2 Pages V   1 2 >
"Undoing" AutoCapitilise ?
swayzak
post Nov 8 2008, 01:15
hi
After a few too many glasses of wine ( wink.gif ) I stupidly Capitilised my entire 160GB music collection - thereby correcting some annoying problems with letters, but creating annoying problems
e.g all "DJ"s became Dj, MCs to Mc, vol II to vol Ii, CD1 to Cd1 etc.
Is there anyway I can correct this relatively painlessly ?
PS. FB2K is far to powerful a tool to be toyed with on alcohol ...
Andreasvb
post Nov 8 2008, 01:27
You can use Mp3tag and create actions that replaces specific words.
I've several for e.g.
dj = DJ
Ft. = feat.
Vs = vs.
It's very powerful, and free.
Give it a try.
Windows 8.1u3 Pro x64 Media Center // foobar2000 1.3.7
swayzak
post Nov 8 2008, 01:31
QUOTE (Andreasvb @ Nov 7 2008, 18:27) *
dj = DJ
Ft. = feat.
Vs = vs.
Give it a try.
thanks
just installed it & will give it a go !
PS Is this program better suited than FB2K to do this ?
This post has been edited by swayzak: Nov 8 2008, 01:40
Yirkha
post Nov 8 2008, 01:42
Group: FB2K Moderator
Awfully late, however:
Properties for all items > Right-click on "Track title" whatever you mangled > Format from Other Fields... > "$replace(%title%,Dj,DJ,Mc,MC,Ii,II,Cd,CD)" etc. > Review, apply.
Canar
post Nov 8 2008, 02:16
QUOTE (swayzak @ Nov 7 2008, 16:31) *
IMO, not at all. There have been a few people recommending third-party software for tasks that foobar2000 can perform lately. This is silly and should stop.
2. Assume good faith.
Lyx
post Nov 8 2008, 02:42
Here's a better fix, since i became "victim" of the same problem a while ago:
[$trim($replace($meta(title)' ',' ep ',' EP ',' Ep ',' EP ',' cd ',' CD ',' Cd ',' CD ',' dj ',' DJ ',' Dj ',' DJ ',' Ii ',' II ',' Iii ',' III ',' Iv ',' IV ',' Vi ',' VI ',' Vii ',' VII ',' Viii ',' VIII ',' Ix ',' IX '))]
Replace $meta(title) with any field of your choice.
Explanation:
This avoids three issues. First, by making the whole string [conditional], the return will never be "?" and therefore the field will not be created if it doesn't exist. Second, by using $meta() it avoids fieldremappings. Third, by first adding a space to the end of the value and then trimming it away again, you avoid accidentally doing false matches. For example, ' ep' would also match ' episode', thus turning it into ' EPisode'. Since there is no way to define "end of value", i simply cheat by first adding a space to the end of the value, so that we can just match ' ep '. Then after the replacement i $trim the space away again.
Frank Bicking
post Nov 8 2008, 02:46
You don't actually need any of those apostrophes:
[$trim($replace($meta(title) , ep , EP , Ep , EP , cd , CD , Cd , CD , dj , DJ , Dj , DJ , Ii , II , Iii , III , Iv , IV , Vi , VI , Vii , VII , Viii , VIII , Ix , IX ))]
Lyx
post Nov 8 2008, 02:47
Same reply as yesterday. If whitespace is important, i prefer to explicitely quote it, regardless of it not being "required".
If you can give me a hint how i can set a monospace font for all formattingstring inputareas in fb2k, i may drop that habbit :)
This post has been edited by Lyx: Nov 8 2008, 02:49
Lyx
post Nov 8 2008, 03:09
P.S.:
Doing such replacement operations for MC can result in false matches, because there IS an abbreviation which is capitalized as "Mc". You dont want "Mc Donalds" turned into "MC Donalds", right? For that case, better do a manual DB search and then apply a fix to handselected set of tracks.
kwanbis
post Nov 8 2008, 23:28
Group: Developer (Donating)
QUOTE (Lyx @ Nov 8 2008, 01:42) *
Sorry, what do you mean?
