Possible bug in LAME 3.98, MP3 files sometimes play back at the wro
Paul Sanders
post Nov 8 2008, 15:37
I don't know if this has been reported elsewhere, but I have discovered that LAME 3.98 sometimes produces MP3 files that play back at the wrong speed (!). We are using VBR encoding. It is possible that CBR files are OK.
LAME 3.98.2 appears to be OK (as are 3.96.1 and 3.97). I have to say I am baffled that nobody but me seems to have noticed this problem, but two of our users have reported it and sent us sound samples to confirm. I can post these if anyone is interested.
This post has been edited by Paul Sanders: Nov 11 2008, 17:41
I am an independent software developer (VinylStudio) based in UK
PHOYO
post Nov 8 2008, 16:05
So what's the problem here? If it's fixed in 3.98.2, I don't understand the purpose of this thread.
Neasden
post Nov 8 2008, 18:02
Group: Banned
care to reproduce the issue in 3.98?
pdq
post Nov 8 2008, 19:36
QUOTE (PHOYO @ Nov 8 2008, 11:05) *
I guess the purpose is to tell people who have not yet upgraded that they should stop using 3.98.
Also, if the bug was not known about in 3.98 then maybe it is not truly fixed in 3.98.2 but only appears in different samples. We need to know which is the vase.
simonh
post Nov 8 2008, 21:12
I hope this isn't a lame(!) attempt to drive traffic to your site?
This post has been edited by simonh: Nov 8 2008, 21:19
Paul Sanders
post Nov 8 2008, 23:20
I'm not sure I can, but sending LAME 3.98.2 to the user who reported the problem made it go away when generating the same MP3 file in otherwise identical circumstances.
Simon, I resent that remark. I felt this was something people might like to know. Nevertheless, I have removed the link.
This post has been edited by Paul Sanders: Nov 9 2008, 01:34
simonh
post Nov 9 2008, 10:56
Sorry Paul. It's just the link contained exactly the same information as your first post. I was expecting a discussion of the issue on your forum.
This post has been edited by simonh: Nov 9 2008, 10:56
robert
post Nov 9 2008, 11:00
LAME developer
A sample and a description on how to reproduce the problem would be helpful to solve this issue.
Paul Sanders
post Nov 9 2008, 12:31
To Simon: OK, point taken.
To pdq: yes, quite
To Robert: No, I can't reproduce the problem here, nor I have not observed it during routine testing. Also, if it were widespread, I'm sure we would have received more bug reports. But a user has sent in two files, one encoded with LAME 3.98 and one with 3.98.2 from the same source material, which demonstrate the problem. The one encoded with LAME 3.98 plays about 10% more slowly than it should - specifically the duration is reported as 3:00 (mm:ss) rather than 2:44 as it should be.
The files are here if you want to take a gander:
http://www.alpinesoft.co.uk/private/correct.mp3 (LAME 3.98.2)
http://www.alpinesoft.co.uk/private/dragging.mp3 (LAME 3.98)
If you listen to 'dragging.mp3' you will hear the pitch (and tempo) suddenly shift down a tad about 15.8 seconds in. This then lasts until the end of the track. correct.mp3 plays correctly. I have not examined the MP3 frame headers but it looks as if LAME has switched sample rates on us part-way through the file. We would not handle that correctly (although just one errant frame would not throw us off in this way). I will see if I can lay my hands on the source material for you. Encoder parameters are: VBR new, Quality 7, 44kHz.
I had a bug report from another user of a similar (but different in detail) problem but I think that might be a red herring. Worryingly, his problem did *not* go away with LAME 3.98.2 I have asked him to try LAME 3.96.1. I will keep you posted. [Edit] This does indeed seem to be a red herring - LAME 3.96.1 does it too. Some other force seems to be at work. Leave this one with me. [/Edit].
You know, I hope I'm right about all this. It would be terribly embarassing otherwise.
Addendum: I just took a quick look at the MP3 frame heaers. They are correct (they all report 44kHz). But LAME switching (internally) from 44kHz to 48kHz would account for the discrepancy in track duration, pretty much. I'll try to get you the source material.
This post has been edited by Paul Sanders: Nov 9 2008, 12:53
robert
post Nov 9 2008, 13:45
LAME developer
I've just compared 3.98 with 3.98.2 again, and there are no changes which would count as a fix for the described problem. As the problem seemed to get resolved by sending an update, I believe it could have been "solved" because of a different use case.
<speculation mode on>
Maybe the user had a bunch of files, mostly 44.1 kHz stuff with one 48 kHz file inbetween. After sending him the update, the user encoded only the problem sample and was happy now.
</speculation mode off>
We need more info about what really happened and how the workflow looks like. (Are we talking about lame_enc.dll or lame.exe) There may be some bugs in LAME, but it may be a misunderstanding in using LAME too.
QUOTE (Paul Sanders @ Nov 9 2008, 12:31) *
As duration was extended, it is more like feeding a 48 kHz file and telling LAME the samplerate is 44.1 kHz.
This post has been edited by robert: Nov 9 2008, 13:42
Paul Sanders
post Nov 9 2008, 14:43
Robert,
Thanks for doing that. As a result, I remain worried that we are still shipping flawed software despite upgrading our users to LAME 3.98.2.
We are talking about lame_enc.dll. None of the things you suggest could feasibly have happened, given the way our software works. If you listen to the 'dragging' sample I think you will be forced to agree. The transition happens right in the middle of a section of music, 15.8 seconds in. Also, the customer was able to reproduce the problem when I asked him to switch back to LAME 3.98 and send me the result.
What I *do* think is that there might have been something subtly different in the encoding process. One file has a couple of seconds of silence on the front that the other does not. Anyway, I will see if I can get hold of the source material and reproduce the problem here. I for one would like to see this laid to rest. In the meantime, thank you for your time.
Update, 11Nov08:
Well, the customer has kindly sent me his files and I cannot reproduce the fault. I think, on balance, I am relieved about this. Nevertheless, *something* is going on and I can't imagine how my own software could cause an effect like this. Anyway, thank you again Robert for your time. If I learn anything more I will post back to this thread. Would someone please reply to this message so that I can make a new post, should I need to in future. Thanks.
This post has been edited by Paul Sanders: Nov 11 2008, 11:41
RSS Lo-Fi Version Time is now: 5th May 2015 - 03:35
