the menu system rather than via settings
2) I use a naming convention for my playlists eg. "s_blahblah". The s_ denotes a singles ie. non-album related playlist. Could you please implement a wildcard naming convention (a la SQL) to allow one playlist settings to be applied to any playlist matching the criteria.
Thanks for your time in developing the foobar components - they are much appreciated.
+Quote Post
Robertina
post Aug 2 2009, 11:59
Post #10
Group: Banned
fbuser,
I have tested your new plugin but I have some difficulties to understand how it works. I hope my questions are not to foolish:
QUOTE
On starting a playback session, the attributes, which are specific to a playlist, are set. They will be reset on stopping a playback session. ... Changing the attributes for the playing playlist will take affect on the following playback session.
I assume that a "playback session" and a "foobar session" are two different things.
So when exactly begins / stops a "playback session"? With the choosing of an playlist (and playing an arbitrary track in it)?
Additionally
What do you think about an option to send the removed tracks to a special playlist to delete the files later from this playlist? This would be very usefully for me for my podcasts.
Thank you for foo_playlist_playback_attributes.
Robertina.
+Quote Post
smkk
post Aug 2 2009, 23:57
Post #11
Group: Members
Very nice component, thanks for this.
Only one very minor issue. For some reason foo_whatsnew keeps showing the "new" features of this plugin every time i start foobar (instead of only showing them once).
+Quote Post
wojtek
post Aug 3 2009, 13:02
Post #12
Group: Members
QUOTE (Black_Over_Bills_Mothers @ Aug 2 2009, 12:25) *
+1
+Quote Post
fbuser
post Aug 3 2009, 18:33
Post #13
Group: Developer
QUOTE (Black_Over_Bills_Mothers @ Aug 2 2009, 11:25) *
You may have noted it already, but you can change the attributes for the active playlist via the main menu. See the post above yours.
I have not decided, if I will do it, yet. It is obviously useful when using many playlist, but it would add an additional level of complexity. Further such a feature has currently no use for me, so I'm not very eager to implement it.
QUOTE (Robertina @ Aug 2 2009, 11:59) *
It's discussed in a more technical way here. Simplified said, a playback session starts, when you press play and ends when you press stop.
For removing played tracks, you can achieve the same with foo_navigator. But I like the idea and think that I will implement it.
QUOTE (smkk @ Aug 2 2009, 23:57) *
I can't reproduce it here, although I'm alway using foo_whatsnew, even in my test environment. But I recognized a similar issue, not related to foo_playlist_playback_attribute, when I used foo_menu_addons. Are you using this component?
+Quote Post
smkk
post Aug 3 2009, 20:36
Post #14
Group: Members
QUOTE (fbuser @ Aug 3 2009, 19:33) *
I have to apologize, it wasnt foo_playlist_playback_attribute which was causing the problem appearently. The problem was that foobar was unable to update the features.dat (access denied), after removing the hidden attribute from the file everything worked again.
Again thanks for this useful component. =)
+Quote Post
q-stankovic
post Aug 5 2009, 17:31
Post #15
Group: Members
hello fbuser,
i have no feature requests but two minor suggestions - if you like call them pedantic.
1. Could you use the new case sentence style for the name of the commands?
2. Wouldn't main menu -> edit be the better place for assigning playback attributes as this submenu is related to current/active playlist?
german support forum: www.foobar-users.de / user: qwert73
+Quote Post
Fractal_Mortalit...
post Aug 6 2009, 08:46
Post #16
Group: Members
Excellent plugin!
My request: Adding integration of "stop after current" behavior for individual playlists.
http://www.last.fm/user/magnumforce2006
+Quote Post
odyssey
post Aug 6 2009, 09:32
Post #17
Group: Members
Ooooh have we been missing this component forever? I think we have!! Brilliant - THANKS!!!!!
I only have one request for change to it: Instead of choosing specific playlists, it would be great if you could assign attributes with wildcards, just like in columnsui options. I believe this could be done with a combo-box, in style with the "Send to" playlist selection, so it wouldn't affect people that want it the way it is today.
