CUETools versions 1.9.5 through 2.1.5 (current), AccurateRip support & more
Gregory S. Chudo...
post Oct 2 2008, 12:26
Please welcome, CUETools v2.1.4. (CUETools download page) or direct link: http://www.cuetools.net/install/CUETools_2.1.4.rar
16.04.2012: CUETools 2.1.4:
* CTDB 2.0: now ignoring pregap in parity calculations
* CTDB 2.0: popular CDs can have twice larger correction files
* CTDB 2.0: confidence values no longer include AccurateRip data
* CTDB 2.0: simplified (per-track) verification log
* CTDB 2.0: faster verification process with less network traffic
* CUERipper: support for some older drives, like PLEXTOR W1210A
* CUERipper: support for cover art
* CUERipper: main window resizable
* CUERipper: real test&copy mode
* CUERipper: options dialog
* Tagging: support for release date, release country, disc subtitle, label, catalog number, comment
* Local DB: can now refresh folder, removing missing files from database and adding new files.
* Codecs: LAME encoder updated to use libmp3lame.dll, which is now included in CUETools download (version 3.98.4)
* Various bug fixes
14.06.2011: CUETools 2.1.2:
* AccurateRip v2 support (without cross-pressing verification)
* EAC CTDB plugin
* CTDB now supports musicbrainz Next Generation Schema (NGS) metadata. Old musicbrainz library removed. New musicbrainz NGS metadata can now be used in filename templates, including %discname%, %label%, %releasedate%, %country%, %releasedateandlabel%, %discnumberandname%
* CTDB submissions are now based on the same data that was used when verifying, so 'submit' script was removed, and data is submitted after verification, after showing confirmation dialog
* CTDB verification is now much faster
* Local DB: option to purge records
* Local DB: now shown in the same window as folder browser
* metadata editing window size is now saved in settings
* CUERipper now sends CD barcode and rip quality when submitting
* support for wierd CDs with two data tracks before audio
IMPORTANT: .NET Framework 2.0 (SP2) required. If you get a "could not load file or assembly" error message for CUETools.Codecs.TTA/APE/WavPack/FLAC, make sure the recent version of Visual C++ 2008 runtime files (x86,x64) is installed.
You can always download the latest source code from project's SVN repository at SourceForge.
Instructions for svn access can be found here.
This post has been edited by Gregory S. Chudov: Apr 17 2012, 03:55
CUETools 2.1.4
Fandango
post Oct 3 2008, 17:11
WAV output is greyed out<edit>
Ah I didn't see the "embed cue sheet" was selected! But still, if the configuration file of the 1.9.1 version had WAV output, 1.9.2 will still output a WAV file... the greyed out radio button is selected wink.gif 1.9.2 needs at least an error box before conversion begins or automatically change to FLAC or (best solution IMHO) default to "Single File + CUE" if is was "Single File" in 1.9.1.
</edit>when I want to add a cue sheet via drag & drop into the "Input:" box, the cue sheet is not added. sad.gif
But apart from that... embed cue sheet, add AR CRC tags, and so on... great job!
The status report is a nice feature, too. Make it so that the log can be written to the output dir (using the name scheme) for each conversion, would be useful for batch conversion. biggrin.gif
<edit>...I'm going blind I guess.</edit>
This post has been edited by Fandango: Oct 3 2008, 17:35
Gregory S. Chudo...
post Oct 4 2008, 02:48
QUOTE (Fandango @ Oct 3 2008, 19:11) *
Wierd, drag&drop works for me.
QUOTE (foorious @ Oct 3 2008, 20:17) *
Hi, Gregory sent me to this thread from this one : http://www.hydrogenaudio.org/forums/index....showtopic=56531
What I don't understand is that my need is to be able to analyze a whole album made of single-track files in lossless form (FLAC, etc.) put inside the same album folder. I may be blind too Fandango laugh.gif , but I don't see CUETools doing that yet. Am I wrong ?
This functionality is mandatory for me since I have thousands of single-FLAC files and not a single cuesheet.
No, it's me who is blind, i didn't notice you didn't have cuesheets.
