foo_playlist_attributes, Assign relevant attributes to a playlist
fbuser
post Aug 1 2009, 22:48
This component lets you assign various attributes to a playlist. The component also reimplements two options which are already provided by foo_removeplayed, to make them useable on a per playlist basis.
Download the latest version: here
This post has been edited by fbuser: Sep 16 2011, 22:52
fbuser
post Aug 3 2009, 18:33
QUOTE (Black_Over_Bills_Mothers @ Aug 2 2009, 11:25) *
1) Implement a context menu for each playlist so that only it's attributes could be changed/viewed from the menu system rather than via settings
You may have noted it already, but you can change the attributes for the active playlist via the main menu. See the post above yours.
2) I use a naming convention for my playlists eg. "s_blahblah". The s_ denotes a singles ie. non-album related playlist. Could you please implement a wildcard naming convention (a la SQL) to allow one playlist settings to be applied to any playlist matching the criteria.
I have not decided, if I will do it, yet. It is obviously useful when using many playlist, but it would add an additional level of complexity. Further such a feature has currently no use for me, so I'm not very eager to implement it.
QUOTE (Robertina @ Aug 2 2009, 11:59) *
So when exactly begins / stops a "playback session"? With the choosing of an playlist (and playing an arbitrary track in it)?
It's discussed in a more technical way here. Simplified said, a playback session starts, when you press play and ends when you press stop.
What do you think about an option to send the removed tracks to a special playlist to delete the files later from this playlist? This would be very usefully for me for my podcasts.
For removing played tracks, you can achieve the same with foo_navigator. But I like the idea and think that I will implement it.
QUOTE (smkk @ Aug 2 2009, 23:57) *
Very nice component, thanks for this.
Only one very minor issue. For some reason foo_whatsnew keeps showing the "new" features of this plugin every time i start foobar (instead of only showing them once).
I can't reproduce it here, although I'm alway using foo_whatsnew, even in my test environment. But I recognized a similar issue, not related to foo_playlist_playback_attribute, when I used foo_menu_addons. Are you using this component?
- fbuser   foo_playlist_attributes   Aug 1 2009, 22:48
- - Mar2zz   Very nice. some options that are on the featurelis...   Aug 2 2009, 00:18
- - Mar2zz   Hmm can't edit my post? obviously remove play...   Aug 2 2009, 10:17
|- - fbuser   QUOTE (Mar2zz @ Aug 2 2009, 10:17) obviou...   Aug 2 2009, 10:49
- - lwiczek   Brilliant component! One small question/reques...   Aug 2 2009, 10:42
|- - fbuser   QUOTE (lwiczek @ Aug 2 2009, 10:42) One s...   Aug 2 2009, 10:52
|- - lwiczek   QUOTE (fbuser @ Aug 2 2009, 11:52) That d...   Aug 2 2009, 11:02
|- - fbuser   QUOTE (lwiczek @ Aug 2 2009, 11:02) you s...   Aug 2 2009, 11:23
- - Black_Over_Bills_Mothers   @fbuser Great component - thanks. And now the usua...   Aug 2 2009, 11:25
|- - lwiczek   QUOTE (Black_Over_Bills_Mothers @ Aug 2 2009,...   Aug 3 2009, 13:02
- - Robertina   fbuser, I have tested your new plugin but I have ...   Aug 2 2009, 11:59
- - smkk   Very nice component, thanks for this. Only one ver...   Aug 2 2009, 23:57
- - fbuser   QUOTE (Black_Over_Bills_Mothers @ Aug 2 2009,...   Aug 3 2009, 18:33
- - smkk   QUOTE (fbuser @ Aug 3 2009, 19:33) I can...   Aug 3 2009, 20:36
- - q-stankovic   hello fbuser, i have no feature requests but two ...   Aug 5 2009, 17:31
