> Hydrogenaudio Forum Rules
- No Warez. This includes warez links, cracks and/or requests for help in getting illegal software or copyrighted music tracks!
- No Spamming or Trolling on the boards, this includes useless posts, trying to only increase post count or trying to deliberately create a flame war.
- No Hateful or Disrespectful posts. This includes: bashing, name-calling or insults directed at a board member.
Which LAME VBR settings do you use?, Poll regarding LAME VBR preferences
LAME VBR Preferences
What VBR setting do you use?
-V0 (.XXX) (--[alt-]preset [fast] extreme) [ 125 ] ** [28.28%]
-V1 (.XXX) [ 17 ] ** [3.85%]
-V2 (.XXX) (--[alt-]preset [fast] standard) [ 171 ] ** [38.69%]
-V3 (.XXX) [ 43 ] ** [9.73%]
-V4 (.XXX) (--[alt-]preset [fast] medium) [ 23 ] ** [5.20%]
-V5 (.XXX) [ 52 ] ** [11.76%]
-V6 (.XXX) [ 7 ] ** [1.58%]
-V7 (.XXX) [ 0 ] ** [0.00%]
-V8 (.XXX) or -V9 (.XXX) [ 1 ] ** [0.23%]
Other [ 3 ] ** [0.68%]
What LAME version do you use?
3.98 (.2) [ 385 ] ** [87.10%]
3.97 [ 39 ] ** [8.82%]
3.90.3 [ 12 ] ** [2.71%]
Other [ 6 ] ** [1.36%]
If using 3.98, do you use floating point values?
Yes [ 57 ] ** [12.90%]
No [ 333 ] ** [75.34%]
I don't use 3.98 [ 52 ] ** [11.76%]
Total Votes: 603
Synthetic Soul
post Oct 20 2008, 18:23
Following memomai's thread on the subject, a poll regarding your LAME VBR habits.
NB: If you use -V5.5, choose the "-V5 (.XXX)" option.
If you don't use VBR, don't bother contributing; this poll is for LAME VBR users only.
This post has been edited by Synthetic Soul: Oct 21 2008, 19:15
I'm on a horse.
GeneV
post Jul 3 2009, 14:36
I went through a couple of test with a few pop/rock songs, comparing ABR 160 and 192 vs. VBR at similar bitrates.
I made ABX-Tests and the outcome is that ABR clearly sounds better.
It should be mentioned that I always use the -q 0 switch, which increases encoding time but seems to deliver significantly better quality.
I also compared different ABR bitrates. The optimum seems to be 192. I found that 224 or more do not produce audible improvements,
while 160 is only slightly less in qualitiy and 128 a tolerable value, if size matters at least as much as quality.
So my default encoding options are: --abr 192 -q 0
Peace
Gene
halb27
post Jul 3 2009, 18:53
QUOTE (GeneV @ Jul 3 2009, 15:36) *
... I made ABX-Tests and the outcome is that ABR clearly sounds better. ...
Do you use 3.98?
I've been an ABR advocate for a long time before 3.98 came out (maybe I still am at very high bitrate ABR 250...300, but it's not very relevant to me any more).
With 3.98 however I can hardly imagine samples where ABR is clearly better than VBR in your bitrate range though ABR certainly is fine too.
GeneV
post Jul 10 2009, 21:40
QUOTE (halb27 @ Jul 3 2009, 19:53) *
Do you use 3.98?
OK, the tests were back in Jan.2008 and I used 3.98beta. Maybe things turn out different with 3.98.2 - I haven't tested that.
So THX for the hint, maybe I should repeat the tests based on the lastest stable version (I guess it's 3.98.2).
GeneV
post Oct 11 2009, 19:02
QUOTE (GeneV @ Jul 10 2009, 21:40) *
Do you use 3.98?
Coming back to my own posting I'd like to add this:
I finally made some new ABX-tests with lame 3.98.2. The outcome again is that with the same bitrate ABR sounds slightly better than VBR. Possible explanation is: With ABR I can effectively use the -q0 switch, which is ignored(!) when using VBR (-V2 is always q=2, -V3 is always q=3 etc., even if -q0 is specified sad.gif ). Although the encoding time significantly increases with -q0 compared to -q2 or less, I don't care, because on my machine encoding is still fast enough. What counts is that I get better quality at the same bitrate resp. more qualtiy with lower filesize.
