CUETools versions 1.9.5 through 2.1.5 (current), AccurateRip support & more
Gregory S. Chudo...
post Oct 2 2008, 12:26
Please welcome, CUETools v2.1.4. (CUETools download page) or direct link: http://www.cuetools.net/install/CUETools_2.1.4.rar
16.04.2012: CUETools 2.1.4:
* CTDB 2.0: now ignoring pregap in parity calculations
* CTDB 2.0: popular CDs can have twice larger correction files
* CTDB 2.0: confidence values no longer include AccurateRip data
* CTDB 2.0: simplified (per-track) verification log
* CTDB 2.0: faster verification process with less network traffic
* CUERipper: support for some older drives, like PLEXTOR W1210A
* CUERipper: support for cover art
* CUERipper: main window resizable
* CUERipper: real test&copy mode
* CUERipper: options dialog
* Tagging: support for release date, release country, disc subtitle, label, catalog number, comment
* Local DB: can now refresh folder, removing missing files from database and adding new files.
* Codecs: LAME encoder updated to use libmp3lame.dll, which is now included in CUETools download (version 3.98.4)
* Various bug fixes
14.06.2011: CUETools 2.1.2:
* AccurateRip v2 support (without cross-pressing verification)
* EAC CTDB plugin
* CTDB now supports musicbrainz Next Generation Schema (NGS) metadata. Old musicbrainz library removed. New musicbrainz NGS metadata can now be used in filename templates, including %discname%, %label%, %releasedate%, %country%, %releasedateandlabel%, %discnumberandname%
* CTDB submissions are now based on the same data that was used when verifying, so 'submit' script was removed, and data is submitted after verification, after showing confirmation dialog
* CTDB verification is now much faster
* Local DB: option to purge records
* Local DB: now shown in the same window as folder browser
* metadata editing window size is now saved in settings
* CUERipper now sends CD barcode and rip quality when submitting
* support for wierd CDs with two data tracks before audio
IMPORTANT: .NET Framework 2.0 (SP2) required. If you get a "could not load file or assembly" error message for CUETools.Codecs.TTA/APE/WavPack/FLAC, make sure the recent version of Visual C++ 2008 runtime files (x86,x64) is installed.
You can always download the latest source code from project's SVN repository at SourceForge.
Instructions for svn access can be found here.
This post has been edited by Gregory S. Chudov: Apr 17 2012, 03:55
CUETools 2.1.4
Alex B
post Oct 11 2008, 13:06
Thank you for the excellent new CUEtools features.
I wonder if it would be possible to add a new simple filename extension corrector that would not need to check the audio files on the disk at all.
Then you could just select the desired target extension (wav, flac, ape or wv) and mass process a bunch of cue sheets even if the audio files are not organized in separate folders.
Personally, I have stored my "single file + cue" multi-disc albums in single album folders so I would need to reorganize them before I could use the filename corrector tool for fixing the cue sheets after a file format change.