MAREO: http://www.webearce.com.ar
Lyx
post Nov 8 2008, 23:33
QUOTE (kwanbis @ Nov 8 2008, 23:28) *
Example: %title% will use the filename if the title-field is missing. In masstagging-scripts however, you typically do not want a file which as no title to get the filename applied as title. Especially not in a script which is supposed to only correct wrong capitalization.
kwanbis
post Nov 8 2008, 23:47
QUOTE (Lyx @ Nov 8 2008, 22:33) *
really? i never seen that behavior before, and i use masstager, a lot (not that it means that i know it wink.gif).
so you mean that if i have a script like:
Format Value: Destination Field: TITLE: Formating Pattern: $ansi(%title%)
but there is no TITLE field, i would get $ansi($filename)?
Lyx
post Nov 8 2008, 23:52
Just tested - the answer is "yes".
swayzak
post Nov 9 2008, 01:08
Wow - so many further helpful replies ! Thanks.
However, I have again consumed several glasses of red wine so will refrain from implementing suggestions until tomorrow ... smile.gif
swayzak
post Nov 9 2008, 01:21
Post #15
QUOTE (swayzak @ Nov 8 2008, 18:08) *
Actually that's a lie.
Here is a first attempt using "title" - the new value for Roman numerals is unchanged !? Am I doing something wrong ?
Lyx
post Nov 9 2008, 02:30
Post #16
Works here with 0.9.6 beta. The behaviour of that input-field by the way is VERY WEIRD here (inputfield-limit is set by window-width - and no scrolling allowed).
edit: inputfield length issue described above was reported and verified.
This post has been edited by Lyx: Nov 9 2008, 02:52
Yirkha
post Nov 9 2008, 04:52
Post #17
You'd need to add another space between "$replace(" and "$meta" for it to work at the beginning of the title. As well as add another set with a dot for it to work with titles like "Ii. Adagio".
swayzak
post Nov 9 2008, 12:00
Post #18
QUOTE (Yirkha @ Nov 8 2008, 21:52) *
Brilliant - thanks again.
There does seem to be a character limit though - after adding most Roman numerals with dots I couldn't type in V. . It just wouldn't let me.
ie. I got as far as :
[$trim($replace( $meta(title) , ep , EP , Ep , EP , cd , CD , Cd , CD , dj , DJ , Dj , DJ , Ii , II , Iii , III , Iv , IV , Vi , VI , Vii , VII , Viii , VIII , I. , I , Ix , IX , Ii. , II , Iii. , III , Iv. , IV , Vi. , VI , Vii. , VII , Viii., VIII , Ix. , IX , X. , X , Xi. , XI , Xii. , XII , Xiii. , XIII , Xiv. , XIV ))]
This post has been edited by swayzak: Nov 9 2008, 12:04
swayzak
post Nov 9 2008, 12:59
Post #19
I've tried to adapt that string to correct the album field as well - but it seems to still want to change the title field .. ??
Am I doing this wrong ?
Yirkha
post Nov 9 2008, 13:07
Post #20
The column "Title" is apparently only for reference, the old value of the field you selected is not shown.
swayzak
post Nov 9 2008, 13:22
Post #21
QUOTE (Yirkha @ Nov 9 2008, 06:07) *
Ah - so if I go with this, I'm not going to rename all those tracks to the new album value ?
Yirkha
post Nov 9 2008, 13:26
Post #22
No.
Besides, no changes are done to your files until you close the Properties dialog, so you can safely verify the result. You would save yourself a lot of time if you had just tried it right away.
swayzak
post Nov 9 2008, 13:49
Post #23
Does FB2K have an undo function that could correct "accidental" massive changes like this ?
That would be very useful ....
Yirkha
post Nov 9 2008, 14:12
Post #24
No.
The closest you can get to such a feature would probably be opening the Properties dialog twice - once for managing, once as a backup. Then if something goes wrong, you'd display another Properties, copy all data from the backup one to the new one and rewrite it back. (Simply pressing OK on the backup dialog wouldn't work, as it doesn't write anything if no items were changed in it.)
swayzak
post Nov 9 2008, 14:15
Post #25
OK - thanks. That's useful to know ..
2 Pages V   1 2 >
RSS Lo-Fi Version Time is now: 27th March 2015 - 09:45
