Resampler plugin, uses SoX 14.2.0 resampling routines
lvqcl
post Nov 19 2008, 03:45
Uploaded here
Good quality, fast resampler (~2 times faster than PPHS Ultra, although ~2.5 times slower than regular PPHS). Minimum / intermediate / linear phase.
Any comments?
Added: If you want to know what settings are best:
1. Read SoX FAQ, "What are the best 'rate' settings to resample a file and retain the highest quality?"
2. This post: http://www.hydrogenaudio.org/forums/index....st&p=626176 (an excerpt from SoX help)
3. Feel free to experiment and decide what's best for you.
This post has been edited by lvqcl: Apr 10 2009, 20:37
lvqcl
post Dec 5 2009, 00:29
I hope you understand that 24/96 files will have the same quality than original 16/44?
But if you want to do so, just use foobar2000 converter: add SoX resampler into DSP chain and configure it as you wish.
If you don't know how to use converter... my english is quite limited and I think I cannot describe this to you in detail. Maybe it's better to ask someone else about converter.
- lvqcl   Resampler plugin   Nov 19 2008, 03:45
- - patul   Downloading now & will try soon. I use SSRC ho...   Nov 19 2008, 06:41
- - AFAIK   well... somebody made this test http://src.infin...   Nov 19 2008, 13:19
|- - vigylant   QUOTE (AFAIK @ Nov 19 2008, 14:19) well.....   Nov 19 2008, 22:28
|- - lvqcl   QUOTE (vigylant @ Nov 20 2008, 00:28) The...   Nov 19 2008, 23:27
|- - bandpass   QUOTE (lvqcl @ Nov 19 2008, 22:27) QUOTE ...   Nov 20 2008, 07:38
- - Canar   Now does this resampler use the "High" o...   Nov 19 2008, 16:00
|- - lvqcl   QUOTE (Canar @ Nov 19 2008, 18:00) Now do...   Nov 19 2008, 19:11
- - AFAIK   I think i found a bug when using in dsp chain an...   Nov 19 2008, 18:46
|- - lvqcl   QUOTE (AFAIK @ Nov 19 2008, 20:46) when u...   Nov 19 2008, 19:22
- - Canar   Please ignore my earlier comment. I missed the con...   Nov 19 2008, 19:48
- - vigylant   Hmm, ok, i take it this one is better then But im...   Nov 19 2008, 23:45
- - jaro1   I had carefully compared this SRC, based on SOX 14...   Nov 23 2008, 01:22
- - Canar   @jaro1: I am not convinced that you did, indeed, h...   Nov 23 2008, 01:46
|- - jaro1   QUOTE (Canar @ Nov 23 2008, 01:46) @jaro1...   Nov 23 2008, 20:05
- - hidn   question which I must ask. He as well as PPHS Ultr...   Nov 23 2008, 14:37
- - Jorgo   This seems to be a very good resampler. From my li...   Nov 23 2008, 20:23
- - hidn   someone who can compile and lay out icl version?   Nov 24 2008, 07:09
- - lvqcl   Version 0.3.0 is out. It seems that resampling rou...   Nov 27 2008, 20:16
- - Canar   SoX Resampler. Resampler (SoX) in the DSP list.   Nov 28 2008, 02:33
- - .halverhahn   Thank You for transfering this great resampler to ...   Dec 31 2008, 13:36
- - Jorgo   0.4.0... uh, what? Please don't rename stuff s...   Mar 9 2009, 22:34
|- - lvqcl   QUOTE (Jorgo @ Mar 10 2009, 00:34) 0.4.0....   Mar 9 2009, 23:03
- - jaro1   Hi, I know it's a little offtopic, but I wante...   Mar 10 2009, 11:00