Cheers
Gene
- Synthetic Soul   Which LAME VBR settings do you use?   Oct 20 2008, 18:23
- - Bodhi   V5 3.98.2 No floating point (Since today...)   Oct 20 2008, 18:30
- - memomai   thanks Synthetic_Soul, perfect poll!   Oct 20 2008, 18:37
- - zipr   I use 3.98.2 with V2. I probably could get by with...   Oct 20 2008, 18:40
- - xmixahlx   3.98.2 + -V2   Oct 20 2008, 18:54
- - Neasden   -V 0 (excessive but this is my comfort zone) LAME...   Oct 20 2008, 19:25
- - skelly831   3.98.2, -V 5, no floating point values, keep it si...   Oct 20 2008, 19:41
- - /mnt   Am still using V2, since V0 sometimes only does so...   Oct 20 2008, 19:56
- - Slipstreem   Voted! 3.98.2 at -V3 with no floating point us...   Oct 20 2008, 20:11
- - Alexxander   I use v3.98.2, -V2 for my "mobile music...   Oct 20 2008, 21:00
- - mr budzone   I actually went from -V5 to V5.7 on my portable, I...   Oct 20 2008, 21:18
- - lvqcl   3.98.2, -V 2. Winamp, foobar2000, CDex... They al...   Oct 20 2008, 21:40
- - houyhnhnm   V2, 3.98.2, no floating point values. 200420052006...   Oct 20 2008, 22:22
|- - melomaniac   QUOTE (houyhnhnm @ Oct 20 2008, 23:22) V2...   Oct 21 2008, 10:20
- - twostar   I voted 3.98.2 and -V2. Just a sidenote, the last...   Oct 20 2008, 23:32
- - kornchild2002   I chose -V 3 with Lame 3.98.2 and no floating poin...   Oct 21 2008, 00:49
- - memomai   QUOTE I voted 3.98.2 and -V2. Just a sidenote, th...   Oct 21 2008, 07:46
- - Synthetic Soul   Thanks for the links to other polls, it will be in...   Oct 21 2008, 10:09
- - david.lisb   -V0 -b224 best quality !!   Oct 21 2008, 10:53
|- - PHOYO   QUOTE (david.lisb @ Oct 21 2008, 12:53) -...   Oct 21 2008, 11:10
|- - halb27   QUOTE (david.lisb @ Oct 21 2008, 11:53) -...   Oct 21 2008, 13:59
- - .halverhahn   Version: Lame 3.98.2 Music: V0 Audio Book, Radio P...   Oct 21 2008, 11:21
- - david.lisb   ABR 270 was my favorite, but now: -V0 -b224: the q...   Oct 21 2008, 11:28
|- - kornchild2002   QUOTE (david.lisb @ Oct 21 2008, 04:28) A...   Oct 21 2008, 12:08
|- - halb27   QUOTE (kornchild2002 @ Oct 21 2008, 13:08...   Oct 21 2008, 14:22
|- - pdq   QUOTE (kornchild2002 @ Oct 21 2008, 07:08...   Oct 21 2008, 15:51
|- - /mnt   QUOTE (kornchild2002 @ Oct 21 2008, 12:08...   Oct 21 2008, 19:51
- - bug80   version: 3.98.2 portable: V4   Oct 21 2008, 11:28
- - Lyx   Using V3, because i don't keep a lossless back...   Oct 21 2008, 11:38
- - Slipstreem   As -V0 -b224 is neither an option in this poll nor...   Oct 21 2008, 12:23
- - poleepkwa   I have been using V5 as well after I Synthetic rec...   Oct 21 2008, 12:42
- - memomai   QUOTE I wonder who voted for 3.90.3 as that is rat...   Oct 21 2008, 14:48
- - _Raziel-BG   LAME VBR: -V2 LAME version: 3.98.2 Floating point:...   Oct 21 2008, 15:05
- - Synthetic Soul   With regard to newer versions vs 3.90.3: it should...   Oct 21 2008, 15:18
|- - kornchild2002   QUOTE (memomai @ Oct 21 2008, 07:48) some...   Oct 21 2008, 15:47
|- - Synthetic Soul   QUOTE (kornchild2002 @ Oct 21 2008, 15:47...   Oct 21 2008, 19:06
|- - kornchild2002   QUOTE (memomai @ Oct 21 2008, 09:27) Ever...   Oct 21 2008, 20:08
- - memomai   QUOTE Just to make it clear: my comment wasn't...   Oct 21 2008, 16:27
- - null-null-pi   hi there, first post for me on ha.org ^^ i use 3....   Oct 22 2008, 18:08
- - TRE   I use -V5 (3.98.2) as it is a good ratio size / qu...   Oct 23 2008, 07:46
- - sketchy_c   I listen to my own stuff on Vorbis (q5), but if I...   Oct 24 2008, 12:54
- - audiobookie   File size for spoken word is important to me. Was ...   Nov 5 2008, 02:01
- - Xenno   Hangin with 3.96.1 and alt pre ext   Nov 5 2008, 04:23
- - halb27   The poll results are very interesting, especially ...   Nov 5 2008, 18:56
- - pdq   I am not so much surprised that a few people use -...   Nov 5 2008, 19:07
