Resampler plugin, uses SoX 14.2.0 resampling routines
lvqcl
post Nov 19 2008, 03:45
Uploaded here
Good quality, fast resampler (~2 times faster than PPHS Ultra, although ~2.5 times slower than regular PPHS). Minimum / intermediate / linear phase.
Any comments?
Added: If you want to know what settings are best:
1. Read SoX FAQ, "What are the best 'rate' settings to resample a file and retain the highest quality?"
2. This post: http://www.hydrogenaudio.org/forums/index....st&p=626176 (an excerpt from SoX help)
3. Feel free to experiment and decide what's best for you.
This post has been edited by lvqcl: Apr 10 2009, 20:37
jaro1
post Mar 10 2009, 11:00
Hi, I know it's a little offtopic, but I wanted to ask lvqcl to something, because I suppose he knows SOX internal routines quiet good yet.
Would it be possible in the future make a plugin, which implements SOX deemphasis filter? (deemph: ISO 908 CD de-emphasis (shelving) IIR filter)
Till now I use for it wav impuls responses with FB2Ks Convolver plugin, but this isn't a right choice according to this german page:
http://www.radonmaster.de/robernd/tAFILTER.html (thanks to author and Surfi for the link)
On this side there are packed wav signals, with explanation, for testing different deemphasis filters ( there is also filter of old SOX version, which results very badly, it altered also stereo image... )
Filter from recent SOX version is perfect, but solution with Convolver plugin (whatever impulse I use) alters a signal after closser look in Audition quiet a lot from what it should do, although frequencygoing could be very close and therefore after listening undistinguishable.
For me is use of Convolver plugin, at least for this purpose, a little unpractical and ultimately inaccurate, so therefore this idea. By the way, it may or may not be a problem, but I think SOX deemph filter has 32bit internal precision, which is, on the other side, for this kind of operation absolutely necessary.
Once more, sorry for offtopic and thanks for your opinion.
This post has been edited by jaro1: Mar 10 2009, 11:48
lvqcl
post Mar 10 2009, 17:56
QUOTE (jaro1 @ Mar 10 2009, 13:00) *
Seems strange for me. Try to use this impulse: deemph_SoX.wav
I tested SoX and Convolver with my impulse: difference between them is about -130 dB. So convolver is quite accurate.
And don't use "Auto level adjust" option.
This post has been edited by lvqcl: Feb 14 2013, 16:19
bandpass
post Mar 10 2009, 23:02
QUOTE (lvqcl @ Mar 10 2009, 16:56) *
It's just a simple (but accurate) biquad; coefficients in the freqz line below. So if there's already a foobar biquad plug-in, just plug-in smile.gif the numbers.
-bandpass
% GNU Octave file (may also work with MATLAB® )
Fs=44100;minF=10;maxF=Fs/2;
sweepF=logspace(log10(minF),log10(maxF),200);
[h,w]=freqz([0.460351 -0.284408 0.0338888],[1 -1.05429 0.264123],sweepF,Fs);
semilogx(w,20*log10(h))
title('SoX effect: deemph gain=-9.477 frequency=5283 slope=0.4845 (rate=44100)')
xlabel('Frequency (Hz)')
ylabel('Amplitude Response (dB)')
axis([minF maxF -35 25])
grid on
disp('Hit return to continue')
pause
- lvqcl   Resampler plugin   Nov 19 2008, 03:45
- - patul   Downloading now & will try soon. I use SSRC ho...   Nov 19 2008, 06:41
- - AFAIK   well... somebody made this test http://src.infin...   Nov 19 2008, 13:19
|- - vigylant   QUOTE (AFAIK @ Nov 19 2008, 14:19) well.....   Nov 19 2008, 22:28
|- - lvqcl   QUOTE (vigylant @ Nov 20 2008, 00:28) The...   Nov 19 2008, 23:27
|- - bandpass   QUOTE (lvqcl @ Nov 19 2008, 22:27) QUOTE ...   Nov 20 2008, 07:38
- - Canar   Now does this resampler use the "High" o...   Nov 19 2008, 16:00
|- - lvqcl   QUOTE (Canar @ Nov 19 2008, 18:00) Now do...   Nov 19 2008, 19:11
