29 Pages V  < 1 2 3 4 > »
Kameleon by Br3tt, Columns UI configuration
AxaliaN
post Feb 15 2009, 10:53
Post #26
Yay finally! Gonna test it now! <3 Br3tt!
Edit: I keep getting a warning from Shpeck when I start Foobar:
Original Winamp or some other Winamp emulator has been detected. This can result in wrongly reported data, nonfunctional plugins and other conflicts, be warned.
This post has been edited by AxaliaN: Feb 15 2009, 11:16
Falstaff
post Feb 15 2009, 11:13
Post #27
KAMELEON v1.0b released. some fixes ... (lastest foo_skip plugin too)
the bug cover display (bad scale in the CD Case) is maybe fixed because i can't reproduce it, but i've made a little change...
This post has been edited by Falstaff: Feb 15 2009, 11:22
http://br3tt.online.fr/
AlStorm
post Feb 15 2009, 11:24
Post #28
QUOTE (Falstaff @ Feb 15 2009, 19:25) *
QUOTE (Tjmber @ Feb 15 2009, 09:16) *
Here a bug!
My config:
It's OK if I set: kameleon_artistart_filename: artist.jpg
Hmmm... you show me the Cover pic bug and talk about artistart filename ???!!
so the problem is about covers :
kameleon_coverart_path : default (=music folder) / specified path (i.e: C:/covers/) (be careful, specified path must close with a '/')
kameleon_coverart_filename : i.e: folder.jpg / folder.* / %album%.jpg / etc ...
if nothing setted in Foo_exvar, it search for folder.jpg images in the music folder, is it your case ? does it happen with all covers CD or only some of them ?
I understand it!
It is necessary to remove any extra spaces before and after the %artist%.jpg!
After that, the picture shows a well
Falstaff
post Feb 15 2009, 11:25
Post #29
rawgue_
post Feb 15 2009, 11:31
Post #30
Very beatiful work, but i'd like to see you tackle a lighter/easier on the eye config instead. I admit it's very nice, but i can't see myself using that for my actual config. edit: through more white in there too for a change too : )
This post has been edited by rawgue_: Feb 15 2009, 11:33
AxaliaN
post Feb 15 2009, 11:37
Post #31
I use Discogs for my artist art, and then use %DISCOGS_ARTIST_ID%_1.jpg for my artist image. However, It doesnt show up tongue.gif
I have kameleon_artistart_path set to E:/foobar2000/images/Artist/, and kameleon_artistart_filename to %DISCOGS_ARTIST_ID%_1.jpg.
This should work I guess?
Falstaff
post Feb 15 2009, 11:47
Post #32
QUOTE (AxaliaN @ Feb 15 2009, 11:37) *
foo-exvar do not handle variables like %var%, except %artist%, %album%, %album artist% be cause i have tweaked the code in K to handle them.
so all other %% can't work without some coding ... Same for all titleformat functions (like $replace(...) for example), they are not supported by foo_exvar.
i'll add this info in the INSTALLATION NOTES. (done)
This post has been edited by Falstaff: Feb 15 2009, 11:56
Falstaff
post Feb 15 2009, 11:54
Post #33
QUOTE (rawgue_ @ Feb 15 2009, 11:31) *
the more white it can be is to use a full white wallpaper as background :
Mr. Pacman
post Feb 15 2009, 11:58
Post #34
Man! This is a miracle! Br3tt thank you soooo much!!!
Falstaff
post Feb 15 2009, 11:59
Post #35
QUOTE (Mr. Pacman @ Feb 15 2009, 11:58) *
You're welcome Mr. Pac
rawgue_
post Feb 15 2009, 12:10
Post #36
What i mean is that maybe you should try something different. Too much stuff, bells and whistles. I suppose you'll say 1) i do it for my personal needs or 2) If you don't like it don't use. But the thing is that not many "waste" so much time to give configs to the community so maybe you could experiment with something else. Maybe a Pimp my Foobar kind of thing. I'll be the first to submit : D http://img8.imageshack.us/img8/3366/clipboard01gx0.jpg
Don't mean to sound like an ungrateful asshole, keep doing what you like most : )
This post has been edited by rawgue_: Feb 15 2009, 12:17
meDveD.spb
post Feb 15 2009, 12:55
Post #37
these components are new versions:
foo_run
foo_lastfm_radio
foo_uie_lyrics
why the required components are not foo_audioscrobbler?
foo_lastfm_radio meaningless without foo_audioscrobbler
and please, delete foo_playback_custom (automatic editing tags and corrupted hash files of torrents and dc++)
gaabrysz
post Feb 15 2009, 14:28
Post #38
Hey Guys.
