DarkOne, Columns UI + PSS configuration
tedgo
post Jan 31 2009, 13:05
A Columns UI + Panel Stack Splitter + WSH Panel mod configuration
Actual screenshot with a link to a list of required files, changelog and downloadlink:
http://tedgo.deviantart.com/
This post has been edited by Yirkha: Jun 3 2009, 11:01
Reason for edit: Updated by request.
yevi
post Feb 25 2009, 15:58
I understand.
Did i tell you that this is the best foobar build ever (at least for me)?
I know how to change and add rating to files and database but what those ratings do?
This post has been edited by yevi: Feb 25 2009, 16:06
- tedgo   DarkOne   Jan 31 2009, 13:05
- - lokioki   I love this theme :3 e. and it works like a charm ...   Jan 31 2009, 13:21
- - tedgo   Thank you   Feb 1 2009, 00:29
- - Jakuchu   Thank you, extremely nice config.   Feb 1 2009, 09:14
- - tedgo   I corrected an error in the english user guide tod...   Feb 1 2009, 14:33
- - tedgo   UPDATE 2009-02-04 - Fixed: Forgot the queue index ...   Feb 4 2009, 12:16
- - lokioki   There was problems in this ? Thanks ^^   Feb 4 2009, 12:21
- - tedgo   Minor problems, very smaaaaaal problems   Feb 4 2009, 12:24
- - SpanishSpawn   Your config is brilliant...good work Hope to see...   Feb 6 2009, 00:30
- - tedgo   Thank you I have some ideas for a new config base...   Feb 6 2009, 01:09
- - Nighthawk_NL   Hii Tedgo, Keep up the good work. Maybe it's...   Feb 6 2009, 09:36
- - tedgo   You can get artist pictures and album art with foo...   Feb 6 2009, 10:40
- - Nighthawk_NL   Hi Tedgo, many thanks for your quick reply. I will...   Feb 6 2009, 11:48
- - tedgo   My first DarkOne MiniPlayer outline: I could com...   Feb 7 2009, 00:25
- - Godsh0t   I'm having trouble getting the background of t...   Feb 7 2009, 01:55
- - tedgo   @Godshot I can't ignore this. Maybe my user gu...   Feb 7 2009, 14:28
- - oxyd21   Hi, my foobar looses the buttons regularly. So th...   Feb 7 2009, 19:43
- - tedgo   The Panel Stack Splitter is a bit buggy, especiall...   Feb 7 2009, 20:16
- - oxyd21   seems to work now. thanks   Feb 7 2009, 20:42
- - tedgo   I'm working on version 1.4 now (will be releas...   Feb 21 2009, 21:07
- - Dan Popescu   I would replace all of them by "_" - it...   Feb 21 2009, 21:51
- - 77Pat   I just installed this and like it a lot, but there...   Feb 21 2009, 22:42
- - tedgo   If the %artist% tag is filled with AC/DC then your...   Feb 21 2009, 22:49
- - Nighthawk_NL   Hi Tedgo, I have a question about the automatic l...   Feb 21 2009, 23:07
- - tedgo   You mean when there's no lyric available, righ...   Feb 21 2009, 23:17
- - Nighthawk_NL   Hi Tedgo, Thanks it works now and the new layout ...   Feb 22 2009, 00:33
- - tedgo   When you sort which panel? Do you mean the filters...   Feb 22 2009, 00:40
- - 77Pat   I have music in the playlist. Here is a screensho...   Feb 22 2009, 02:19
- - Takaji   Thank you very much for this. It's always grea...   Feb 22 2009, 04:04
- - RavenSoft   does the album art plugin not play nice with windo...   Feb 22 2009, 05:59
- - tedgo   @77Pat As is can see, there are no images in ELPla...   Feb 22 2009, 09:16
- - tedgo   @Takaji I made a quick (and maybe dirty) solution ...   Feb 22 2009, 12:26
- - szczepek   Thank you very much for DarkOne 1.3. I'm watin...   Feb 22 2009, 12:39
- - tedgo   Thanks   Feb 22 2009, 12:42
- - 77Pat   Thank you. The problem was that I had originally ...   Feb 22 2009, 16:06
- - SubV   Tedgo, your config is the best. Thank you very mu...   Feb 23 2009, 23:57
- - yevi   I've just downloaded this theme and trying to ...   Feb 24 2009, 12:37
- - yevi   Is it possible some how to sort album list so the ...   Feb 24 2009, 12:55
- - tedgo   To your first question: How are your pictures name...   Feb 24 2009, 15:35
- - yevi   QUOTE (tedgo @ Feb 24 2009, 16:35) To you...   Feb 24 2009, 16:15
|- - ton   Hi tedgo, May I ask you a question ? I am rather n...   Feb 24 2009, 16:33
- - tedgo   @yevi Now i see the point. You could easily solve ...   Feb 24 2009, 16:38
- - tedgo   @ton The display is made in a panel stack splitter...   Feb 24 2009, 16:44
|- - ton   QUOTE (tedgo @ Feb 24 2009, 07:44) @ton T...   Feb 24 2009, 19:29
- - yevi   "new preset" worked perfectly. A questio...   Feb 24 2009, 17:08
- - tedgo   1st question: Just delete the [%tracknumber% - ] p...   Feb 24 2009, 17:49
- - tedgo   Do you have raised your DPI-settings in windows fr...   Feb 24 2009, 19:47