yury_usa
post Oct 11 2008, 22:59
Question:
Original Log
Exact Audio Copy V0.99 prebeta 3 from 28. July 2007
EAC extraction logfile from 15. September 2008, 16:35
California Guitar Trio / Yamanashi Blues
Used drive : YAMAHA CRW2100E Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : Yes
Make use of C2 pointers : No
Read offset correction : 733
Overread into Lead-In and Lead-Out : Yes
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Installed external ASPI interface
Gap handling : Appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 768 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Archivos de programa\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -6 -V -T "ARTIST=%a" -T "TITLE=%t" -T "ALBUM=%g" -T "DATE=%y" -T "TRACKNUMBER=%n" -T "GENRE=%m" -T "COMMENT=%e" %s -o %d
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 2:21.52 | 0 | 10626
2 | 2:21.52 | 2:10.05 | 10627 | 20381
3 | 4:31.57 | 1:29.70 | 20382 | 27126
4 | 6:01.52 | 2:01.13 | 27127 | 36214
5 | 8:02.65 | 5:04.62 | 36215 | 59076
6 | 13:07.52 | 1:54.48 | 59077 | 67674
7 | 15:02.25 | 1:19.70 | 67675 | 73669
8 | 16:22.20 | 4:37.32 | 73670 | 94476
9 | 20:59.52 | 1:28.23 | 94477 | 101099
10 | 22:28.00 | 2:17.02 | 101100 | 111376
11 | 24:45.02 | 1:45.43 | 111377 | 119294
12 | 26:30.45 | 1:46.07 | 119295 | 127251
13 | 28:16.52 | 11:44.35 | 127252 | 180086
14 | 40:01.12 | 2:14.70 | 180087 | 190206
15 | 42:16.07 | 3:12.58 | 190207 | 204664
Track 1
Filename D:\Datos\audio rips\01 - Yamanashi Blues.wav
Pre-gap length 0:00:02.00
Peak level 87.1 %
Track quality 100.0 %
Test CRC CB0C5459
Copy CRC CB0C5459
Cannot be verified as accurate (confidence 2) [0C56D51D], AccurateRip returned [6ACB9DE4]
Copy OK
Track 2
Filename D:\Datos\audio rips\02 - Melrose Avenue.wav
Peak level 100.0 %
Test CRC E61F48D9
Copy CRC E61F48D9
Cannot be verified as accurate (confidence 2) [A4E7F44C], AccurateRip returned [8626201C]
Copy OK
Track 3
Filename D:\Datos\audio rips\03 - Corrente.wav
Peak level 45.6 %
Test CRC 0DCED459
Copy CRC 0DCED459
Cannot be verified as accurate (confidence 2) [818FD48C], AccurateRip returned [B1A8D24C]
Copy OK
Track 4
Filename D:\Datos\audio rips\04 - Walk Don't Run.wav
Peak level 92.8 %
Track quality 99.9 %
Test CRC 2740BABB
Copy CRC 2740BABB
Cannot be verified as accurate (confidence 2) [7E0BF22D], AccurateRip returned [288D709D]
Copy OK
Track 5
Filename D:\Datos\audio rips\05 - Ricercar.wav
Peak level 55.9 %
Test CRC 0971BFCF
Copy CRC 0971BFCF
Cannot be verified as accurate (confidence 2) [FE96930D], AccurateRip returned [A7E04B1D]
Copy OK
Track 6
Filename D:\Datos\audio rips\06 - Pipeline.wav
Peak level 97.7 %
Test CRC 6B69F644
Copy CRC 6B69F644
Cannot be verified as accurate (confidence 2) [66C9EB2F], AccurateRip returned [68298E0F]
Copy OK
Track 7
Filename D:\Datos\audio rips\07 - Beeline.wav
Peak level 100.0 %
Test CRC 98FD9219
Copy CRC 98FD9219
Cannot be verified as accurate (confidence 2) [47D2D9C9], AccurateRip returned [EBF33DEF]
Copy OK
Track 8
Filename D:\Datos\audio rips\08 - Chromatic Fugue In D Minor.wav
Peak level 100.0 %
Test CRC 43027130
Copy CRC 43027130
Cannot be verified as accurate (confidence 2) [D14A54B1], AccurateRip returned [9BF87C1B]
Copy OK
Track 9
Filename D:\Datos\audio rips\09 - Tenor Madness.wav
Peak level 97.4 %
