16 Pages V  « < 2 3 4 5 6 > »
Resampler plugin, uses SoX 14.2.0 resampling routines
gecus
post Dec 4 2009, 23:44
Post #76
Thanks lvqcl. Another question, how can I learn to use your program. I have downloaded your component and installed it in Foobar...now, I have no idea how to make it work. Are there any posts out there explainig how to use it? I am not a developper as most of the people in this Forum.
I would like to convert my current 16bits/44.1khz files into 24bits/96khz or higher sampling.
How could I learn how to use your tool?
Thanks again!
gecus
post Dec 5 2009, 00:20
Post #77
In Foobar, File-->Preferences-->DSP Manager--> I activated Resampler (SoX) --> Configuration/Resampler Settings:
Target Samplerate: 96000 Hz / Quality: Very High
Passband: the default is 95%
I allowed alliasing for faster response...?
Phase response: Linear
My ssystem also allows up to 192Khz...would this be better?
Would this make sense?
Do I set up the 24 bits on the Output data format: 24 bits and that's all?
Thanks again! And sorry to everybody if my questions sound too obvious... crying.gif
lvqcl
post Dec 5 2009, 00:29
Post #78
I hope you understand that 24/96 files will have the same quality than original 16/44?
But if you want to do so, just use foobar2000 converter: add SoX resampler into DSP chain and configure it as you wish.
If you don't know how to use converter... my english is quite limited and I think I cannot describe this to you in detail. Maybe it's better to ask someone else about converter.
Infinito
post Dec 20 2009, 02:38
Post #79
Allow aliassing or not?
:\ i dont know what is better
Herbeck
post Dec 25 2009, 06:10
Post #80
Hi Ivqcl,
Would it be possible to add a mode that bypassed the filter completely?
(I would like to try some up and down sampling with my own filters)
All the best
Herbeck
lvqcl
post Dec 25 2009, 16:26
Post #81
QUOTE (Herbeck @ Dec 25 2009, 08:10) *
Just remove the plugin from DSP chain. Or set output samplerate equal to input samplerate.
Herbeck
post Dec 26 2009, 06:52
Post #82
QUOTE (lvqcl @ Dec 25 2009, 16:26) *
I want to change the sample rate but without the low pass filter.
I know this is an odd request, and the sound will be awful.
But I would like to try some ideas with another low pass filter.
Herbeck
lvqcl
post Dec 26 2009, 16:29
Post #83
You see, lowpass filter is integrated into SoX routines that I use, and I don't fully understand all those algorithms. I'd rather not touch them.
You can try foo_dsp_src9 with "ZOH Interpolator" and 2x/3x/4x/... upsampling.
Herbeck
post Dec 27 2009, 04:54
Post #84
Hi Ivqcl,
I have already tried it, but it messes up the bitrates and have a little slope on the passband.
But otherwise it is the kind of SRC I am locking for.
So if you know someone who can disable the low pass filter in sox,
or have another idea how to solve this, please let me know.
Many thanks
Herbeck
This post has been edited by Herbeck: Dec 27 2009, 05:28
kode54
post Dec 27 2009, 08:58
Post #85
Group: Admin
I don't get the point of disabling the low pass filter. It should only be filtering to the Nyquist frequency for the target sample rate you choose. Plus, it's not like an upsampling filter can magically introduce high frequency content above the Nyquist frequency for your source sample rate. Anything above that would be aliasing.
lvqcl
post Dec 27 2009, 12:02
Post #86
That's how foo_dsp_src9 works for 2x up- and downsampling. (44.1 -> 88.2 and 44.1 -> 22.05 kHz).
Original signal:
Upsampled signal:
Downsampled signal:
Is this what you want?
Herbeck
post Dec 27 2009, 14:05
Post #87
Hi Ivqcl,
Thank you for trying to help me with this odd request.
But the foo_dsp_src9 is not good enough for what I am trying to do.
If you do a simple test with foo_dsp_src9 and upsample a 44.1 file to 88.2 and then back to 44.1.
Then you will find that the converted file is smaller than the original file.
Like I said it messes up the bitrate.
And the slope on the passband you can see in this SRC Comparison (http://src.infinitewave.ca/)
Sox is very good for a freeware, but I use iZotope 64-bit SRC for up and down sampling.
The filter in a SRC is what make the big deferens between different SRC's.
