? In the place of track length on last track
Emperor5353
post Dec 25 2008, 20:57
When I load a cue file all the tracks load fine except for the last track....instead of track length I get a question mark....I cannot access tagging sites and it wont let me convert flacs to .mpcs.....any ideas??
Replies (1 - 9)
Jan S.
post Dec 25 2008, 21:14
Group: Admin
Where? foobar?
Embedded or external?
Does it happen with all cue sheets?
Please post an example (the cue sheet).
Emperor5353
post Dec 25 2008, 21:20
Well, this is odd...not sure what I did but I closed out Foobar and restarted and everything works fine now??
Boiled Beans
post Dec 26 2008, 17:04
QUOTE (Emperor5353 @ Dec 26 2008, 04:20) *
I have similar error, on the Sony Ericsson Disc2Phone software. I would use foobar to convert FLAC files to MP3 files. The last MP3 always displayed track time as ?.
But it didn't bother me much since it displayed the correct time on the phone.
Pavlo Vovk
post Jan 31 2009, 04:28
I have the same problem for a very long time already.... OK. I have a CUE and APE files (separately) on my laptop.
1) Playing CUE with APE inside from laptop - fine.
2) Converting APE to FLAC. Changing APE -> FLAC in CUE file. Playing CUE from laptop - fine.
3) Copying FLAC and CUE to folder on external hard drive. Playing CUE - last track is "?", total time unknown.
4) Copying APE to the external hard drive.. Changing back in CUE: FLAC -> APE. PLaying CUE - fine!
5) ODD STUFF! Again, changing back APE -> FLAC in CUE. Playing CUE - FINE!
6) Removing APE, playing CUE - still fine! The problem is gone!
Foobar2000 0.9.6.2.
This post has been edited by Pavlo Vovk: Jan 31 2009, 04:31
rrlagic
post Apr 14 2010, 05:53
QUOTE (Emperor5353 @ Dec 26 2008, 04:57) *
I have manually deleted lines with "FLAGS DCP" and my cue-s get fixed. In other cue-s it was enough to open-save cue with text editor.
This post has been edited by rrlagic: Apr 14 2010, 05:58
hlloyge
post Apr 14 2010, 08:25
I had similar problem the other day with some cue files which wanted to be played ONLY from original folder where unpacked. When moved to work folder, the questionmark showed.
I didn't really know what happened. I will post details next time.
nmccrina
post Apr 14 2010, 21:23
I have this problem too. To clarify, I am using single FLAC files + external cuesheet generated from EAC. On some discs (not all) the last track doesn't have a duration, even though there is nothing obviously different about the cuesheet. Also, the one song affected by this that I've played so far did not get uploaded to Last.fm via the audioscrobbler component. I'll try a few more to see if this is consistent.
Edit: Confirmed. The affected songs do not get uploaded to last.fm.
This post has been edited by nmccrina: Apr 14 2010, 21:35
nmccrina
post Apr 14 2010, 21:51
Ha! I have a solution. Find the track in your library, right click the file, and click "Properties". Go to the "Properties" tab, then click the "Tools" button. There will be an option that says "Reload Info". Click this, and the song should now have a duration instead of a ?.
Nanonyma
post Jan 19 2013, 16:35
Ok, I know, this thread is quite old, but as I've stumbled in with the same problem with the questionmark on the last track of some flac-images, I wanna give my solution to all other future visitors.
I've found out, that this seems to be a problem with hidden command characters in the cue-sheet, which are there cause the file went through a unix/linux system. So you have to clean the cue-sheet and all will be fine. To do this automatically, you can make a batch-file to tell a tiny cl-tool Unix2Dos http://waterlan.home.xs4all.nl/dos2unix.html to do the work.
That's all.
RSS Lo-Fi Version Time is now: 26th January 2015 - 07:59