I'll think about automating the process, but for now i would recomend to write a script whch would create cuesheets for each directory. This would be very easy if your files have gaps appended. If they have gaps prepended or left out, there's nothing really that can be done - you have to know the size of gaps to be able to compare the disc to the database. Also if the first track had index 00, you're out of luck.
Here is a a template for your cuesheet:
PERFORMER "Performer"
TITLE "Title"
FILE "first_filename.flac" WAVE
  TRACK 01 AUDIO
    TITLE "title 01"
    INDEX 01 00:00:00
FILE "second_filename.flac" WAVE
  TRACK 02 AUDIO
    TITLE "title 02"
    INDEX 01 00:00:00
In fact, you don't even have to specify correct file names - you can use an option "Preprocess with filename corrector if unable to locate audio files".
You just have to have the correct number of tracks.
So you can create those dummy cuesheets by hand, and then just copy into each folder a .cue sheet which has the same number of tracks as this folder.
This post has been edited by Gregory S. Chudov: Oct 4 2008, 03:33
CUETools 2.1.4
foorious
post Oct 5 2008, 21:58
troll / ban evasion
Group: Banned
QUOTE (Gregory S. Chudov @ Oct 3 2008, 19:48) *
Well, I believe there must already be some utility that can batch-create cuesheets from single-track files. I'm talking about simply selecting a start folder, and then the utility would scan all the subfolders, find all tracks within a given subfolder, then create a cuesheet from them. Am I wrong ?
I am not a programmer, but I guess if such utility doesn't exist yet, it should be quite easy to create, and also to implement in CUETools. So Gregory, I hope you'll have the time to automate such process in the future. Thank you.
Um, yes, sure, but I have several thousand folders, so by hand is not a solution...
No Fun
post Oct 6 2008, 00:53
Strange...
Can it be that CUE Tools cannot find right offset for a set of FLACs linked up with a dummy cuesheet?
In my case it gives only "(00/01) No matches.", while TripleFlac! easily found offset to be -1501 (with "LeadIn: 0") and verification in CT with that value showed "Accurately ripped as in pressing(s) #1". Also when I converted "tracks + dummy cuesheet" to WAV "Single File + CUE", ARcue found -1501 as well.
At the same time with another rip (in the form of "flac-image + cuesheet") verification, as it should, showed two results: one without offset correction ("No matches") and another, "offsetted".
Command line parameters is the feature I missed so much! Very nice verification mode & awesome new log!
Now I wish only CT could directly handle a set of FLAC files (or folder containing them) - I'd throw away TripleFlac!
As for usability I can suggest hotkeys (Alt+letter) and Write Offset box right in the main window (yeah, it was there already some time ago, and IMHO so it were much more convenient). Also an option to set up filename for AccurateRip report would be nice to have. And to be completely a bore… tongue.gif maybe you can remove those points at the end of almost every line of AR report to save a few bytes on HDD? laugh.gif
Gregory S. Chudo...
post Oct 6 2008, 15:40
QUOTE (No Fun @ Oct 6 2008, 02:53) *
Strange...
Can i see that dummy cuesheet? Is the accuraterip discId identical in those logs? Did you use CUETools to convert "tracks + dummy cuesheet" to WAV "Single File + CUE", or something else was involved in that process?
CUETools 2.1.4
No Fun
post Oct 7 2008, 00:15
QUOTE (Gregory S. Chudov @ Oct 6 2008, 18:40) *
Of cause you can, although I can't even imagine what can be wrong there smile.gif
FILE "01.flac" WAVE
  TRACK 01 AUDIO
    INDEX 01 00:00:00
FILE "02.flac" WAVE
  TRACK 02 AUDIO
    INDEX 01 00:00:00
FILE "03.flac" WAVE
  TRACK 03 AUDIO
    INDEX 01 00:00:00
FILE "04.flac" WAVE
  TRACK 04 AUDIO
    INDEX 01 00:00:00
FILE "05.flac" WAVE
  TRACK 05 AUDIO
    INDEX 01 00:00:00
FILE "06.flac" WAVE
  TRACK 06 AUDIO
    INDEX 01 00:00:00
FILE "07.flac" WAVE
  TRACK 07 AUDIO
    INDEX 01 00:00:00
FILE "08.flac" WAVE
  TRACK 08 AUDIO
    INDEX 01 00:00:00
FILE "09.flac" WAVE
  TRACK 09 AUDIO
    INDEX 01 00:00:00
FILE "10.flac" WAVE
  TRACK 10 AUDIO
    INDEX 01 00:00:00
FILE "11.flac" WAVE
  TRACK 11 AUDIO
    INDEX 01 00:00:00
FILE "12.flac" WAVE
  TRACK 12 AUDIO
    INDEX 01 00:00:00
FILE "13.flac" WAVE
  TRACK 13 AUDIO
    INDEX 01 00:00:00
Here's CUE Tools verify log:
[Disc ID: 001a219e-01121231-9e0ea70d]
Track    [ CRC    ] Status
01    [3b855413] (00/01) No matches.
