96kHz 24bit flac distorted, Codec or hardware issue?
audioaficionado
post Jul 26 2009, 03:01
I downloaded a 96kHz/24bit flac album and it plays distorted through Winamp and foobar2000
I have a (onboard sound) ADI 1988B - 8-channel HD audio codec, Supreme FX audio card on an Asus Commando under Server 2008 (Vista x64 BlackHawk driver) playing SPDIF to a Yamaha RX-V450 receiver.
96kHz/24bit .wav files play just fine.
I went in the driver configuration and player output configs to select 24bit and 96kHz settings.
Didn't seem to help.
What will fix this?
Won't play:
http://www.cardas.com/music/dobler/
Duration : 6:31.408 (37575168 samples)
Sample Rate : 96000 Hz
Channels : 2
Bits Per Sample : 24
Bitrate : 3786 kbps
Codec : FLAC
Encoding : lossless
Tool : reference libFLAC 1.2.1 20070917
foobar2000 .flac -> .wav conversion
Channels : 2
Bitrate : 4608 kbps
Codec : PCM
Encoding : lossless
Will play:
Nine Inch Nails - The Slip - Wave 96-24 High Res album:
Duration : 3:58.681 (22913373 samples)
Channels : 2
Bitrate : 4608 kbps
Codec : PCM
Encoding : lossless
This post has been edited by audioaficionado: Jul 26 2009, 03:29
audioaficionado
post Jul 26 2009, 18:01
OK I read those links but I'm still lost. The files still don't play in the latest versions of foobar or winamp. Will play in VLC player.
How would I implement the fix so they play in foobar/winamp?
- audioaficionado   96kHz 24bit flac distorted   Jul 26 2009, 03:01
- - uart   It seems like it might just be a bad file. Where d...   Jul 26 2009, 04:06
|- - audioaficionado   QUOTE (uart @ Jul 25 2009, 20:06) It seem...   Jul 26 2009, 04:18
|- - uart   QUOTE (audioaficionado @ Jul 25 2009, 20...   Jul 26 2009, 04:59
|- - audioaficionado   QUOTE (uart @ Jul 25 2009, 20:59) Yeah I...   Jul 26 2009, 05:10
- - uart   Ok I just d/l'ed "Smoove_Funk_Thang...   Jul 26 2009, 05:22
- - andy o   I downloaded Smoove Funk Thing too. What player di...   Jul 26 2009, 14:43
- - audioaficionado   Hmmm... Those FLACs play fine in VLC player too. ...   Jul 26 2009, 16:18
- - Case   From the description it sounds like they were save...   Jul 26 2009, 17:23
- - uart   Yeah I tried to play it in foobar2000 and it was d...   Jul 26 2009, 17:26
- - Case   Now that my download finished it is clear that it ...   Jul 26 2009, 17:32
|- - uart   QUOTE (Case @ Jul 26 2009, 09:32) Now tha...   Jul 26 2009, 17:59
- - audioaficionado   OK I read those links but I'm still lost. The ...   Jul 26 2009, 18:01
|- - uart   QUOTE (audioaficionado @ Jul 26 2009, 10...   Jul 26 2009, 18:23
- - audioaficionado   I have FLAC 1.2.1.exe in foobar2000 and I converte...   Jul 27 2009, 01:05
|- - uart   QUOTE (audioaficionado @ Jul 26 2009, 17...   Jul 27 2009, 03:32
|- - audioaficionado   QUOTE (uart @ Jul 26 2009, 19:32) Anyway ...   Jul 27 2009, 22:28
- - CoyoteSmith   the first batch of WAV / FLAC files for this album...   Jul 27 2009, 02:49
|- - uart   QUOTE (CoyoteSmith @ Jul 26 2009, 18:49) ...   Jul 27 2009, 03:22
- - .halverhahn   Off topic: All files are bandlimited to 22kHz exce...   Jul 27 2009, 13:53
|- - uart   QUOTE (.halverhahn @ Jul 27 2009, 05:53) ...   Jul 28 2009, 13:32
- - .halverhahn   Just use the FLAC installer, it will also install ...   Jul 28 2009, 10:52
RSS Lo-Fi Version Time is now: 29th August 2015 - 02:21
