mpTrim Pro, Nice For Batch Trimming?
FormerlyDFox
post Nov 22 2008, 00:08
Group: Banned
I was looking at mpTrim Pro, is it nice to do it's automatic batch trimming?
I've seen it in action, just drop and drag a directory on it, and it goes to work.
I wondered how nice it worked, and if any quality loss of the mp3 would happen as a result of this, if everything was just left on the Default settings...
But from what I saw it's not just dealing with trimming, it's looking at tags, crc, cbr/vbr, cleaning up unrecognized info, volume/maybe gain adjustment, etc...
So I'm wondering if it might mess up mp3s too?
THANKS
FormerlyDFox
post Nov 24 2008, 01:16
Group: Banned
QUOTE (chromium @ Nov 23 2008, 11:08) *
Can mp3val repair the inconsistency created by mp3trim?
MP3Val can do repairs, the question is, is it capable of doing a proper repair, and do I trust it? Hmmm
Here are some screenshots:
Menu shows it can repair:
Repair run on a few mp3s. (Now those show as 'Fixed'):
Scan the mp3s over. (Now these show up as Ok)
Well all I can say is, here is mptrim pro someone selling an app for like $70, and it's supposedly causing problems, and then some opensource freeware software is detecting a problem and fixing it. All I can say is typically speaking it should be the other way around, LOL...
I don't know what to think and what to trust anymore...
I used these programs and none of them found a problem except MP3-Check with Gain Volume.
Ashampoo Music Studio 3
MP3Test
MP3-Check (Says all files Gain volume insufficient, shows all of them on 0)
MP3 Checker
MP3 Shield
For some reason the default settings on mptrim Pro are messing with the gain volume, all my mp3s I used mptrim pro on erased the gain volume to 0. I put it back to default with MP3Gain, and tested again with MP3Val thinking this might of been the problem, but MP3Val still reports the same problem.
Now it seems mprtrim is creating two problems:
1. Creating a wrong number of MPEG data bytes
2. Messing up the Gain Volume
Here's MP3-Check showing all the songs now with 0 for the gain volume: (Notice all the zeros to the left of C:)
This post has been edited by DasFox: Nov 24 2008, 01:23
chromium
post Nov 24 2008, 09:55
QUOTE (DasFox @ Nov 24 2008, 02:16) *
I wonder if it is mp3val that does the volume checks. Probably, it is some other utility that is used by the graphical front end you are using.
I cannot see how mp3trim could mess with gain settings, other than removing replay gain tags, or an mp3gain undo tag. That would indicate that it is changing/removing tags it does not like. Might be well possible, though.
Anyway, I am not sure whether these inconsistencies have any practical consequence that you can experience, though.
- DasFox   mpTrim Pro   Nov 22 2008, 00:08
- - DasFox   Someone I know let me try mpTrim Pro, I was thinki...   Nov 22 2008, 06:12
- - Moonbase   Id trust mp3val had a similar problem with VBRF...   Nov 22 2008, 23:49
|- - DasFox   QUOTE (Moonbase @ Nov 22 2008, 16:49) Id...   Nov 23 2008, 00:45
|- - chromium   Can mp3val repair the inconsistency created by mp3...   Nov 23 2008, 18:08
- - DasFox   QUOTE (chromium @ Nov 23 2008, 11:08) Can...   Nov 24 2008, 01:16
|- - chromium   QUOTE (DasFox @ Nov 24 2008, 02:16) QUOTE...   Nov 24 2008, 09:55
|- - DasFox   QUOTE (chromium @ Nov 24 2008, 02:55) QUO...   Nov 24 2008, 22:42
|- - odyssey   QUOTE (chromium @ Nov 24 2008, 09:55) I c...   Nov 26 2008, 06:16
|- - DasFox   QUOTE (odyssey @ Nov 25 2008, 23:16) QUOT...   Nov 26 2008, 07:49
|- - bilbo   [quote name='odyssey' date='Nov 26 200...   Nov 26 2008, 14:28
|- - senab   QUOTE (odyssey @ Nov 26 2008, 06:16) mpTr...   Nov 26 2008, 14:55
- - bilbo   I don't trust mp3val. I have tried it and ALL ...   Nov 25 2008, 03:17
|- - DasFox   QUOTE (bilbo @ Nov 24 2008, 20:17) I don...   Nov 26 2008, 04:50
- - odyssey   QUOTE (bilbo @ Nov 26 2008, 14:28) QUOTE ...   Nov 26 2008, 16:57
- - DasFox   Sheesh my bad, because I have only been using mp3t...   Nov 26 2008, 22:59
|- - odyssey   ...using foobar2000? What are "deprecated ta...   Nov 26 2008, 23:32
|- - DasFox   QUOTE (odyssey @ Nov 26 2008, 16:32) ...u...   Nov 26 2008, 23:39
- - odyssey   Even though there are a few deprecated ID3 field t...   Nov 27 2008, 09:27
|- - DasFox   QUOTE (odyssey @ Nov 27 2008, 02:27) Even...   Nov 28 2008, 01:30
- - Freon   I use mptrim pro a lot and I would like to warn us...   Oct 18 2012, 23:41
- - mjb2006   Does the problem go away if you minimize the use o...   Oct 19 2012, 03:29
RSS Lo-Fi Version Time is now: 26th May 2015 - 17:34