- - Fractal_Mortality   Excellent plugin! My request: Adding integrat...   Aug 6 2009, 08:46
|- - Robertina   QUOTE (Fractal_Mortality @ Aug 5 2009, 20...   Aug 6 2009, 17:47
- - odyssey   Ooooh have we been missing this component forever?...   Aug 6 2009, 09:32
- - odyssey   Another thing I thought of; would it be possible t...   Aug 6 2009, 11:03
- - fbuser   QUOTE (q-stankovic @ Aug 5 2009, 17...   Aug 6 2009, 19:29
|- - odyssey   QUOTE QUOTE (odyssey @ Aug 6 2009, 11:03)...   Aug 6 2009, 23:23
||- - fbuser   QUOTE (odyssey @ Aug 6 2009, 23:23) QUOTE...   Aug 6 2009, 23:48
||- - odyssey   Yes that makes more sense. I would probably refer ...   Aug 6 2009, 23:56
|- - Fractal_Mortality   QUOTE (fbuser @ Aug 6 2009, 14:29) QUOTE ...   Aug 7 2009, 05:33
|- - odyssey   QUOTE (fbuser @ Aug 6 2009, 20:29) QUOTE ...   Aug 7 2009, 10:29
- - DaMatrix   Very nice component! Besides the request for ...   Aug 7 2009, 08:05
- - DaMatrix   QUOTE (DaMatrix @ Aug 7 2009, 08:05) Very...   Aug 7 2009, 10:37
|- - odyssey   QUOTE (DaMatrix @ Aug 7 2009, 11:37) Anot...   Aug 11 2009, 15:43
- - fbuser   QUOTE (DaMatrix @ Aug 7 2009, 08:05) Besi...   Aug 7 2009, 11:16
|- - Yirkha   QUOTE (fbuser @ Aug 7 2009, 12:16) This i...   Aug 7 2009, 20:51
- - q-stankovic   QUOTE (fbuser @ Aug 6 2009, 20:29) QUOTE ...   Aug 7 2009, 14:21
|- - fbuser   QUOTE (q-stankovic @ Aug 7 2009, 14...   Aug 7 2009, 15:00
- - q-stankovic   Sorry for confusion as i used the wrong names. Wh...   Aug 7 2009, 16:32
|- - fbuser   QUOTE (q-stankovic @ Aug 7 2009, 16...   Aug 7 2009, 17:26
- - shakey_snake   He's being consistent with the OS. It's re...   Aug 7 2009, 16:45
- - Mar2zz   I really like your component and use it too. It re...   Aug 7 2009, 19:12
- - Dr_Colossus   Here's a feature I'd like to see. I would...   Aug 7 2009, 19:53
|- - odyssey   QUOTE (Dr_Colossus @ Aug 7 2009, 20:53) I...   Aug 7 2009, 20:00
- - fbuser   QUOTE (Mar2zz @ Aug 7 2009, 19:12) I real...   Aug 7 2009, 21:45
- - Mar2zz   QUOTE (fbuser @ Aug 7 2009, 22:45) QUOTE ...   Aug 7 2009, 22:54
|- - fbuser   QUOTE (Mar2zz @ Aug 7 2009, 22:54) Playba...   Aug 7 2009, 23:26
- - Mar2zz   That's enough for me that function. didn't...   Aug 8 2009, 00:02
- - q-stankovic   (As my point is not related to functionality of fo...   Aug 8 2009, 12:59
|- - fbuser   QUOTE (q-stankovic @ Aug 8 2009, 12...   Aug 8 2009, 15:00
- - odyssey   "Stop after current album" might also be...   Aug 10 2009, 13:35
- - odyssey   This is probably an idea nobody but me want I thi...   Aug 10 2009, 17:40
- - DaMatrix   QUOTE (odyssey @ Aug 11 2009, 15:43) QUOT...   Aug 14 2009, 09:06
- - odyssey   No, I figured it was just my laptop that did this   Aug 14 2009, 10:26
- - grimes   Bravo for this useful component. post #1: QUOTE A...   Aug 14 2009, 12:35
- - fbuser   After the start of foobar2000 the first playback s...   Aug 14 2009, 13:57
|- - odyssey   QUOTE (fbuser @ Aug 14 2009, 14:57) After...   Aug 14 2009, 16:18
|- - fbuser   QUOTE (odyssey @ Aug 14 2009, 16:18) QUOT...   Aug 14 2009, 16:43
- - grimes   Is this a "Resume playback after restart...   Aug 14 2009, 15:11
- - odyssey   I'm unable to override the Playlist Attribute ...   Aug 28 2009, 18:27
- - fbuser   This is intended. Changing a global attribute duri...   Aug 28 2009, 19:09
|- - Forfit   LastFm component always changes the playlist name ...   Sep 12 2009, 23:39
- - --pv--   I think no one will like this idea because bookmar...   Sep 13 2009, 10:49
- - odyssey   @--pv-- Well it makes sense by it's logical d...   Sep 13 2009, 11:58