QUOTE (Fractal_Mortality @ Aug 6 2009, 09:46) *
+1
This post has been edited by odyssey: Aug 6 2009, 09:35
+Quote Post
odyssey
post Aug 6 2009, 11:03
Post #18
Group: Members
Another thing I thought of; would it be possible to make defaults? Say, any playlist not specified should follow these attributes?
+Quote Post
Robertina
post Aug 6 2009, 17:47
Post #19
Group: Banned
QUOTE (Fractal_Mortality @ Aug 5 2009, 20:46) *
Great idea!
And a dream would be if Stop on current could be integrated as well, but I assume there is not much chance because it is an additional plugin which isn't available on all systems.
+Quote Post
fbuser
post Aug 6 2009, 19:29
Post #20
Group: Developer
QUOTE (q-stankovic @ Aug 5 2009, 17:31) *
No. Althought I don't no what you exactly mean with "new case sentence style", it doesn't matter in this case. The problem is that the commands are available via the menu and via a dropdown box in the preferences. According to an older style guide menu commands should use book title style and dropdown box entries should use sentence style. According to a new style guide (the actual?) even menu commands should use sentence style, which is currently inconsistent with the menus in foobar2000. But consistency within the component is more important for me, so I use sentence style for all entries. It also fits better to the replaygain processing modes, which are also written in sentence style.
No, although assigning attributes to a playlist is technically a kind of editing the playlist, all attributes are related to playback in the first place.
QUOTE (Fractal_Mortality @ Aug 6 2009, 08:46) *
It ist not very useful IMHO. It will only produce playlists which will stop after each track. What can be done with this?
QUOTE (odyssey @ Aug 6 2009, 11:03) *
It's already there. If you choose the global value for an attribute, it uses the fb2k standard settings.
This post has been edited by fbuser: Aug 7 2009, 17:25
+Quote Post
odyssey
post Aug 6 2009, 23:23
Post #21
Group: Members
QUOTE
Who said fb2k's standard settings are my preffered settings? wink.gif I suppose the default fb2k setting is "Default" i.e. non-shuffled?
+Quote Post
fbuser
post Aug 6 2009, 23:48
Post #22
Group: Developer
QUOTE (odyssey @ Aug 6 2009, 23:23) *
QUOTE
Maybe we misunderstand each other, but if you choose for example from the main menu "Playback -> Order -> Repeat (playlist)" as your standard setting, it will be used for all playlists, which have the global option assigned for playback order. Actually it means there is no attribute assigned to these playlists, so in this case the component will do nothing for the specific attribute.
+Quote Post
odyssey
post Aug 6 2009, 23:56
Post #23
Group: Members
Yes that makes more sense. I would probably refer to it as it "reverts to previous state" or "reverts to last manually set state" smile.gif
+Quote Post
Fractal_Mortalit...
post Aug 7 2009, 05:33
Post #24
Group: Members
QUOTE (fbuser @ Aug 6 2009, 14:29) *
Well, I am a radio DJ at my college and I use foobar to play tracks... Typically I like to have "stop after current" activated and have my tracks for the night all lined up. I normally don't use this feature while listening to music regularly, so having a specific "radio" playlist would be nice to have default play order and stop after current.
+Quote Post
DaMatrix
post Aug 7 2009, 08:05
Post #25
Group: Members
Very nice component!
Besides the request for "stop after current" behavior for individual playlists, I would like to see "Monitor Playing Tracks" for individual playlists. Sometimes I do not want Foobar to monitor the playing tracks. It would be nice when I play those songs in a specific playlist, "Monitor Playing Tracks" would automatically turn off (and of course would turn on when playing other playlists). It does occur from time to time, that I forget to put "Monitor Playing Tracks" on or off and this can be fixed with your component.
One other thing. When switching the playback order via "Playback -> Playlist playback attributes -> Playback order", the playback order will only change after the playlist is manually started. One would think that when changing the playback order via the menu, the playback order will change immediately especially when the playlist is playing.
+Quote Post
9 Pages V   1 2 3 > »
0 Members:
RSS Lo-Fi Version Time is now: 31st August 2015 - 20:06
