foo_musicbrainz, MusicBrainz Tagger
Dremora
post Mar 23 2009, 04:31
Allows tagging files using data from MusicBrainz.
Features:
  • Fetches data by automatically calculated MusicBrainz Disc ID, existing Artist/Album or MusicBrainz Album ID tags;
  • Uses the latest version of MusicBrainz web service, which corresponds to the NGS data model;
  • Supports many different tags, including artist, album, date, tracknumber/totaltracks, discnumber/totaldiscs, label, catalognumber, barcode etc.;
  • Supports MusicBrainz-specific tags: Artist ID, Album ID, Release Group ID, Disc ID, Track ID, album type, album status;
  • Missing TOCs can be submitted to MusicBrainz from the context menu.
For the list of planned features, see issue tracker.
Any feedback or suggestions are appreciated!
Download foo_musicbrainz 0.3 | Join Last.fm group | Get source on Github
Note regarding TOC submission:
Submit new TOCs to MusicBrainz only if you know what you are doing. Use only full rips from trusted sources (so, most likely, the files should orignate from a CD of your own). Choose release wisely — if your version of an album doesn't exist, add a new one. That means, if you don't know the version, don't submit.
To submit TOC, select all tracks belonging to a single disc and choose “Tagging → Add TOC to MusicBrainz” from the context menu. This feature is available only for registered MusicBrainz users.
Version history
v0.3 (2012-06-24)
* Fixed crash when metadata has different track count
* New tag: original release date
v0.3 beta 2 (2011-06-03)
* NGS support;
* New tags: musicbraiz_releasegroupid, label, catalognumber, barcode, totaldiscs;
* Proxy support;
* Option to convert punctuation to ASCII;
* Open-sourced.
v0.2.1 (2011-05-21) (requires foobar2000 1.1 or newer)
* Added ability to submit new TOCs from the context menu;
* CDStubs are excluded from search;
* Preferences page is now using latest API;
* foo_musicbrainz has been added to the components repository, so from now on in can be updated automatically.
v0.2 (2009-04-10)
* Added preferences page;
* Added ability to edit queries.
v0.1 (2009-03-23)
* Initial release.
This post has been edited by Dremora: Jul 25 2012, 00:40
Purple Monkey
post Oct 7 2010, 19:40
Yes you are right index 00s are ignored, foobar only looks at 01 indexes. However the cue-sheets and separate tracks still produce a different DiscID.
In both cases the first track is shortened by 00:42 and 00:33 respectively (pre-gap), however if you check the release pages you will see the first disc has more than one DiscID, one of which matches a change of 00:42 (so MB returns the album.) However the second album only has one DiscID so is not matched at all. The component has no way of knowing what the pre-gap size was and so has to use 0.
Solution: If looking up by TOC fails: try by Artist/Album, and if that fails: look it up on the site and use by AlbumID.
- Dremora   foo_musicbrainz   Mar 23 2009, 04:31
- - aliumalik   I have been using Picard for a long time...integra...   Mar 23 2009, 05:29
- - novembre   Interesting! Thanks!   Mar 23 2009, 10:38
- - smkk   Very nice. Thank you.   Mar 23 2009, 10:58
- - qwertz   Looks very good, thank you. Though I had never hea...   Mar 23 2009, 11:22
- - FavioD   this is so great, thanks a lot! hopefully this...   Mar 23 2009, 11:42
- - Andu   Would it be possible to add just the year to date?...   Mar 23 2009, 16:14
|- - Canar   QUOTE (Andu @ Mar 23 2009, 08:14) Would i...   Mar 23 2009, 18:34
- - Lucky Luciano   What do TOC and MBID mean?   Mar 23 2009, 16:33
|- - d0ng   QUOTE (Lucky Luciano @ Mar 23 2009, 10:33...   Mar 24 2009, 02:36
- - grimes   Nice plugin! Thanks. QUOTE (Andu @ Mar 2...   Mar 23 2009, 17:06
