Foobar crashes on file, ogg + win2k = crash
Evil Nickname
post Mar 10 2003, 13:28
I'm using Foobar a lot now, but on certain .ogg files, it crashes.
To be more specific:
at home I'm using Win2k (sp3), all files encoded with EAC / OggEnc1 (-q 4,99) and VorbisGained.
This behaviour happens from 0.5 to 0.56b.
When I put these file in the playlist, and the previous song is ended, it plays fine. If I don't wait until the previous song is ended (press next) Foobar hangs (standard Windows error screen: FOOBAR.exe has created errors etc.)
This also happens when I double click a file, or when I select "play in foobar" from the context menu.
This does not happen under winXP, or at my school (also win2k)...
Example included: Error.ogg
This file is the smallest (+\- 0.6M ) I could find which shows this behaviour.
Can anyone shed a light on this, or is it just a case of installing Win2k again, or....
William
"Murphy was being optimistic"
Wizard
post Mar 10 2003, 14:35
I have W2K+SP3 too, but your file plays fine here with fb2k 0.57. Have you tried it with another audio player that supports ogg? btw, all these options you say like "play in foobar" from the context menu, I guess you used the installer, right? I use the zip file. Perhaps, try deleting the foobar.cfg file, so as to use the default configuration options? dry.gif
Peter
post Mar 10 2003, 16:21
foobar2000 developer
Group: Admin
can't reproduce
_random_
post Mar 10 2003, 19:02
Evil Nickname, what DSP's are you using, and in what order? I was able to reproduce the bug with these DSP settings (in order):
Advanced Limiter
Crossfeed
When I reversed the order of the DSP's, the crashing problems went away. For those interested, I'm running w2kproSP3, with an Audigy1(.324 drivers) used for playback.
Wizard
post Mar 10 2003, 19:19
QUOTE (_random_ @ Mar 10 2003 - 09:02 PM)
Advanced Limiter
Crossfeed
_random_ is right, it happened to me too.
Wizard
post Mar 10 2003, 20:11
The problem is gone for me with newest version of crossfeed (0.666): http://www.naivesoftware.com/crossfeed.html
_random_
post Mar 10 2003, 20:14
You're right. Just tested and confirmed your results
Peter
post Mar 10 2003, 20:40
Group: Admin
workedaround on both sides (modified limiter for 0.58 + supposedly fixed in latest crossfeed)
Evil Nickname
post Mar 11 2003, 12:15
_random_ that's indeed the order of my DSP's.
This file (and others with the same problem) worked fine with winamp
I'll change the settings when I get home, update my crossfeed, and when I get back (don't have an internet connection at home yet) I'll let you all now.
Thanks for now, and I really apreciate the effort!
William
Evil Nickname
post Mar 13 2003, 13:29
Changed the order, updated the crossfeed... works like a charm!
Thanks again for the support, I really wouldn't have known what to do without it....
William
RSS Lo-Fi Version Time is now: 24th May 2015 - 10:27