Track quality 99.8 %
Test CRC 55607C9F
Copy CRC 55607C9F
Cannot be verified as accurate (confidence 2) [9DE020F5], AccurateRip returned [FCA36A15]
Copy OK
Track 10
Filename D:\Datos\audio rips\10 - Sleewalk.wav
Peak level 69.1 %
Test CRC 934EA7BC
Copy CRC 934EA7BC
Cannot be verified as accurate (confidence 2) [7E619E3B], AccurateRip returned [0BC6DFFB]
Copy OK
Track 11
Filename D:\Datos\audio rips\11 - Carnival.wav
Peak level 66.6 %
Test CRC D54C937A
Copy CRC D54C937A
Cannot be verified as accurate (confidence 2) [200C7AF2], AccurateRip returned [4DB39EE9]
Copy OK
Track 12
Filename D:\Datos\audio rips\12 - Prelude In C Minor.wav
Peak level 54.0 %
Test CRC 22685572
Copy CRC 22685572
Cannot be verified as accurate (confidence 2) [D9E0F7AE], AccurateRip returned [6B5F77AF]
Copy OK
Track 13
Filename D:\Datos\audio rips\13 - Ciaccona.wav
Peak level 61.0 %
Test CRC 38F5A639
Copy CRC 38F5A639
Cannot be verified as accurate (confidence 2) [A29460B6], AccurateRip returned [0F0A5387]
Copy OK
Track 14
Filename D:\Datos\audio rips\14 - Blockhead.wav
Peak level 100.0 %
Test CRC 42266934
Copy CRC 42266934
Cannot be verified as accurate (confidence 2) [C0007BA4], AccurateRip returned [45D75600]
Copy OK
Track 15
Filename D:\Datos\audio rips\15 - Kan-Non Power.wav
Peak level 84.9 %
Test CRC 0A69F0AD
Copy CRC 0A69F0AD
Cannot be verified as accurate (confidence 2) [1AFEE1A0], AccurateRip returned [2F2FAE7B]
Copy OK
No tracks could be verified as accurate
You may have a different pressing from the one(s) in the database
No errors occurred
End of status report
accuraterip result:
[Disc ID: 0015b781-00fd75be-d70aa80f]
Track [ CRC ] Status
01 [0c56d51d] (00/02) No matches
02 [a4e7f44c] (00/02) No matches
03 [818fd48c] (00/02) No matches
04 [7e0bf22d] (00/02) No matches
05 [fe96930d] (00/02) No matches
06 [66c9eb2f] (00/02) No matches
07 [47d2d9c9] (00/02) No matches
08 [d14a54b1] (00/02) No matches
09 [9de020f5] (00/02) No matches
10 [7e619e3b] (00/02) No matches
11 [200c7af2] (00/02) No matches
12 [d9e0f7ae] (00/02) No matches
13 [a29460b6] (00/02) No matches
14 [c0007ba4] (00/02) No matches
15 [1afee1a0] (00/02) No matches
Offsetted by 112:
01 [6acb9de4] (02/02) Accurately ripped as in pressing(s) #1
02 [8626201c] (02/02) Accurately ripped as in pressing(s) #1
03 [b1a8d24c] (02/02) Accurately ripped as in pressing(s) #1
04 [288d709d] (02/02) Accurately ripped as in pressing(s) #1
05 [a7e04b1d] (02/02) Accurately ripped as in pressing(s) #1
06 [68298e0f] (02/02) Accurately ripped as in pressing(s) #1
07 [ebf33def] (02/02) Accurately ripped as in pressing(s) #1
08 [9bf87c1b] (02/02) Accurately ripped as in pressing(s) #1
09 [fca36a15] (02/02) Accurately ripped as in pressing(s) #1
10 [0bc6dffb] (02/02) Accurately ripped as in pressing(s) #1
11 [4db39ee9] (02/02) Accurately ripped as in pressing(s) #1
12 [6b5f77af] (02/02) Accurately ripped as in pressing(s) #1
13 [0f0a5387] (02/02) Accurately ripped as in pressing(s) #1
14 [45d75600] (02/02) Accurately ripped as in pressing(s) #1
15 [2f2fae7b] (02/02) Accurately ripped as in pressing(s) #1
How is this possible? If I go and check offets page (http://www.accuraterip.com/driveoffsets.htm), it's clear that offset for "YAMAHA - CRW2100E" +733. Yet, accuraterip shows "Offsetted by 112" having confidence level 2?
