"Silent audio computer", ...how to build a pc for music listening
NumLOCK
post Feb 24 2003, 09:57
Neutrino G-RSA developer
Hi all,
What about sharing our personal experiences with building silent, flexible home audio/entertainment devices? wink.gif
This was my first time - and the choice of components was not easy ! Very often, you can't have both speed and silence. Here's what I did.
I've just built a PC on a following basis:
- ABIT KD7-E mainboard (VIA KT333 chipset / allows cpu multiplier setting / voltage lowering in BIOS / down to 1.1V in 0.025V increments).
- AMD Thoroughbred 2000+ 1.65V cpu (multiplier is unlocked out-of-the-box).
- flower CPU heatsink -- it rocks: depending on cpu voltage, there's no need for a fan !!
- 256MB of cheap PC266 ddr sdram
- nice black midi-tower case without PSU.
- special, ultra-quiet 300W PSU
- 7200RPM, 80GB WD HDD
- ATI Radeon 9000pro with VGA, DVI- and TV-out
The following components were modified:
- cpu was underclocked and heavily under-volted (running as 1500+ @ 1.2V). Can also run ~1200MHz @ 1.1V.
- Radeon 9000 pro was modified for passive cooling
- northbridge fan of the motherboard was replaced with passive cooling solution.
- HDD was put in silent 5 1/4'' acoustic armor.
- the case was stuffed with custom acoustic damping material.
The special components were mostly Zalman stuff, found on:
- http://www.quietpc.com/cpucool2.php (CPU flower cooler)
- http://www.quietpc.com/psu.html (silent PSU)
- http://www.quietpc.com/silentdrive.html (HDD armor)
- http://www.quietpc.com/vgamb.php (VGA and M/B heatsinks).
Results:
- there are two fans in the system (PSU & CPU), one of which can be deactivated.
- runs smoothly at 1500+, 1.2V, ~40 Celsius with big, silent 600RPM fan to blow some air into the case (no fan is fine also: ~42-55 Celsius depending on cpu voltage).
- pc is near-silent (just about "undetectable" from 30cm distance).
Additional thoughts:
- I'll add a soundcard and a LAN card (no fans, so no problem)
- I'm still hesitating about what DVD-rom drive I'll put in there.
- I've put the 7200RPM HDD because that's all I had.. but maybe I'll replace it with a 5400RPM (or lower) one.
- operating system not chosen yet.
Epilogue / What I learned:
- I'm VERY satisfied with this silent PC.
- In the future I'll be careful about the noise when buying components for other pc's.
- There's no way I'd buy a GeForce FX (think noise..)
- Silent machines need more expensive cooling components, but I think it's really worth it !
This post has been edited by NumLOCK: Feb 24 2003, 11:01
Try Leeloo Chat at http://leeloo.webhop.net
Delirium
post Apr 19 2003, 02:53
I'm a bit late on this thread, but I'll add a few of my experiences. I have a Zalman 5100CU CPU fan/heatsink combo, and it's nearly silent in my setup. The fan is variable-speed (manually variable with a knob, not heat-sensing, though you could probably rig up something ify ou wanted), and I keep it around 2200 rpm, which is inaudible when the case is closed.
My hard drives are also nearly silent with the case closed. I have 3 5400 RPM hard drive I can't hear at all (I manually spin them up and down with hdparm and I can't tell the difference), and a 7200 RPM hard drive that I can only hear when it's spinning up, not during normal operation. The 7200 is a Western Digital, the others are Maxtors. This seems hit-or-miss though; my brother has a 7200 Maxtor that's incredibly loud (makes a noticeable noise when reading/writing data). If yours is loud and you use Linux, read through hdparm's manpage; most modern hard drives have multiple modes of operation, and you can move it to a slower head-motion mode that will significantly decrease noise (by default they're on the noisiest/fastest setting, but if it's just a drive for MP3s or movies, you don't need anything near the max speed).
I also have some entirely silent 1800 RPM case fans.
