foo_queuecontents - View and edit queue
kerpondile
post Jul 27 2009, 11:51
foo_queuecontents enables the user to edit and view queue contents through an ui element. Both the Default User Interface (DUI) and Columns User Interface (CUI/uie) are supported. As a legacy option, queue contents can also be viewed and edited by a special queue playlist, which is updated automatically with queue contents.
Newest version: 0.5.1 / 2012-03-11
For more information, please see the Wiki page.
Links:
Homepage: http://sites.google.com/site/salskisite/foo_queuecontents
Download the latest version: Official component repository
Source code: github (Please see the license files)
Please add any comments, I appreciate them!
Sami Salonen
This post has been edited by kerpondile: Mar 11 2012, 10:21
2E7AH
post Feb 24 2010, 20:49
Group: Validating
You can use ELPlaylist as a panel: Bind it to your queue playlist and deactivate "follow active playlist"
You can also follow NowPlaying playlist, and the only drawback seems that it isn't easy customizable, but as a queue panel it can be great
krzyszcz
post Feb 24 2010, 21:07
QUOTE (2E7AH @ Feb 24 2010, 20:49) *
Seems really cool, but it's still missing something: when I choose "add to playback queue" from the context menu, ElPlaylist remains the same. It cannot be modified by drag&drop too... It only shows e.g. contents of album that I chose to be played.
2E7AH
post Feb 24 2010, 21:23
Group: Validating
QUOTE (krzyszcz @ Feb 24 2010, 21:07) *
you should select Queue as ELPlaylist playlist, and it will work
drag&drop isn't supported for queue, so if you want it just use normal playlist and pretend it's queue
krzyszcz
post Feb 24 2010, 21:38
The "list of songs that will be played next", as you put it, is the playlist. That's specifically what a playlist is, a "list of songs to be played". You don't need a special component to display this.
In playlists tab I have "My music", *Browser*, "Filter Results" (from Columns UI) and Queue (by foo_queuecontents) and none of them is a queue.
Queue is a list of all songs waiting to be played. And how can it be impossible with foobar, which is so configurable and has so many plugins available, while in Winamp it is an onboard functionality.
Yes, but only for files, that I queued by context menu. And this is why it won't show all files that will be played next: e.g. I choose first song of an album to play and foobar (columns UI) will automatically play all songs of this album following this one. And then, maybe, files that I added by context menu. ElPlaylist, in this configuration, will show only those from context menu.
When I choose "Follow NowPlaying playlist" in ElPlaylist, on the other hand, my NowPlaying album is shown there, but I cannot add there files to queue, neither by context menu nor by drag&drop.
I need a combination of Queue (by foo_queuecontents) and NowPlaying playlist (by ElPlaylist) that would be able to show in a particular moment everything that foobar will play since that moment, unless I change something.
This post has been edited by krzyszcz: Feb 24 2010, 21:57
- kerpondile   foo_queuecontents - View and edit queue   Jul 27 2009, 11:51
- - Horst Fux   This is just awesome, since foo_queuemanager doesn...   Jul 27 2009, 12:09
|- - kerpondile   Thank you! I appreciate it. The main reason I ...   Jul 27 2009, 13:42
- - s33m33   Used foo_pqview till now, but it had limitations. ...   Jul 27 2009, 14:00
- - q-stankovic   Reordering in Queue Playlist causes that numbers i...   Jul 27 2009, 17:04
|- - Yotsuya   QUOTE (q-stankovic @ Jul 27 2009, 11...   Jul 27 2009, 17:14
||- - kerpondile   Playlist name can be set in the 'Advanced...   Jul 27 2009, 20:27
|- - kerpondile   QUOTE (q-stankovic @ Jul 27 2009, 09...   Jul 28 2009, 06:46
- - durch   Is this the same Columns UI does with "View/C...   Jul 28 2009, 12:25
