A new resampler DSP for foobar2000, uses resampling routines from SoX effect "rate"
lvqcl
post Nov 19 2008, 02:11
Good & fast resampler based on SoX resampling routines. (several times faster than PPHS Ultra).
0.8.3:
normal version: Attached File  foo_dsp_resampler_0.8.3.zip ( 147.62K ) Number of downloads: 48621
modified: Attached File  foo_dsp_resampler_mod_0.8.3.zip ( 152.88K ) Number of downloads: 16047
and Attached File  foo_dsp_resampler_mod2_0.8.3.zip ( 152.87K ) Number of downloads: 14668
sources: Attached File  foo_dsp_resampler_0.8.3_src.rar ( 86.1K ) Number of downloads: 3629
Discussion thread is here.
This post has been edited by lvqcl: Nov 4 2014, 00:47
2 Pages V   1 2 >
Replies (1 - 24)
lvqcl
post Nov 26 2008, 22:05
Changelog:
Version 0.8.3:
  • FFmpeg FFT code updated; other minor code updates.
Version 0.8.2:
  • An improvement from git: "speed up small-factor downsampling; e.g. ~15% improvement for 48k->44100".
Version 0.8.1:
  • Recompiled with TDM-GCC 4.7.1. Slightly smaller filesize.
Version 0.8.0:
  • Updated sources from git (downsampling speed-up).
Version 0.7.9:
  • Updated sources from git ("rate speed-ups: down-sample by 3/4, down-sample by > 4").
  • Code cleanup.
Version 0.7.8:
  • Even faster than before, especially for upsampling.
Version 0.7.6:
  • Improved speed for 1.5x, 3x, 4x, 5x, ... upsampling and 3x downsampling.
Version 0.7.0:
  • Bugfix in UI.
This post has been edited by lvqcl: Feb 4 2013, 19:35
lvqcl
post Dec 4 2008, 22:12
<OLD content>
Version 0.6.9:
  • Bugfix: error in initialization when CPU doesn't have SSE3.
Version 0.6.8:
  • Bugfix for new quality modes & multithreading
Version 0.6.6 have new quality modes:
  • Best -- the same as old 'Very high' mode
  • Good -- old 'Very high' mode but with single precision (instead of double precision in 'Best' mode)
  • Normal -- old 'High' mode with single precision
Version 0.6.0:
  • Uses SSE3 optimizations but also works on CPUs without SSE3 support (0.5.6 and 0.5.4.4 merged).
Version 0.5.6 (for CPU with SSE3 support):
  • Bugfix
  • Switched to MSVS 2010 + Intel compiler 12.0
Version 0.5.5:
  • SSE3 optimizations
Version 0.5.4.4 (for CPU without SSE3 support):
  • Bugfix: SSE2 instructions were enabled in 0.5.4.3, and plugin crashes on AthlonXP.
  • Optimized versions removed (use 0.5.5)
Version 0.5.4.3:
  • Minor UI changes.
  • Default settings are configurable in Advanced Preferences (reasmpling service now uses them).
  • Atom/Core 2/K8 optimized versions (compiled with MinGW32 4.5.0).
Version 0.5.4.2:
  • Recompiled with newer SDKs (foobar2000 1.0+ now required).
Version 0.5.4.1:
  • Added: Fast 4x upsampling.
Version 0.5.3:
  • Changed: Code cleanup.
Version 0.5.2:
  • Changed: Minor fixes and improvements.
Version 0.5.0:
  • Improved: New UI. Now it offers more control of passband and phase response.
  • Improved: New modes: "Upsample x2", "Downsample x2".
  • Improved: Now it uses resampler_entry class and WTL.
Version 0.4.0: was alpha only.
Version 0.3.2:
  • Fixed: memory leak was REALLY fixed.
Version 0.3.1:
  • Fixed: memory leak.
  • Added: "Low" quality setting.
Version 0.3.0a: plugin is just renamed to a shorter name. Nothing more, even plugin version number is still 0.3.0.
Version 0.3.0:
  • Fixed: resampling routines are changed to allow multiple instances of the plugin to work.
  • Fixed: incorrect flushing of audio stream when seeking
Version 0.2.1:
  • Fixed: bug in latency reporting
Version 0.2.0:
  • Initial public release
lvqcl
post Mar 5 2009, 23:28
Modified version allows you to set a list of input frequencies that will pass through the plugin, unmodified. Or it can choose proper output frequency from the list.
*_mod: It doesn't resample the frequencies that you enter in the text field.
*_mod2: It resamples only the frequencies that you enter in the field.
This post has been edited by lvqcl: Aug 17 2012, 18:47
lvqcl
post Jun 10 2009, 18:47
Normal quality is enough for 16-bit precision output and is noticeably faster than Best.