Thank You Br3tt for this theme:) it's great but it's slow as hell on my pc.
Any help??
Hmm... Now it's working ok for cuple of minutes and then it slows down. You can see that when you try to switch between different panels ect..
This post has been edited by gaabrysz: Feb 15 2009, 15:03
qwertz
post Feb 15 2009, 14:32
Post #39
I specially like how easy it is, to adapt the config, to my needs, that's quite an achievement with Panel Stack Splitter.
This post has been edited by qwertz: Feb 15 2009, 14:33
cloudol
post Feb 15 2009, 14:39
Post #40
snapix font cannt support chinese and japanese
ojdo
post Feb 15 2009, 15:12
Post #41
QUOTE (Falstaff @ Feb 15 2009, 11:13) *
Happens still here, but also not reproducable. (v0.9.6.3 beta 1 with kameleon 1.0b fully installed)
http://freemusi.cc/
blackey
post Feb 15 2009, 15:36
Post #42
First of all - another great config smile.gif Thanks for great work wink.gif
Nevertheless I've got a few problems with Kameleon
1. CPU usage - over 60% sometimes (c2d@3.2Ghz so I don't think that hardware is the case). I've noticed it jumps so high only in two moments - when lyrics or now playing panel is active (even worse when both)
2. Playlist switcher should be in the left panel (wishlist:P), I'm using it a lot and it's somehow weird now
3. Chronoflow - viewing by playlists? (It's probably more for developer of chronoflow;))
bismuth
post Feb 15 2009, 15:39
Post #43
I have a question:
I want to set the cover file name like this:
If there is a file named %album%.jpg, then use that one, if not, use the file folder.jpg
Is it possible?
& I also receive this warning when start foobar: "Original Winamp or some other Winamp emulator has been detected. This can result in wrongly reported data, nonfunctional plugins and other conflicts, be warned." How to fix it?
This post has been edited by bismuth: Feb 15 2009, 15:44
exxecutor
post Feb 15 2009, 15:41
Post #44
Thank you very much, Brett! Kameleon is really amazing. Visually stunning, everything worked out in great detail. The new left, right and "now playing" panels are a big improvement (I didn't think that was even possible) over your last configs. smile.gif
Now some constructive criticism: wink.gif
In my opinion, Album List and Playlist Switcher could be implemented in a better way. Currently they open in a panel roughly 600x300 big. Ideally, this should be something like 300x600 because both AL and PS can have many rows and don't need too much space horizontally.
I suggest that the panel for AL and PS has the same size as the left panel and appears directly above it. This would be a nice combination of Ibiza (position) and Curacao/Kameleon (functionality). The buttons to show AL/PS could be moved to the right of the play/pause, etc buttons.
For my needs that would be perfect because when I browse playlists or AL, I am anyway more interested in what happens in ELPlaylist than the visuals of the left panel.
Dan Popescu
post Feb 15 2009, 16:03
Post #45
QUOTE (AxaliaN @ Feb 15 2009, 11:53) *
Maybe you have kmplayer started
Falstaff
post Feb 15 2009, 16:39
Post #46
QUOTE (ojdo @ Feb 15 2009, 15:12) *
read post #28 above (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=69485&view=findpost&p=615358)
be sure that there is no gap in the variables values
qwertz
post Feb 15 2009, 16:40
Post #47
I just found a little bug with foo_input_mslive.dll. Kameleon freezes when I open a mms stream, it worked fine with curacao. Probably some of the new code in ELPlaylist?
ojdo
post Feb 15 2009, 16:49
Post #48
QUOTE (Falstaff @ Feb 15 2009, 16:39) *
Sure, I read the whole thread before reporting. I have not even set a custom variable for the album art. About 50% of the time (it decides always when I start foobar) it works, 50% it doesn't. When I find a common property (probable of the resized cover image, I suppose) I will report.
Artistart issue: I just read the drawback of foo_exvar, that it is not capable of reflecting my artist art naming scheme for your theme:
Folder: $replace(%path%,%directoryname%\%filename_ext%,)
Filename: folder.jpg
Is there any chance you might include this (I hope often used) convention to store the artist image in the folder hierarchy one level above the album art?
http://freemusi.cc/
Divajjn
post Feb 15 2009, 17:12
Post #49
hi, amazing config br3tt . as always biggrin.gif .....when i start a track, background image is automaticly set to the cover image of the band, is it possible to set a bg image that is displayed even when i play a track
kkamion
post Feb 15 2009, 17:13
Post #50
QUOTE (Divajjn @ Feb 15 2009, 10:12) *
RSS Lo-Fi Version Time is now: 25th January 2015 - 16:40
