foo_podcatcher
nausea
post Jan 31 2009, 17:25
This is a component for subscribing to, downloading, and playing podcasts in foobar2000.
Get versions 0.1.2 (beta) and 0.2.1 (beta) here: download foo_podcatcher
To manage your podcast subscriptions open the Podcatcher UI from the View->Podcatch Manager menu. Here you can add new feed URLs and create playlists. The component will parse RSS 2.0 and Atom 1.0 feeds.
In the preferences you can set the download path and the time period over which to download from each feed automatically. The component will check for new podcasts 15 seconds after foobar2000 starts and then again every 60 minutes.
Known issue for 0.1.6+: Group headings don't respect UI colours and fonts reliably.
Recent changes:
  • 0.2.0: Import and export OPML feed lists. (Hold the shift key when opening the foobar2000 File menu to see the hidden import/export menu options.)
  • 0.2.0: Create filter-based Podcatcher autoplaylists. (First filter the Feed Manager dialog by assigning a keyboard shortcut to the hidden 'Filter Podcatcher Feed Manager' main-menu command, and then click 'P'.)
  • 0.2.0: Backend now uses a database, meaning that if there is a crash, your feeds' and casts' statuses are not lost to the mists of time.
  • 0.2.1: Fix for potential crash when updating feeds.
Anyway, let me know if you find any problems, and post any feeds which don't seem to work.
Note for 0.2.x - this version has major changes to the way that feed and cast statuses are stored, so it is possible and likely that stability has regressed. As always, help me help you by submitting those crash reports!
This post has been edited by nausea: Jan 8 2011, 22:54
El Noire
post Feb 8 2009, 00:08
Great plugin! I just did what the author recommended, put the Podcast Path to the "Podcast" folder (I created) in my library (D:/Music/Podcast) and created an autoplaylist "Podcast" (* HAS podcast) and everything turned out fine cool.gif I noticed the downloaded music files (I only subscribed to audio-podcasts) all have embedded art so I will try to display those in the Curacao elpplaylist ^^ Thanks for the great work!
- nausea   foo_podcatcher   Jan 31 2009, 17:25
- - thecircusfreak   It works! I also like the ability of playing t...   Jan 31 2009, 18:40
- - ojdo   Great plugin! A bug report: The podcatcher UI...   Feb 1 2009, 00:42
|- - nausea   QUOTE (ojdo @ Jan 31 2009, 23:42) A bug r...   Feb 1 2009, 21:30
- - thecircusfreak   Some feedback: -The time you create the podcast p...   Feb 1 2009, 01:07
- - lyh   how to delete the program list? I remove the feed...   Feb 1 2009, 10:17
- - predator29   u roxx mate! the greatest plugin ever a lit...   Feb 1 2009, 10:47
- - nausea   Thanks for the feedback guys. I've released a ...   Feb 1 2009, 21:20
|- - predator29   QUOTE (nausea @ Feb 1 2009, 21:20) 1) I g...   Feb 2 2009, 09:37
- - El Noire   Great plugin! I just did what the author recom...   Feb 8 2009, 00:08
- - aliumalik   Can you make it so that the plugin updates the pla...   Feb 10 2009, 15:35
- - nausea   Version 0.0.3 released. Main change is to the down...   Feb 21 2009, 13:25
|- - --pv--   QUOTE (nausea @ Feb 21 2009, 14:25) alium...   Feb 21 2009, 21:09
- - 2E7AH   "remove selected" button removes only on...   Feb 22 2009, 02:29
- - predator29   i'm not sitting in front of my box, but i have...   Feb 22 2009, 12:51
|- - nausea   QUOTE (predator29 @ Feb 22 2009, 11:51) i...   Feb 22 2009, 13:02
- - bellingman   Something is seriously wrong here... I set the do...   Mar 3 2009, 20:20
