65 Pages V  « < 53 54 55 56 57 > »
WSH Panel Mod, foo_uie_wsh_panel_mod
vapkse
post Jan 28 2012, 16:13
Post #1351
Thanks Marc, that work for text.
godrick
post Feb 2 2012, 23:30
Post #1352
I can't seem to use the preferences>components>get updates button or the help>check for updated components menu item to get updates for this component - am I doing something incorrectly, or are these methods not available for WSH panel mod?
Thanks very much for this very powerful component!
Zao
post Feb 2 2012, 23:35
Post #1353
Group: Members (Donating)
The update notifier and downloader only works with components hosted on the official components site.
If it's not on there, foobar2000 doesn't know about it.
majzo
post Feb 17 2012, 22:48
Post #1354
made some rectangles with gr.drawrect and noticed unexpected behaviour (at least for me)
when the line width is odd number, line is drawn 1 point from left to right and from up to down instead of from outside to inside or vice versa
is it supposed to be like that ?
Falstaff
post Mar 4 2012, 18:44
Post #1355
@T.P. Wang : possible bug with timer (SetTimout or SetInterval methods)
WSH panel mod version = 1.5.2
i work on a script for a playlist viewer, and for scrolling my playlist with mousewheel, i use this function:
function on_mouse_wheel(delta) {
    var i;
    if(!list.waiter_timer) {
        fb.trace("false!!");
        if(delta>0) {
            fb.trace(">0");
            list.waiter_timer = window.SetTimeout(function () {
                fb.trace(">0 run");
                for(i=0;i<list.mousewheel_scrollstep;i++) {
                            scrollup_spv(fb.ActivePlaylist, 1);
                list.waiter_timer = false;
                window.Repaint();
            }, 25);
        } else {
            fb.trace("<0");
                fb.trace("<0 run");
                            scrolldown_spv(fb.ActivePlaylist, 1);
                window.Repaint();
            }, 25);
if i use mousewheel massively, console display this:
false!!
>0
false!!
<0
false!!
<0
false!!
<0
false!!
<0
false!!
>0
as you can see, the timeout is never rechead because console never display ">0 run" or "<0 run", and result is that my playlist isn't scrolling at all ! sad.gif
Important comment about this weird behaviour: this problem is NOT PRESENT when i run foobar (so at the first launch of the WSH jscript), but it happens after some while, that became messy and no more scroll (the mousewheel is just an example, it seems that all my timer are broken!)
only a restart of foobar fix the problem (editing script then Applying has NO effect ...)
So, after testing this, i'm pretty sure that's a problem with these new methods to set timers brought with v1.5.x version of your component, and i've read in v1.5.0 betas that you've already encoutered some issues with them (timers never stopped on exit if i remember ...)
Could you check it please, because for now i'm really stuck!
Thanx by advance for your feedback
Regards,
Br3tt
This post has been edited by Falstaff: Mar 4 2012, 18:56
http://br3tt.online.fr/
Falstaff
post Mar 10 2012, 11:14
Post #1356
FYI: that wasn't a bug: timer creation overflow or something like that.... fixed. Thanx T.P for the help.
Falstaff
post Mar 10 2012, 14:21
Post #1357
WSH PM v1.5.2: on the script editor, Replace All feature seems broken (at least for me) ...
just try to replace a string by another: press CTRL+H, fill source string, fill target string, click Replace All button ==> only the last occurs found is changed !!!
i'm the only one with this weird behaviour ?
thanx for any feedback about this please.
ExtremeHunter
post Mar 10 2012, 22:33
Post #1358
You are not alone, it's not working here too.
Falstaff
post Mar 10 2012, 22:50
Post #1359
T.P Wang
post Mar 15 2012, 07:31
Post #1360
QUOTE (Falstaff @ Mar 10 2012, 21:21) *
Thanks for reporting.
It's already fixed in r251d912aa29f (source code), I'll release it when it's ready.
