"Undoing" AutoCapitilise ?
swayzak
post Nov 8 2008, 01:15
hi
After a few too many glasses of wine ( wink.gif ) I stupidly Capitilised my entire 160GB music collection - thereby correcting some annoying problems with letters, but creating annoying problems
e.g all "DJ"s became Dj, MCs to Mc, vol II to vol Ii, CD1 to Cd1 etc.
Is there anyway I can correct this relatively painlessly ?
PS. FB2K is far to powerful a tool to be toyed with on alcohol ...
Yirkha
post Nov 9 2008, 14:12
Group: FB2K Moderator
No.
The closest you can get to such a feature would probably be opening the Properties dialog twice - once for managing, once as a backup. Then if something goes wrong, you'd display another Properties, copy all data from the backup one to the new one and rewrite it back. (Simply pressing OK on the backup dialog wouldn't work, as it doesn't write anything if no items were changed in it.)
- swayzak   "Undoing" AutoCapitilise ?   Nov 8 2008, 01:15
- - Andreasvb   You can use Mp3tag and create actions that replace...   Nov 8 2008, 01:27
|- - swayzak   QUOTE (Andreasvb @ Nov 7 2008, 18:27) You...   Nov 8 2008, 01:31
|- - Canar   QUOTE (swayzak @ Nov 7 2008, 16:31) PS Is...   Nov 8 2008, 02:16
- - Yirkha   Awfully late, however: Properties for all items ...   Nov 8 2008, 01:42
- - Lyx   Here's a better fix, since i became "vict...   Nov 8 2008, 02:42
|- - kwanbis   QUOTE (Lyx @ Nov 8 2008, 01:42) Second, b...   Nov 8 2008, 23:28
|- - Lyx   QUOTE (kwanbis @ Nov 8 2008, 23:28) QUOTE...   Nov 8 2008, 23:33
|- - kwanbis   QUOTE (Lyx @ Nov 8 2008, 22:33) Example: ...   Nov 8 2008, 23:47
- - Frank Bicking   You don't actually need any of those apostroph...   Nov 8 2008, 02:46
|- - Lyx   Same reply as yesterday. If whitespace is importan...   Nov 8 2008, 02:47
|- - Lyx   P.S.: Doing such replacement operations for MC ca...   Nov 8 2008, 03:09
|- - odyssey   QUOTE (Lyx @ Nov 8 2008, 03:09) P.S.: Do...   Nov 9 2008, 19:20
- - Lyx   Just tested - the answer is "yes".   Nov 8 2008, 23:52
- - swayzak   Wow - so many further helpful replies ! Thanks...   Nov 9 2008, 01:08
|- - swayzak   QUOTE (swayzak @ Nov 8 2008, 18:08) Wow -...   Nov 9 2008, 01:21
- - Lyx   Works here with 0.9.6 beta. The behaviour of that ...   Nov 9 2008, 02:30
- - Yirkha   You'd need to add another space between ...   Nov 9 2008, 04:52
|- - swayzak   QUOTE (Yirkha @ Nov 8 2008, 21:52) You...   Nov 9 2008, 12:00
- - swayzak   I've tried to adapt that string to correct the...   Nov 9 2008, 12:59
- - Yirkha   The column "Title" is apparently only fo...   Nov 9 2008, 13:07
|- - swayzak   QUOTE (Yirkha @ Nov 9 2008, 06:07) The co...   Nov 9 2008, 13:22
- - Yirkha   No. Besides, no changes are done to your files unt...   Nov 9 2008, 13:26
- - swayzak   Thanks. Does FB2K have an undo function that coul...   Nov 9 2008, 13:49
- - Yirkha   No. The closest you can get to such a feature woul...   Nov 9 2008, 14:12
- - swayzak   OK - thanks. That's useful to know ..   Nov 9 2008, 14:15
- - Mar2zz   What is the order of process in your string, odyss...   Nov 9 2008, 20:20
|- - odyssey   QUOTE (Mar2zz @ Nov 9 2008, 20:20) What i...   Nov 9 2008, 22:27
- - Purple Monkey   I think Mar2zz meant that if you have the title ...   Nov 10 2008, 00:13
- - odyssey   I see it now. It's true with the string I post...   Nov 10 2008, 09:36
- - Mar2zz   That could be solved with nesting your string insi...   Nov 10 2008, 11:17
- - odyssey   AFAIR, that's exactly what I'm doing. The ...   Nov 10 2008, 13:21
- - Lyx   Coming soon to a screen near you: From the peop...   Nov 10 2008, 18:39
- - foorious   Hi everyone, Just a few words to say that unless ...   Nov 16 2008, 03:34
RSS Lo-Fi Version Time is now: 2nd August 2015 - 14:16