- - AFAIK   I think i found a bug when using in dsp chain an...   Nov 19 2008, 18:46
|- - lvqcl   QUOTE (AFAIK @ Nov 19 2008, 20:46) when u...   Nov 19 2008, 19:22
- - Canar   Please ignore my earlier comment. I missed the con...   Nov 19 2008, 19:48
- - vigylant   Hmm, ok, i take it this one is better then But im...   Nov 19 2008, 23:45
- - jaro1   I had carefully compared this SRC, based on SOX 14...   Nov 23 2008, 01:22
- - Canar   @jaro1: I am not convinced that you did, indeed, h...   Nov 23 2008, 01:46
|- - jaro1   QUOTE (Canar @ Nov 23 2008, 01:46) @jaro1...   Nov 23 2008, 20:05
- - hidn   question which I must ask. He as well as PPHS Ultr...   Nov 23 2008, 14:37
- - Jorgo   This seems to be a very good resampler. From my li...   Nov 23 2008, 20:23
- - hidn   someone who can compile and lay out icl version?   Nov 24 2008, 07:09
- - lvqcl   Version 0.3.0 is out. It seems that resampling rou...   Nov 27 2008, 20:16
- - Canar   SoX Resampler. Resampler (SoX) in the DSP list.   Nov 28 2008, 02:33
- - .halverhahn   Thank You for transfering this great resampler to ...   Dec 31 2008, 13:36
- - Jorgo   0.4.0... uh, what? Please don't rename stuff s...   Mar 9 2009, 22:34
|- - lvqcl   QUOTE (Jorgo @ Mar 10 2009, 00:34) 0.4.0....   Mar 9 2009, 23:03
- - jaro1   Hi, I know it's a little offtopic, but I wante...   Mar 10 2009, 11:00
|- - lvqcl   QUOTE (jaro1 @ Mar 10 2009, 13:00) Hi, I ...   Mar 10 2009, 17:56
|- - bandpass   QUOTE (lvqcl @ Mar 10 2009, 16:56) QUOTE ...   Mar 10 2009, 23:02
- - jaro1   Thanks to both lvqcl, bandpass for your comments, ...   Mar 11 2009, 09:33
- - bandpass   Just a thought: to be on the safe side, here are t...   Mar 11 2009, 15:11
- - a3aan   May I suggest a configuration option to only resam...   Mar 11 2009, 20:21
|- - kode54   QUOTE (a3aan @ Mar 11 2009, 12:21) May I ...   Mar 11 2009, 21:49
||- - lvqcl   QUOTE (kode54 @ Mar 12 2009, 00:49) Sound...   Apr 5 2009, 16:28
|- - lvqcl   QUOTE (a3aan @ Mar 11 2009, 22:21) May I ...   Mar 12 2009, 18:28
|- - a3aan   Thanks a lot for considering. I'm ready to hel...   Mar 12 2009, 21:56
- - lvqcl   QUOTE Are you saying that if I choose 44.1 kHz as ...   Mar 12 2009, 22:35
- - punkrockdude   I wonder what are the difference and therefore ten...   Mar 15 2009, 01:35
|- - lvqcl   QUOTE (punkrockdude @ Mar 15 2009, 04:35)...   Apr 5 2009, 16:21
- - Yirkha   is_conversion_supported() - some resamplers are ab...   Apr 5 2009, 17:31
- - lvqcl   Thanks, but what if my component doesn't have ...   Apr 5 2009, 18:35
- - Yirkha   dsp is a generic DSP service. resampler_entry ser...   Apr 5 2009, 18:56
- - lvqcl   Thanks again. I will use resampler_entry class (an...   Apr 5 2009, 19:18
- - Mix3dmessagez   QUOTE (lvqcl @ Nov 18 2008, 22:45) Upload...   Apr 6 2009, 10:51
- - Mr.Duck   Thanks, lvqcl. A really excelent plugin. Must be t...   Apr 6 2009, 13:16
- - lvqcl   QUOTE (Mix3dmessagez)My question is, what does tho...   Apr 6 2009, 15:34
|- - Mix3dmessagez   QUOTE (lvqcl @ Apr 6 2009, 10:34) QUOTE (...   Apr 6 2009, 17:42
- - lvqcl   From help file of standalone SoX program (ver. 14....   Apr 6 2009, 18:29
|- - Mix3dmessagez   Thank you for your great support, one last questio...   Apr 6 2009, 18:45
- - lvqcl   QUOTE Thank you for your great support, one last q...   Apr 6 2009, 18:51
- - Steve Forte Rio   I do not understand.... What about "allow ali...   Jul 9 2009, 20:20
- - lvqcl   QUOTE (Steve Forte Rio)I do not understand.... Wha...   Jul 10 2009, 16:36
|- - Steve Forte Rio   QUOTE (lvqcl @ Jul 10 2009, 14:36) Origin...   Jul 16 2009, 20:49
- - lvqcl   I made it myself with Adobe Audition: Generate -...   Jul 18 2009, 07:26