|- - lvqcl   QUOTE (jaro1 @ Mar 10 2009, 13:00) Hi, I ...   Mar 10 2009, 17:56
|- - bandpass   QUOTE (lvqcl @ Mar 10 2009, 16:56) QUOTE ...   Mar 10 2009, 23:02
- - jaro1   Thanks to both lvqcl, bandpass for your comments, ...   Mar 11 2009, 09:33
- - bandpass   Just a thought: to be on the safe side, here are t...   Mar 11 2009, 15:11
- - a3aan   May I suggest a configuration option to only resam...   Mar 11 2009, 20:21
|- - kode54   QUOTE (a3aan @ Mar 11 2009, 12:21) May I ...   Mar 11 2009, 21:49
||- - lvqcl   QUOTE (kode54 @ Mar 12 2009, 00:49) Sound...   Apr 5 2009, 16:28
|- - lvqcl   QUOTE (a3aan @ Mar 11 2009, 22:21) May I ...   Mar 12 2009, 18:28
|- - a3aan   Thanks a lot for considering. I'm ready to hel...   Mar 12 2009, 21:56
- - lvqcl   QUOTE Are you saying that if I choose 44.1 kHz as ...   Mar 12 2009, 22:35
- - punkrockdude   I wonder what are the difference and therefore ten...   Mar 15 2009, 01:35
|- - lvqcl   QUOTE (punkrockdude @ Mar 15 2009, 04:35)...   Apr 5 2009, 16:21
- - Yirkha   is_conversion_supported() - some resamplers are ab...   Apr 5 2009, 17:31
- - lvqcl   Thanks, but what if my component doesn't have ...   Apr 5 2009, 18:35
- - Yirkha   dsp is a generic DSP service. resampler_entry ser...   Apr 5 2009, 18:56
- - lvqcl   Thanks again. I will use resampler_entry class (an...   Apr 5 2009, 19:18
- - Mix3dmessagez   QUOTE (lvqcl @ Nov 18 2008, 22:45) Upload...   Apr 6 2009, 10:51
- - Mr.Duck   Thanks, lvqcl. A really excelent plugin. Must be t...   Apr 6 2009, 13:16
- - lvqcl   QUOTE (Mix3dmessagez)My question is, what does tho...   Apr 6 2009, 15:34
|- - Mix3dmessagez   QUOTE (lvqcl @ Apr 6 2009, 10:34) QUOTE (...   Apr 6 2009, 17:42
- - lvqcl   From help file of standalone SoX program (ver. 14....   Apr 6 2009, 18:29
|- - Mix3dmessagez   Thank you for your great support, one last questio...   Apr 6 2009, 18:45
- - lvqcl   QUOTE Thank you for your great support, one last q...   Apr 6 2009, 18:51
- - Steve Forte Rio   I do not understand.... What about "allow ali...   Jul 9 2009, 20:20
- - lvqcl   QUOTE (Steve Forte Rio)I do not understand.... Wha...   Jul 10 2009, 16:36
|- - Steve Forte Rio   QUOTE (lvqcl @ Jul 10 2009, 14:36) Origin...   Jul 16 2009, 20:49
- - lvqcl   I made it myself with Adobe Audition: Generate -...   Jul 18 2009, 07:26
- - Steve Forte Rio   Thank you very much!   Jul 18 2009, 10:15
- - lxofith   Hello lvqcl, First of all thanks a lot for your c...   Aug 19 2009, 22:08
|- - theilladelph   Yea thanks a lot lvqcl... Been doing a lot of read...   Aug 22 2009, 12:01
- - lvqcl   QUOTE (lxofith @ Aug 20 2009, 01:08) Do y...   Aug 22 2009, 12:13
- - lvqcl   Modified version available now here: http://www.hy...   Nov 19 2009, 18:40
|- - a3aan   QUOTE (lvqcl @ Nov 19 2009, 18:40) Modifi...   Nov 21 2009, 16:39
- - lvqcl   Add 2 resamplers in your DSP chain 1st: target = ...   Nov 19 2009, 23:02
|- - lxofith   QUOTE (lvqcl @ Nov 19 2009, 23:02) Add 2 ...   Nov 20 2009, 18:44
|- - lvqcl   QUOTE (lxofith @ Nov 20 2009, 20:44) I as...   Nov 20 2009, 22:52