The PSU I'm much less happy about. I bought the 300-watt PSU from quietpc.com, and it's still fairly loud. To be fair, it is quite a high-quality PSU; it's one of the few 300-watt PSUs approved for use on Athlon Thunderbirds, because its power is very consistent and doesn't get dirty under load. It has no trouble handling my Athlon T-Bird 1.33 GHz with four hard drives and a CD-RW, which would require a 350-400 Watt PSU from most manufacturers. It also is much quieter than the stock PSU I had before. But it's far from silent, and still a bit louder than I'd like considering that I sleep in the same room as it. Unfortunately, the quieter ones seem to be far more expensive.
On that note, does anyone have any particular recommendations for quiet power supplies that are reasonably-priced?
- NumLOCK   "Silent audio computer"   Feb 24 2003, 09:57
- - Hanky   Sorry but I have no knowledge at all on this, but ...   Feb 24 2003, 10:05
- - NumLOCK   I haven't tried water cooling, it should be fi...   Feb 24 2003, 10:12
- - rc55   @Hanky: I don't meant to be rude, but if you d...   Feb 24 2003, 10:28
- - wdekler   @Numlock You can get your money PSU back if you wa...   Feb 24 2003, 10:38
- - NumLOCK   QUOTE (rc55 @ Feb 24 2003 - 10:28 AM)@Numlock...   Feb 24 2003, 10:43
- - NumLOCK   QUOTE (wdekler @ Feb 24 2003 - 10:38 AM)@Numl...   Feb 24 2003, 10:58
- - AiZ   Hello everybody, As long as your hard drive suppo...   Feb 24 2003, 11:02
- - niktheblak   The following are some of my personal experiences ...   Feb 24 2003, 11:24
- - NumLOCK   @AiZ At least for my HDD, the most "disturbi...   Feb 24 2003, 11:39
- - Gabriel   I think that electrical tape means the IDE/floppy ...   Feb 24 2003, 11:45
- - niktheblak   Sorry, I didn't know the exact english express...   Feb 24 2003, 11:52
- - NumLOCK   I see.. it seems to be that ugly kind of red tape...   Feb 24 2003, 12:03
- - Annuka   I managed to silence my workstation some months ag...   Feb 24 2003, 12:06
- - n68   yup... i don`t belive in quieting each compo...   Feb 24 2003, 12:16
- - dgover2   Just a couple of notes, don't know if they wil...   Feb 24 2003, 12:24
- - KikeG   QUOTE (n68 @ Feb 24 2003 - 12:16 PM)i don...   Feb 24 2003, 12:58
- - NumLOCK   QUOTE (dgover2 @ Feb 24 2003 - 12:24 PM)Now i...   Feb 24 2003, 13:54
- - niktheblak   QUOTE (NumLOCK @ Feb 24 2003 - 01:03 PM)I see...   Feb 24 2003, 14:04
- - userXYZ   I can recommend the following components out of my...   Feb 24 2003, 14:33
- - DonP   A former employer set up the training rooms with m...   Feb 24 2003, 14:59
- - NumLOCK   QUOTE (DonP @ Feb 24 2003 - 02:59 PM)A former...   Feb 24 2003, 15:09
- - Kim_C   Here's a review of fanless ProSilence 350 PSU....   Feb 24 2003, 15:14
- - fileman   Hello everybody, I'm using a water cooled sys...   Feb 24 2003, 15:18
- - GeSomeone   QUOTE (AiZ @ Feb 24 2003 - 11:02 AM)As long a...   Feb 24 2003, 17:56
- - aabxx   I would say my solution is as good as it gets.. my...   Feb 24 2003, 18:11
- - Artemis3   This is only a reminder: Hard Disks and CD Drives ...   Feb 24 2003, 18:36
- - niktheblak   QUOTE (Artemis3 @ Feb 24 2003 - 07:36 PM)This...   Feb 24 2003, 23:25