02    [a94794c5] (00/01) No matches.
03    [10defeda] (00/01) No matches.
04    [2bf1fba0] (00/01) No matches.
05    [9005ab87] (00/01) No matches.
06    [3cddaad7] (00/01) No matches.
07    [21d37bf7] (00/01) No matches.
08    [fe595914] (00/01) No matches.
09    [2e4d4e4d] (00/01) No matches.
10    [31fd9da0] (00/01) No matches.
11    [32eecc56] (00/01) No matches.
12    [0d96ef91] (00/01) No matches.
13    [93bb2533] (00/01) No matches.
Here's TripleFlac screenshot:
As you can see DiscIDs are the same.
And here's ARcue++ log (yes, "tracks + dummy cuesheet" converted to WAV "Single File + CUE" using CUE Tools):
VAO.fake.cue:
Checking AccurateRip database
Track   Ripping Status          [Disc ID: 001a219e-9e0ea70d]
1      ** Rip offset: -1501 **   (confidence 1)     [f4412e2c]
2      ** Rip offset: -1501 **   (confidence 1)     [c73179c8]
3      ** Rip offset: -1501 **   (confidence 1)     [34a31f66]
4      ** Rip offset: -1501 **   (confidence 1)     [869a31b8]
5      ** Rip offset: -1501 **   (confidence 1)     [c02a617d]
6      ** Rip offset: -1501 **   (confidence 1)     [a0f3d5c0]
7      ** Rip offset: -1501 **   (confidence 1)     [0ef8470f]
8      ** Rip offset: -1501 **   (confidence 1)     [48c15f65]
9      ** Rip offset: -1501 **   (confidence 1)     [59c30bc1]
10     ** Rip offset: -1501 **   (confidence 1)     [695a2514]
11     ** Rip offset: -1501 **   (confidence 1)     [f2dbd886]
12     ** Rip offset: -1501 **   (confidence 1)     [0bd99066]
13     ** Rip offset: -1501 **   (confidence 1)     [c55bb653]
_______________________
Track(s) Accurately Ripped: 0
**** Track(s) Not Ripped Accurately: 0 ****
Track(s) Not in Database: 0
Gregory S. Chudo...
post Oct 7 2008, 23:10
QUOTE (No Fun @ Oct 7 2008, 02:15) *
Offsetted by -1501:
01    [f4412e2c] (01/01) Accurately ripped as in pressing(s) #1.
02    [c73179c8] (01/01) Accurately ripped as in pressing(s) #1.
03    [34a31f66] (01/01) Accurately ripped as in pressing(s) #1.
04    [869a31b8] (01/01) Accurately ripped as in pressing(s) #1.
05    [c02a617d] (01/01) Accurately ripped as in pressing(s) #1.
06    [a0f3d5c0] (01/01) Accurately ripped as in pressing(s) #1.
07    [0ef8470f] (01/01) Accurately ripped as in pressing(s) #1.
08    [48c15f65] (01/01) Accurately ripped as in pressing(s) #1.
09    [59c30bc1] (01/01) Accurately ripped as in pressing(s) #1.
10    [695a2514] (01/01) Accurately ripped as in pressing(s) #1.
11    [f2dbd886] (01/01) Accurately ripped as in pressing(s) #1.
12    [0bd99066] (01/01) Accurately ripped as in pressing(s) #1.
