Biwiring and Cables, A couple of questions on how to
atici
post Feb 28 2003, 22:17
Group: Members (Donating)
I want to buy decent cables for my speakers and was wondering on how the setup should be.
The speakers in question (Infinity Alpha 40) is biwirable. My amp has two pairs of speaker outputs. In this case which one is a better idea: to use biwiring cables or use separate wires using both of the speaker outputs on my amp? If I use separate identical cables, does the length make difference?
And about the cable diameter, are the thick ones necessarily better? If so how much? I am planning to spend around $80 for my cabling. 7 feet cable for each channel is sufficient. Do you have any suggestions on quality but cheap cables? What do you think about the ones here?
Please let me know what you think. Your help is much appreciated.
The object of mankind lies in its highest individuals.
One must have chaos in oneself to be able to give birth to a dancing star.
KikeG
post Mar 11 2003, 09:09
WinABX developer
Oh man... biwiring is *useless*, has no sense from an electrical/technical point of view. The only thing you do biwiring is double the capacitance and half the resistance. Capacitance is negligible in case of speaker cable. And resistance, well, once you are using a thick enough cable, there's no point in halving it.
About high and low frequencies going through same cable, this is fine, cables are perfect linear devices from an audio point of view, so can carry all frequencies without interfering each other at all.
If anyone can give me an alternative technical explanation of why could it be better, I'll be pleased to read it.
- atici   Biwiring and Cables   Feb 28 2003, 22:17
- - Amadablam   http://home.earthlink.net/~rogerr7/wire.htm I can...   Feb 28 2003, 22:29
- - Dex4now   Hi Atici, you have to be careful about articles li...   Mar 10 2003, 02:41
- - gdougherty   "Audiophile grade" copper cable is bunk....   Mar 10 2003, 04:28
- - atici   Is thicker cable necessarily better? I got a 10 ga...   Mar 10 2003, 05:30
- - boojum   Doesn't Ohm's Law cover all of this? Buy ...   Mar 10 2003, 05:40
- - KikeG   Even biwiring is vodoo audio. From an electrical p...   Mar 10 2003, 09:04
- - Dex4now   QUOTE (gdougherty @ Mar 9 2003 - 07:28 PM)I p...   Mar 10 2003, 10:13
- - KikeG   QUOTE (Dex4now @ Mar 10 2003 - 10:13 AM)And, ...   Mar 10 2003, 10:26
- - Dibrom   QUOTE (Dex4now @ Mar 10 2003 - 02:13 AM)And, ...   Mar 10 2003, 11:21
- - LoKi128   I believe that there are some things in the audio ...   Mar 10 2003, 16:12
- - Bedeox   QUOTE (LoKi128 @ Mar 10 2003 - 07:12 AM)I bel...   Mar 10 2003, 17:28
- - LoKi128   ABX is a statistical method... it is a scientific ...   Mar 10 2003, 20:03
- - atici   QUOTE (LoKi128 @ Mar 10 2003 - 10:12 AM)Bi-wi...   Mar 10 2003, 20:20
- - Bedeox   But this difference is not hearable and is hardly ...   Mar 10 2003, 20:47
- - DigitalMan   QUOTE (atici @ Mar 10 2003 - 11:20 AM)AFAIK I...   Mar 10 2003, 21:38
- - Dex4now   Well, unfortunately, much of the criticism of my c...   Mar 11 2003, 00:37
- - lucpes   CODE1) single wire: preamp->amp-...   Mar 11 2003, 00:59
- - Dex4now   Hi lucpes, just so you know, Bi-amping and bi-wiri...   Mar 11 2003, 01:15
- - Annuka   Responding to original question: It has been my e...   Mar 11 2003, 01:36
- - Annuka   I'd like to add a comment: Audio is a physic...   Mar 11 2003, 01:53