|- - zygzak   It would be possible to save queue between Foobars...   Jul 28 2009, 12:53
- - kerpondile   QUOTE (durch @ Jul 28 2009, 13:25) Is thi...   Jul 28 2009, 18:37
- - Xezzy   Except if you dont mind changing name to foo_queue...   Jul 28 2009, 18:50
- - Xezzy   Uhmm, good point mixcherry.   Jul 28 2009, 19:09
|- - zygzak   My point is: if we have queue that looks like play...   Jul 28 2009, 19:29
- - Anas   Thank you very much, kerpondile. This is much requ...   Jul 28 2009, 19:29
- - mixcherry   My point is: if we have queue that looks like play...   Jul 28 2009, 19:45
- - Yotsuya   I'm posting to confirm the latest version fixe...   Jul 29 2009, 03:05
- - mixcherry   Where did I say I don't like this component? I...   Jul 29 2009, 09:33
- - q-stankovic   I am very aware that kerpondile surely put much ef...   Jul 29 2009, 16:42
- - FavioD   thanks for this, very useful   Jul 29 2009, 18:39
- - sPeziFisH   AFAIK the only thing that makes a queue interestin...   Jul 29 2009, 19:54
- - durch   I agree it would be great if the queue would be a ...   Jul 30 2009, 00:14
- - kerpondile   QUOTE (mixcherry @ Jul 28 2009, 20:01) I ...   Jul 30 2009, 08:17
- - q-stankovic   Hello kerpondile, my point wasn't only that f...   Jul 30 2009, 15:02
- - zygzak   Kerpondile, there a lot of users who use your plug...   Jul 30 2009, 17:28
- - odyssey   Kerpondile, I hope you have not abandoned this com...   Aug 14 2009, 17:52
- - mixcherry   I like the idea. No messing with playlists, just p...   Aug 14 2009, 18:27
- - AndyL   I've been waiting for something like this for ...   Aug 14 2009, 20:00
- - kerpondile   QUOTE (odyssey @ Aug 14 2009, 19:52) Kerp...   Aug 20 2009, 17:56
- - haazetzet   hey this is awesome. i just wanted to start a sear...   Aug 20 2009, 19:34
- - Stonefred   QUOTE (zygzak @ Jul 30 2009, 17:28) [...]...   Aug 25 2009, 17:29
- - q-stankovic   QUOTE (kerpondile @ Aug 20 2009, 18:56) A...   Aug 25 2009, 17:39
- - Stonefred   i did! but his statement QUOTE Someone suggest...   Aug 25 2009, 17:48
- - q-stankovic   Yep, but then it wouldn't be the queue! ...   Aug 25 2009, 17:51
- - q-stankovic   A quick idea for a socalled party playlist: 1. It...   Aug 25 2009, 18:19
- - odyssey   That sounds very much like the behavior of AlbumPl...   Aug 25 2009, 19:01
- - q-stankovic   (I am not sure what you mean exactly - please, don...   Aug 25 2009, 19:53
- - kerpondile   QUOTE (kerpondile @ Jul 27 2009, 13:51) f...   Jan 25 2010, 20:48
- - s33m33   @kerpondile Please keep component as a playlist t...   Jan 25 2010, 21:17
|- - bubi jackson   QUOTE (s33m33 @ Jan 25 2010, 21:17) @kerp...   Jan 26 2010, 05:22
- - stripe   Good to hear! Looking forward to new developme...   Jan 26 2010, 03:44
- - freetochoose   I would like to try your component. But somehow I ...   Jan 26 2010, 12:40
|- - kerpondile   I wonder if this works for you: http://dl.dropbox...   Jan 26 2010, 18:06
- - electricprophet   an UI component would be awesome! keep up the ...   Jan 26 2010, 18:12
- - freetochoose   I wonder if this works for you: http://dl.dropbox....   Jan 27 2010, 03:47
- - krzyszcz   Thx for working on the plugin But in my opinion,...   Feb 24 2010, 20:43
|- - fbuser   QUOTE (krzyszcz @ Feb 24 2010, 20:43) But...   Feb 24 2010, 21:04
|- - Hitchhiker427   QUOTE (krzyszcz @ Feb 24 2010, 13:43) Thx...   Feb 24 2010, 21:14
- - 2E7AH   You can use ELPlaylist as a panel: Bind it to your...   Feb 24 2010, 20:49
|- - krzyszcz   QUOTE (2E7AH @ Feb 24 2010, 20:49) You ca...   Feb 24 2010, 21:07
|- - 2E7AH   QUOTE (krzyszcz @ Feb 24 2010, 21:07) whe...   Feb 24 2010, 21:23
|- - krzyszcz   QUOTE The "list of songs that will be played ...   Feb 24 2010, 21:38
- - lvqcl   QUOTE In playlists tab I have "My music...   Feb 24 2010, 21:55
- - 2E7AH   When you double click an item in playlist view tha...   Feb 24 2010, 22:00
- - krzyszcz   QUOTE (lvqcl @ Feb 24 2010, 21:55) QUOTE ...   Feb 24 2010, 22:04