Falstaff
post Mar 15 2012, 07:48
Post #1361
VirDim
post Mar 15 2012, 22:10
Post #1362
Hello! whs panel mod(1.5.2) is not working on windows 8 CP x64. Foobar v1.1.10. Skin: ZiX. On windows 7 it works fine. Enclose logs.
UI Hacks: DLL-hijacking failed
UI Hacks: hooks status 0x020000
Watching: C:\Users\Дмитрий\Music
Watching: C:\Users\Public\Music
Watching: D:\torrents\Prodigy
WSH Panel Mod ({30E5E5AB-C693-4364-BBC6-5F20AC7C8C8D}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\VBscript.js"
WSH Panel Mod ({30E5E5AB-C693-4364-BBC6-5F20AC7C8C8D}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Button.js"
WSH Panel Mod ({30E5E5AB-C693-4364-BBC6-5F20AC7C8C8D}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Options.js"
Error: WSH Panel Mod ({30E5E5AB-C693-4364-BBC6-5F20AC7C8C8D}): Microsoft JScript runtime error:
Automation server can't create object
File: <main>
Ln: 1089, Col: 5
WSH Panel Mod ({26A7BCC7-EE59-4150-A3EA-E1FFD07EE3F6}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\VBscript.js"
WSH Panel Mod ({26A7BCC7-EE59-4150-A3EA-E1FFD07EE3F6}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Button.js"
WSH Panel Mod ({26A7BCC7-EE59-4150-A3EA-E1FFD07EE3F6}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\TabbedPlaylistManager.js"
WSH Panel Mod ({26A7BCC7-EE59-4150-A3EA-E1FFD07EE3F6}): initialized in 8 ms
WSH Panel Mod ({B9777502-06C9-45D2-A62D-917C89F2E968}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Button.js"
WSH Panel Mod ({B9777502-06C9-45D2-A62D-917C89F2E968}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Options.js"
Error: WSH Panel Mod ({B9777502-06C9-45D2-A62D-917C89F2E968}): Microsoft JScript runtime error:
File: C:\Program Files\Foobar2000\themes\tech\scripts\Options.js
Ln: 28, Col: 1
WSH Panel Mod ({5C157219-D29F-47E5-A394-58B183B9DDE4}): initialized in 3 ms
Error: WSH Panel Mod ({4E726A85-4788-4FEE-8476-F5A11B1A3D89}): Microsoft JScript runtime error:
File: <main>
Ln: 149, Col: 1
WSH Panel Mod ({0605A192-2F68-4E40-AF10-38D5E184F6CF}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Button.js"
Error: WSH Panel Mod ({0605A192-2F68-4E40-AF10-38D5E184F6CF}): Microsoft JScript runtime error:
File: <main>
Ln: 72, Col: 1
Album list panel: initialised in 0.010 s
Filter Panel - Genre: initialised in 0.002
WSH Panel Mod ({409D6A1A-5037-4F7A-AEF0-1D73BC23761B}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\VBscript.js"
WSH Panel Mod ({409D6A1A-5037-4F7A-AEF0-1D73BC23761B}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Button.js"
WSH Panel Mod ({409D6A1A-5037-4F7A-AEF0-1D73BC23761B}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\TabbedPlaylistManager.js"
WSH Panel Mod ({409D6A1A-5037-4F7A-AEF0-1D73BC23761B}): initialized in 7 ms
WSH Panel Mod ({9624DCFB-CA24-4C48-9C3C-1CCA1BEF3A04}): initialized in 2 ms
WSH Panel Mod ({0FD6B6B6-2BAF-4D4E-8CDE-08D414151CF8}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Options.js"
WSH Panel Mod ({0FD6B6B6-2BAF-4D4E-8CDE-08D414151CF8}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Button.js"