This post has been edited by greynol: Oct 14 2008, 03:30
- Gregory S. Chudov   CUETools versions 1.9.5 through 2.1.5 (current)   Oct 2 2008, 12:26
- - Fandango   WAV output is greyed out<edit> Ah I didn...   Oct 3 2008, 17:11
|- - Gregory S. Chudov   QUOTE (Fandango @ Oct 3 2008, 19:11) WAV ...   Oct 4 2008, 02:48
|- - Fandango   QUOTE (Gregory S. Chudov @ Oct 4 2008, 03...   Oct 4 2008, 14:53
|- - foorious   QUOTE (Gregory S. Chudov @ Oct 3 2008, 19...   Oct 5 2008, 21:58
|- - No Fun   Strange... Can it be that CUE Tools cannot find ri...   Oct 6 2008, 00:53
|- - Gregory S. Chudov   QUOTE (No Fun @ Oct 6 2008, 02:53) Strang...   Oct 6 2008, 15:40
|- - No Fun   QUOTE (Gregory S. Chudov @ Oct 6 2008, 18...   Oct 7 2008, 00:15
|- - Gregory S. Chudov   QUOTE (No Fun @ Oct 7 2008, 02:15) So why...   Oct 7 2008, 23:10
|- - No Fun   QUOTE (Gregory S. Chudov @ Oct 8 2008, 02...   Oct 8 2008, 00:32
- - foorious   Hi, Gregory sent me to this thread from this one :...   Oct 3 2008, 18:17
- - Gregory S. Chudov   I encountered some very strange logs: CODE[Dis...   Oct 4 2008, 22:53
- - No Fun   Gregory S. Chudov Thanks for nice new features...   Oct 4 2008, 23:49
- - Raiden   This is a great tool! I'm using it to batc...   Oct 5 2008, 00:34
|- - Gregory S. Chudov   QUOTE (Raiden @ Oct 5 2008, 02:34) This i...   Oct 5 2008, 14:57
- - Raiden   It now says (excerpt): CODE 19 [8c2ca83c...   Oct 5 2008, 20:39
- - greynol   Maybe 1501 is beyond the window being used. The A...   Oct 7 2008, 04:12
|- - No Fun   QUOTE (greynol @ Oct 7 2008, 07:12) Maybe...   Oct 7 2008, 07:07
- - Moitah   It should be able to find offsets within +/- 2939....   Oct 7 2008, 05:48
- - Gregory S. Chudov   QUOTE (greynol @ Oct 7 2008, 06:12) The l...   Oct 7 2008, 18:25
|- - Gregory S. Chudov   QUOTE (Moitah @ Oct 7 2008, 07:48) By the...   Oct 7 2008, 19:51
- - Gregory S. Chudov   Well, in this case there is no bug. Either your co...   Oct 8 2008, 01:47
|- - No Fun   QUOTE (Gregory S. Chudov @ Oct 8 2008, 04...   Oct 8 2008, 08:58
||- - foorious   QUOTE (No Fun @ Oct 8 2008, 01:58) Creati...   Oct 8 2008, 14:49
|||- - yury_usa   Ok, how is this possible, then? CODEEAC extractio...   Oct 14 2008, 03:25
|||- - greynol   QUOTE (yury_usa @ Oct 13 2008, 19:25) Now...   Oct 14 2008, 03:29
||- - Gregory S. Chudov   QUOTE (No Fun @ Oct 8 2008, 10:58) Maybe ...   Oct 9 2008, 20:35
|- - greynol   QUOTE (Gregory S. Chudov @ Oct 7 2008, 17...   Oct 8 2008, 16:04
|- - Gregory S. Chudov   QUOTE (greynol @ Oct 8 2008, 18:04) QUOTE...   Oct 8 2008, 17:00
- - NachoMan77   Hi Gregory ! thanks a lot for jumpstarting CU...   Oct 8 2008, 13:56
- - spoon   Correct AR has 2 CRCs one for the track, the other...   Oct 8 2008, 16:31
- - Moitah   @spoon: Is there a way to query the AccurateRip da...   Oct 8 2008, 17:34
- - foorious   I think I have the same problem as "No Fun...   Oct 10 2008, 01:24
|- - Gregory S. Chudov   QUOTE (foorious @ Oct 10 2008, 03:24) Gre...   Oct 10 2008, 11:00