|- - ton   QUOTE (tedgo @ Feb 24 2009, 10:47) Do y...   Feb 24 2009, 20:03
|- - ton   QUOTE (tedgo @ Feb 24 2009, 10:47) But...   Feb 24 2009, 22:43
- - tedgo   It shouldn't decrease performance or something...   Feb 24 2009, 20:22
- - yevi   tedgo I have some requests for you to consider in ...   Feb 24 2009, 21:52
- - tedgo   1.) No, not in DarkOne. Maybe in another skin late...   Feb 24 2009, 22:26
- - tedgo   Do you have a total tracks tag in your files?   Feb 24 2009, 22:44
|- - ton   QUOTE (tedgo @ Feb 24 2009, 13:44) Do you...   Feb 24 2009, 23:05
- - tedgo   On yevi's screenshot there is a thing that mad...   Feb 24 2009, 23:06
|- - ton   QUOTE (tedgo @ Feb 24 2009, 14:06) @ton S...   Feb 24 2009, 23:33
- - tedgo   You should be able to do it for the whole playlist...   Feb 24 2009, 23:40
- - yevi   QUOTE (tedgo @ Feb 24 2009, 23:26) Btw. i...   Feb 25 2009, 00:03
- - tedgo   I'm talking about the big cover view (by click...   Feb 25 2009, 01:40
- - yevi   Another question (I know i am giving you a head ...   Feb 25 2009, 09:14
- - tedgo   Couldn't happen with the default grouping sche...   Feb 25 2009, 09:35
- - yevi   QUOTE (tedgo @ Feb 25 2009, 10:35) Couldn...   Feb 25 2009, 10:22
- - yevi   Another thing that is bothering me a lot: In my ...   Feb 25 2009, 11:10
- - tedgo   To the last post: This happens because, if there i...   Feb 25 2009, 11:35
- - yevi   QUOTE (tedgo @ Feb 25 2009, 12:35) To the...   Feb 25 2009, 12:58
- - tedgo   Go to: Preferences --> Playlist Switcher and d...   Feb 25 2009, 13:02
- - yevi   In next version, can you recolor the menu(file, e...   Feb 25 2009, 15:46
- - tedgo   I can't change the colours for the menu bar be...   Feb 25 2009, 15:55
- - yevi   I understand. Did i tell you that this is the bes...   Feb 25 2009, 15:58
- - yevi   And another question regarding artist's pictur...   Feb 25 2009, 16:16
- - tedgo   The image has to have the EXACT name as the artist...   Feb 25 2009, 16:48
- - yevi   QUOTE (tedgo @ Feb 25 2009, 17:48) The im...   Feb 25 2009, 16:58
- - tedgo   Would you please be a little more detailed? What i...   Feb 25 2009, 17:20
- - yevi   LOL Nevermind, I am an IDIOT.   Feb 25 2009, 17:52
- - yevi   QUOTE (tedgo @ Feb 25 2009, 02:40) To the...   Feb 25 2009, 18:22
- - tedgo   I suggested the %directoryname% as ALTERNATIVE sol...   Feb 25 2009, 18:39
- - yevi   I've found a bug or something like it: If i tr...   Feb 26 2009, 10:13
- - tedgo   That bug is already known. It is caused by the Pan...   Feb 26 2009, 10:27
- - yevi   Another suggestion (maybe it's already exits a...   Feb 26 2009, 16:27
- - tedgo   No sorry, the context menu is really suitable enou...   Feb 26 2009, 16:36
- - tedgo   I updated the skin to v1.4. See changelog and deta...   Feb 26 2009, 19:15
- - szczepek   Lovely. Thanx.   Feb 26 2009, 19:43
- - yevi   QUOTE (tedgo @ Feb 26 2009, 20:15) I upda...   Feb 26 2009, 21:57
- - Falstaff   the compact mode rocks, congratulations tedgo   Feb 26 2009, 22:03
- - tedgo   Thanks to all   Feb 26 2009, 22:53
- - tedgo   UPDATE to v1.4.1: 2009-02-27 I wasn't satisfie...   Feb 27 2009, 13:29
- - yevi   Is there a simple way to update? cause every time ...   Feb 27 2009, 14:54
- - tedgo   No sorry, no easy way to update and hold all your ...   Feb 27 2009, 15:18
- - Nighthawk_NL   Hi Tedgo, I have a weird problem. In the playlist...   Feb 28 2009, 19:54
- - tedgo   The NG Playlists "group header" isn...   Feb 28 2009, 20:04
|- - Nighthawk_NL   Hi Tedgo, Thanks for your reply but I did not cha...   Mar 1 2009, 14:24
- - tedgo   I updated the download last night. Since some unex...   Mar 1 2009, 10:31
- - tedgo   How is the name of the folder the album is stored ...   Mar 1 2009, 14:36
- - lokioki   http://theo.foobar2000.com.cn/projects/fb2k-0_9_6-...   Mar 2 2009, 16:12
- - tedgo   Oh, that's strange. I hope T.P Wang will host ...   Mar 2 2009, 16:19
- - lokioki   Works Thanks for sending it   Mar 2 2009, 16:56
- - tedgo   Btw. i fixed the links to foo_uie_tabs 0.2.7 and W...   Mar 2 2009, 17:13
- - tedgo   UPDATE TO v1.4.2 (I hope it is the last update for...   Mar 3 2009, 00:48
- - yevi   QUOTE (tedgo @ Mar 3 2009, 01:48) UPDATE ...   Mar 3 2009, 13:15
- - tedgo   If you've already setup your artist pictures, ...   Mar 3 2009, 14:20
7 Pages V   1 2 3 > »
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 30th January 2015 - 07:49
