Public MP3 Listening Test @ 128 kbps - FINISHED
Sebastian Mares
post Nov 24 2008, 22:30
The much awaited results of the Public, MP3 Listening Test @ 128 kbps are ready - partially. So far, I only uploaded an overall plot along with a zoomed version. The details will be available in the next few days. You can also download the encryption key along with the submitted results on the results page that is located here: http://www.listening-tests.info/mp3-128-1/results.htm
The results show that all encoders are tied on first place, except l3enc which of course comes out last being the low anchor.
What is interesting to see is how the MP3 codec actually evolved since its first days (l3enc was the first MP3 software encoder back in 1994 when it was released) and how it is still competitive with newer formats like AAC or Ogg Vorbis.
Another very interesting thing, which was also one of the goals for this test, is that Fraunhofer and especially Helix, which both outperform LAME in terms of encoding speed, are still very competitive. While statistically being tied to LAME on first place, Helix actually even received a higher rating than LAME 3.98.2 - and this at 90x encoding speed! Even FhG received a slightly higher score at least against LAME 3.97 which was the recommended encoder by the Hydrogenaudio community for a long time. But again, statistically, they are all tied so there is no quality winner.
The quality at 128 kbps is very good and MP3 encoders improved a lot since the last test. This was the last test conducted by me at this bitrate. It's time to move to bitrates like 96 kbps or 80 kbps.
Here is a zoomed version of the plot showing the competitors only and leaving out the low anchor l3enc.
Finally, I would like to thank everyone who participated!
EDIT: Whoops, the link to the results was pointing to the 64 kbps multiformat test by mistake. Corrected now.
This post has been edited by Sebastian Mares: Nov 24 2008, 22:46
http://listening-tests.hydrogenaudio.org/sebastian/
JasonQ
post Nov 26 2008, 06:18
Good test. Good to see that Helix had a solid showing. What I take away from this is that Lame 3.98 is rock solid. It seems to be a bit more consistent then 3.97, and should probably be used instead. If you want a fast encoder, Helix or Fraunhofer will do the trick with no worries.
This post has been edited by JasonQ: Nov 26 2008, 06:28
- Sebastian Mares   Public MP3 Listening Test @ 128 kbps - FINISHED   Nov 24 2008, 22:30
- - /mnt   Wow am really shocked, Helix (Xing) has performed ...   Nov 24 2008, 22:52
- - Sebastian Mares   I kept telling you guys that the results will be q...   Nov 24 2008, 22:56
- - Neasden   Does that make Helix the new recommended MP3 encod...   Nov 24 2008, 23:00
|- - /mnt   QUOTE (Neasden @ Nov 24 2008, 23:00) Does...   Nov 24 2008, 23:05
- - Neasden   Yes it is, I just noticed it! I can't bel...   Nov 24 2008, 23:14
- - greynol   I don't think open source has anything to do w...   Nov 24 2008, 23:14
- - Sebastian Mares   If you submitted results, I recommend you look at ...   Nov 24 2008, 23:14
- - halb27   I am curious about the detailed results as my inte...   Nov 24 2008, 23:22
- - Neasden   They are all techincally tied, but Helix outperfor...   Nov 24 2008, 23:25
|- - halb27   QUOTE (Neasden @ Nov 25 2008, 00:25) ... ...   Nov 25 2008, 00:43
|- - Pio2001   Excuse me, but what is the correspondance between ...   Nov 25 2008, 00:48
|- - lvqcl   QUOTE (Pio2001 @ Nov 25 2008, 02:48) Excu...   Nov 25 2008, 01:16
- - Canar   Thank you very much Sebastian. We have some things...   Nov 24 2008, 23:51
- - DigitalDictator   This is indeed surprising. I'm sure I've s...   Nov 24 2008, 23:56