- - Moitah   @foorious: I checked freedb/Amazon and it looks l...   Oct 10 2008, 04:01
- - foorious   Oh, that's too bad : I have manually splitted ...   Oct 10 2008, 10:32
|- - Gregory S. Chudov   QUOTE (foorious @ Oct 10 2008, 12:32) How...   Oct 10 2008, 11:14
|- - foorious   QUOTE (Gregory S. Chudov @ Oct 10 2008, 04...   Oct 10 2008, 12:57
||- - Gregory S. Chudov   QUOTE (foorious @ Oct 10 2008, 14:57) I d...   Oct 10 2008, 13:31
|- - Porcus   QUOTE (Gregory S. Chudov @ Oct 10 2008, 12...   Oct 16 2008, 19:14
|- - Gregory S. Chudov   QUOTE (Porcus @ Oct 16 2008, 21:14) (1) I...   Oct 16 2008, 20:47
|- - Porcus   QUOTE (Gregory S. Chudov @ Oct 16 2008, 21...   Oct 17 2008, 01:06
|- - Gregory S. Chudov   QUOTE (Porcus @ Oct 17 2008, 03:06) Accur...   Oct 20 2008, 06:42
|- - Porcus   QUOTE (Gregory S. Chudov @ Oct 20 2008, 07...   Oct 20 2008, 10:38
|- - Gregory S. Chudov   QUOTE (Porcus @ Oct 20 2008, 12:38) First...   Oct 20 2008, 11:44
|- - Porcus   QUOTE (Gregory S. Chudov @ Oct 20 2008, 12...   Oct 20 2008, 15:17
- - NachoMan77   Gregory, I can't make the "encode if % o...   Oct 11 2008, 00:29
|- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 11 2008, 02:29) G...   Oct 11 2008, 12:39
|- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 11 2008, 02:29) W...   Oct 12 2008, 15:29
|- - NachoMan77   QUOTE (Gregory S. Chudov @ Oct 12 2008, 08...   Oct 12 2008, 16:33
- - Alex B   Thank you for the excellent new CUEtools features....   Oct 11 2008, 13:06
|- - yury_usa   Question: Original Log CODEExact Audio Copy V0.99...   Oct 11 2008, 22:59
|- - Fandango   QUOTE (yury_usa @ Oct 11 2008, 23:59) How...   Oct 11 2008, 23:41
- - yury_usa   Fandango So this pressing is different by an offse...   Oct 12 2008, 00:42
|- - Fandango   QUOTE (yury_usa @ Oct 12 2008, 01:42) Fan...   Oct 12 2008, 00:45
- - Alex B   I created a mockup to demonstrate my suggestion: ...   Oct 12 2008, 15:54
- - Moitah   I thought this was pretty cool, it runs fine with ...   Oct 12 2008, 19:47
|- - Gregory S. Chudov   QUOTE (Moitah @ Oct 12 2008, 21:47) I tho...   Oct 12 2008, 23:32
||- - NachoMan77   QUOTE (Gregory S. Chudov @ Oct 12 2008, 16...   Oct 12 2008, 23:45
|- - Corwin   QUOTE (Moitah @ Oct 12 2008, 10:47) I tho...   Oct 19 2008, 11:45
- - Gregory S. Chudov   Update: some bugs were fixed, fresher build can be...   Oct 13 2008, 05:03
|- - Alex B   QUOTE (Gregory S. Chudov @ Oct 13 2008, 07...   Oct 13 2008, 16:39
- - NachoMan77   Gregory, when converting from single APE to single...   Oct 13 2008, 12:30
|- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 13 2008, 14:30) G...   Oct 13 2008, 13:51
- - NachoMan77   Also I see that you're embedding the LOG file ...   Oct 13 2008, 12:54
- - Caleb   Hey, Great job on a great utility! Does th...   Oct 13 2008, 14:54
|- - Gregory S. Chudov   QUOTE (Caleb @ Oct 13 2008, 16:54) Hey, ...   Oct 13 2008, 17:42
- - Alex B   I converted a "tagged APE disc image + CUE...   Oct 13 2008, 15:18
