Which CD DAE software is the most accurate for Mac OS X?, Is XLD the most accurate with feature set?
macman4hire
post Sep 1 2008, 22:45
I would like to archive my CD collection and have chosen to use FLAC as my lossless codec. I believe FLAC's wide range of hardware support, comparable compression rates vs. other lossless codecs and the encode/decode rates are a par with its competition. I have tried the following software for DAE XLD, Max, xACT, iTunes and Toast. I am leaning towards using XLD with its new features of AccurateRip, disable cache and its log report. Please read the following questions posted below and give your answers and advice about XLD or any other DAE software for Mac Os X.
1. I have read CD Paranoia will not allow the cache to be disabled if the cache is larger than 1 meg. Is the this correct?
2. Does the disable cache feature work in XLD?
3. Can the AccurateRip feature be trusted in XLD?
4. Can the the error log report be trusted in XLD?
5. What about using VMware Fusion with XP and EAC. Would this method produce accurate results?
Thank you for answers and help. 500 plus CD's to rip!
This post has been edited by macman4hire: Sep 2 2008, 05:38
macman4hire
post Sep 4 2008, 21:37
I have created a comparison for three CD rippers that use CDParanoia on the Mac. This comparison is in no way a definitive comparison as the feature sets of these applications constantly change. Please contact me if any information appears inaccurate or you feel a crucial feature has been omitted. I attempted to list the features in an unbiased manner. All these applications offer several audio codecs which are listed in HA's 2008 ripping/encoding polls which confirms the most the popular ones are offered. I intentionally did not list the audio codecs because the focus for this comparison is the DAE capabilities on the Mac.
Click here for a larger image
This post has been edited by macman4hire: Sep 26 2008, 16:22
gloog
post Jan 2 2009, 19:39
QUOTE (macman4hire @ Sep 4 2008, 21:37) *
I'd like contribute to this summary with a little research on very important subject, completely omitted in any XLD-related topic. It is a question of Pre-Emphasis.
I've found the only solution how to correctly detect PRE flag, and it is provided by xAct, only as a result log that is not even saved with rip.
Log looks like this (check the last two lines):
cdda2wav: There is no sound support configured!
Type: ROM, Vendor 'TSSTcorp' Model 'CDDVDW SH-S202N ' Revision 'SB01' MMC+CDDA
176128 bytes buffer memory requested, transfer size 32768 bytes, 4 buffers, 13 sectors
cdda2wav: Read TOC CD Text failed (probably not supported).
#Cdda2wav version 2.01.01a28_darwin_8.10.1_i386_i386, libparanoia support
cdda2wav: Host is down. Cddb connect failed.
AUDIOtrack pre-emphasis  copy-permitted tracktype channels
      1-10          yes              no     audio    2
How to handle such CD is another question, probably best solution is to burn on CD-R using reliable sw with PRE flag set ON. Toast supports this, but does not read this setting from CUE. It has to be set manually.
For those who want to play files from computer, there are some options: iTunes 7 during ripping performs frequency equalization similar to the one provided by stand-alone CD player, when encounters a PRE flag. The resulting Wav file is of course not a bit-perfect copy of a CD track. Any other ripping sw ignores this. Only some rippers can write correct PRE flag on the CUE sheet [like EAC], bot none on Mac OS-X. Playback with equalization on-the-fly is only possible in Foobar2000 / Win.
So for this reason, line containing Pre-Emphasis should be added to the table, with important benefit of xAct allowing to detect it, at least, and there's also a recommendation to XLD developer to consider implementing of proper PRE flag reading and logging.
- macman4hire   Which CD DAE software is the most accurate for Mac OS X?   Sep 1 2008, 22:45
- - Pepzhez   I have spent a lot of time in other forums rigorou...   Sep 2 2008, 06:09
- - Pepzhez   I failed to answer the main question, didn't I...   Sep 2 2008, 06:48
- - macman4hire   Thank you for your answers Pepzhez. The drives I ...   Sep 2 2008, 07:45
- - Tyashki   Um, does any Mac use those? Also, is there a way ...   Sep 2 2008, 10:05
|- - tim.lance   QUOTE (Tyashki @ Sep 2 2008, 04:05) Um, d...   Sep 2 2008, 11:29
|- - Tyashki   QUOTE (tim.lance @ Sep 2 2008, 20:29) QUO...   Sep 3 2008, 13:49