- - --pv--   I imagine it this way. I'll restart foobar 200...   Sep 15 2009, 18:29
|- - odyssey   QUOTE (--pv-- @ Sep 15 20...   Sep 16 2009, 07:53
- - fbuser   @--pv-- To make it short: it was already implement...   Sep 15 2009, 20:10
- - Fractal_Mortality   Found a bug: When you have a song queued up in an...   Sep 26 2009, 20:39
|- - fbuser   I don't consider this as a bug. It's more ...   Oct 8 2009, 08:03
- - fbuser   Version 0.2.0 is available. See the first post for...   Oct 8 2009, 08:05
- - 2E7AH   Component got new shorter name - that's good ...   Oct 8 2009, 08:51
|- - fbuser   QUOTE (2E7AH @ Oct 8 2009, 08:51) And the...   Oct 8 2009, 09:06
- - 2E7AH   I missed that, but isn't item in "menu ...   Oct 8 2009, 09:15
- - fbuser   No, the items in the playback menu are for global ...   Oct 8 2009, 09:19
- - Squeller   I have not yet tried your component, but from what...   Oct 8 2009, 09:20
|- - fbuser   QUOTE (Squeller @ Oct 8 2009, 09:20) I ha...   Oct 8 2009, 11:48
- - Fractal_Mortality   Thanks for stop after current! Much appreciate...   Oct 8 2009, 20:26
- - 2E7AH   I use playlist for skipped tracks. But there also ...   Oct 11 2009, 12:28
|- - fbuser   QUOTE (2E7AH @ Oct 11 2009, 12:28) I use ...   Oct 11 2009, 13:06
|- - 2E7AH   QUOTE (fbuser @ Oct 11 2009, 14:06) Becau...   Oct 12 2009, 07:45
- - trashcan   Hi and thanks for a very nice plugin! I wonder...   Oct 11 2009, 15:19
- - fbuser   You're always welcome to make feature suggesti...   Oct 11 2009, 15:51
- - trashcan   I thought it could be considered related since thi...   Oct 11 2009, 19:00
|- - fbuser   QUOTE (trashcan @ Oct 11 2009, 19:00) Wha...   Oct 11 2009, 19:30
- - lwiczek   Would it be possible to assing option "Reset ...   Oct 12 2009, 12:10
- - fbuser   QUOTE (2E7AH @ Oct 12 2009, 07:45) QUOTE ...   Oct 12 2009, 19:08
|- - 2E7AH   QUOTE (fbuser @ Oct 12 2009, 20:08) I thi...   Oct 13 2009, 06:17
- - fbuser   Basically, this is possible, as the SDK offers the...   Oct 13 2009, 17:37
- - 2E7AH   If set to 1 min - played tracks will correspond to...   Oct 14 2009, 10:35
- - TehNomad   I'm using the latest version and I have an odd...   Oct 20 2009, 07:54
- - fbuser   I can confirm this behaviour, when using a "R...   Oct 20 2009, 17:59
- - q-stankovic   For me enabling the global option "Playback o...   Oct 20 2009, 18:47
- - fbuser   Strange, even after a short glance on the source c...   Oct 20 2009, 19:48
- - fbuser   Both issues should be fixed now. See the first pos...   Oct 20 2009, 22:12
- - fbuser   New version. See first post for download and detai...   Nov 16 2009, 20:51
- - odyssey   Request to add DSP preset to playlist attributes   Nov 26 2009, 15:42
- - fbuser   Do you mean different saved presets for the preset...   Nov 26 2009, 20:34
- - odyssey   Yes! It's possible with 1.0! And it...   Nov 27 2009, 09:17
|- - fbuser   QUOTE (odyssey @ Nov 27 2009, 09:17) Yes...   Nov 27 2009, 21:08
- - odyssey   I just downloaded (upgraded to) the latest version...   Dec 10 2009, 09:36
|- - fbuser   QUOTE (odyssey @ Dec 10 2009, 09:36) I ju...   Dec 10 2009, 20:21
- - odyssey   Well, when I change DSP settings (e.g. remove Cont...   Dec 10 2009, 21:46
- - fbuser   I can't confirm this. For me removing Continua...   Dec 10 2009, 22:31
- - odyssey   You are right, it works fine - I must have overloo...   Dec 11 2009, 15:31
- - Robertina   At the moment I am using foo_playlist_attributes 0...   Jan 11 2010, 09:54
- - Yirkha   QUOTE (Robertina @ Jan 11 2010, 09:54) Ar...   Jan 11 2010, 12:05
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 30th July 2015 - 01:11
