Interesting Papers re temporal resolution
ncdrawl
post Jul 25 2009, 07:27
http://www.physics.sc.edu/kunchur/Acoustics-papers.htm
http://www.physics.sc.edu/kunchur/papers/FAQs.pdf
Canar
post Aug 4 2009, 02:41
I just had a random thought about this and I wanted to run it by here:
The experimental procedure calls for a low-pass filtering of the signal. Does low-pass filtering significantly affect the perceived volume? Could the low-pass filter's effect on the perceived loudness be the perceived trait here? It is well-documented that decrease in loudness is perceived as decrease in quality. By slightly amplifying the filtered signal, could the perceived difference disappear?
So then, could the simple existence of the higher-order harmonics affect the overall power-spectrum (I'm aware that it will obviously be different in the frequency domain) significantly enough to be perceptible?
2. Assume good faith.
andy_c
post Aug 4 2009, 02:57
Well, the 4.7us time constant does decrease the level of the 7 kHz fundamental by 0.18 dB, which he mentions in his paper. According to a description in his paper of another experiment (done by a different author), the just noticeable difference is 0.7 dB at that frequency.
This post has been edited by andy_c: Aug 4 2009, 03:40
andy_c
post Aug 4 2009, 14:23
Here's another thing I noticed in his test apparatus. He describes the switching of the filter time constants and how it was optimized to minimize switching transients. He states that "...relays (which can induce a disturbance through magnetic flux change) were avoided...", although he does not say whether he tried any, and if so, whether this alleged disturbance was a problem in practice. The advantage of a relay would be to allow computer control of the switching, which when performed with the appropriate software, would allow for double-blind testing. IOW, it would allow for a test in which only the software, and not the test administrator, "knows" the state of the switch at any given time. He further states "...switch-bounce distortion was avoided by minimizing contact areas...", so this implies that a mechanical switch was used. Since that switch isn't a relay, it's just going to be a purely manual switching arrangement done by the test administrator physically flipping the switch. This in turn says that the test administrator is aware of the state of the switch at all times. It is therefore not a double-blind test. He does take care to call his tests "blind tests" rather than double-blind, so that is good. He uses the phrase "very effective blind listening tests" at one point in his article in fact. But he doesn't spell out what precautions, if any, were used to prevent the test subjects from observing the test administrator, which has the potential to influence the test results (AKA the Clever Hans Effect).
Arnold B. Kruege...
post Aug 13 2009, 12:56
QUOTE (andy_c @ Aug 4 2009, 09:23) *
As a rule, relays don't induce significant disturbances in the signals they control when they change state. For example, one of the benchmarks for the ABX RM-2 relay module was an audibly transient-free switchover between two integrated amplifiers including phono or microphone input stages.
http://www.provide.net/~djcarlst/abx_rm2.htm
The production RM2 was based on reed relays with 5 volt coils, but its first adequate prototype (equally effective) was based on traditional open-frame, open-contact relays with 28 volt coils. Damping networks were placed across relay coils to prevent arcing and damage to the control circuits.
Transient free switching of audio gear is not always trivial, but the important issues are related to the actual oder and kind (NC or NO) of contact openings. The original Clark JAES article tells all.
Paranoia about relay contacts is just another high end audiophile straw man. Professional audio gear and communications equipment has been reliably switching audio signals with relays for over a century.