- - anishbenji   Really useful plugin. I like the interface alot, n...   Mar 23 2009, 17:24
- - unabatedshagie   QUOTE (Andu @ Mar 23 2009, 15:14) Would i...   Mar 23 2009, 17:59
|- - Canar   QUOTE (unabatedshagie @ Mar 23 2009, 09:5...   Mar 23 2009, 18:37
|- - Falstaff   QUOTE (Canar @ Mar 23 2009, 18:37) QUOTE ...   Mar 23 2009, 19:40
|- - Falstaff   QUOTE (Canar @ Mar 23 2009, 18:37) QUOTE ...   Mar 24 2009, 11:14
- - Talion   Very nice, thank you! The plugin seems to use...   Mar 23 2009, 18:36
- - hick   I use picard, but I use it starting with only the ...   Mar 23 2009, 20:19
- - TehNomad   Great plugin, MB is easily my favorite database (i...   Mar 23 2009, 21:12
- - bubbleguuum   I couldn't get any result (using the 'by t...   Mar 24 2009, 01:09
- - aliumalik   Regarding the date thing, I would rather have the ...   Mar 24 2009, 03:01
|- - shakey_snake   Thank you very much for this component, it is some...   Mar 24 2009, 03:30
|- - Zarggg   QUOTE (aliumalik @ Mar 23 2009, 22:01) Re...   Mar 26 2009, 17:39
- - tehfuzz   Hey all, just registered here (and started using f...   Mar 24 2009, 03:44
- - Canar   tehfuzz, I take it you've never noticed the To...   Mar 24 2009, 04:00
- - tehfuzz   Well crap. So there is. Thanks. This plugin was ...   Mar 24 2009, 04:21
- - Anas   I did know of muscibrainz before, but didn't u...   Mar 26 2009, 12:08
- - 2E7AH   i like musicbrainz way of tagging mainly because o...   Apr 3 2009, 08:31
- - Andu   I like this plugin. It would be great if I could m...   Apr 3 2009, 14:09
|- - odyssey   QUOTE (Andu @ Apr 3 2009, 15:09) I like t...   Apr 3 2009, 14:35
- - Andu   You are right. Discogs can't do that. Only Rep...   Apr 3 2009, 15:10
|- - vogliadicane   I like this plugin. Would be nice if it would also...   Apr 4 2009, 12:14
|- - odyssey   QUOTE (vogliadicane @ Apr 4 2009, 13:14) ...   Apr 4 2009, 13:50
- - foolver   it would be nice if we could choose the default va...   Apr 4 2009, 16:47
|- - vogliadicane   QUOTE (foolver @ Apr 4 2009, 16:47) it wo...   Apr 5 2009, 19:20
- - odyssey   All you people bitching about the full date, why d...   Apr 4 2009, 19:13
- - Anas   Or why not keep the additional data and just displ...   Apr 5 2009, 12:15
- - Nemphael   Musicbrainz's Picard has some scripting abilit...   Apr 5 2009, 16:37
|- - Keesface   QUOTE (Nemphael @ Apr 5 2009, 16:37) Musi...   Jan 7 2010, 14:51
- - Chaser   Thank you. The component works very nicely. I have...   Apr 5 2009, 20:49
- - Dremora   Thanks everybody for your feedback. I've imple...   Apr 10 2009, 21:18
- - Anas   Thanks a lot for the update, Dremora. The new vers...   Apr 11 2009, 11:16
- - Olaf   Thanks for this component and for the new version,...   Apr 12 2009, 10:22
- - atzaus   Thanks for the update but I have one issue. For al...   Apr 12 2009, 10:34
|- - vogliadicane   Thanks for the update Dremora! I like the feat...   Apr 16 2009, 17:54
- - Yirkha   Hint: info_lookup_handler   Apr 16 2009, 17:58
- - Fractal_Mortality   Hey guys, in order to use the "Album ID...   Apr 17 2009, 17:09
|- - Dremora   In URL http://musicbrainz.org/release/2c54468a-de....   Apr 18 2009, 07:47
- - dannymichel   can u make a mirror? this server keeps disconnecti...   Apr 24 2009, 12:00
- - rekees   Hey can someone with 0.2 reupload it? Thanks.   May 1 2009, 10:48
|- - dreadroach   foo_musicbrainz 0.2   May 1 2009, 10:56
- - M@d Man   First of all, thank you for this great plug-in...   May 7 2009, 19:43
- - fbuser   It's a license violation to use GPL libraries ...   May 7 2009, 20:07
|- - M@d Man   QUOTE (fbuser @ May 7 2009, 20:07) It...   May 7 2009, 21:18
|- - shakey_snake   QUOTE (fbuser @ May 7 2009, 15:07) It...   May 15 2009, 16:01
- - locutus   When we don't have fingerprint support here th...   May 15 2009, 15:15