13    [c55bb653] (01/01) Accurately ripped as in pressing(s) #1.
CUETools 2.1.4
- Gregory S. Chudov   CUETools versions 1.9.5 through 2.1.5 (current)   Oct 2 2008, 12:26
- - Fandango   WAV output is greyed out<edit> Ah I didn...   Oct 3 2008, 17:11
|- - Gregory S. Chudov   QUOTE (Fandango @ Oct 3 2008, 19:11) WAV ...   Oct 4 2008, 02:48
|- - Fandango   QUOTE (Gregory S. Chudov @ Oct 4 2008, 03...   Oct 4 2008, 14:53
|- - foorious   QUOTE (Gregory S. Chudov @ Oct 3 2008, 19...   Oct 5 2008, 21:58
|- - No Fun   Strange... Can it be that CUE Tools cannot find ri...   Oct 6 2008, 00:53
|- - Gregory S. Chudov   QUOTE (No Fun @ Oct 6 2008, 02:53) Strang...   Oct 6 2008, 15:40
|- - No Fun   QUOTE (Gregory S. Chudov @ Oct 6 2008, 18...   Oct 7 2008, 00:15
|- - Gregory S. Chudov   QUOTE (No Fun @ Oct 7 2008, 02:15) So why...   Oct 7 2008, 23:10
|- - No Fun   QUOTE (Gregory S. Chudov @ Oct 8 2008, 02...   Oct 8 2008, 00:32
- - foorious   Hi, Gregory sent me to this thread from this one :...   Oct 3 2008, 18:17
- - Gregory S. Chudov   I encountered some very strange logs: CODE[Dis...   Oct 4 2008, 22:53
- - No Fun   Gregory S. Chudov Thanks for nice new features...   Oct 4 2008, 23:49
- - Raiden   This is a great tool! I'm using it to batc...   Oct 5 2008, 00:34
|- - Gregory S. Chudov   QUOTE (Raiden @ Oct 5 2008, 02:34) This i...   Oct 5 2008, 14:57
- - Raiden   It now says (excerpt): CODE 19 [8c2ca83c...   Oct 5 2008, 20:39
- - greynol   Maybe 1501 is beyond the window being used. The A...   Oct 7 2008, 04:12
|- - No Fun   QUOTE (greynol @ Oct 7 2008, 07:12) Maybe...   Oct 7 2008, 07:07
- - Moitah   It should be able to find offsets within +/- 2939....   Oct 7 2008, 05:48
- - Gregory S. Chudov   QUOTE (greynol @ Oct 7 2008, 06:12) The l...   Oct 7 2008, 18:25
|- - Gregory S. Chudov   QUOTE (Moitah @ Oct 7 2008, 07:48) By the...   Oct 7 2008, 19:51
- - Gregory S. Chudov   Well, in this case there is no bug. Either your co...   Oct 8 2008, 01:47
|- - No Fun   QUOTE (Gregory S. Chudov @ Oct 8 2008, 04...   Oct 8 2008, 08:58
||- - foorious   QUOTE (No Fun @ Oct 8 2008, 01:58) Creati...   Oct 8 2008, 14:49
|||- - yury_usa   Ok, how is this possible, then? CODEEAC extractio...   Oct 14 2008, 03:25
|||- - greynol   QUOTE (yury_usa @ Oct 13 2008, 19:25) Now...   Oct 14 2008, 03:29
||- - Gregory S. Chudov   QUOTE (No Fun @ Oct 8 2008, 10:58) Maybe ...   Oct 9 2008, 20:35
|- - greynol   QUOTE (Gregory S. Chudov @ Oct 7 2008, 17...   Oct 8 2008, 16:04
|- - Gregory S. Chudov   QUOTE (greynol @ Oct 8 2008, 18:04) QUOTE...   Oct 8 2008, 17:00
- - NachoMan77   Hi Gregory ! thanks a lot for jumpstarting CU...   Oct 8 2008, 13:56
- - spoon   Correct AR has 2 CRCs one for the track, the other...   Oct 8 2008, 16:31
- - Moitah   @spoon: Is there a way to query the AccurateRip da...   Oct 8 2008, 17:34
- - foorious   I think I have the same problem as "No Fun...   Oct 10 2008, 01:24
|- - Gregory S. Chudov   QUOTE (foorious @ Oct 10 2008, 03:24) Gre...   Oct 10 2008, 11:00