- ncdrawl   Interesting Papers re temporal resolution   Jul 25 2009, 07:27
- - rpp3po   I'm not sure wether they have actually tested ...   Jul 25 2009, 13:17
- - Ethan Winer   Nice to see this topic here where it can be discus...   Jul 25 2009, 18:26
- - hellokeith   from the link: QUOTE Our recent behavioral studies...   Jul 25 2009, 20:39
|- - C.R.Helmrich   QUOTE (hellokeith @ Jul 25 2009, 21:39) D...   Jul 25 2009, 22:09
||- - rpp3po   QUOTE (C.R.Helmrich @ Jul 25 2009, 23:09)...   Jul 25 2009, 22:28
||- - Woodinville   QUOTE (rpp3po @ Jul 25 2009, 14:28) Well,...   Jul 28 2009, 09:27
|- - John_Siau   From the first paragraph at: www.physics.sc.edu/ku...   Jul 31 2009, 19:16
|- - andy_c   QUOTE (John_Siau @ Jul 31 2009, 12:16) Th...   Jul 31 2009, 21:30
- - hellokeith   Well after reading through the first 3 PDF's a...   Jul 26 2009, 01:24
- - Axon   Don't even bother using a square wave generato...   Jul 28 2009, 02:55
|- - rpp3po   Yes, I asked myself why Adobe would even include s...   Jul 28 2009, 03:06
- - Mike Giacomelli   I only skimmed the paper, but IIRC tried a digital...   Jul 28 2009, 03:31
- - Canar   Now the WAV files won't load in foobar2000... ...   Jul 28 2009, 03:51
|- - rpp3po   QUOTE (Canar @ Jul 28 2009, 04:51) These ...   Jul 28 2009, 11:37
|- - lvqcl   QUOTE (rpp3po @ Jul 28 2009, 14:37) Could...   Jul 28 2009, 12:52
|- - Mike Giacomelli   QUOTE (rpp3po @ Jul 28 2009, 06:37) Could...   Jul 28 2009, 15:58
- - Nick.C   Why not just just create a 7.35kHz square wave ...   Jul 28 2009, 13:13
|- - benski   QUOTE (Nick.C @ Jul 28 2009, 08:13) Why n...   Jul 31 2009, 15:39
|- - 2Bdecided   QUOTE (benski @ Jul 31 2009, 15:39) QUOTE...   Jul 31 2009, 16:33
|- - benski   QUOTE (2Bdecided @ Jul 31 2009, 11:33) QU...   Jul 31 2009, 16:39
- - Axon   Because that places unacceptable restrictions on t...   Jul 28 2009, 16:12
- - Canar   If I may grossly oversimplify your argument Axon, ...   Jul 28 2009, 19:46
|- - Axon   QUOTE (Canar @ Jul 28 2009, 13:46) If I m...   Jul 28 2009, 20:14
||- - andy_c   I'd like to add a few comments regarding the ...   Jul 29 2009, 16:52
||- - Axon   QUOTE (andy_c @ Jul 29 2009, 10:52) I...   Jul 29 2009, 17:11
||- - andy_c   QUOTE (Axon @ Jul 29 2009, 10:11) Well, g...   Jul 29 2009, 17:27
|- - Mike Giacomelli   QUOTE (Canar @ Jul 28 2009, 14:46) As an ...   Jul 28 2009, 21:08
|- - NullC   QUOTE (Mike Giacomelli @ Jul 28 2009, 12...   Jul 29 2009, 05:48
|- - Mike Giacomelli   QUOTE (NullC @ Jul 29 2009, 00:48) QUOTE ...   Jul 29 2009, 16:19
- - Axon   So, on that note.... an off topic comment. I just ...   Jul 29 2009, 17:01
|- - Canar   QUOTE (Axon @ Jul 29 2009, 09:01) So, on ...   Jul 29 2009, 18:18
- - krabapple   It may well be that Dr. Kunchur's audio work i...   Jul 29 2009, 17:04
- - kode54   Where did you come up with that 1.45GHz figure? Th...   Jul 29 2009, 20:22
- - Axon   Well, I'm thinking more specifically of the th...   Jul 29 2009, 20:41
- - Audible!   QUOTE (ncdrawl @ Jul 30 2009, 23:07) QUOT...   Jul 31 2009, 08:36
- - 2Bdecided   Yes, I see it now (having tried it!), it's...   Jul 31 2009, 17:13
- - John_Siau   From the summary paragraph in "Audibility of ...   Jul 31 2009, 19:37
|- - Axon   QUOTE (John_Siau @ Jul 31 2009, 13:37) Fr...   Jul 31 2009, 21:28
|- - John_Siau   QUOTE (Axon @ Jul 31 2009, 16:28) That se...   Jul 31 2009, 22:15
|- - WernerO   QUOTE (Axon @ Jul 31 2009, 21:28) Dr. Kun...   Aug 1 2009, 06:46
|- - 2Bdecided   QUOTE (Axon @ Jul 31 2009, 21:28) That se...   Aug 1 2009, 08:24
|- - rpp3po   I'm just coming back from vacation. Thanks for...   Aug 2 2009, 17:42
