24 Pages V  « < 20 21 22 23 24 >
Closed TopicStart new topic
Curaçao by Br3tt, Columns UI configuration
jazzthieve
post Mar 6 2009, 09:57
Post #526
It's the rating of the track. You can alter it in the lower left corner.
s3fr
post Mar 11 2009, 18:28
Post #527
I wanted to remove the lyrics panel, any pointers on how to do that?
Also the graphical browser doesnt show the album art on startup, it shows the coracao logo, how do i configure it to display otherwise?
bubi jackson
post Mar 11 2009, 18:56
Post #528
1. Replace the Lyric Show Panel in Columns UI Layout - but I woudn't do that, if I don't know what I am doing.
2. Check hide panel on start up and uncheck the one you would like to see.
http://www.last.fm/user/BubiJackson
Jny
post Mar 15 2009, 23:33
Post #529
Kameleon 1.2.0 :
- Playback Order button now remains good image on restart (memory added)
kmk
post Mar 19 2009, 20:20
Post #530
First of all, thank you for this beautiful theme which I am using since december (v.1.2a tweaked). I am currently editing it a little, which brings me to my two questions (which are pretty trite, I am afraid). Here it goes:
1.) I was able to get rid of the date shown in the header, however the album title still get's cut off. Where can I increase the width of the second line (in this case ending with the disc count) in order to use the free space? There is an awful lot of spacing and size related stuff in the "Group Header" script, and honestly I can't make heads and tails of it.
2.) I edited the script for the lyrics viewer (and solved the resulting conflicts with the keywords) to show some general information via the comment tag. It works pretty good so far, but I still need to put a blank line between the date/publisher line and the comment. I tried some stuff with symbols and queries but that is simply discarded instead of generating a blank line. There's got to be a simple code for this.
Thank you,
Chris
This post has been edited by kmk: Mar 19 2009, 20:37
jazzthieve
post Mar 19 2009, 23:01
Post #531
kmk, I use the lyrics panel the same way as you do, to enter a blank line I use:
$crlf()
kmk
post Mar 20 2009, 13:56
Post #532
Draconus
post Mar 22 2009, 03:16
Post #533
How can I read albumart from id3v2 tags? I think that ELPlaylist is showing images only from specified definition of __ART_PATH__ variable and not from embedded images in files.
This post has been edited by Draconus: Mar 22 2009, 03:40
Andreasvb
post Mar 22 2009, 03:36
Post #534
In the ELPlaylist settings, change __EMBEDDED_ART__ to 1.
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.8
Draconus
post Mar 22 2009, 03:45
Post #535
QUOTE (Andreasvb @ Mar 21 2009, 18:36) *
I don't have that variable. I added it, but doesn't work either.
Andreasvb
post Mar 22 2009, 04:08
Post #536
See here, http://www.hydrogenaudio.org/forums/index....st&p=604157
Draconus
post Mar 22 2009, 05:51
Post #537
QUOTE (Andreasvb @ Mar 21 2009, 19:08) *
I installed the tweaked version, now I see the album art on the list, but on the left panel, the cover display shows the default no cover image. Any solution?
Jack Schmaltz
post Apr 26 2009, 23:08
Post #538
hey again, wondering if i can get some help of someone in the know.
im trying to update the rating system so it doesnt write it to file tags & just reads to & from the Playback stats database.
i tried a script from this thread for this but it only semi works, it appears to write to file when you first click a star/rating then when you re-rate it (ie from 5 to 4) it unwrites the tag& reads the database, but then if i go to re-rate again it goes back to writing to tag & continiues to follow this behaviour.