|- - Gregory S. Chudov   QUOTE (Alex B @ Oct 13 2008, 17:18) I con...   Oct 13 2008, 17:23
- - yury_usa   Would it be possible to generate AccurateRip repor...   Oct 14 2008, 18:47
|- - Gregory S. Chudov   QUOTE (yury_usa @ Oct 14 2008, 20:47) Wou...   Oct 14 2008, 19:30
- - naturfreak   Thanks for this useful tool. A small feature requ...   Oct 14 2008, 22:07
- - NachoMan77   Gregory, Update5 is working fine. Got a couple of...   Oct 15 2008, 06:06
|- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 15 2008, 08:06) 1...   Oct 16 2008, 21:30
- - Caleb   QUOTE (Gregory S. Chudov @ Oct 13 2008, 18...   Oct 15 2008, 09:58
|- - Gregory S. Chudov   QUOTE (Caleb @ Oct 15 2008, 11:58) Hi Gre...   Oct 17 2008, 19:13
- - NachoMan77   Hi Gregory ! here's my report on Update 6...   Oct 18 2008, 01:43
|- - NachoMan77   QUOTE (NachoMan77 @ Oct 17 2008, 18:43) H...   Oct 19 2008, 00:29
|- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 19 2008, 02:29) O...   Oct 19 2008, 03:02
- - Porcus   Feature request: duplicates detection. For "d...   Oct 18 2008, 15:20
- - Corwin   Just wanted to let people know that the "CUE ...   Oct 19 2008, 09:41
- - Corwin   Accurite rip reports the offset is wrong. I found ...   Oct 19 2008, 09:53
|- - Gregory S. Chudov   QUOTE (Corwin @ Oct 19 2008, 11:53) Accur...   Oct 19 2008, 12:44
- - Caleb   QUOTE (Gregory S. Chudov @ Oct 17 2008, 20...   Oct 19 2008, 12:28
|- - Gregory S. Chudov   QUOTE (Caleb @ Oct 19 2008, 14:28) I trie...   Oct 19 2008, 14:02
||- - mhudson7   I love this tool! Thanks to everybody for the...   Oct 19 2008, 16:43
|- - Corwin   QUOTE (Caleb @ Oct 19 2008, 03:28) Well I...   Oct 20 2008, 08:25
|- - Gregory S. Chudov   QUOTE (Caleb @ Oct 19 2008, 14:28) I trie...   Oct 22 2008, 12:55
- - NachoMan77   Gregory, I can confirm that Update7 is now workin...   Oct 19 2008, 14:50
|- - fredhammersmith   I have a question: can CueTools process hi-rez fil...   Oct 19 2008, 15:34
- - Moitah   @Corwin: I will see about posting a WAV-only build...   Oct 19 2008, 19:09
- - NightOwl   Moitah and Gregory, thank you so much for CUE Tool...   Oct 22 2008, 21:56
- - NightOwl   I started using the latest Update 8 (after replaci...   Oct 23 2008, 01:03
|- - Gregory S. Chudov   QUOTE (NightOwl @ Oct 23 2008, 03:03) I s...   Oct 23 2008, 08:13
- - NightOwl   OK, thanks for the explanation, Gregory. The toolt...   Oct 23 2008, 17:15
- - Moitah   IMHO even if the modified times are preserved, wri...   Oct 23 2008, 19:12
|- - NachoMan77   QUOTE (Moitah @ Oct 23 2008, 12:12) IMHO ...   Oct 23 2008, 21:20
- - NachoMan77   Gregory, while using the "Verify, then encod...   Oct 25 2008, 21:14
- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 25 2008, 23:14) G...   Oct 26 2008, 09:31
- - NachoMan77   QUOTE (Gregory S. Chudov @ Oct 26 2008, 02...   Oct 26 2008, 14:32
27 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 27th February 2015 - 05:46