- - Jonas Nyrup   #bellingsman Alle three feeds works for me. It mig...   Mar 3 2009, 23:19
- - bellingman   Not for me. No matter how long I wait, nothing hap...   Mar 3 2009, 23:24
- - bellingman   I see the problem now: it does not recognize my pr...   Mar 3 2009, 23:39
- - David Heath   Has anyone tried combining this with some kind of ...   Mar 12 2009, 14:04
- - Jleagle   Can anyone explain why this podcast wont work? ht...   Mar 14 2009, 14:37
|- - nausea   QUOTE (Jleagle @ Mar 14 2009, 13:37) Can ...   Mar 14 2009, 18:54
- - Jleagle   Thanks alot, id love to uninstall iTunes and use t...   Mar 14 2009, 18:59
- - aliumalik   nausea did you get my PM?   Mar 15 2009, 00:11
- - thecircusfreak   QUOTE (nausea @ Feb 21 2009, 14:25) preda...   Mar 17 2009, 10:36
- - ingver   awesome plugin. I've been waiting for this.. A...   Apr 1 2009, 21:50
- - tpijag   Small buglet. I've XP set with Foobar in the ...   Apr 7 2009, 20:33
- - DaveTheStalker   Forgive my ignorance with using Foobar, I'm ne...   Apr 9 2009, 22:05
- - tpijag   Very new to podcasts with Foobar myself....but are...   Apr 9 2009, 22:43
|- - DaveTheStalker   QUOTE (tpijag @ Apr 9 2009, 16:43) Very n...   Apr 9 2009, 22:49
- - tpijag   No terry   Apr 9 2009, 22:51
- - nausea   Updated to version 0.0.4 (alpha). Implemented som...   Apr 23 2009, 23:24
- - halabund   Why is the seek bar often disabled in foo_podcatch...   May 9 2009, 22:40
- - ingver   halabund, Umm are u sure those are downloaded trac...   May 9 2009, 22:46
- - halabund   Yes, I am talking about downloaded tracks. The ve...   May 10 2009, 20:24
- - ingver   well maybe the podcathcer ignores the fact that th...   May 12 2009, 16:49
- - Xezzy   It would be nice to have tag mappings on the go. A...   Aug 21 2009, 15:53
- - Cablespider   I started using this today. This is hot! Thank...   Aug 21 2009, 21:43
- - nausea   Released version 0.0.5. Available from all the usu...   Sep 2 2009, 05:19
- - nausea   Now at version 0.0.6. This version has a fix for ...   Sep 12 2009, 12:11
- - thecircusfreak   I get object not found errors with both versions ....   Sep 14 2009, 18:12
- - halabund   I'm glad this useful component is still being ...   Sep 14 2009, 21:50
- - nausea   thecircusfreak: I get the "object not found...   Sep 14 2009, 23:40
- - thecircusfreak   Ouch, didnt think the feed was to blame! Now ...   Sep 15 2009, 13:17
|- - nausea   QUOTE (thecircusfreak)Ouch, didnt think the feed w...   Sep 15 2009, 14:03
- - thecircusfreak   duh, it was the download dir at the local drive wh...   Sep 15 2009, 16:22
- - halabund   nausea, The seekbar problem seems to only be pres...   Sep 15 2009, 22:20
|- - nausea   Cool. I'll see what there is that can be done ...   Sep 16 2009, 00:06
- - nausea   There's a serious bug in foo_podcatcher v0.0.7...   Sep 16 2009, 10:38
- - thecircusfreak   also created playlists contain items from other su...   Sep 16 2009, 16:32
- - nausea   Thanks for reporting. Fixed in the just released v...   Sep 16 2009, 21:07
|- - LoopinFool   Nausea, First of all, thanks for creating a reall...   Sep 25 2009, 23:25
- - Benji99   I finally installed this plugin a couple days ago ...   Sep 26 2009, 07:21
- - LoopinFool   Here's my main feature suggestion: I'd li...   Oct 2 2009, 21:36
- - nausea   LoopinFool: The next major update will probably ha...   Oct 2 2009, 22:27
- - ingver   Glad to see it updated! Only 2 things i notice...   Oct 3 2009, 19:23
|- - nausea   QUOTE (ingver @ Oct 3 2009, 18:23) Glad t...   Oct 3 2009, 21:04
- - ingver   http://ws.audioscrobbler.com/2.0/user/Ingver/podca...   Oct 4 2009, 15:35
