how to get the lower bitrates?
amppa
post Jan 12 2002, 19:46
So, I would like to have mp3 files close to 192 kbps. I listen mostly metal (various types - heavy, power, black, ...) and --alt-preset standard seems to create mostly bitrates of 200-250 (tested with several albums). I consider this to be too high, how should I create the files to get lower rates? Should I use ABR with --alt-preset [rate] or maybe some VBR command line (for example, edited -r3mix), using -V[n] to adjust the bitrates? Any suggestions?
tangent
post Jan 12 2002, 20:16
I would recommend only using --lowpass (try 17.5) to modify --alt-preset standard to get lower bitrates. Other parameters are likely to interfere with some of the internal workings of --alt-preset standard.
Something riskier would be to use --ath-lower with a small negative value, maybe -2 or -3. Be warned though, this is not tested and I doubt Dibrom will recommend it.
Another alternative would be to use --alt-preset 192
Or --r3mix if you really must use VBR
If you can wait a few months, Dibrom will be working on tuning for lower bitrates.... smile.gif
- amppa   how to get the lower bitrates?   Jan 12 2002, 19:46
- - tangent   I would recommend only using --lowpass (try 17.5) ...   Jan 12 2002, 20:16
- - ami   hi, hmm since ive read, that dibrom listens and en...   Jan 12 2002, 20:25
- - amppa   So, if I got it right, lame --alt-preset [rate] sh...   Jan 12 2002, 21:38
- - NeoRenegade   You got it dead on   Jan 13 2002, 23:46
- - TheBashar   I don't recall ever reading Dibrom say that with h...   Jan 14 2002, 00:56
- - Weiman   How about --alt-preset standard -V 3 -B 256? It gi...   Mar 7 2002, 21:29
- - Dibrom   My stance on this: Lowering the lowpass is by far...   Mar 7 2002, 21:57
- - mp3fan   QUOTE like employing an adaptive lowpass, with a l...   Mar 8 2002, 03:59
- - kxy   Newbie questions... when I use -alt-preset stand...   Mar 8 2002, 08:22
- - Sachankara   I still donīt see why you donīt use --alt-preset 1...   Mar 8 2002, 22:55
- - Dibrom   QUOTE Originally posted by mp3fan Currently [b]--...   Mar 8 2002, 23:42
- - kxy   Thx Dibrom. So despite the sfb21 warning, if some...   Mar 9 2002, 15:32
- - Dibrom   You don't need to use a lowpass when you use -Y. ...   Mar 9 2002, 19:10
- - kxy   Oh yea, of course I don't need to use -y and --low...   Mar 9 2002, 20:50
- - Dibrom   QUOTE Originally posted by kxy To recap, the -Y o...   Mar 9 2002, 21:03
- - mp3fan   Dibrom, QUOTE By using -Y, and disabling noise sh...   Mar 10 2002, 03:10
- - jkeating   You are forgetting about stereo settings! Right no...   Mar 12 2002, 00:04
- - Dibrom   QUOTE Originally posted by mp3fan So by using a -...   Mar 12 2002, 00:21
- - Dibrom   QUOTE Originally posted by jkeating You are forge...   Mar 12 2002, 00:24
- - ErikS   QUOTE Originally posted by Dibrom The reason fo...   Mar 12 2002, 02:28
- - JohnV   QUOTE Originally posted by ErikS No. Sorry for be...   Mar 12 2002, 03:30
- - Delirium   JohnV and Dibrom -- thanks for the explanations, I...   Mar 12 2002, 09:40
- - mithrandir   Considering that MP3s primary function is to reduc...   Mar 12 2002, 17:35
- - mp3fan   QUOTE Also, when I use an --athlower number up to ...   Mar 16 2002, 20:06
- - Dalkus   Reading through the FAQs and other threads I can...   May 4 2003, 16:30
- - SometimesWarrior   Using the -Y switch with --ap extreme carries the ...   May 5 2003, 06:36
- - Dalkus   Thanx for the reply. I'm just thinking that if...   May 5 2003, 13:30
RSS Lo-Fi Version Time is now: 4th August 2015 - 09:18
