How Good Can Vinyl Sound?, Anyone got some sample clips?
sshd
post May 15 2009, 14:47
I do not own a turntable and have never heard the "great vinyl sound" coming from a good turntable handled correctly. I am however sligltly interested in purchasing one, as there are some interesting albums out there unavailable on CD.
Recently I found a small clip on the net: A lossless needledrop of Santana's debut album on the MFSL label. Since I own the CD on same label I had something to compare with: I was very disappointed with the needle drop. There were no pops or clicks, but the sound was dead.
Can anyone provide some sample clips of very good needle drops?
krabapple
post May 15 2009, 21:07
First, all digital ends up as 'analog sound' when it comes out of the DAC and ultimately your loudspeakers/earbuds/headphones
Second, your objection presumes that a good digitizing of an LP somehow changes the sound. Why would you think that?
C.R.Helmrich
post May 15 2009, 22:23
QUOTE (krabapple @ May 15 2009, 22:07) *
I've recorded a song from an 80's LP on my PC in 24bit/96kHz once and noticed that the bandwidth extended to around 30 kHz (true, the roll-off started at 15 kHz or so, but still, it reached till 30). So to be fair, one should record at 16bit/96kHz to get a "good digitizing of an LP", I think. Correct me if I'm wrong, but all above links offer only 16bit/44kHz samples. One FLACs was even processed with LossyWav!
Chris
Arnold B. Kruege...
post May 15 2009, 22:36
QUOTE (C.R.Helmrich @ May 15 2009, 17:23) *
There's a very fair question to ask about LP tanscriptions whose spectral analysis shows content > 20 KHz:
Is it music or is it distortion?
The LP format does have a lot of inherent nonlinear distoriton at high frequencies due to geometric mismatch between the path of the sharp, chisel-shaped cutter, and the round or elliptical stylus.
Also, there is considerable dynamic deformation of the groove itself. which mostly springs back shortly after playing. Point being, the stylus deforms the groove in a nonlinear way while its being played.
And of course there's the other issue about which so much relevant evidence has been collected that there is hardly a controversy over it any more. Can we hear the removal of audio > 22 Khz? The answer is generally no, not at all.
C.R.Helmrich
post May 15 2009, 23:02
QUOTE (Arnold B. Krueger @ May 15 2009, 23:36) *
Good question. Maybe this distortion has a similar effect like the "added warmth" of a tube amp? Maybe it's the reason why some people prefer the "smooth sound" of an LP? (To me, the mentioned 24/96 recording also sounded sort of "smooth and warm"). Surely such distortion must also be present in the audible band, I guess?
I read a scientific article a few years ago demonstrating how in blind tests, subjects were able to hear a 24-kHz tone and that for all of them, the threshold of hearing did not increase between 20 and 24 kHz but actually stayed on a rather constant level (at 80 dB SPL, true, but still...). 26-kHz tones, however, were inaudible to all, IIRC. I'll try to dig up that paper again.
Edit: Here is the paper. Did not quite remember it correctly, but see for yourself.
Chris
This post has been edited by C.R.Helmrich: May 15 2009, 23:11
Arnold B. Kruege...
post May 15 2009, 23:23
QUOTE (C.R.Helmrich @ May 15 2009, 18:02) *
While it is not a slam dunk that tests involving pure tones and music will have signficiantly different results, this is no doubt one of them.
Since there are very very few musical instruments with fundamentals > even 10 KHz, anything above 20 KHz is going to be a harmonic of some fundamental below 20 KHz. Unless the content > 20 KHz is very, very strong, its going to be masked by fundamentals and/or lower harmonics below 20 KHz. Or its simply going to fall below the limit of audibility, which is very high at frequencies this high.
This would be a good time to post a spectral analysis of one of your 24/96 files... HA has a forum for doing this, so you don't need to line up space on your own. You could even post excerpts for others to listen to and/or analyze.
If you look in the scientific section of HA, there's even a paper about perception that has some masking curves in it. If you scale them up to the 8-10 KHz range, they do a pretty good job of wiping out all but the strongest responses > 10 KHz.
C.R.Helmrich
post May 15 2009, 23:48
QUOTE (Arnold B. Krueger @ May 16 2009, 00:23) *
I'd really like to post a FLAC file of the LP here, but I recorded that 4 years ago at on a relative's turntable, and deleted it shortly afterwards (if only I knew back then... smile.gif ). Anyway, as I said, the high-frequency roll-off ended at 30 kHz. So the energy was already down quite low at 22 kHz. Yes, agreed, most likely below the hearing threshold. Just thought I'd add this comment since the original discussion was about accurate representation of Vinyl sound. If you don't digitize the entire spectrum "coming out of a vinyl", then it's not an accurate representation, I'd say.