- - Benji99   Problem with unicode podcasts? I just added a fren...   Oct 12 2009, 20:34
|- - LoopinFool   QUOTE (Benji99 @ Oct 12 2009, 13:34) Furt...   Oct 13 2009, 00:14
|- - Benji99   QUOTE (LoopinFool @ Oct 12 2009, 19:14) Q...   Oct 13 2009, 02:51
|- - sirDaniel   I found that plugin is very nice. Actually i am su...   Nov 6 2009, 13:09
- - nausea   Released another quick update. Main change is that...   Nov 9 2009, 14:22
|- - LoopinFool   QUOTE (nausea @ Nov 9 2009, 07:22) sirDan...   Nov 9 2009, 18:52
- - nausea   Updated the first post with details of version 0.1...   Nov 12 2009, 00:46
- - q-stankovic   Hello nausea, since the podcatch manager doesn...   Nov 15 2009, 19:51
- - kaoruAngel   Hey nausea, just now trying to get into the podcas...   Nov 16 2009, 00:58
|- - nausea   Released v0.1.0b. Only change is fix for a crash b...   Nov 20 2009, 11:03
- - skyfish   Doesn't work with foobar v.1.0b   Nov 27 2009, 06:44
- - Hank H.   Thanks a lot for the great work, it's really a...   Nov 27 2009, 11:57
- - odyssey   Please update it to work with foobar2000 1.0   Dec 7 2009, 13:41
- - nausea   QUOTE I have one problem though: Whenever I shut d...   Dec 11 2009, 01:57
|- - Hank H.   QUOTE (nausea @ Dec 10 2009, 19:57) QUOTE...   Dec 14 2009, 18:51
|- - Hank H.   Well, about the write protection: Windows Explorer...   Dec 14 2009, 20:03
- - q-stankovic   Nice update and happy to see the component on foob...   Dec 13 2009, 11:56
- - StuPC   I'm running foobar 1.0 beta 4 on Windows 7 and...   Dec 13 2009, 20:53
- - q-stankovic   Two posts before yours: QUOTE (nausea @ Dec ...   Dec 13 2009, 21:50
|- - odyssey   QUOTE (q-stankovic @ Dec 13 2009, 21...   Dec 13 2009, 23:16
|- - nausea   QUOTE (odyssey @ Dec 13 2009, 22:16) How ...   Dec 13 2009, 23:35
- - Yirkha   Because many other components don't use the ol...   Dec 13 2009, 23:30
- - sirDaniel   I see the plugin is impoving continuously, i like ...   Dec 15 2009, 13:56
- - Hank H.   I chose the application install folder for my conf...   Dec 17 2009, 15:43
- - RockandRoll19   Hey! Thank you so much for your contribution t...   Dec 20 2009, 02:32
- - ubiquitousnfunky   Hey! foo_podcatcher is great! I have some ...   Dec 20 2009, 19:46
- - halabund   There is one thing that is slightly annoying about...   Dec 24 2009, 11:35
|- - nausea   QUOTE (halabund @ Dec 24 2009, 10:35) Som...   Dec 24 2009, 14:45
- - halabund   Ah, OK, that's great! Didn't notice t...   Dec 24 2009, 14:59
- - nausea   Versions 0.1.2 and 0.1.5 for foobar2000 v0.9.6 and...   Dec 25 2009, 03:39
- - q-stankovic   QUOTE (nausea @ Dec 25 2009, 03:39) ... b...   Dec 25 2009, 19:24
|- - nausea   QUOTE (q-stankovic @ Dec 25 2009, 18...   Dec 26 2009, 00:03
|- - halabund   QUOTE (nausea @ Dec 26 2009, 01:03) QUOTE...   Dec 26 2009, 00:06
- - halabund   How can we turn on the "cover art" displ...   Dec 25 2009, 21:14
- - q-stankovic   For me it seems to be removed also. Here one issu...   Dec 25 2009, 21:39
- - q-stankovic   QUOTE (nausea @ Dec 26 2009, 00:03) This ...   Dec 26 2009, 01:02
- - q-stankovic   Hello nausea! Here a behaviour that seems ...   Dec 26 2009, 16:13
- - AndyL   Many thanks for the updates!   Dec 27 2009, 11:34
- - wolver1ne   Finally! Have been looking for ever for a podc...   Dec 27 2009, 12:58
- - halabund   A chance for a minor improvement is making the ...   Dec 27 2009, 16:34
- - Hank H.   Request: It would be great to be able to sort the...   Jan 1 2010, 19:23
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 28th July 2015 - 10:29