Use Best mode if higher precision (24-bit, 32-bit float) is needed.
This post has been edited by lvqcl: Aug 17 2012, 18:57
lvqcl
post Jun 15 2009, 17:30
This post has been edited by lvqcl: Aug 17 2012, 18:45
lvqcl
post Nov 19 2009, 18:22
lvqcl
post Jan 12 2010, 20:12
lvqcl
post May 28 2010, 19:27
This post has been edited by lvqcl: Aug 17 2012, 18:46
shakey_snake
post Jun 18 2010, 18:39
Group: FB2K Moderator
Discussion posts moved to discussion thread.
Please follow the Uploads - (fb2k) forum guidelines found in the stickied thread, guys.
elevatorladylevitateme
lvqcl
post Aug 24 2010, 19:45
lvqcl
post Sep 14 2010, 20:27
lvqcl
post Nov 19 2010, 19:02
TWIMC: Speex SRC for foobar2000. I just took SoX resampler component and replaced SoX routines with Speex routines. Sources included.
(another implementation: http://www.hydrogenaudio.org/forums/index....howtopic=90322)
Update: Speex SRC with a few improvements from opus-tools project:
Attached File  foo_dsp_speexsrc_0.1.2.rar ( 75.77K ) Number of downloads: 1469
This post has been edited by lvqcl: Nov 4 2014, 00:53
o770
post Apr 29 2012, 00:34
Thanks for your work but Foobar only installs components from zip and rar archives, you provide the main component in zip already, so why the 7z?
tpijag
post Apr 29 2012, 01:04
Post #15
Has not always been the case and post is from 1.5 years ago when it may not of been the case. Also looks to be a different version than post#1.
Is the point of your post that you want to install? If so, drag dll to the components preference page of your foobar2000 installation. By the way, this is the uploads forum and questions regarding the component should be placed in the appropriate dedicated thread.
regards
sam5050
post May 23 2012, 20:38
Post #16
Love the SoX reampler in Foobar - I have tested it against other DSPs. It is still the best. Even beats JPlay on system using 176k resampling of redbook files.
Request - my new DAC/PC interface can handle up to 384K , I would like to re-sample my redbook files from 44 to 352, can you add a 352k sample rate or an 8x option in your next update.
I have some archived LPs I recorded at 176 and the 2x option worked great! Sounded a bit better then 176k.
Thanks again for a great plugin!
This post has been edited by sam5050: May 23 2012, 20:39
skuppy
post Jul 29 2012, 22:16
Post #17
Really great resampler! Looking forward to all future updates! Thank you so much.
mudlord
post Jul 29 2012, 23:58
Post #18
Group: Developer (Donating)
Thanks also for reimplementing my Speex resampler. So there indeed was some buffering bugs smile.gif
lvqcl
post Aug 6 2012, 16:29
Post #19
Oery
post Aug 9 2012, 11:03
Post #20
QUOTE (lvqcl @ Aug 6 2012, 22:29) *
SoX resampler 0.8.0 beta: uses newer version of the resampling algorithm, with downsampling speed-up. Want to test?
[attachment=7076:foo_dsp_...0.8.0_b1.zip]
[attachment=7077:foo_dsp_....0_beta2.zip]
thank you............
SoNic67
post Aug 10 2012, 00:41
Post #21
Thanks, will test it right now.
I upsample most of the time thou...
LE: 44.1>96 and 192>96 sound clean.
This post has been edited by SoNic67: Aug 10 2012, 00:47
BarracudaSurf
post Dec 30 2012, 09:18
Post #22
Hello, is there going to be a "mod" edition of 0.8.3?
I find the "mod" version very practical, I use it to upsample/downsample different sample rates.
QUOTE (lvqcl @ Nov 18 2008, 20:11) *
0.8.3 exp: [attachment=7259:foo_dsp_...er_0.8.3.zip] sources: [attachment=7260:foo_dsp_....8.3_src.rar]
0.8.2:
normal version: [attachment=7228:foo_dsp_...er_0.8.2.zip]modified: [attachment=7229:foo_dsp_...od_0.8.2.zip]and [attachment=7230:foo_dsp_...d2_0.8.2.zip]
sources: [attachment=7231:foo_dsp_....8.2_src.rar]
version for foobar2000 0.9.4+: see post #3
d_headshot
post Jan 3 2013, 23:35
Post #23
In the DSP plugin I don't see an option to dither. What settings with the plugin would I need to use if going from 24bit/96kHz to 16bit/44.1kHz? Or should I use the command line instead and how would I do that with foobar?
d_headshot
post Jan 7 2013, 19:53
Post #24
Any updates?
Fabulist
post Jan 17 2013, 21:09
Post #25
Hope this great work will keep happening!
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 4th August 2015 - 21:27