heres the script that i currently have on it:
// Background
$drawrect(0,0,%_width%,%_height%,brushcolor-035-035-040 pencolor-null)
// Global
$puts(config_name,'curacao')
$puts(foo_path,'./')
// PerTrack
// .deb --- Rating System
// drawing RATING info
$if($stricmp('FOO_LASTFM',$left(%path%,10)),
$puts(rate.x,2)
$puts(rate.y,$sub(%_height%,70))
$imageabs2(0,0,0,0,0,0,$get(rate.x),$get(rate.y),$get(foo_path)'images/'$get(config_name)'/rating/set2/r0.png',alpha-128)
$puts(aa-fp,$year(%first_played%))
$puts(mm-fp,$month(%first_played%))
$puts(jj-fp,$day_of_month(%first_played%))
$puts(aa-lp,$year(%last_played%))
$puts(mm-lp,$month(%last_played%))
$puts(jj-lp,$day_of_month(%last_played%))
$ifgreater(%rating%,0,
$puts(rating,$if2($meta(rating),0))
$puts(no.set,1)
$ifgreater($get(aa-lp),$get(aa-fp),
$ifgreater($get(mm-lp),$get(mm-fp),
$puts(nb.aa,$sub($get(aa-lp),$get(aa-fp)))
$puts(nb.mm,$sub($get(mm-lp),$get(mm-fp)))
$ifgreater($get(jj-lp),$get(jj-fp),
$puts(nb.jj,$sub($get(jj-lp),$get(jj-fp)))
$puts(nb.mm,$sub($get(nb.mm),1))
$puts(nb.jj,$add($sub(30,$get(jj-fp)),$get(jj-lp)))
$puts(nb.aa,$sub($sub($get(aa-lp),$get(aa-fp)),1))
$puts(nb.mm,$add($sub(12,$get(mm-fp)),$get(mm-lp)))
$puts(nb.aa,0)
$puts(nb.mm,0)
$puts(nb.jj,0)
$puts(autorate.add,2)
$puts(autorate.nbdays.sub,30)
$puts(daterange, $add( $add($mul(365,$get(nb.aa)),$mul(30,$get(nb.mm))),$get(nb.jj)) )
$puts(fix,$div($get(daterange),$get(autorate.nbdays.sub)))
$if(%play_counter%,$puts(rating,$div(%play_counter%,$get(autorate.add))),$puts(rating,0))
$puts(rating,$sub($get(rating),$get(fix)))
$if($greater($get(rating),5),$puts(rating,5))
$if($greater(0,$get(rating)),$puts(rating,0))
$puts(no.set,3)
$puts(rate.x,2)
$imageabs2(0,0,0,0,0,0,$get(rate.x),$get(rate.y),$get(foo_path)'/images/'$get(config_name)'/rating/set2/r0.png',alpha-128)
$if(%_isplaying%,
$ifequal($get(rating),5,
$button($get(rate.x),$get(rate.y),0,0,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r5x.png',<not set>,TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),0,0,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r5.png',5,TOOLTIP:"Average")
$ifequal($get(rating),4,
$button($get(rate.x),$get(rate.y),0,14,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r4x.png',<not set>,TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),0,14,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r4.png',4,TOOLTIP:"Good")
$ifequal($get(rating),3,
$button($get(rate.x),$get(rate.y),0,28,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r3x.png',<not set>,TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),0,28,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r3.png',3,TOOLTIP:"Very Good")
$ifequal($get(rating),2,
$button($get(rate.x),$get(rate.y),0,42,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r2x.png',<not set>,TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),0,42,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r2.png',2,TOOLTIP:"Excellent")
$ifequal($get(rating),1,
$button($get(rate.x),$get(rate.y),0,56,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r1x.png',<not set>,TOOLTIP:"Reset")
$button($get(rate.x),$get(rate.y),0,56,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r1.png',1,TOOLTIP:"MegaHit")
$puts(rate.x,2)
$if(%isplaying%,
$button($get(rate.x),$get(rate.y),0,0,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/_r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r5.png',5,TOOLTIP:"Average")
$button($get(rate.x),$get(rate.y),0,14,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/_r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r4.png',4,TOOLTIP:"Good")
$button($get(rate.x),$get(rate.y),0,28,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/_r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r3.png',3,TOOLTIP:"Very Good")
$button($get(rate.x),$get(rate.y),0,42,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/_r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r2.png',2,TOOLTIP:"Excellent")
$button($get(rate.x),$get(rate.y),0,56,13,14,$get(foo_path)'images/'$get(config_name)'/rating/set2/_r'$get(rating)'.png',$get(foo_path)'images/'$get(config_name)'/rating/set2/r1.png',1,TOOLTIP:"MegaHit")
$imageabs2(0,0,0,0,0,0,$get(rate.x),$get(rate.y),$get(foo_path)'images/'$get(config_name)'/rating/set2/_r0.png',alpha-255)
// .fin --- Rating System
// MOOD TAG SET/UNSET to feed automatically auto-playlist for my portable device
$puts(x,1)
$puts(y,$sub(%_height%,86))
$imageabs2(14,14,0,0,0,0,$get(x),$get(y),$get(foo_path)'images/'$get(config_name)'/bt/mood_off.png',nokeepaspect)
$ifgreater(%MOOD%,0,
$button($get(x),$get(y),0,0,14,14,$get(foo_path)'images/'$get(config_name)'/bt/mood_on.png',$get(foo_path)'images/'$get(config_name)'/bt/mood_off.png',TAG:SET:MOOD:0,TOOLTIP:"Unset")
