mp3 to wav to mp3 to wav same?
gts
post Feb 27 2003, 14:42
If a file is encoded to mp3, then coverted back to a wav, and then that wav is convered back to mp3, will the both mp3s be the same?
- gts   mp3 to wav to mp3 to wav same?   Feb 27 2003, 14:42
- - CiTay   No. MP3 encoding is a lossy process. The WAV that ...   Feb 27 2003, 14:46
- - gts   Well the first conversion from wav to mp3 removes ...   Feb 27 2003, 15:05
- - Xenion   QUOTE (gts @ Feb 27 2003 - 03:05 PM)Well the ...   Feb 27 2003, 15:15
- - X-Fixer   QUOTE (gts @ Feb 27 2003 - 09:05 PM)Well the ...   Feb 27 2003, 15:26
- - gts   QUOTE theoretically this could work this way. (sec...   Feb 27 2003, 23:30
- - gts   QUOTE original wav => mp3 =lossy agreed QUOTE m...   Feb 27 2003, 23:33
- - Messer   Codec does not remove anything. It rounds some val...   Feb 27 2003, 23:39
- - gts   Thank you. What search words will find the topic? ...   Feb 27 2003, 23:43
- - Mac   I'll chip in because it took me a few goes of ...   Feb 27 2003, 23:46
- - Messer   I'd try "reencoding". This is for e...   Feb 27 2003, 23:49
- - gts   Thank you!   Feb 28 2003, 00:01
- - CiTay   QUOTE Codec does not remove anything. It rounds so...   Feb 28 2003, 00:21
- - gts   QUOTE It doesn't care if the WAV was previousl...   Feb 28 2003, 00:30
- - Messer   QUOTE (CiTay @ Feb 28 2003 - 01:21 AM)QUOTE C...   Feb 28 2003, 00:35
- - gts   QUOTE that essential process in lossy compression ...   Feb 28 2003, 00:37
- - fewtch   There's a simple way to test this. Encode a ....   Feb 28 2003, 00:42
- - Artemis3   If you record a CD into a cassette tape, then use ...   Feb 28 2003, 02:14
- - gts   QUOTE If you record a CD into a cassette tape, the...   Feb 28 2003, 02:29
- - rjamorim   QUOTE (gts @ Feb 27 2003 - 08:30 PM)In the jp...   Feb 28 2003, 02:39
- - gts   QUOTE But reducing the amount of colors is only ON...   Feb 28 2003, 02:44
- - rjamorim   QUOTE (gts @ Feb 27 2003 - 10:44 PM)but the p...   Feb 28 2003, 03:05
- - andrew3199   I think we can all agree that there is some loss w...   Feb 28 2003, 04:29
- - rjamorim   QUOTE (andrew3199 @ Feb 28 2003 - 12:29 AM)fo...   Feb 28 2003, 04:36
- - dreamliner77   QUOTE I perceived the decay of plucked notes on an...   Feb 28 2003, 05:19
|- - makarov   An analogy to JPEG lossy image compression was mad...   Jan 30 2005, 07:33
- - NeoRenegade   gts, with regards to your JPEG analogy... you refe...   Mar 2 2003, 23:14
- - kdo   QUOTE (rjamorim @ Feb 28 2003 - 03:05 AM)Code...   Mar 3 2003, 00:37
- - aggies11   Not to resurrect a dead thread or anything, but it...   Aug 21 2003, 02:13
- - Doctor   aggies: no. Lossy sound encoding is not like you ...   Aug 21 2003, 02:54
- - phong   An interesting thought, but probably academic. MP...   Aug 21 2003, 02:58
- - AtaqueEG   QUOTE (dreamliner77 @ Feb 27 2003, 11:19 PM)R...   Aug 21 2003, 03:18
- - 2Bdecided   QUOTE (aggies11 @ Aug 21 2003, 01:13 AM)Could...   Aug 21 2003, 10:33
- - 2Bdecided   In reply to the original question, the simplistic ...   Aug 21 2003, 10:39
- - sld   (Redundant post, sorry)   Aug 21 2003, 10:40
- - Vietwoojagig   I remember long time ago, there was a technology c...   Aug 21 2003, 12:53
- - 2Bdecided   DCC used (what would become) MPEG-1 layer I. You ...   Aug 21 2003, 13:24
- - aggies11   Thanks for the quick replies. Very informative ind...   Aug 21 2003, 17:06
- - phong   The answer to the first question is "no...   Aug 21 2003, 19:29
- - Doctor   Yawn. phong: I think you are wrong on both counts...   Aug 22 2003, 03:29
- - phong   I think I mis-specified which questions I was answ...   Aug 22 2003, 03:46
- - Canar   QUOTE (2Bdecided @ Aug 21 2003, 01:33 AM)I do...   Aug 22 2003, 04:08
- - bexx   Isn't wavpacklossy/hybrid whatever its called ...   Aug 22 2003, 04:29
- - sublimelouie   easiest way to think of it, its like xeroxing a xe...   Aug 22 2003, 04:51
- - aggies11   Sublime: easiest way to think of it, its like xero...   Aug 22 2003, 05:26
- - 2Bdecided   This reply is in response to no one in particular....   Aug 22 2003, 11:05
- - Gabriel   QUOTE IIRC FhG looked at this. You could call it a...   Aug 22 2003, 11:23
- - smg   QUOTE (2Bdecided @ Aug 22 2003, 06:05 AM)This...   Aug 22 2003, 14:46
- - phong   QUOTE Do it enough, you can reduce the complexity ...   Aug 22 2003, 16:13
- - ErikS   QUOTE (Gabriel @ Aug 22 2003, 11:23 AM)Now, t...   Aug 22 2003, 16:50
- - Zilva   Cosine transformation is NOT LOSSY. After transofm...   Sep 10 2003, 10:06
- - tigre   QUOTE (Zilva @ Sep 10 2003, 01:06 AM)Cosine t...   Sep 10 2003, 10:35
- - 2Bdecided   QUOTE (Zilva @ Sep 10 2003, 09:06 AM)Cosine t...   Sep 10 2003, 11:11
- - MugFunky   wow.. old post. ("holy thread resurrection, b...   Jan 31 2005, 04:06
- - h.tuehn   I don't want to correct anything MugFunky or m...   Jan 31 2005, 07:16
RSS Lo-Fi Version Time is now: 3rd June 2015 - 23:24