- - Patsoe   QUOTE (aabxx @ Feb 24 2003 - 06:11 PM)I would...   Feb 25 2003, 00:48
- - ff123   I'm going to upgrading my system in the coming...   Feb 25 2003, 03:27
- - DonP   QUOTE (NumLOCK @ Feb 24 2003 - 06:09 AM)lengt...   Feb 25 2003, 03:59
- - SometimesWarrior   QUOTE (ff123 @ Feb 24 2003 - 06:27 PM)4. NVid...   Feb 25 2003, 07:30
- - SometimesWarrior   My current dual-XP1600+ machine is so noisy I can ...   Feb 25 2003, 07:45
- - ff123   QUOTE (SometimesWarrior @ Feb 24 2003 - 10:30...   Feb 25 2003, 08:10
- - Continuum   QUOTE (aabxx @ Feb 24 2003 - 06:11 PM)If this...   Feb 25 2003, 08:19
- - KikeG   QUOTE (ff123 @ Feb 25 2003 - 03:27 AM)1. Athl...   Feb 25 2003, 09:25
- - Gabriel   Hard drive considerations: A current 7200rpm driv...   Feb 25 2003, 09:31
- - Gabriel   Just found this Fanless heatsink with fluid inside...   Feb 25 2003, 09:47
- - arman68   QUOTE (Gabriel @ Feb 25 2003 - 08:31 AM)A goo...   Feb 25 2003, 09:48
- - Gabriel   PII, PIII and PPro were unable to automatically th...   Feb 25 2003, 10:15
- - Patsoe   In light of the fact that were talking audio compu...   Feb 25 2003, 14:35
- - Trelane   Nobody's mentioned laptops yet! My PC (wh...   Feb 25 2003, 15:27
- - NumLOCK   I have a japanese Panasonic T1 laptop which has no...   Feb 25 2003, 16:45
- - SometimesWarrior   Sorry for resurrecting the thread, but this site i...   Mar 6 2003, 15:32
- - JEN   OK... I have decided to join in with the cat theme...   Apr 10 2003, 20:36
- - Joseph   http://www.alienware.com has some pretty small li...   Apr 10 2003, 21:37
- - atici   I recently discovered something which I liked a lo...   Apr 10 2003, 21:46
- - cd-rw.org   I think I will switch from this server cased behem...   Apr 10 2003, 22:26
- - CiTay   QUOTE (atici @ Apr 10 2003 - 10:46 PM)I recen...   Apr 10 2003, 22:46
- - ff123   QUOTE (atici @ Apr 10 2003 - 12:46 PM)I recen...   Apr 11 2003, 02:40
- - atici   Yeah I know I think the usual brute force soluti...   Apr 11 2003, 02:56
- - fewtch   I think I'll be transplanting my PC to a new c...   Apr 11 2003, 03:03
- - SometimesWarrior   QUOTE (fewtch @ Apr 10 2003 - 07:03 PM)I thin...   Apr 11 2003, 03:34
- - wynlyndd   I was reading somewhere about how two fans placed ...   Apr 11 2003, 03:44
- - SometimesWarrior   QUOTE (atici @ Apr 10 2003 - 06:56 PM)BTW do ...   Apr 11 2003, 03:46
- - SometimesWarrior   QUOTE (wynlyndd @ Apr 10 2003 - 07:44 PM)I wa...   Apr 11 2003, 03:54
- - DonP   One of the guys on a US tv show "The Screensa...   Apr 11 2003, 04:14
- - ff123   QUOTE (SometimesWarrior @ Apr 10 2003 - 06:46...   Apr 11 2003, 04:25
- - atici   I don't understand. When I first boot my compu...   Apr 11 2003, 04:39
- - fileman   I upgraded again (in cooling, not in power ;-) Th...   Apr 11 2003, 05:12
- - ff123   QUOTE (atici @ Apr 10 2003 - 07:39 PM)I don...   Apr 11 2003, 05:40
- - SometimesWarrior   QUOTE (DonP @ Apr 10 2003 - 08:14 PM)One of t...   Apr 11 2003, 06:03
- - 12345   It's wonderful to se people put dollars, ...   Apr 11 2003, 08:07
- - JEN   QUOTE (12345 @ Apr 11 2003 - 08:07 AM)It...   Apr 11 2003, 13:48