|- - Olev   QUOTE (lvqcl @ Nov 20 2009, 23:52) QUOTE ...   Nov 24 2009, 21:07
|- - lxofith   QUOTE (Olev @ Nov 24 2009, 21:07) Wouldn...   Nov 24 2009, 21:23
|- - Olev   QUOTE (lxofith @ Nov 24 2009, 22:23) QUOT...   Nov 24 2009, 22:08
|- - lvqcl   QUOTE (Olev @ Nov 25 2009, 00:08) Of cour...   Nov 25 2009, 00:40
- - Robertina   lvqcl, first I would like to say thank you for th...   Nov 21 2009, 05:51
|- - kode54   QUOTE (Robertina @ Nov 20 2009, 20:51) On...   Nov 21 2009, 07:39
- - Robertina   Question answered, thank you, kode54.   Nov 21 2009, 11:03
- - lvqcl   ...And you will see [DSP not found] line in the DS...   Nov 21 2009, 13:12
- - Robertina   Thank you, lvqcl. And I love you new modified ver...   Nov 21 2009, 13:17
- - gecus   Just a silly question for most of you in the devel...   Dec 2 2009, 17:31
|- - lvqcl   QUOTE (gecus @ Dec 2 2009, 19:31) I am us...   Dec 2 2009, 18:07
- - gecus   Thanks lvqcl. Another question, how can I learn to...   Dec 4 2009, 23:44
- - gecus   Thanks lvqcl. Another question, how can I learn to...   Dec 5 2009, 00:20
- - lvqcl   I hope you understand that 24/96 files will have t...   Dec 5 2009, 00:29
- - Infinito   Allow aliassing or not? :\ i dont know what i...   Dec 20 2009, 02:38
- - Herbeck   Hi Ivqcl, Would it be possible to add a mode tha...   Dec 25 2009, 06:10
|- - lvqcl   QUOTE (Herbeck @ Dec 25 2009, 08:10) Woul...   Dec 25 2009, 16:26
|- - Herbeck   QUOTE (lvqcl @ Dec 25 2009, 16:26) QUOTE ...   Dec 26 2009, 06:52
- - lvqcl   You see, lowpass filter is integrated into SoX rou...   Dec 26 2009, 16:29
- - Herbeck   Hi Ivqcl, I have already tried it, but it messes ...   Dec 27 2009, 04:54
- - kode54   I don't get the point of disabling the low pas...   Dec 27 2009, 08:58
- - lvqcl   That's how foo_dsp_src9 works for 2x up- and d...   Dec 27 2009, 12:02
- - Herbeck   Hi Ivqcl, Thank you for trying to help me with th...   Dec 27 2009, 14:05
- - lvqcl   QUOTE I am not even close to have the knowledge to...   Dec 27 2009, 14:44
- - Herbeck   Yes, but I also need to be able to convert from le...   Dec 27 2009, 16:15
- - lvqcl   I'm not a programmer too, I just know C++ a li...   Dec 27 2009, 20:07
- - Herbeck   Hi Ivqcl, If you use your "2x upsample w/o l...   Dec 28 2009, 08:58
- - Herbeck   Or maybe this is exactly how it should look like b...   Dec 28 2009, 12:27
- - Herbeck   "Sample rate conversion process often adjusts...   Jan 3 2010, 12:26
|- - lvqcl   QUOTE (Herbeck @ Jan 3 2010, 14:26) ...   Jan 3 2010, 13:12
- - chuuey   thanks for the sse2 version   Jan 14 2010, 11:03
- - PostOfficeBuddy   I just wanted to say thanks for this. You rock lvq...   Apr 8 2010, 06:46
- - h34rtb1t   Well done and thank you for your effort.   May 18 2010, 20:47
- - h34rtb1t   Would you please add one more configuration settin...   May 20 2010, 10:19
- - lvqcl   QUOTE (h34rtb1t @ May 20 2010, 13:19) Wou...   May 20 2010, 14:15
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 2nd September 2015 - 11:42