The low pass filter I want to try is a linear phase filter but with less preringing than the one in Sox and iZotope.
I am not even close to have the knowledge to make my own SRC.
So what I am looking for is a good SRC without the lowpass filter.
And then let the SRC do the math so I can add the low pass filter manually.
Thanks again and all the best
Herbeck
This post has been edited by Herbeck: Dec 27 2009, 14:07
lvqcl
post Dec 27 2009, 14:44
Post #88
For N x upsampling without filter, all you need is to insert (N-1) null samples after each input sample.
Herbeck
post Dec 27 2009, 16:15
Post #89
Yes, but I also need to be able to convert from lets say 192Khz to 44.1Khz,
and to make a program of it with an easy workflow.
By the way that is what I like so much with your Sox plug, the easy workflow.
I am simply not a programmer.
If you can help me with this, I am willing to donate some money, because I really want to
try this filter that I wrote about on a SRC.
Don't take me wrong, I'm not rich, I'm talking about a symbolic sum to show my appreciation.
Herbeck
lvqcl
post Dec 27 2009, 20:07
Post #90
Try this simple plugin. It adds 2 entries to DSP: "2x upsample w/o lpf" and "2x downsample w/o lpf".
Herbeck
post Dec 28 2009, 08:58
Post #91
Hi Ivqcl,
If you use your "2x upsample w/o lpf" and look at the upsampled file at a sample level,
you will se that every second sample is missing, and the volume is half of the original file.
I think upsampling is pretty strait forward compared to downsampling.
Pretty much what you have done in "2x upsample w/o lpf", but without the gaps between the samples.
I've had the impression that down sampling is more complicated.
But I don't know, and I've been wrong before.
Hebeck
This post has been edited by Herbeck: Dec 28 2009, 09:00
Herbeck
post Dec 28 2009, 12:27
Post #92
Or maybe this is exactly how it should look like before the low pass filter is added.
Like I said, I've been wrong before.
but I had to add two of the upsampled files to get the original file volume before I added the filter.
And of course the gaps between the samples were gone after I added the filter.
If there were no gaps the "2x upsample w/o lpf" would have added something that wasn't there
from the beginning.
But it looked so weird I thought some thing is wrong.
I'm a little busy for a couple of days, but I'll be doing some test as soon as I can.
Thank you again Ivqcl !!!!
Herbeck
Herbeck
post Jan 3 2010, 12:26
Post #93
"Sample rate conversion process often adjusts peak structure of the original program material" -Aleksey Vaneev
This is what the "2x upsample w/o lpf" is lacking.
However, I was able to do some tests thanks to your little plugin, and it looks promising.
So now I'm eager to find out if it's possible to bypass the lowpass filter in Sox.
I've seen you mention a member that calls him/herself "Bandpass".
Do you think "Bandpass" would be able to help me with this issue.
All the best
Herbeck
lvqcl
post Jan 3 2010, 13:12
Post #94
QUOTE (Herbeck @ Jan 3 2010, 14:26) *
I doubt it, but you can ask him directly: his profile
chuuey
post Jan 14 2010, 11:03
Post #95
a3aan
post Jan 14 2010, 12:14
Post #96
QUOTE (lvqcl @ Jan 12 2010, 20:12) *
SSE2 version is available (see the 1st post). It works ca. Up to 10% faster than the default one.
Great! Mod version from a few posts up in the pipeline?
Adriaan.
This post has been edited by a3aan: Jan 14 2010, 12:15
PostOfficeBuddy
post Apr 8 2010, 06:46
Post #97
I just wanted to say thanks for this. You rock lvqcl.
h34rtb1t
post May 18 2010, 20:47
Post #98
Well done and thank you for your effort.
h34rtb1t
post May 20 2010, 10:19
Post #99
Would you please add one more configuration setting, which do upsample 4x for [0, 48]kHz and 2x for (48, 96]kHz source.
This post has been edited by h34rtb1t: May 20 2010, 10:20
lvqcl
post May 20 2010, 14:15
Post #100
QUOTE (h34rtb1t @ May 20 2010, 13:19) *
You can do this with SoX_resampler_mod.
Just add 2 resamplers to DSP chain. First makes 4x upsampling and passes 64000,88200,96000 unmodified. Second makes 2x upsampling and passes 128000,176400,192000 unmodified.
RSS Lo-Fi Version Time is now: 31st January 2015 - 19:58