Error: WSH Panel Mod ({0FD6B6B6-2BAF-4D4E-8CDE-08D414151CF8}): Microsoft JScript runtime error:
Ln: 28, Col: 1
WSH Panel Mod ({0FD6B6B6-2BAF-4D4E-8CDE-08D414151CF8}): initialized in 3 ms
WSH Panel Mod ({087C3FA2-1CE7-4E33-AB60-A10F3E21F9FD}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Options.js"
Error: WSH Panel Mod ({087C3FA2-1CE7-4E33-AB60-A10F3E21F9FD}): Microsoft JScript runtime error:
Ln: 28, Col: 1
WSH Panel Mod ({49F61F0E-2BE1-4B88-85C2-DFB4F4599C45}): initialized in 0 ms
WSH Panel Mod ({B0B475A5-B24B-4885-8DE1-01BBC4D99025}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Button.js"
Error: WSH Panel Mod ({B0B475A5-B24B-4885-8DE1-01BBC4D99025}): Microsoft JScript runtime error:
File: <main>
Ln: 151, Col: 1
WSH Panel Mod ({38DE0A5D-0F6E-4A44-8F89-557E30C3642C}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Button.js"
WSH Panel Mod ({38DE0A5D-0F6E-4A44-8F89-557E30C3642C}): initialized in 3 ms
WSH Panel Mod ({ECE63506-16B9-4936-AC76-95AC2E44874D}): initialized in 1 ms
WSH Panel Mod ({F11C31E3-6E25-4176-B1F4-14BC6A3D54FC}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Button.js"
WSH Panel Mod ({F11C31E3-6E25-4176-B1F4-14BC6A3D54FC}): initialized in 2 ms
WSH Panel Mod ({BC89B381-A74B-4965-8379-6A43520F2169}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Button.js"
WSH Panel Mod ({BC89B381-A74B-4965-8379-6A43520F2169}): initialized in 7 ms
WSH Panel Mod ({21E87952-AAE5-4900-9F3B-154C0B342457}): initialized in 0 ms
WSH Panel Mod ({F30A52BF-6778-441E-8C28-965DACD4809A}): Parsing file "C:\Program Files\Foobar2000\themes\tech\scripts\Button.js"
WSH Panel Mod ({F30A52BF-6778-441E-8C28-965DACD4809A}): initialized in 4 ms
Error: WSH Panel Mod (ZiX+ HeadCoverPanel by Jensen and karvos): Microsoft JScript runtime error:
File: <main>
Ln: 49, Col: 3
WSH Panel Mod (ZiX+ AniTrackInfoPanel by Jensen): initialized in 2 ms
WSH Panel Mod (ZiX+ PBCPanel by Neonphytismo): initialized in 2 ms
WSH Panel Mod (ZiX+ RatingPanel): initialized in 0 ms
WSH Panel Mod (ZiX+ VolPanel by Neonphytismo): initialized in 1 ms
WSH Panel Mod (ZiX+ VolPanel by Neonphytismo and r0lZ): Parsing file "C:\Program Files\Foobar2000\themes\ZiX\skins\ZiX+\Scrollbar\scrollbar.js"
WSH Panel Mod (ZiX+ VolPanel by Neonphytismo and r0lZ): initialized in 2 ms
WSH Panel Mod (ZiX+ SimpleCoverPanel by Br3tt Modified by Neonphytismo): initialized in 1 ms
WSH Panel Mod (ZiX+ PBOPanel by Neonphytismo): initialized in 3 ms
WSH Panel Mod (ZiX+ VolPanel by Neonphytismo): initialized in 0 ms
w7shell: init started
w7shell: GDI+ initialized
w7shell: COM initialized
w7shell: running on Windows NT 6.1.7600
w7shell: DWM composition enabled
w7shell: WA_DISALLOW_PEEK successfully set
w7shell: WA_HAS_ICONIC_BITMAP successfully set
w7shell: WA_FORCE_ICONIC_REPRESENTATION successfully set
w7shell: failed to set WA_FLIP3D_POLICY: 0x80070057
w7shell: all green
Startup time : 0:04.478754
This post has been edited by VirDim: Mar 15 2012, 22:10
marc2003
post Mar 15 2012, 23:05
Post #1363
this usually means you haven't turned off safe mode in the preferences.
