DarkOne, Columns UI + PSS configuration
tedgo
post Jan 31 2009, 13:05
A Columns UI + Panel Stack Splitter + WSH Panel mod configuration
Actual screenshot with a link to a list of required files, changelog and downloadlink:
http://tedgo.deviantart.com/
This post has been edited by Yirkha: Jun 3 2009, 11:01
Reason for edit: Updated by request.
tedgo
post Feb 24 2009, 16:44
@ton
The display is made in a panel stack splitter.
You can easily copy the content of the display script.
Download my skin --> import the skin (BUT SAVE YOURS FIRST BY EXPORT TO FCL FOR LATER RELOAD!!!) --> Right-click on the display --> Splitter Settings --> and copy the content to clipboard or to a txt-file.
Then, after reloading your own configuration, insert a panel stack splitter, place it where you want it to be placed and insert the copied code wink.gif.
But you need the DarkOne.ttf installed to display the same font!
(Is included in the download folder)
This post has been edited by tedgo: Feb 24 2009, 16:47
ton
post Feb 24 2009, 19:29
QUOTE (tedgo @ Feb 24 2009, 07:44) *
@ton
Tedgo, thanks for your very quick reply.
I tried it and although I got it showing up and working, the words and numbers are not displayed correctly. For instance I see "Tot" instead of Total and I don't see the number for the Total tracks. Moreover the height of the numbers is a bit to large. The bottom part is left out. Must have something to do with the font size I think, but I cannot find out where to change it, due to being a newbie I think. Tried it with your configuration and my own b.t.w.
Probably it is a bit too much for me at the moment.
- tedgo   DarkOne   Jan 31 2009, 13:05
- - lokioki   I love this theme :3 e. and it works like a charm ...   Jan 31 2009, 13:21
- - tedgo   Thank you   Feb 1 2009, 00:29
- - Jakuchu   Thank you, extremely nice config.   Feb 1 2009, 09:14
- - tedgo   I corrected an error in the english user guide tod...   Feb 1 2009, 14:33
- - tedgo   UPDATE 2009-02-04 - Fixed: Forgot the queue index ...   Feb 4 2009, 12:16
- - lokioki   There was problems in this ? Thanks ^^   Feb 4 2009, 12:21
- - tedgo   Minor problems, very smaaaaaal problems   Feb 4 2009, 12:24
- - SpanishSpawn   Your config is brilliant...good work Hope to see...   Feb 6 2009, 00:30
- - tedgo   Thank you I have some ideas for a new config base...   Feb 6 2009, 01:09
- - Nighthawk_NL   Hii Tedgo, Keep up the good work. Maybe it's...   Feb 6 2009, 09:36
- - tedgo   You can get artist pictures and album art with foo...   Feb 6 2009, 10:40
- - Nighthawk_NL   Hi Tedgo, many thanks for your quick reply. I will...   Feb 6 2009, 11:48
- - tedgo   My first DarkOne MiniPlayer outline: I could com...   Feb 7 2009, 00:25
- - Godsh0t   I'm having trouble getting the background of t...   Feb 7 2009, 01:55
- - tedgo   @Godshot I can't ignore this. Maybe my user gu...   Feb 7 2009, 14:28
- - oxyd21   Hi, my foobar looses the buttons regularly. So th...   Feb 7 2009, 19:43
- - tedgo   The Panel Stack Splitter is a bit buggy, especiall...   Feb 7 2009, 20:16
- - oxyd21   seems to work now. thanks   Feb 7 2009, 20:42
- - tedgo   I'm working on version 1.4 now (will be releas...   Feb 21 2009, 21:07
- - Dan Popescu   I would replace all of them by "_" - it...   Feb 21 2009, 21:51