- - Steve Forte Rio   Thank you very much!   Jul 18 2009, 10:15
- - lxofith   Hello lvqcl, First of all thanks a lot for your c...   Aug 19 2009, 22:08
|- - theilladelph   Yea thanks a lot lvqcl... Been doing a lot of read...   Aug 22 2009, 12:01
- - lvqcl   QUOTE (lxofith @ Aug 20 2009, 01:08) Do y...   Aug 22 2009, 12:13
- - lvqcl   Modified version available now here: http://www.hy...   Nov 19 2009, 18:40
|- - a3aan   QUOTE (lvqcl @ Nov 19 2009, 18:40) Modifi...   Nov 21 2009, 16:39
- - lvqcl   Add 2 resamplers in your DSP chain 1st: target = ...   Nov 19 2009, 23:02
|- - lxofith   QUOTE (lvqcl @ Nov 19 2009, 23:02) Add 2 ...   Nov 20 2009, 18:44
|- - lvqcl   QUOTE (lxofith @ Nov 20 2009, 20:44) I as...   Nov 20 2009, 22:52
|- - Olev   QUOTE (lvqcl @ Nov 20 2009, 23:52) QUOTE ...   Nov 24 2009, 21:07
|- - lxofith   QUOTE (Olev @ Nov 24 2009, 21:07) Wouldn...   Nov 24 2009, 21:23
|- - Olev   QUOTE (lxofith @ Nov 24 2009, 22:23) QUOT...   Nov 24 2009, 22:08
|- - lvqcl   QUOTE (Olev @ Nov 25 2009, 00:08) Of cour...   Nov 25 2009, 00:40
- - Robertina   lvqcl, first I would like to say thank you for th...   Nov 21 2009, 05:51
|- - kode54   QUOTE (Robertina @ Nov 20 2009, 20:51) On...   Nov 21 2009, 07:39
- - Robertina   Question answered, thank you, kode54.   Nov 21 2009, 11:03
- - lvqcl   ...And you will see [DSP not found] line in the DS...   Nov 21 2009, 13:12
- - Robertina   Thank you, lvqcl. And I love you new modified ver...   Nov 21 2009, 13:17
- - gecus   Just a silly question for most of you in the devel...   Dec 2 2009, 17:31
|- - lvqcl   QUOTE (gecus @ Dec 2 2009, 19:31) I am us...   Dec 2 2009, 18:07
- - gecus   Thanks lvqcl. Another question, how can I learn to...   Dec 4 2009, 23:44
- - gecus   Thanks lvqcl. Another question, how can I learn to...   Dec 5 2009, 00:20
- - lvqcl   I hope you understand that 24/96 files will have t...   Dec 5 2009, 00:29
- - Infinito   Allow aliassing or not? :\ i dont know what i...   Dec 20 2009, 02:38
- - Herbeck   Hi Ivqcl, Would it be possible to add a mode tha...   Dec 25 2009, 06:10
|- - lvqcl   QUOTE (Herbeck @ Dec 25 2009, 08:10) Woul...   Dec 25 2009, 16:26
|- - Herbeck   QUOTE (lvqcl @ Dec 25 2009, 16:26) QUOTE ...   Dec 26 2009, 06:52
- - lvqcl   You see, lowpass filter is integrated into SoX rou...   Dec 26 2009, 16:29
- - Herbeck   Hi Ivqcl, I have already tried it, but it messes ...   Dec 27 2009, 04:54
- - kode54   I don't get the point of disabling the low pas...   Dec 27 2009, 08:58
- - lvqcl   That's how foo_dsp_src9 works for 2x up- and d...   Dec 27 2009, 12:02
- - Herbeck   Hi Ivqcl, Thank you for trying to help me with th...   Dec 27 2009, 14:05
- - lvqcl   QUOTE I am not even close to have the knowledge to...   Dec 27 2009, 14:44
- - Herbeck   Yes, but I also need to be able to convert from le...   Dec 27 2009, 16:15
- - lvqcl   I'm not a programmer too, I just know C++ a li...   Dec 27 2009, 20:07
- - Herbeck   Hi Ivqcl, If you use your "2x upsample w/o l...   Dec 28 2009, 08:58
- - Herbeck   Or maybe this is exactly how it should look like b...   Dec 28 2009, 12:27
- - Herbeck   "Sample rate conversion process often adjusts...   Jan 3 2010, 12:26
|- - lvqcl   QUOTE (Herbeck @ Jan 3 2010, 14:26) ...   Jan 3 2010, 13:12
- - chuuey   thanks for the sse2 version   Jan 14 2010, 11:03
- - PostOfficeBuddy   I just wanted to say thanks for this. You rock lvq...   Apr 8 2010, 06:46
- - h34rtb1t   Well done and thank you for your effort.   May 18 2010, 20:47
- - h34rtb1t   Would you please add one more configuration settin...   May 20 2010, 10:19
- - lvqcl   QUOTE (h34rtb1t @ May 20 2010, 13:19) Wou...   May 20 2010, 14:15
4 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 29th July 2015 - 19:54