and i don't know that theme but my own scripts work fine in the windows 8 x64 CP (i'm not using it now but i tried it for a few days when it was first released)
Falstaff
post Apr 2 2012, 22:49
Post #1364
@T.P Wang
hi,
a callback function is missing :
function on_playlist_items_added(playlist) {} is ok to check when items are added, but there is nothing to alert us when item is removed from a playlist, i need it too sad.gif
could you add for next version a such callback please?
function on_playlist_items_removed(playlist) {}
marc2003
post Apr 2 2012, 22:52
Post #1365
// [1.4.1] Added:
// playlist: index to indicate that which playlist has items removed
// new_count: new items count of the playlist.
function on_playlist_items_removed(playlist, new_count) {}
Falstaff
post Apr 2 2012, 23:26
Post #1366
thanx marc
Falstaff
post Apr 7 2012, 18:29
Post #1367
QUOTE (T.P Wang @ Mar 15 2012, 07:31) *
is the next release close ?
marc2003
post Apr 20 2012, 06:01
Post #1368
i see 1.5.3 is now released but it seems to be broken. the editor dialog will not open.
Falstaff
post Apr 20 2012, 07:17
Post #1369
QUOTE (marc2003 @ Apr 20 2012, 07:01) *
T.P Wang
post Apr 20 2012, 12:55
Post #1370
QUOTE (marc2003 @ Apr 20 2012, 13:01) *
A quick fix is provided hopefully fix that issue.
Falstaff
post Apr 20 2012, 17:42
Post #1371
QUOTE (T.P Wang @ Apr 20 2012, 13:55) *
thank you for the update and the fix!
i've just tested the SortByFormat feature, it seems ok, but there is a gap according to me: no direction option to sort ascending or descending like provided on the handlelist object (direction: integer, ascending while >0.)
is it intended or just thing you forgot?
marc2003
post Apr 20 2012, 19:03
Post #1372
thanks for the fix.
Supaiku
post May 5 2012, 02:09
Post #1373
QUOTE (marc2003 @ Apr 21 2012, 02:03) *
thanks for the fix.
I keep getting this error:
Failed to load DLL: foo_uie_wsh_panel_mod.dll
Do the docs have any info about dependencies I'm missing?
Foobar 1.11.11
ExtremeHunter
post May 11 2012, 22:11
Post #1374
Hi T.P. Wang!
Is it possible to update the wsh panel engine to support ECMAScript 5 ?
There are some new useful features that would be nice to have in wsh panel mod. rolleyes.gif
some examples here
r0k
post May 20 2012, 10:52
Post #1375
Warning : Noob request
Hello. I'm trying to get my way into writing some WSH panel scripts, and of course, as someone who hardly programmed anything but simple macros for years and never used java script, i'm doing mistakes.
The worst of those mistakes i've made so far was a dreaded endless loop lalala.gif
The result was immediate : WSH panel hang, making fb2k hang as well. I had to kill it using the task manager.
But what was worse is that the panel somehow managed to keep the bad script in it's config, so when i restarted fb2k ... it directly hang. I was able to start in safe mode but since i didn't had columns UI in safe mode, i couldn't remove the bad panel so i had to delete wsh_panel.dll.cfg to get rid of this panel and loose other WSH panels as well.
Of course, i can blame noone but myself for forgetting to post-increment the counter in one branch of a conditional statement inside the while-loop. However, it would be nice if you could implement something like the security built-in the firefox java-script environment. If a script runs on itself for some time, a popup shows asking whether the user wants to stop the script or continue running it. This way, a bad script will only crash itself and not the whole application.
RSS Lo-Fi Version Time is now: 5th May 2015 - 13:47