- - 77Pat   I just installed this and like it a lot, but there...   Feb 21 2009, 22:42
- - tedgo   If the %artist% tag is filled with AC/DC then your...   Feb 21 2009, 22:49
- - Nighthawk_NL   Hi Tedgo, I have a question about the automatic l...   Feb 21 2009, 23:07
- - tedgo   You mean when there's no lyric available, righ...   Feb 21 2009, 23:17
- - Nighthawk_NL   Hi Tedgo, Thanks it works now and the new layout ...   Feb 22 2009, 00:33
- - tedgo   When you sort which panel? Do you mean the filters...   Feb 22 2009, 00:40
- - 77Pat   I have music in the playlist. Here is a screensho...   Feb 22 2009, 02:19
- - Takaji   Thank you very much for this. It's always grea...   Feb 22 2009, 04:04
- - RavenSoft   does the album art plugin not play nice with windo...   Feb 22 2009, 05:59
- - tedgo   @77Pat As is can see, there are no images in ELPla...   Feb 22 2009, 09:16
- - tedgo   @Takaji I made a quick (and maybe dirty) solution ...   Feb 22 2009, 12:26
- - szczepek   Thank you very much for DarkOne 1.3. I'm watin...   Feb 22 2009, 12:39
- - tedgo   Thanks   Feb 22 2009, 12:42
- - 77Pat   Thank you. The problem was that I had originally ...   Feb 22 2009, 16:06
- - SubV   Tedgo, your config is the best. Thank you very mu...   Feb 23 2009, 23:57
- - yevi   I've just downloaded this theme and trying to ...   Feb 24 2009, 12:37
- - yevi   Is it possible some how to sort album list so the ...   Feb 24 2009, 12:55
- - tedgo   To your first question: How are your pictures name...   Feb 24 2009, 15:35
- - yevi   QUOTE (tedgo @ Feb 24 2009, 16:35) To you...   Feb 24 2009, 16:15
|- - ton   Hi tedgo, May I ask you a question ? I am rather n...   Feb 24 2009, 16:33
- - tedgo   @yevi Now i see the point. You could easily solve ...   Feb 24 2009, 16:38
- - tedgo   @ton The display is made in a panel stack splitter...   Feb 24 2009, 16:44
|- - ton   QUOTE (tedgo @ Feb 24 2009, 07:44) @ton T...   Feb 24 2009, 19:29
- - yevi   "new preset" worked perfectly. A questio...   Feb 24 2009, 17:08
- - tedgo   1st question: Just delete the [%tracknumber% - ] p...   Feb 24 2009, 17:49
- - tedgo   Do you have raised your DPI-settings in windows fr...   Feb 24 2009, 19:47
|- - ton   QUOTE (tedgo @ Feb 24 2009, 10:47) Do y...   Feb 24 2009, 20:03
|- - ton   QUOTE (tedgo @ Feb 24 2009, 10:47) But...   Feb 24 2009, 22:43
- - tedgo   It shouldn't decrease performance or something...   Feb 24 2009, 20:22
- - yevi   tedgo I have some requests for you to consider in ...   Feb 24 2009, 21:52
- - tedgo   1.) No, not in DarkOne. Maybe in another skin late...   Feb 24 2009, 22:26
- - tedgo   Do you have a total tracks tag in your files?   Feb 24 2009, 22:44
|- - ton   QUOTE (tedgo @ Feb 24 2009, 13:44) Do you...   Feb 24 2009, 23:05
- - tedgo   On yevi's screenshot there is a thing that mad...   Feb 24 2009, 23:06
|- - ton   QUOTE (tedgo @ Feb 24 2009, 14:06) @ton S...   Feb 24 2009, 23:33
- - tedgo   You should be able to do it for the whole playlist...   Feb 24 2009, 23:40
- - yevi   QUOTE (tedgo @ Feb 24 2009, 23:26) Btw. i...   Feb 25 2009, 00:03
- - tedgo   I'm talking about the big cover view (by click...   Feb 25 2009, 01:40
- - yevi   Another question (I know i am giving you a head ...   Feb 25 2009, 09:14
- - tedgo   Couldn't happen with the default grouping sche...   Feb 25 2009, 09:35