- - DigitalMan   QUOTE (Annuka @ Mar 10 2003 - 04:36 PM)Connec...   Mar 11 2003, 01:57
- - lucpes   QUOTE (Dex4now @ Mar 11 2003 - 12:15 AM)...po...   Mar 11 2003, 04:15
- - lucpes   QUOTE (atici @ Mar 10 2003 - 07:20 PM)Biwirin...   Mar 11 2003, 04:18
- - KikeG   Oh man... biwiring is *useless*, has no sense from...   Mar 11 2003, 09:09
- - gdougherty   QUOTE (Annuka @ Mar 10 2003 - 06:36 PM)Respon...   Mar 11 2003, 09:31
- - KikeG   gdougherty, I agree on nearly everything: About i...   Mar 11 2003, 10:03
- - Pio2001   When a single 4 mm2 cable is used and a 1000 Hz si...   Mar 12 2003, 01:35
- - KikeG   QUOTE (Pio2001 @ Mar 12 2003 - 01:35 AM)Thus,...   Mar 12 2003, 09:01
- - Annuka   I studied electronics for a short while many years...   Mar 12 2003, 12:06
- - KikeG   QUOTE (Annuka @ Mar 12 2003 - 12:06 PM)But wh...   Mar 12 2003, 12:48
- - Annuka   QUOTE (KikeG @ Mar 12 2003 - 01:48 PM)Sorry, ...   Mar 12 2003, 14:44
- - KikeG   Well, when I call somebody an expert (which I don...   Mar 12 2003, 15:22
- - 2Bdecided   QUOTE (atici @ Feb 28 2003 - 09:17 PM)I want ...   Mar 12 2003, 15:37
- - 2Bdecided   QUOTE (Dex4now @ Mar 10 2003 - 01:41 AM)Hi At...   Mar 12 2003, 15:59
- - KikeG   Yep... I'm more of an objectivist, but I try n...   Mar 12 2003, 16:09
- - KikeG   By the way, I'm 100% of the opinion of that an...   Mar 12 2003, 16:24
- - DonP   QUOTE (DigitalMan @ Mar 10 2003 - 07:57 PM)[...   Mar 12 2003, 16:32
- - KikeG   But silver has a pay-off. It weights more than cop...   Mar 12 2003, 16:37
- - atici   QUOTE (2Bdecided @ Mar 12 2003 - 09:37 AM)The...   Mar 12 2003, 21:53
- - Dex4now   QUOTE (2Bdecided @ Mar 12 2003 - 06:59 AM)QUO...   Mar 12 2003, 23:27
- - KikeG   QUOTE (Dex4now @ Mar 12 2003 - 11:27 PM)I...   Mar 13 2003, 10:07
- - KikeG   Addition to my previous post: Note, I always talk...   Mar 13 2003, 10:15
- - 2Bdecided   QUOTE (KikeG @ Mar 12 2003 - 03:24 PM)By the ...   Mar 13 2003, 11:52
- - 2Bdecided   Sorry Dex - I didn't mean to offend, and I kno...   Mar 13 2003, 12:35
- - KikeG   @2Bdecided: QUOTE BUT it's not always trivial...   Mar 13 2003, 12:36
- - Daneel   QUOTE (Dex4now @ Mar 9 2003 - 05:41 PM)....Th...   Mar 13 2003, 13:43
- - Pio2001   I did the same calculus, though using the complete...   Mar 13 2003, 20:48
- - Dex4now   2Bdecided: As I look back at my post, the bold em...   Mar 13 2003, 23:47
- - KikeG   QUOTE (Dex4now @ Mar 13 2003 - 11:47 PM)The d...   Mar 14 2003, 09:03
- - gdougherty   QUOTE (Annuka @ Mar 12 2003 - 05:06 AM)Here i...   Mar 14 2003, 11:39
- - SometimesWarrior   QUOTE (gdougherty @ Mar 11 2003 - 12:31 AM)As...   Mar 14 2003, 12:03
- - gdougherty   QUOTE (Dex4now @ Mar 13 2003 - 04:47 PM)One o...   Mar 14 2003, 12:07
- - gdougherty   QUOTE (SometimesWarrior @ Mar 14 2003 - 05:03...   Mar 14 2003, 12:14
- - Pio2001   QUOTE (Dex4now @ Mar 14 2003 - 01:47 AM)whate...   Mar 15 2003, 00:01
- - Dex4now   QUOTE (KikeG @ Mar 14 2003 - 12:03 AM)QUOTE (...   Mar 15 2003, 02:48
- - Bedeox   QUOTE (gdougherty @ Mar 14 2003 - 03:07 AM)Ou...   Mar 15 2003, 17:16
- - Dex4now   C'mon Bedeox, you couldn't have meant that...   Mar 16 2003, 00:26
- - Pio2001   In HA, MP3 vs original, with measurable time smear...   Mar 16 2003, 00:32
- - LoKi128   QUOTE (Pio2001 @ Mar 15 2003 - 06:32 PM)And i...   Mar 16 2003, 00:57
RSS Lo-Fi Version Time is now: 3rd August 2015 - 20:40