$button($get(x),$get(y),0,0,14,14,$get(foo_path)'images/'$get(config_name)'/bt/mood_off.png',$get(foo_path)'images/'$get(config_name)'/bt/mood_on.png',TAG:SET:MOOD:1,TOOLTIP:"Set")
// SKIP TAG SET/UNSET to skip unwanted tracks using the 'Skip Track' (foo_skip.dll) plugin
$puts(x,1)
$puts(y,$sub(%_height%,102))
$imageabs2(14,14,0,0,0,0,$get(x),$get(y),$get(foo_path)'images/'$get(config_name)'/bt/skip_off.png',nokeepaspect)
$ifgreater(%SKIP%,0,
$button($get(x),$get(y),0,0,14,14,$get(foo_path)'images/'$get(config_name)'/bt/skip_on.png',$get(foo_path)'images/'$get(config_name)'/bt/skip_off.png',TAG:SET:SKIP:0,TOOLTIP:"Unset")
$button($get(x),$get(y),0,0,14,14,$get(foo_path)'images/'$get(config_name)'/bt/skip_off.png',$get(foo_path)'images/'$get(config_name)'/bt/skip_on.png',TAG:SET:SKIP:1,TOOLTIP:"Set")
http://www.discogs.com/user/jackschmaltz
bubi jackson
post Apr 27 2009, 06:05
Post #539
Changing
$puts(no.set,1)
to
    $puts(rating,$if2(%rating%,0))
    $puts(no.set,1)
should work, I hope
Edit: typo
This post has been edited by bubi jackson: Apr 27 2009, 06:07
Jack Schmaltz
post Apr 27 2009, 14:49
Post #540
QUOTE (bubi jackson @ Apr 27 2009, 06:05) *
Changing
$puts(no.set,1)
to
    $puts(no.set,1)
should work, I hope
Edit: typo
Thanks for the response bubi, but i tried this & its still behaving as stated before, adding the rating meta then removing on re-rating & so on.
any other ideas anyone? i was pulling my hair out all weekend on this 1 but just cannot figure it out.
bubi jackson
post Apr 27 2009, 15:28
Post #541
hmmm......
I'm using this and the official Playback Statistics Plugin and it's working fine.
Edit: I compared the two scripts with nozepad+ again, and this is the only difference between yours and mine. I really don't know why it's not working.
This post has been edited by bubi jackson: Apr 27 2009, 15:31
Jack Schmaltz
post Apr 27 2009, 20:26
Post #542
QUOTE (bubi jackson @ Apr 27 2009, 15:28) *
hmmm......
how very odd, thanks for having a look for me though.
if its any help im on the latest version of foobar (although i tried this script previous to the update which had the same results) & version 2.1.8 of the official playback stats component.
Jny
post Apr 27 2009, 20:53
Post #543
QUOTE (Jny @ Mar 16 2009, 04:33) *
Kameleon 1.2.0 :
qwertz
post Apr 28 2009, 08:34
Post #544
QUOTE (Jack Schmaltz @ Apr 27 2009, 20:26) *
Do you have Quick Tagger with a rating script installed? Then a command like "1" in trackinfo will trigger both, the rating to database and the Quick Tagger script.
Jack Schmaltz
post Apr 28 2009, 11:53
Post #545
QUOTE (qwertz @ Apr 28 2009, 08:34) *
qwertz, your an absolute god send haha. exactly the problem, removed the quicktag component & the rating sytem now works like a dream.
it would appear i can now keep my hair haha
bubi jackson
post Apr 28 2009, 15:18
Post #546
Now I remember, there was something with identical script names. biggrin.gif
Thx qwertz for recalling this.
But Jack, you don't have to remove quicktag, just rename the rating scripts to other than 1-5 or delete only them (maybe you still want using QT for some other purpose)
Edit: typo
This post has been edited by bubi jackson: Apr 28 2009, 15:25
nikolai4ik
post May 10 2009, 17:59
Post #547
Can anyone help me please? :]
I want to replace default lyrics panel with last.fm biographies
, but when I right click and choose add panel, it covers up the whole left side
I've managed to do it in the bottom part of the config, everything went well.
Also, I've tried hard to change the sizes of the left panels with lyrics "zoomed in", but something always messes up.
Can I make them a bit bigger and keep cover art bigger than lyrics panel at the same time?
something like this
any tips would be much appreciated
bubi jackson
post May 10 2009, 20:41
Post #548
You have to replace the Lyrics Panel at Preferences-->Columns UI-->Layout
Or do it my way
nikolai4ik
post May 10 2009, 21:08
Post #549
stupid me :\
that was kind of easy, thanks a lot!
Jack Schmaltz
post May 14 2009, 05:00
Post #550
im wondering if anyone can help me out.
iv added a few mods to this theme, 1 of which is a filter via the panel stacker as shown here:
my question is, how can i adjust the width of the individual filters?
when i hover over them i get the resive icon but im unable to resize & iv tried changing different variables but to no avail.
im not fused if the width i change it too is permanent but would like to be able to adjust the size to my personal preference.
i added it by stacking 3 filters in a panel stacker & adding it to the playlists stack if that helps.
thanks for your time
This post has been edited by Jack Schmaltz: May 14 2009, 05:01
RSS Lo-Fi Version Time is now: 29th May 2015 - 20:09