- - Moitah   @foorious: I checked freedb/Amazon and it looks l...   Oct 10 2008, 04:01
- - foorious   Oh, that's too bad : I have manually splitted ...   Oct 10 2008, 10:32
|- - Gregory S. Chudov   QUOTE (foorious @ Oct 10 2008, 12:32) How...   Oct 10 2008, 11:14
|- - foorious   QUOTE (Gregory S. Chudov @ Oct 10 2008, 04...   Oct 10 2008, 12:57
||- - Gregory S. Chudov   QUOTE (foorious @ Oct 10 2008, 14:57) I d...   Oct 10 2008, 13:31
|- - Porcus   QUOTE (Gregory S. Chudov @ Oct 10 2008, 12...   Oct 16 2008, 19:14
|- - Gregory S. Chudov   QUOTE (Porcus @ Oct 16 2008, 21:14) (1) I...   Oct 16 2008, 20:47
|- - Porcus   QUOTE (Gregory S. Chudov @ Oct 16 2008, 21...   Oct 17 2008, 01:06
|- - Gregory S. Chudov   QUOTE (Porcus @ Oct 17 2008, 03:06) Accur...   Oct 20 2008, 06:42
|- - Porcus   QUOTE (Gregory S. Chudov @ Oct 20 2008, 07...   Oct 20 2008, 10:38
|- - Gregory S. Chudov   QUOTE (Porcus @ Oct 20 2008, 12:38) First...   Oct 20 2008, 11:44
|- - Porcus   QUOTE (Gregory S. Chudov @ Oct 20 2008, 12...   Oct 20 2008, 15:17
- - NachoMan77   Gregory, I can't make the "encode if % o...   Oct 11 2008, 00:29
|- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 11 2008, 02:29) G...   Oct 11 2008, 12:39
|- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 11 2008, 02:29) W...   Oct 12 2008, 15:29
|- - NachoMan77   QUOTE (Gregory S. Chudov @ Oct 12 2008, 08...   Oct 12 2008, 16:33
- - Alex B   Thank you for the excellent new CUEtools features....   Oct 11 2008, 13:06
|- - yury_usa   Question: Original Log CODEExact Audio Copy V0.99...   Oct 11 2008, 22:59
|- - Fandango   QUOTE (yury_usa @ Oct 11 2008, 23:59) How...   Oct 11 2008, 23:41
- - yury_usa   Fandango So this pressing is different by an offse...   Oct 12 2008, 00:42
|- - Fandango   QUOTE (yury_usa @ Oct 12 2008, 01:42) Fan...   Oct 12 2008, 00:45
- - Alex B   I created a mockup to demonstrate my suggestion: ...   Oct 12 2008, 15:54
- - Moitah   I thought this was pretty cool, it runs fine with ...   Oct 12 2008, 19:47
|- - Gregory S. Chudov   QUOTE (Moitah @ Oct 12 2008, 21:47) I tho...   Oct 12 2008, 23:32
||- - NachoMan77   QUOTE (Gregory S. Chudov @ Oct 12 2008, 16...   Oct 12 2008, 23:45
|- - Corwin   QUOTE (Moitah @ Oct 12 2008, 10:47) I tho...   Oct 19 2008, 11:45
- - Gregory S. Chudov   Update: some bugs were fixed, fresher build can be...   Oct 13 2008, 05:03
|- - Alex B   QUOTE (Gregory S. Chudov @ Oct 13 2008, 07...   Oct 13 2008, 16:39
- - NachoMan77   Gregory, when converting from single APE to single...   Oct 13 2008, 12:30
|- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 13 2008, 14:30) G...   Oct 13 2008, 13:51
- - NachoMan77   Also I see that you're embedding the LOG file ...   Oct 13 2008, 12:54
- - Caleb   Hey, Great job on a great utility! Does th...   Oct 13 2008, 14:54
|- - Gregory S. Chudov   QUOTE (Caleb @ Oct 13 2008, 16:54) Hey, ...   Oct 13 2008, 17:42