I know about the masking curves at high frequencies. I posted some of them the other day smile.gif Yes, if you consider masking, it's even more likely that anything beyond 20 kHz on an LP is inaudible. Still, there's something there smile.gif The next time I get a hold of a turntable, I'll post a 24/96 FLAC.
Chris
krabapple
post May 16 2009, 00:17
QUOTE (C.R.Helmrich @ May 15 2009, 18:48) *
Chris
No one's said there's nothing there. The question is what 'it' is, and whether it matters.
I have some FLACs that were originally 192/24 (ripped from DVD-A) , 96/24 (same) , some SACD 'laserdrops' that are 88/24, and I'm sure I've got some LP captures that are 'hi rez' too. I would never claim that the high sample rate makes an audible difference, though. if anyone wants to hear clips, I can post some.
- sshd   How Good Can Vinyl Sound?   May 15 2009, 14:47
- - 2Bdecided   See this thread for recent discussion on this topi...   May 15 2009, 16:02
- - bryant   http://www.hydrogenaudio.org/forums/index....showt...   May 15 2009, 17:39
- - DVDdoug   QUOTE I do not own a turntable and have never hear...   May 15 2009, 17:54
- - Arnold B. Krueger   QUOTE (sshd @ May 15 2009, 09:47) I do no...   May 15 2009, 19:51
|- - Glenn Gundlach   QUOTE (Arnold B. Krueger @ May 15 2009, 10...   May 15 2009, 21:03
|- - Arnold B. Krueger   QUOTE (Glenn Gundlach @ May 15 2009, 16:0...   May 15 2009, 21:45
- - krabapple   First, all digital ends up as 'analog sound...   May 15 2009, 21:07
|- - C.R.Helmrich   QUOTE (krabapple @ May 15 2009, 22:07) Fi...   May 15 2009, 22:23
|- - Arnold B. Krueger   QUOTE (C.R.Helmrich @ May 15 2009, 17:23)...   May 15 2009, 22:36
||- - C.R.Helmrich   QUOTE (Arnold B. Krueger @ May 15 2009, 23...   May 15 2009, 23:02
||- - Arnold B. Krueger   QUOTE (C.R.Helmrich @ May 15 2009, 18:02)...   May 15 2009, 23:23
|||- - C.R.Helmrich   QUOTE (Arnold B. Krueger @ May 16 2009, 00...   May 15 2009, 23:48
|||- - greynol   QUOTE (C.R.Helmrich @ May 15 2009, 15:48)...   May 16 2009, 00:02
|||- - krabapple   QUOTE (C.R.Helmrich @ May 15 2009, 18:48)...   May 16 2009, 00:17
|||- - C.R.Helmrich   QUOTE (krabapple @ May 16 2009, 01:17) No...   May 16 2009, 00:26
||- - 2Bdecided   QUOTE (C.R.Helmrich @ May 15 2009, 23:02)...   May 18 2009, 11:13
|||- - Arnold B. Krueger   QUOTE (2Bdecided @ May 18 2009, 06:13) QU...   May 18 2009, 16:35
||- - 2Bdecided   delete duplicate post   May 18 2009, 11:13
|- - krabapple   QUOTE (C.R.Helmrich @ May 15 2009, 17:23)...   May 16 2009, 00:03
|- - cliveb   QUOTE (krabapple @ May 16 2009, 00:03) Ju...   May 16 2009, 09:03
- - boondocks   As someone that grew up with vinyl, who had 3 copi...   May 15 2009, 22:09
- - Axon   Many people get that "great vinyl sound...   May 15 2009, 22:11
|- - boondocks   QUOTE (Axon @ May 15 2009, 17:11) Many pe...   May 16 2009, 22:27
- - greynol   I think the implication is that the information ab...   May 16 2009, 00:08
|- - WonderSlug   QUOTE (greynol @ May 15 2009, 16:08) I th...   May 16 2009, 00:26
- - krabapple   I looked at spectra pf my complete repertoire of s...   May 16 2009, 08:10