|- - halb27   QUOTE (pdq @ Nov 5 2008, 20:07) I am not ...   Nov 5 2008, 22:32
- - Maggi   I'm using LAME 3.98 (not yet updated to .2) wi...   Nov 6 2008, 09:31
|- - Alexxander   QUOTE (Maggi @ Nov 6 2008, 10:31) I'm...   Nov 6 2008, 09:50
|- - Maggi   QUOTE (Alexxander @ Nov 6 2008, 09:50) QU...   Nov 6 2008, 10:07
- - GeSomeone   up-to-date LAME 3.98.2 For (my) highest quality...   Nov 6 2008, 18:43
- - quackalist   Voted V0, 3.98, not that I imagine it betters V2 w...   Nov 7 2008, 01:58
- - Kitsuned   My two cents buys a vote for: Lame 3.98 -V3 setti...   Nov 14 2008, 12:48
- - ajfoucault   3.98.2 V0 Real me do this! JK~!   Dec 4 2008, 05:29
- - antman   Lame 3.98.2/V5.7   Dec 5 2008, 03:10
|- - somemightsay   3.98.2 -V0   Dec 5 2008, 03:38
- - xSerpentx   V4 LAME 3.98 I'm actually re-ripping. I want...   Dec 13 2008, 02:44
- - Frankie   Mostly V4 for use with my iAudio F2. Up to V0 for ...   Apr 3 2009, 18:43
- - rick.hughes   I play my FLAC archive on my home stereo, and only...   Apr 3 2009, 19:30
- - trout   -V 1.337   Apr 3 2009, 19:46
- - skope   Hey everyone! I stick to using 3.90.3modified ...   May 9 2009, 22:04
- - PaJaRo   When I transcode from a lossy source (I know it is...   May 10 2009, 19:13
- - Pike84   What is the practical significance of using floati...   May 12 2009, 09:39
- - halb27   IMO the advantage of non-integer -V values is with...   May 12 2009, 11:26
|- - Pike84   So, it's just about being able to use decimal ...   May 13 2009, 09:03
|- - halb27   QUOTE (Pike84 @ May 13 2009, 09:03) So, i...   May 13 2009, 11:21
- - Pike84   Well, I'm not sure if I understand this floati...   May 13 2009, 15:29
- - halb27   It's not about implementation, just about the ...   May 13 2009, 15:35
- - Pike84   Oh, ok. I thought it had some deeper meaning behin...   May 13 2009, 16:24
- - ZinCh   Sometimes I am using floating point to get target ...   May 17 2009, 20:40
- - gasmann   It looks like I'm stuck with LAME 3.98.2 -V 5 ...   May 18 2009, 19:36
- - d_headshot   What are floating point values?   May 20 2009, 03:44
|- - WonderSlug   QUOTE (d_headshot @ May 19 2009, 19:44) W...   May 20 2009, 04:42
- - lock67ca   Most of my collection is ripped with 3.97b at vbr...   Jun 21 2009, 13:49
- - GeneV   I went through a couple of test with a few pop/roc...   Jul 3 2009, 14:36
|- - halb27   QUOTE (GeneV @ Jul 3 2009, 15:36) ... I m...   Jul 3 2009, 18:53
|- - GeneV   QUOTE (halb27 @ Jul 3 2009, 19:53) QUOTE ...   Jul 10 2009, 21:40
|- - GeneV   QUOTE (GeneV @ Jul 10 2009, 21:40) QUOTE ...   Oct 11 2009, 19:02
|- - lvqcl   QUOTE (GeneV @ Oct 11 2009, 22:02) Possib...   Oct 12 2009, 15:54
|- - GeneV   QUOTE (lvqcl @ Oct 12 2009, 15:54) QUOTE ...   Oct 14 2009, 15:58
|- - dv1989   I don't want to bump for its own sake, and thi...   May 27 2010, 13:58
- - Rei Murasame   I go with Lame 3.98, -V2. The distribution of the ...   Jul 3 2009, 19:36
- - kwanbis   What you mean? almost 40% use V2.   Jul 3 2009, 20:22
- - Rei Murasame   QUOTE (kwanbis @ Jul 3 2009, 20:22) What ...   Jul 3 2009, 21:25
|- - rpp3po   QUOTE (Rei Murasame @ Jul 3 2009, 22:25) ...   Jul 11 2009, 05:04
- - kwanbis   I'm sure 95% just to be safe No abx to prove   Jul 3 2009, 22:21
- - jmcguckin   while I stick to AAC for my primary lossy format, ...   Oct 14 2009, 17:19
- - vvill   I switch between v0 and v2 for music, depending on...   Nov 12 2009, 17:08
- - Soviet Commissar   I actually regularly use V0 and V2, one for classi...   Nov 12 2009, 22:28
- - moozooh   LAME has become surprisingly good in the last few ...   May 27 2010, 14:27
|- - а.п.т.   QUOTE (moozooh @ May 27 2010, 16:27) Some...   May 28 2010, 12:09
- - moozooh   Actually it's somewhat easier. If I know an al...   Jun 1 2010, 00:21
Closed TopicStart new topic
RSS Lo-Fi Version Time is now: 26th May 2015 - 05:58