- - yevi   QUOTE (tedgo @ Feb 25 2009, 10:35) Couldn...   Feb 25 2009, 10:22
- - yevi   Another thing that is bothering me a lot: In my ...   Feb 25 2009, 11:10
- - tedgo   To the last post: This happens because, if there i...   Feb 25 2009, 11:35
- - yevi   QUOTE (tedgo @ Feb 25 2009, 12:35) To the...   Feb 25 2009, 12:58
- - tedgo   Go to: Preferences --> Playlist Switcher and d...   Feb 25 2009, 13:02
- - yevi   In next version, can you recolor the menu(file, e...   Feb 25 2009, 15:46
- - tedgo   I can't change the colours for the menu bar be...   Feb 25 2009, 15:55
- - yevi   I understand. Did i tell you that this is the bes...   Feb 25 2009, 15:58
- - yevi   And another question regarding artist's pictur...   Feb 25 2009, 16:16
- - tedgo   The image has to have the EXACT name as the artist...   Feb 25 2009, 16:48
- - yevi   QUOTE (tedgo @ Feb 25 2009, 17:48) The im...   Feb 25 2009, 16:58
- - tedgo   Would you please be a little more detailed? What i...   Feb 25 2009, 17:20
- - yevi   LOL Nevermind, I am an IDIOT.   Feb 25 2009, 17:52
- - yevi   QUOTE (tedgo @ Feb 25 2009, 02:40) To the...   Feb 25 2009, 18:22
- - tedgo   I suggested the %directoryname% as ALTERNATIVE sol...   Feb 25 2009, 18:39
- - yevi   I've found a bug or something like it: If i tr...   Feb 26 2009, 10:13
- - tedgo   That bug is already known. It is caused by the Pan...   Feb 26 2009, 10:27
- - yevi   Another suggestion (maybe it's already exits a...   Feb 26 2009, 16:27
- - tedgo   No sorry, the context menu is really suitable enou...   Feb 26 2009, 16:36
- - tedgo   I updated the skin to v1.4. See changelog and deta...   Feb 26 2009, 19:15
- - szczepek   Lovely. Thanx.   Feb 26 2009, 19:43
- - yevi   QUOTE (tedgo @ Feb 26 2009, 20:15) I upda...   Feb 26 2009, 21:57
- - Falstaff   the compact mode rocks, congratulations tedgo   Feb 26 2009, 22:03
- - tedgo   Thanks to all   Feb 26 2009, 22:53
- - tedgo   UPDATE to v1.4.1: 2009-02-27 I wasn't satisfie...   Feb 27 2009, 13:29
- - yevi   Is there a simple way to update? cause every time ...   Feb 27 2009, 14:54
- - tedgo   No sorry, no easy way to update and hold all your ...   Feb 27 2009, 15:18
- - Nighthawk_NL   Hi Tedgo, I have a weird problem. In the playlist...   Feb 28 2009, 19:54
- - tedgo   The NG Playlists "group header" isn...   Feb 28 2009, 20:04
|- - Nighthawk_NL   Hi Tedgo, Thanks for your reply but I did not cha...   Mar 1 2009, 14:24
- - tedgo   I updated the download last night. Since some unex...   Mar 1 2009, 10:31
- - tedgo   How is the name of the folder the album is stored ...   Mar 1 2009, 14:36
- - lokioki   http://theo.foobar2000.com.cn/projects/fb2k-0_9_6-...   Mar 2 2009, 16:12
- - tedgo   Oh, that's strange. I hope T.P Wang will host ...   Mar 2 2009, 16:19
- - lokioki   Works Thanks for sending it   Mar 2 2009, 16:56
- - tedgo   Btw. i fixed the links to foo_uie_tabs 0.2.7 and W...   Mar 2 2009, 17:13
- - tedgo   UPDATE TO v1.4.2 (I hope it is the last update for...   Mar 3 2009, 00:48
- - yevi   QUOTE (tedgo @ Mar 3 2009, 01:48) UPDATE ...   Mar 3 2009, 13:15
- - tedgo   If you've already setup your artist pictures, ...   Mar 3 2009, 14:20
7 Pages V   1 2 3 > »
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 27th April 2015 - 00:46