- - 2E7AH   Musicbrainz context menu entry disappears when mor...   May 31 2009, 04:39
- - fbuser   It's probably intented, because the menu entri...   May 31 2009, 08:26
- - 2E7AH   Yes, that's true, but I thought that something...   May 31 2009, 10:52
- - mudlord   Anyone could upload foo_musicbrainz 0.2 to the fb2...   Jul 30 2009, 11:54
- - Case   Here.   Jul 30 2009, 20:36
- - mudlord   Brilliant. Thanks for that.   Jul 30 2009, 22:43
- - 2E7AH   When tagging Various Artists releases, MusicBrainz...   Oct 1 2009, 20:01
- - labou   thanks. this works well   Oct 5 2009, 19:34
- - hlloyge   I would like to ask proxy support, like Discogs pl...   Oct 5 2009, 19:57
- - Kuraj   I would love to see a couple of things in the next...   Oct 24 2009, 15:49
|- - Dremora   QUOTE (Kuraj @ Oct 24 2009, 17:49) An opt...   Oct 30 2009, 15:11
|- - Kuraj   QUOTE (Dremora @ Oct 30 2009, 08:11) QUOT...   Oct 30 2009, 16:52
- - Crossbar   It works really well, thanks so much, no idea why ...   Nov 24 2009, 07:06
- - mudlord   Strange, using freedb works here fine for disc tag...   Nov 25 2009, 10:58
- - u-neeks   I hope nobody uses the option to remove the (feat....   Jan 22 2010, 09:51
- - radu   First of all thanks for the plug-in, it's grea...   Feb 3 2010, 00:59
- - kitzik   Must have plug-in! Thanks! Could I ask you...   Feb 9 2010, 08:38
- - Bryan in Hawaii   OK I'm between jobs again so that means I have...   Feb 16 2010, 21:10
- - 2E7AH   entering: "foobar musicbrainz tagger" on...   Mar 1 2010, 13:01
- - Ross1   Seems to be fairly successful at finding the right...   Apr 8 2010, 17:54
|- - ankurtg   Proxy support please!   Apr 19 2010, 19:59
- - Benji99   I hope this plugin is still being developed! ...   Apr 23 2010, 16:51
- - innou   Hi, It seems that lookup by Album ID does not wor...   Aug 14 2010, 11:26
- - Zarggg   Second this. Musicbrainz has changed their URI sch...   Aug 15 2010, 14:31
- - ghostly   Hey, I use EAC to rip CDs to FLAC image + CUE she...   Oct 7 2010, 10:53
|- - Sandrine   QUOTE (ghostly @ Oct 7 2010, 11:53) and I...   Oct 7 2010, 21:37
- - Purple Monkey   I suspect that it is the gap detection that is cau...   Oct 7 2010, 12:43
- - ghostly   I think we misunderstood because I used CueTools t...   Oct 7 2010, 17:45
- - Purple Monkey   Yes you are right index 00s are ignored, foobar on...   Oct 7 2010, 19:40
|- - ghostly   QUOTE (Purple Monkey @ Oct 7 2010, 19:40)...   Oct 7 2010, 21:18
- - ghostly   I use images for backup and separate tracks for pl...   Oct 7 2010, 21:56
- - jesus2099   Dremora, thank you so very much for your awesome p...   Jan 5 2011, 15:06
- - Kuraj   Is the author still planning to work on this plugi...   Mar 20 2011, 17:27
- - mudlord   QUOTE release the source why. >_>   Mar 21 2011, 09:51
- - Kuraj   I only meant to ask whatever the author was up to,...   Mar 21 2011, 10:31
- - mudlord   I was asking whats the point in releasing source. ...   Mar 21 2011, 10:37
- - thuan   I think release the source does not equal GPLed it...   Mar 21 2011, 10:55
- - mudlord   Again, depends on licensing. It should be LGPL or ...   Mar 21 2011, 14:16
- - klonuo   hey mudlord, can you stop spoiling threads with yo...   Mar 21 2011, 14:22
- - mudlord   If you ever bothered to check the GPL licensing, y...   Mar 21 2011, 17:15
- - RastaMan   The link to this extension no longer works. Here...   May 14 2011, 20:32
|- - jesus2099   QUOTE (RastaMan @ May 14 2011, 20:32) The...   May 14 2011, 23:29
- - Szekely   Musicbrainz rollout of NGS has broken this plugin....   May 18 2011, 20:35
- - Dremora   First I want to thank everybody for your attention...   May 20 2011, 16:52
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 18th April 2015 - 08:57