|- - Arnold B. Krueger   QUOTE (rpp3po @ Aug 2 2009, 12:42) But un...   Aug 3 2009, 01:24
|- - rpp3po   QUOTE (Arnold B. Krueger @ Aug 3 2009, 02...   Aug 3 2009, 01:42
|- - ncdrawl   QUOTE (rpp3po @ Aug 2 2009, 20:42) QUOTE ...   Aug 3 2009, 04:59
|- - krabapple   QUOTE (ncdrawl @ Aug 2 2009, 23:59) QUOTE...   Aug 3 2009, 07:57
|- - WernerO   QUOTE (ncdrawl @ Aug 3 2009, 04:59) Dr. K...   Aug 3 2009, 08:52
||- - Axon   QUOTE (WernerO @ Aug 3 2009, 02:52) QUOTE...   Aug 3 2009, 19:02
|||- - honestguv   QUOTE (Axon @ Aug 3 2009, 20:02) BTW, I f...   Aug 3 2009, 19:35
||- - ncdrawl   QUOTE (WernerO @ Aug 3 2009, 03:52) we do...   Aug 8 2009, 00:03
|- - honestguv   > Dr. Kunchur will be posting confutations in f...   Aug 3 2009, 08:54
|- - andy_c   Regarding my earlier post about the lack of second...   Aug 3 2009, 17:34
- - benski   I need to do further reading to do a full refutati...   Aug 3 2009, 20:10
|- - benski   Also, for his FAQ example of two peaks separated b...   Aug 3 2009, 20:24
|- - WernerO   QUOTE (benski @ Aug 3 2009, 21:24) two pe...   Aug 3 2009, 20:56
||- - Axon   QUOTE (WernerO @ Aug 3 2009, 14:56) QUOTE...   Aug 3 2009, 21:04
||- - benski   QUOTE (WernerO @ Aug 3 2009, 15:56) QUOTE...   Aug 3 2009, 21:22
|||- - WernerO   QUOTE (benski @ Aug 3 2009, 22:22) Please...   Aug 4 2009, 08:11
|||- - benski   QUOTE (WernerO @ Aug 4 2009, 03:11) QUOTE...   Aug 4 2009, 14:34
||- - honestguv   QUOTE (WernerO @ Aug 3 2009, 21:56) But t...   Aug 3 2009, 21:47
||- - benski   QUOTE (honestguv @ Aug 3 2009, 16:47) QUO...   Aug 3 2009, 22:04
||- - honestguv   QUOTE (benski @ Aug 3 2009, 23:04) They a...   Aug 3 2009, 22:49
|- - 2Bdecided   QUOTE (benski @ Aug 3 2009, 20:24) Also, ...   Aug 3 2009, 22:05
- - Canar   I just had a random thought about this and I wante...   Aug 4 2009, 02:41
|- - andy_c   Well, the 4.7us time constant does decrease the le...   Aug 4 2009, 02:57
|- - andy_c   Here's another thing I noticed in his test app...   Aug 4 2009, 14:23
||- - Arnold B. Krueger   QUOTE (andy_c @ Aug 4 2009, 09:23) Here...   Aug 13 2009, 12:56
|- - Pio2001   Hello, I've just read the first and third arti...   Apr 18 2010, 23:07
|- - C.R.Helmrich   QUOTE (Pio2001 @ Apr 19 2010, 00:07) Ther...   Apr 18 2010, 23:56
|- - Arnold B. Krueger   QUOTE (Pio2001 @ Apr 18 2010, 18:07) QUOT...   Apr 19 2010, 14:49
- - ultrasonic   QUOTE (rpp3po @ Aug 3 2009, 02:42) QUOTE ...   Jan 2 2010, 05:09
|- - Woodinville   QUOTE (ultrasonic @ Jan 1 2010, 20:09) QU...   Jan 2 2010, 05:28
||- - ultrasonic   QUOTE (Woodinville @ Jan 2 2010, 06:28) Q...   Jan 2 2010, 05:41
||- - Arnold B. Krueger   QUOTE (ultrasonic @ Jan 1 2010, 23:41) QU...   Jan 2 2010, 06:15
|- - Arnold B. Krueger   QUOTE (ultrasonic @ Jan 1 2010, 23:09) QU...   Jan 2 2010, 06:01
|- - ultrasonic   QUOTE (Arnold B. Krueger @ Jan 2 2010, 07...   Jan 2 2010, 06:37
|- - Arnold B. Krueger   QUOTE (ultrasonic @ Jan 2 2010, 00:37) QU...   Jan 2 2010, 06:52
|- - Woodinville   QUOTE (ultrasonic @ Jan 1 2010, 21:37) Op...   Jan 2 2010, 10:29
||- - Arnold B. Krueger   QUOTE (Woodinville @ Jan 2 2010, 04:29) B...   Jan 2 2010, 13:24
|- - krabapple   QUOTE (ultrasonic @ Jan 2 2010, 00:37) Op...   Jan 3 2010, 06:43
- - Woodinville   It is interesting to note that now the same people...   Jun 15 2010, 19:31
- - Arnold B. Krueger   QUOTE (Woodinville @ Jun 15 2010, 14:31) ...   Jun 16 2010, 11:09
- - Paulhoff   QUOTE (Woodinville @ Jun 15 2010, 14:31) ...   Jun 16 2010, 12:33
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 1st February 2015 - 16:02