- - DonP   QUOTE (SometimesWarrior @ Apr 11 2003 - 12:03...   Apr 11 2003, 14:42
- - CiTay   QUOTE (ff123 @ Apr 11 2003 - 03:40 AM)Wow, th...   Apr 11 2003, 14:43
- - KikeG   QUOTE (DonP @ Apr 11 2003 - 02:42 PM)Most of ...   Apr 11 2003, 14:59
- - DonP   QUOTE (KikeG @ Apr 11 2003 - 08:59 AM)Anyway,...   Apr 11 2003, 16:02
- - KikeG   See my previous edit.   Apr 11 2003, 16:12
- - Patsoe   QUOTE (JEN @ Apr 11 2003 - 01:48 PM)Interesti...   Apr 11 2003, 16:21
- - JEN   QUOTE (Patsoe @ Apr 11 2003 - 04:21 PM)QUOTE ...   Apr 11 2003, 17:58
- - DonP   QUOTE (JEN @ Apr 11 2003 - 11:58 AM)So, maybe...   Apr 11 2003, 18:44
- - JEN   I just installed the Silent Drive Housing for the ...   Apr 17 2003, 16:02
- - JEN   I have an xp1900+. I tried unlocking it some time...   Apr 17 2003, 23:58
- - SometimesWarrior   QUOTE (JEN @ Apr 17 2003 - 03:58 PM)I have an...   Apr 18 2003, 17:32
- - JEN   How do I find out which Athlon XP 1900+ I have?   Apr 18 2003, 20:49
- - Delirium   I'm a bit late on this thread, but I'll ad...   Apr 19 2003, 02:53
- - SometimesWarrior   QUOTE (Delirium @ Apr 18 2003 - 06:53 PM)On t...   Apr 19 2003, 03:43
- - SometimesWarrior   QUOTE (JEN @ Apr 18 2003 - 12:49 PM)How do I ...   Apr 19 2003, 04:05
- - JEN   QUOTE (SometimesWarrior @ Apr 19 2003 - 04:05...   Apr 19 2003, 10:14
- - CiTay   QUOTE (JEN @ Apr 19 2003 - 11:14 AM)there is ...   Apr 19 2003, 14:12
- - SometimesWarrior   QUOTE (CiTay @ Apr 19 2003 - 06:12 AM)QUOTE (...   Apr 20 2003, 05:25
- - SometimesWarrior   QUOTE (JEN @ Apr 19 2003 - 02:14 AM)QUOTE (So...   Apr 20 2003, 06:00
- - JEN   Thanks for all the advice everyone especialy Somet...   Apr 20 2003, 10:20
- - JEN   What would be better? 1. modding the PSU with 2 s...   Apr 21 2003, 21:27
- - CiTay   QUOTE (JEN @ Apr 21 2003 - 10:27 PM)1. moddin...   Apr 21 2003, 22:13
- - JEN   QUOTE (CiTay @ Apr 21 2003 - 10:13 PM)QUOTE R...   Apr 23 2003, 11:14
- - CiTay   QUOTE (JEN @ Apr 23 2003 - 12:14 PM)Is this t...   Apr 23 2003, 13:24
- - spoon   QUOTE So, my question is, if I leave the vcore @ 1...   Apr 23 2003, 14:54
- - ff123   QUOTE (CiTay @ Apr 23 2003 - 04:24 AM)QUOTE (...   Apr 23 2003, 15:58
- - Annuka   QUOTE (SometimesWarrior @ Apr 19 2003 - 04:43...   Apr 23 2003, 17:04
- - bodhy   Hi all... Maybe some of you will be interested in ...   Apr 23 2003, 22:22
- - JEN   Is the Seagate Barracuda 80Gb 7200rpm UDMA100 Hard...   Apr 26 2003, 17:22
- - CiTay   QUOTE (JEN @ Apr 26 2003 - 06:22 PM)Is the Se...   Apr 26 2003, 17:48
- - ff123   QUOTE (JEN @ Apr 26 2003 - 08:22 AM)Is the Se...   Apr 26 2003, 17:52
- - JEN   I am planning on making a CPU exhaust duct to the ...   Apr 30 2003, 23:22
- - SometimesWarrior   QUOTE (JEN @ Apr 30 2003 - 03:22 PM)As the ca...   May 1 2003, 02:35
- - SometimesWarrior   QUOTE (Annuka @ Apr 23 2003 - 09:04 AM)QUOTE ...   May 1 2003, 02:52
- - ff123   Today I put isolating screws on my case fan, and s...   May 1 2003, 06:03
- - Delirium   QUOTE (ff123 @ Apr 30 2003 - 10:03 PM)Today I...   May 1 2003, 06:08
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 2nd February 2015 - 01:05