|- - halb27   QUOTE (DigitalDictator @ Nov 25 2008, 00...   Nov 25 2008, 00:11
||- - Pio2001   AAAAAAAAAAAARRRRRRRRGGGGHGHHHHHH !! They...   Nov 25 2008, 00:34
|- - melomaniac   I analyzed my results and the ranking of the encod...   Nov 25 2008, 09:19
|- - Pio2001   QUOTE (melomaniac @ Nov 25 2008, 09:19) A...   Nov 25 2008, 14:04
- - ZinCh   This is only 128k tests, so Helix in the winner in...   Nov 24 2008, 23:59
- - Neasden   I encoded a few tracks using -V150 (VBR range 0-15...   Nov 25 2008, 00:07
- - greynol   >Helix can be recomended for 128k encoding. Ho...   Nov 25 2008, 00:10
- - kwanbis   Wow (even if the difference between LAME 3.98.2 an...   Nov 25 2008, 00:42
- - krabapple   Sorry, it's not clear to me how many subjects ...   Nov 25 2008, 01:02
- - Pio2001   Thanks, I analyzed my own results. That's what...   Nov 25 2008, 01:37
- - Raiden   QUOTE (Pio2001 @ Nov 25 2008, 01:34) Oh, ...   Nov 25 2008, 02:12
|- - Canar   QUOTE (Raiden @ Nov 24 2008, 17:12) agree...   Nov 25 2008, 02:32
- - sld   Regarding statistics... the confidence intervals w...   Nov 25 2008, 04:51
|- - Sebastian Mares   QUOTE (sld @ Nov 25 2008, 04:51) Regardin...   Nov 25 2008, 09:02
- - Squeller   Is this claim correct? There has been no improveme...   Nov 25 2008, 08:46
- - halb27   Zoomed view is formally correct, but has a tendenc...   Nov 25 2008, 09:19
|- - Squeller   QUOTE (halb27 @ Nov 25 2008, 10:19) Zoome...   Nov 25 2008, 09:28
|- - halb27   QUOTE (Squeller @ Nov 25 2008, 10:28) Bas...   Nov 25 2008, 09:44
|- - melomaniac   QUOTE (Squeller @ Nov 25 2008, 09:28) Abo...   Nov 25 2008, 09:46
|- - sld   QUOTE (Squeller @ Nov 25 2008, 16:28) Bas...   Nov 25 2008, 20:05
- - memomai   Just confused. Helix worse than lame, Helix better...   Nov 25 2008, 10:08
|- - halb27   QUOTE (memomai @ Nov 25 2008, 11:08) Just...   Nov 25 2008, 10:30
|- - Alexxander   QUOTE (halb27 @ Nov 25 2008, 10:30) ... W...   Nov 25 2008, 10:55
|- - halb27   QUOTE (Alexxander @ Nov 25 2008, 11:55) ....   Nov 25 2008, 13:04
- - Alexxander   Before anything I have to thank Sebastian again fo...   Nov 25 2008, 10:44
- - muaddib   It is not good to conclude, from the results of th...   Nov 25 2008, 11:15
|- - Alexxander   QUOTE (muaddib @ Nov 25 2008, 11:15) It i...   Nov 25 2008, 12:37
- - Jan S.   Wouldn't it be possible to compare the varianc...   Nov 25 2008, 12:33
|- - Sebastian Mares   QUOTE (Jan S. @ Nov 25 2008, 12:33) Would...   Nov 25 2008, 12:44
- - robert   I would be more interested in Quartile, instead of...   Nov 25 2008, 13:01
|- - kwanbis   QUOTE (robert @ Nov 25 2008, 12:01) I wou...   Nov 25 2008, 13:06
|- - Sebastian Mares   QUOTE (robert @ Nov 25 2008, 13:01) I wou...   Nov 25 2008, 14:47
- - westgroveg   If anything the test shows samples where LAME need...   Nov 25 2008, 13:55
|- - Alex B   QUOTE (westgroveg @ Nov 25 2008, 14:55) I...   Nov 25 2008, 14:51
|- - uart   QUOTE (Alex B @ Nov 25 2008, 05:51) In ge...   Nov 25 2008, 16:30
- - /mnt   Just try some Metal tracks on Helix at V60, I guar...   Nov 25 2008, 15:19
- - Neasden   /mnt told me that Helix is not gapless, which is t...   Nov 25 2008, 16:07
|- - Synthetic Soul   QUOTE (Neasden @ Nov 25 2008, 15:07) /mnt...   Nov 25 2008, 17:21
|- - Alexxander   QUOTE (Synthetic Soul @ Nov 25 2008, 17:2...   Nov 25 2008, 18:27
- - DigitalDictator   Why would Helix struggle with metal? IIRC it also ...   Nov 25 2008, 16:15
|- - /mnt   QUOTE (DigitalDictator @ Nov 25 2008, 16...   Nov 25 2008, 16:38
- - Sebastian Mares   Well, one thing you have to consider is that Helix...   Nov 25 2008, 16:32
- - IgorC   I can confirm statements of /mnt . Helix isn't...   Nov 25 2008, 17:23
