Beginning of track cut off about 1 sec, please help, New to Foobar
tim3320070
post Jun 25 2009, 04:48
I run Vista and use Foobar2000 with WASAPI and Columns_UI. All FLAC files ripped in EAC (some older MP3's brought over as well). All tracks when clicked to play, or fowarded to the next song have an approx. 1 second lag, starting the song late, missing the start of the track- it happens to the EAC ripped music as well as the older MP3's. It does not do this in iTunes.
This is very annoying, please help!
shakey_snake
post Jun 25 2009, 06:12
Group: FB2K Moderator
This is a problem with your DAC/receiver shutting down when encountering complete digital silence.
  • One solution would be to use the skip-silence DSP, which obviously doesn't help seeking/skipping.
  • Also, some DACs that have problems with this at higher bit depths are fine with 16 bit output.
  • You could also switch to analog output for your soundcard, which might not have such problems.
This post has been edited by shakey_snake: Jun 25 2009, 06:57
elevatorladylevitateme
tim3320070
post Jun 26 2009, 01:25
Thanks but that did not help. My setup is Vista->Foobar2K->USB->Bel Canto USB Link 2496->Audio-gd Reference-1 DAC. All take 24/96 rates and there is no issue using iTunes, only Foobar.
This is a real issue and I am considering using another player if cannot resolve.
Thanks again
This post has been edited by tim3320070: Jun 26 2009, 01:26
kode54
post Jun 26 2009, 10:11
Group: Admin
Have you tried other output components such as Kernel Streaming, ASIO, or WASAPI?
odyssey
post Jun 26 2009, 11:47
I'm quite sure the receiver/whatever is accounting for this issue. I have the exact same problem when I use digital connections to my H/K receiver. There can be several reasons why some players have this problem and others don't. I think soundcard drivers are part of reason why this happens. I had a Yamaha DSXG once and when used in Winamp - EVEN WITH CROSSFADER OPTION ON - it managed to create this initialisation gap on my receiver.
Other soundcards I've had, has behaved differently, mostly just doing this on track changes. However, it can somewhat easily be worked around. I myself created a solution where I run another foobar in the background, looping a wav with ALMOST silence created in an editor. iTunes could have something similar implemented that ensures no interrupted digital playback.
For that matter, a DSP for foobar2000 that did the same would be great.
This post has been edited by odyssey: Jun 26 2009, 11:47
tim3320070
post Jun 26 2009, 20:56
I use WASAPI output. It does not happen with Media Monkey or iTunes, they work perfectly. I don't use a receiver like that, see my previous post for my setup.
odyssey
post Jun 26 2009, 21:50
So, what you are suggesting is that the "Audio-gd Reference-1 DAC" cannot be held responsible for this delay - Why not? As far as I can see you are using a digital chain, just like me. I don't see why a DAC in a reciever and some other DAC shouldn't behave similarily.
If you are suggesting that foobar2000 is faulty, I think I'd have to disappoint you because that's highly unlikely on this matter. As I mentioned in my previous thread, it's more likely other applications has implemented workarounds for this kind of problem or maybe they are using different output methods - Which did you try besides WASAPI?
tim3320070
post Jun 27 2009, 22:50
Maybe you can explain why I have never heard a delay with 2 other DAC's besides the Ref-1, iTunes and Media Monkey? Only Foobar. I want to use Foobar, really, but the delay is a deal killer.
I will try other plug-ins. There must be some other trouble shooting ideas?
tim3320070
post Jun 27 2009, 23:03
Okay- it seems it is WASAPI. The only one that works correctly is the "Primary Sound Driver". It seems too much to bother though as MM works/ sounds the same to me and works better overall (considering I don't sutomize like a of Foobar users seem to do) -handles more files better too.
shakey_snake
post Jun 27 2009, 23:26
QUOTE (tim3320070 @ Jun 27 2009, 17:50) *
Because iTunes and MediaMonkey don't do bit-perfect playback?
QUOTE (tim3320070 @ Jun 27 2009, 18:03) *
It's likely Primary Sound driver isn't doing bit-perfect output either. Either way, the likelihood that you could ever prove hearing a difference between output modes is very unlikely. If you were attempting to use fb2k+WASAPI simply because you've been told doing so would result in some magical sound quality improvement, I'm afraid you've been lied to.
This post has been edited by shakey_snake: Jun 27 2009, 23:32
lvqcl
post Jun 27 2009, 23:32
QUOTE (tim3320070)
Switch to 16 bit output and turn "Dither" option on. Foobar2000 won't output digital silence.
tim3320070
post Jun 28 2009, 15:52
QUOTE (lvqcl @ Jun 27 2009, 17:32) *
QUOTE (tim3320070)
My Bel Canto converter only does 24 bit so setting it to 16 bit kills output.
Finally someone with a theory, thanks! Anymore ideas?
lvqcl
post Jun 28 2009, 18:07
QUOTE (odyssey @ Jun 26 2009, 14:47) *
Well, I wrote very simple DSP plugin that adds white noise (TPDF) or DC offset to a signal. I wonder if it can help...
http://www.hydrogenaudio.org/forums/index....showtopic=73072
RSS Lo-Fi Version Time is now: 5th August 2015 - 04:54