|- - Alex B   QUOTE (krabapple @ May 16 2009, 10:10) .....   May 16 2009, 15:25
- - C.R.Helmrich   Thanks a lot for the uploads, krabapple! Yes, ...   May 16 2009, 14:00
|- - krabapple   QUOTE (C.R.Helmrich @ May 16 2009, 09:00)...   May 16 2009, 17:21
|- - Arnold B. Krueger   QUOTE (krabapple @ May 16 2009, 12:21) I ...   May 16 2009, 17:50
||- - krabapple   QUOTE (Arnold B. Krueger @ May 16 2009, 12...   May 16 2009, 18:19
|- - C.R.Helmrich   QUOTE (krabapple @ May 16 2009, 18:21) I ...   May 16 2009, 19:33
|- - krabapple   QUOTE (C.R.Helmrich @ May 16 2009, 14:33)...   May 18 2009, 05:57
|- - C.R.Helmrich   QUOTE (krabapple @ May 18 2009, 06:57) ht...   May 18 2009, 21:49
|- - krabapple   QUOTE (C.R.Helmrich @ May 18 2009, 16:49)...   May 19 2009, 00:30
|- - Arnold B. Krueger   QUOTE (krabapple @ May 18 2009, 19:30) Th...   May 19 2009, 03:24
|- - krabapple   QUOTE (Arnold B. Krueger @ May 18 2009, 22...   May 19 2009, 21:00
- - Soap   I fricking hate rapidshare and I doubt I am alone....   May 16 2009, 14:17
|- - krabapple   QUOTE (Soap @ May 16 2009, 09:17) I frick...   May 16 2009, 18:09
- - lvqcl   QUOTE (krabapple)What might also be interesting is...   May 19 2009, 21:47
|- - Arnold B. Krueger   QUOTE (lvqcl @ May 19 2009, 16:47) QUOTE ...   May 19 2009, 22:01
|- - C.R.Helmrich   QUOTE (Arnold B. Krueger @ May 19 2009, 23...   May 19 2009, 22:06
- - krabapple   Ah! I guess I was having a past-life memory. ...   May 20 2009, 05:12
|- - Arnold B. Krueger   QUOTE (krabapple @ May 20 2009, 00:12) Ah...   May 20 2009, 11:04
- - audioapprentice   sshd: My surviving turntable is a p-mount, factor...   Jun 24 2009, 03:39
- - WmAx   A very high pitch stable table with a low resonanc...   Jun 25 2009, 01:16
|- - Arnold B. Krueger   QUOTE (WmAx @ Jun 24 2009, 20:16) A very ...   Jun 26 2009, 14:58
|- - WmAx   QUOTE (WmAx @ Jun 24 2009, 20:16) A very ...   Jun 27 2009, 09:01
- - greynol   It's sort of the spirit of this thread to post...   Jun 26 2009, 16:23
- - 2Bdecided   If you meant "during the music", then I ...   Jun 27 2009, 10:09
- - Mescalito   I have a Linn Sondek LP12/Ittok/Troika/Lingo/Linto...   Jan 19 2010, 15:57
- - Canar   I await your uploads with eager anticipation.   Jan 19 2010, 16:26
|- - Arnold B. Krueger   QUOTE (Canar @ Jan 19 2010, 10:26) I awai...   Jan 25 2010, 13:39
|- - Mescalito   QUOTE (Arnold B. Krueger @ Jan 25 2010, 12...   Jan 26 2010, 09:51
- - Cavaille   I wonder if I also can upload something. To enter...   Jan 26 2010, 12:20
- - RonaldDumsfeld   ^^ Yes please. especially if you have some well kn...   Jan 26 2010, 12:50
|- - Tony T   I recently converted my vinyl to Flac (wav) and wo...   Jan 26 2010, 14:56
- - Cavaille   So, here they are. Some of this music is mainstre...   Jan 26 2010, 14:07
|- - jamie_P84   QUOTE (Cavaille @ Jan 26 2010, 13:07) So,...   Feb 3 2010, 21:47
|- - Arnold B. Krueger   QUOTE (jamie_P84 @ Feb 3 2010, 15:47) The...   Feb 3 2010, 22:25
|- - cliveb   QUOTE (Arnold B. Krueger @ Feb 3 2010, 21...   Feb 4 2010, 09:28
|- - Arnold B. Krueger   QUOTE (cliveb @ Feb 4 2010, 04:28) QUOTE ...   Jun 7 2010, 15:39