|- - ff123   QUOTE (IgorC @ Nov 25 2008, 08:23) I can ...   Nov 25 2008, 17:26
|- - Alex B   QUOTE (Sebastian Mares @ Nov 25 2008, 17...   Nov 25 2008, 17:34
|- - guruboolez   The 2 or 3 first seconds were already ignored in t...   Nov 25 2008, 18:04
|- - TechVsLife   @sebastian mares: thanks for the test! @gurub...   Nov 25 2008, 21:44
- - Sebastian Mares   QUOTE (ff123 @ Nov 25 2008, 17:26) QUOTE ...   Nov 25 2008, 18:08
|- - Alex B   QUOTE (Sebastian Mares @ Nov 25 2008, 19...   Nov 25 2008, 18:50
- - Jillian   I like the part where test result (quality and enc...   Nov 25 2008, 19:13
|- - halb27   QUOTE (Jillian @ Nov 25 2008, 20:13) I li...   Nov 25 2008, 21:13
- - Canar   QUOTE (Neasden @ Nov 25 2008, 07:07) /mnt...   Nov 25 2008, 19:34
- - Alex B   QUOTE (Synthetic Soul @ Nov 25 2008, 18:2...   Nov 25 2008, 19:36
- - Canar   Gapless encoding using Helix is possible by encodi...   Nov 25 2008, 19:51
- - Neasden   Do you mean having to "split" manually t...   Nov 25 2008, 20:06
|- - Alex B   QUOTE (Neasden @ Nov 25 2008, 21:06) Do y...   Nov 25 2008, 20:33
|- - guruboolez   QUOTE (Alex B @ Nov 25 2008, 21:33) Perso...   Nov 25 2008, 21:00
|- - Synthetic Soul   QUOTE (guruboolez @ Nov 25 2008, 20:00) T...   Nov 25 2008, 21:07
- - Sebastian Mares   Created 7 / 14 sample graphs... BTW, Tukey's ...   Nov 25 2008, 20:10
- - kwanbis   Sebastian, where it says, "The results are gr...   Nov 25 2008, 20:18
- - Bodhi   Great Job once again. Thank you Sebastian!   Nov 25 2008, 20:44
- - Neasden   QUOTE As Canar said, it's a hack. That alone ...   Nov 25 2008, 20:58
- - Neasden   unless someone patches Helix and release it with t...   Nov 25 2008, 21:05
- - Sebastian Mares   In case you are interested, here is a quick and di...   Nov 25 2008, 21:10
|- - halb27   QUOTE (Sebastian Mares @ Nov 25 2008, 22...   Nov 25 2008, 21:26
|- - benski   QUOTE (Sebastian Mares @ Nov 25 2008, 15...   Nov 25 2008, 21:50
- - Canar   The point I was trying to make was that though Hel...   Nov 25 2008, 21:14
- - Neasden   in this graph, LAME 3.98.2 seems the more stable e...   Nov 25 2008, 21:42
|- - Alex B   QUOTE (Neasden @ Nov 25 2008, 22:42) in t...   Nov 25 2008, 22:06
- - Sebastian Mares   The graphs for all samples are available on the re...   Nov 25 2008, 22:18
|- - halb27   QUOTE (Sebastian Mares @ Nov 25 2008, 23...   Nov 25 2008, 22:25
- - singaiya   Is anybody else not surprised that each contender ...   Nov 25 2008, 22:21
- - Sunhillow   Thank you for this great checkup, Sebastian! I...   Nov 25 2008, 22:35
- - Zilog Jones   I, as many others was also very surprised by the r...   Nov 25 2008, 22:53
|- - Sebastian Mares   QUOTE (Zilog Jones @ Nov 25 2008, 22:53) ...   Nov 25 2008, 23:24
- - sizetwo   Without adding fuel to the fire, I think its stran...   Nov 25 2008, 23:16
|- - sld   QUOTE (sizetwo @ Nov 26 2008, 06:16) Does...   Nov 26 2008, 05:14
|- - singaiya   QUOTE (sld @ Nov 25 2008, 20:14) You shou...   Nov 26 2008, 05:46
- - DigitalDictator   I've been asking this a couple of times, but I...   Nov 25 2008, 23:30
- - sizetwo   QUOTE Statistically, for the people who tested and...   Nov 25 2008, 23:34
|- - guruboolez   QUOTE (sizetwo @ Nov 26 2008, 00:34) Sorr...   Nov 25 2008, 23:52
|- - kwanbis   QUOTE (guruboolez @ Nov 25 2008, 22:52) N...   Nov 26 2008, 00:36
- - /mnt   I have posted some ABX logs and samples of tracks ...   Nov 26 2008, 00:49
- - JasonQ   Good test. Good to see that Helix had a solid sho...   Nov 26 2008, 06:18
- - sizetwo   QUOTE (guruboolez @ Nov 25 2008, 15:52) Q...   Nov 26 2008, 07:18
3 Pages V   1 2 3 >
RSS Lo-Fi Version Time is now: 31st January 2015 - 13:08