|- - tim.lance   Sorry, no help here and I've checked three dif...   Sep 3 2008, 16:06
- - spoon   Matshita is such an unfortunate name here in the w...   Sep 2 2008, 13:00
- - macman4hire   I ripped this CD and XLD produce this log report p...   Sep 3 2008, 02:37
|- - tim.lance   To have more faith in the rip you might want to ch...   Sep 3 2008, 03:26
- - greynol   For tracks that AR verifies, T&C is a complete...   Sep 3 2008, 03:34
|- - tim.lance   QUOTE (greynol @ Sep 2 2008, 21:34) For t...   Sep 3 2008, 03:43
- - greynol   In EAC my advice is to copy, check AR and then tes...   Sep 3 2008, 03:53
|- - tim.lance   QUOTE (greynol @ Sep 2 2008, 21:53) In EA...   Sep 3 2008, 03:58
- - greynol   I'm interested in what is displayed in the GUI...   Sep 3 2008, 04:01
|- - tim.lance   QUOTE (greynol @ Sep 2 2008, 22:01) I...   Sep 3 2008, 11:24
- - Pepzhez   The only thing displayed in the GUI is a progress ...   Sep 3 2008, 05:01
- - macman4hire   How do you check to see if a CD is in the Accurate...   Sep 3 2008, 06:45
|- - Pepzhez   QUOTE (macman4hire @ Sep 2 2008, 21:45) H...   Sep 3 2008, 07:28
- - spoon   EAC & dBpoweramp will detect if the CD is in A...   Sep 3 2008, 10:49
- - macman4hire   Today XLD added an additional feature under the T...   Sep 3 2008, 21:21
|- - Kees de Visser   This thread made me curious, so I tried to downloa...   Sep 4 2008, 06:26
- - macman4hire   Click on this link Down Load XLD to down load XLD....   Sep 4 2008, 06:37
|- - Kees de Visser   That link works fine and so does XLD's built-i...   Sep 4 2008, 11:34
|- - tim.lance   QUOTE (Kees de Visser @ Sep 4 2008, 05:34...   Sep 4 2008, 14:04
- - macman4hire   I have created a comparison for three CD rippers t...   Sep 4 2008, 21:37
|- - knucklehead   QUOTE (macman4hire @ Sep 4 2008, 12:37) I...   Sep 4 2008, 23:46
||- - macman4hire   QUOTE (knucklehead @ Sep 4 2008, 16:46) Q...   Sep 5 2008, 22:15
||- - macman4hire   QUOTE (knucklehead @ Sep 4 2008, 16:46) Q...   Sep 13 2008, 00:15
|- - gloog   QUOTE (macman4hire @ Sep 4 2008, 21:37) I...   Jan 2 2009, 19:39
- - macman4hire   Today XLD added a new feature to recognize if a CD...   Sep 4 2008, 23:36
- - macman4hire   Just an update on Mac DAE. Today sbooth the devel...   Sep 5 2008, 21:46
- - macman4hire   Their seems to be some disagreement if the disable...   Sep 5 2008, 22:34
- - knucklehead   QUOTE (macman4hire @ Sep 1 2008, 13:45) 4...   Sep 6 2008, 17:16
|- - ffooky   QUOTE (knucklehead @ Sep 6 2008, 17:16) H...   Sep 6 2008, 17:39
|- - Pepzhez   QUOTE (knucklehead @ Sep 6 2008, 08:16) H...   Sep 6 2008, 23:27
|- - ffooky   QUOTE (Pepzhez @ Sep 6 2008, 23:27) You d...   Sep 6 2008, 23:37
|- - tim.lance   QUOTE (ffooky @ Sep 6 2008, 17:37) QUOTE ...   Sep 6 2008, 23:44
||- - ffooky   QUOTE (tim.lance @ Sep 6 2008, 23:44) Yep...   Sep 7 2008, 00:03
||- - macman4hire   QUOTE (ffooky @ Sep 6 2008, 17:03) QUOTE ...   Sep 7 2008, 00:14
||- - Pepzhez   QUOTE (macman4hire @ Sep 6 2008, 15:14) Q...   Sep 7 2008, 03:57
|- - Pepzhez   QUOTE (ffooky @ Sep 6 2008, 14:37) QUOTE ...   Sep 7 2008, 00:04
|- - knucklehead   QUOTE (Pepzhez @ Sep 6 2008, 15:04) QUOTE...   Sep 7 2008, 01:30
- - greynol   QUOTE (knucklehead @ Sep 6 2008, 09:16) H...   Sep 6 2008, 17:51
|- - knucklehead   Time for new glasses... The 8's were hiding i...   Sep 6 2008, 18:10
- - macman4hire   XLD updated via automatic update today with some i...   Sep 7 2008, 00:03
- - tim.lance   No sh*t. I have never seen such user driven (or an...   Sep 7 2008, 00:11
|- - Pepzhez   QUOTE (tim.lance @ Sep 6 2008, 15:11) Now...   Sep 7 2008, 01:17
- - greynol   Did we determine if the "Only when the track...   Sep 7 2008, 00:50
|- - Pepzhez   QUOTE (greynol @ Sep 6 2008, 15:50) Did w...   Sep 7 2008, 01:04
|- - ffooky   Is it realistically possible for different pressin...   Sep 7 2008, 01:08
- - macman4hire   QUOTE (Pepzhez @ Sep 6 2008, 20:57) I not...   Sep 7 2008, 04:37
- - jhart71   I'm new to XLD - just downloaded and started l...   Sep 13 2008, 14:03
|- - Pepzhez   QUOTE (jhart71 @ Sep 13 2008, 05:03) My q...   Sep 13 2008, 14:22
- - jhart71   I just ripped the same track twice - once with the...   Sep 13 2008, 15:45
- - tim.lance   QUOTE (jhart71 @ Sep 13 2008, 09:45) I ju...   Sep 13 2008, 15:52
- - jhart71   QUOTE (tim.lance @ Sep 13 2008, 09:52) QU...   Sep 13 2008, 16:07
- - tim.lance   QUOTE (jhart71 @ Sep 13 2008, 10:07) You...   Sep 13 2008, 16:25
RSS Lo-Fi Version Time is now: 5th July 2015 - 06:03