- - Hitchhiker427   QUOTE (krzyszcz @ Feb 24 2010, 14:38) In ...   Feb 25 2010, 08:53
|- - vogliadicane   @ krzyszcz: the only reason I can imagine, why yo...   Feb 25 2010, 10:45
- - kerpondile   New version of the component is available! Now...   Mar 7 2010, 16:02
- - Xorx   Hello kerpondile! Thanks for the new version e...   Mar 7 2010, 17:16
- - Gapkiller   Thank you for further developing this component. ...   Mar 7 2010, 19:48
- - スラッシ   I didn't want to be the first to request it......   Mar 7 2010, 22:23
- - electricprophet   thanks for making it available for DUI, kerpondile...   Mar 7 2010, 23:03
- - kerpondile   QUOTE (Xorx @ Mar 7 2010, 19:16) Hello ke...   Mar 8 2010, 08:44
- - freetochoose   I really would like to try your plugin, but I cann...   Mar 8 2010, 13:19
- - kerpondile   Here's an mirror http://www.2shared.com/file/1...   Mar 8 2010, 16:33
- - freetochoose   Got it, thanks a lot kerpondile. ftc   Mar 9 2010, 12:45
- - q-stankovic   Yesterday i tried to find a bug in the uielement b...   Mar 9 2010, 17:43
- - AndyL   I would love to see a Columns UI panel too, but I...   Mar 9 2010, 19:59
- - exxecutor   Great work! A small request: It would be grea...   Apr 1 2010, 14:22
|- - kerpondile   Thanks! About the queue playlist: I understan...   Apr 4 2010, 22:08
- - exxecutor   Thanks for the reply, thats fine for me. I doesn...   Apr 4 2010, 23:32
- - lucido   hi great component I report foobar crash when tryi...   Apr 7 2010, 08:15
|- - kerpondile   Thanks, I actually stumbled upon this when develop...   Apr 11 2010, 10:26
- - kerpondile   New version (0.3) released, check the first post f...   Apr 13 2010, 11:02
|- - Jack Schmaltz   QUOTE (kerpondile @ Apr 13 2010, 10:02) ....   Apr 13 2010, 11:05
||- - kerpondile   Sorry not with that avatar face Thanks anyways...   Apr 13 2010, 11:10
|- - Hamallainen   QUOTE (kerpondile @ Apr 13 2010, 11:02) ....   Apr 13 2010, 13:11
|- - kerpondile   CUI or DUI?   Apr 13 2010, 13:22
|- - kerpondile   QUOTE (Hamallainen @ Apr 13 2010, 14:11) ...   Apr 13 2010, 15:27
|- - Hamallainen   QUOTE (kerpondile @ Apr 13 2010, 15:27) Q...   Apr 14 2010, 00:23
|- - Jack Schmaltz   QUOTE (Hamallainen @ Apr 13 2010, 23:23) ...   Apr 14 2010, 10:45
|- - kerpondile   QUOTE (Hamallainen @ Apr 14 2010, 01:23) ...   Apr 14 2010, 12:50
- - jeremija   I get a crash error when I try to rearrange the co...   Apr 13 2010, 11:11
|- - kerpondile   QUOTE (jeremija @ Apr 13 2010, 12:11) I g...   Apr 13 2010, 11:36
|- - jeremija   QUOTE (kerpondile @ Apr 13 2010, 12:36) Q...   Apr 13 2010, 17:46
- - Jack Schmaltz   i'm not at my desktop at the mo, but will get ...   Apr 13 2010, 11:23
- - Hamallainen   Sorry, i did not say i was using CUI since i was t...   Apr 13 2010, 13:36
|- - kerpondile   What do you mean that auto-scale columns does not ...   Apr 13 2010, 14:11
- - Hamallainen   Ah ok, i had misunderstood the behaviour. I though...   Apr 13 2010, 14:22
- - q-stankovic   Thanks for the update! Here some bugs/glitc...   Apr 13 2010, 16:56
|- - kerpondile   QUOTE (q-stankovic @ Apr 13 2010, 17...   Apr 13 2010, 17:33
- - q-stankovic   QUOTE (kerpondile @ Apr 13 2010, 17:33) A...   Apr 14 2010, 18:52
|- - kerpondile   I will fix it in the next version. It annoys me to...   Apr 14 2010, 19:16
- - kerpondile   New version available. CHANGELOG: 0.3.2 / 2010-0...   Apr 20 2010, 09:27
- - Jack Schmaltz   thank you for your continued work kerpondile   Apr 20 2010, 09:34
- - Hamallainen   Thanks for the update, everything's ok now exc...   Apr 21 2010, 23:53
|- - kerpondile   Thanks for the bug report. I've fixed the bug ...   Apr 22 2010, 09:34
- - Hamallainen   Thanks to you. It's perfect.   Apr 22 2010, 10:24
- - Naboul   Hello, thanks a lot for your tool. I got a littl...   Apr 26 2010, 19:21
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 4th July 2015 - 10:09