- - Alex B   I converted a "tagged APE disc image + CUE...   Oct 13 2008, 15:18
|- - Gregory S. Chudov   QUOTE (Alex B @ Oct 13 2008, 17:18) I con...   Oct 13 2008, 17:23
- - yury_usa   Would it be possible to generate AccurateRip repor...   Oct 14 2008, 18:47
|- - Gregory S. Chudov   QUOTE (yury_usa @ Oct 14 2008, 20:47) Wou...   Oct 14 2008, 19:30
- - naturfreak   Thanks for this useful tool. A small feature requ...   Oct 14 2008, 22:07
- - NachoMan77   Gregory, Update5 is working fine. Got a couple of...   Oct 15 2008, 06:06
|- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 15 2008, 08:06) 1...   Oct 16 2008, 21:30
- - Caleb   QUOTE (Gregory S. Chudov @ Oct 13 2008, 18...   Oct 15 2008, 09:58
|- - Gregory S. Chudov   QUOTE (Caleb @ Oct 15 2008, 11:58) Hi Gre...   Oct 17 2008, 19:13
- - NachoMan77   Hi Gregory ! here's my report on Update 6...   Oct 18 2008, 01:43
|- - NachoMan77   QUOTE (NachoMan77 @ Oct 17 2008, 18:43) H...   Oct 19 2008, 00:29
|- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 19 2008, 02:29) O...   Oct 19 2008, 03:02
- - Porcus   Feature request: duplicates detection. For "d...   Oct 18 2008, 15:20
- - Corwin   Just wanted to let people know that the "CUE ...   Oct 19 2008, 09:41
- - Corwin   Accurite rip reports the offset is wrong. I found ...   Oct 19 2008, 09:53
|- - Gregory S. Chudov   QUOTE (Corwin @ Oct 19 2008, 11:53) Accur...   Oct 19 2008, 12:44
- - Caleb   QUOTE (Gregory S. Chudov @ Oct 17 2008, 20...   Oct 19 2008, 12:28
|- - Gregory S. Chudov   QUOTE (Caleb @ Oct 19 2008, 14:28) I trie...   Oct 19 2008, 14:02
||- - mhudson7   I love this tool! Thanks to everybody for the...   Oct 19 2008, 16:43
|- - Corwin   QUOTE (Caleb @ Oct 19 2008, 03:28) Well I...   Oct 20 2008, 08:25
|- - Gregory S. Chudov   QUOTE (Caleb @ Oct 19 2008, 14:28) I trie...   Oct 22 2008, 12:55
- - NachoMan77   Gregory, I can confirm that Update7 is now workin...   Oct 19 2008, 14:50
|- - fredhammersmith   I have a question: can CueTools process hi-rez fil...   Oct 19 2008, 15:34
- - Moitah   @Corwin: I will see about posting a WAV-only build...   Oct 19 2008, 19:09
- - NightOwl   Moitah and Gregory, thank you so much for CUE Tool...   Oct 22 2008, 21:56
- - NightOwl   I started using the latest Update 8 (after replaci...   Oct 23 2008, 01:03
|- - Gregory S. Chudov   QUOTE (NightOwl @ Oct 23 2008, 03:03) I s...   Oct 23 2008, 08:13
- - NightOwl   OK, thanks for the explanation, Gregory. The toolt...   Oct 23 2008, 17:15
- - Moitah   IMHO even if the modified times are preserved, wri...   Oct 23 2008, 19:12
|- - NachoMan77   QUOTE (Moitah @ Oct 23 2008, 12:12) IMHO ...   Oct 23 2008, 21:20
- - NachoMan77   Gregory, while using the "Verify, then encod...   Oct 25 2008, 21:14
- - Gregory S. Chudov   QUOTE (NachoMan77 @ Oct 25 2008, 23:14) G...   Oct 26 2008, 09:31
- - NachoMan77   QUOTE (Gregory S. Chudov @ Oct 26 2008, 02...   Oct 26 2008, 14:32
27 Pages V   1 2 3 > »
RSS Lo-Fi Version Time is now: 6th March 2015 - 09:05