- - 2Bdecided   With the caveat that I have a cold, and I don...   Jan 26 2010, 14:17
- - Cavaille   QUOTE (2Bdecided @ Jan 26 2010, 14:17) Ba...   Jan 26 2010, 14:31
- - Canar   I've got some samples to create and publish he...   Jan 26 2010, 15:06
|- - Cavaille   QUOTE (Canar @ Jan 26 2010, 15:06) I...   Jan 26 2010, 15:41
- - Canar   Here is the list of specifications for my cartridg...   Jan 26 2010, 16:18
|- - DonP   QUOTE (Canar @ Jan 26 2010, 10:18) Here i...   Jan 26 2010, 16:32
|- - pdq   QUOTE (Canar @ Jan 26 2010, 11:18) Credit...   Jan 26 2010, 18:30
- - Canar   Thanks for the info, DonP. I don't know this s...   Jan 26 2010, 16:36
- - Cavaille   Thank you for the explanation, Canar. But Im afra...   Jan 26 2010, 16:36
- - Fedot L   QUOTE (cliveb @ May 16 2009, 09:03) QUOTE...   Jan 26 2010, 23:01
- - Fedot L   QUOTE (Cavaille @ Jan 26 2010, 13:07) So,...   Jan 26 2010, 23:32
- - Cavaille   QUOTE (Fedot L @ Jan 26 2010, 23:32) QUOT...   Jan 27 2010, 06:28
- - Cavaille   QUOTE (jamie_P84 @ Feb 3 2010, 21:47) Des...   Feb 4 2010, 02:13
|- - 2Bdecided   QUOTE (Cavaille @ Feb 4 2010, 01:13) QUOT...   Feb 4 2010, 10:24
- - Cavaille   QUOTE (2Bdecided @ Feb 4 2010, 10:24) QUO...   Feb 4 2010, 15:04
- - 2Bdecided   Here you go: /?sharekey=605ee2b5f85656f5e62ea590d...   Feb 4 2010, 15:34
- - Canar   Based on this incident, we have upped the user sto...   Feb 4 2010, 17:03
|- - 2Bdecided   QUOTE (Canar @ Feb 4 2010, 16:03) Based o...   Feb 4 2010, 18:03
- - Cavaille   QUOTE (2Bdecided @ Feb 4 2010, 15:34) Her...   Feb 5 2010, 04:51
- - yamfox   This good: Link That's my vinyl rip, with a us...   Jun 5 2010, 01:06
|- - Glenn Gundlach   QUOTE (yamfox @ Jun 4 2010, 16:06) This g...   Jun 7 2010, 18:20
|- - doctorcilantro   Here is a 24/192 sample. And here is a 96kHz vers...   Sep 1 2010, 22:16
|- - Canar   QUOTE (doctorcilantro @ Sep 1 2010, 16:16...   Sep 2 2010, 00:10
||- - doctorcilantro   QUOTE (Canar @ Sep 2 2010, 01:10) QUOTE (...   Sep 2 2010, 00:16
|||- - 2Bdecided   QUOTE (doctorcilantro @ Sep 2 2010, 00:16...   Sep 2 2010, 09:56
||- - doctorcilantro   QUOTE (Canar @ Sep 2 2010, 01:10) QUOTE (...   Sep 2 2010, 01:18
||- - Canar   QUOTE (doctorcilantro @ Sep 1 2010, 19:18...   Sep 2 2010, 02:10
|||- - doctorcilantro   QUOTE (Canar @ Sep 2 2010, 03:10) QUOTE (...   Sep 2 2010, 04:58
||- - greynol   QUOTE (doctorcilantro @ Sep 1 2010, 17:18...   Sep 2 2010, 03:39
|||- - doctorcilantro   QUOTE (greynol @ Sep 2 2010, 04:39) QUOTE...   Sep 2 2010, 04:56
||- - 2Bdecided   QUOTE (doctorcilantro @ Sep 2 2010, 01:18...   Sep 2 2010, 09:38
||- - doctorcilantro   QUOTE (2Bdecided @ Sep 2 2010, 10:38) QUO...   Sep 2 2010, 11:21
|- - krabapple   QUOTE (doctorcilantro @ Sep 1 2010, 17:16...   Sep 2 2010, 04:43
|- - doctorcilantro   QUOTE (krabapple @ Sep 2 2010, 05:43) QUO...   Sep 2 2010, 04:53
- - greynol   I can understand the 8 extra bits headroom and pro...   Sep 1 2010, 22:28
- - doctorcilantro   QUOTE (greynol @ Sep 1 2010, 23:28) I can...   Sep 2 2010, 00:20
- - Canar   QUOTE (greynol @ Sep 1 2010, 16:28) Would...   Sep 2 2010, 00:23
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 28th April 2015 - 12:04
