Which CD DAE software is the most accurate for Mac OS X?, Is XLD the most accurate with feature set?
macman4hire
post Sep 1 2008, 22:45
I would like to archive my CD collection and have chosen to use FLAC as my lossless codec. I believe FLAC's wide range of hardware support, comparable compression rates vs. other lossless codecs and the encode/decode rates are a par with its competition. I have tried the following software for DAE XLD, Max, xACT, iTunes and Toast. I am leaning towards using XLD with its new features of AccurateRip, disable cache and its log report. Please read the following questions posted below and give your answers and advice about XLD or any other DAE software for Mac Os X.
1. I have read CD Paranoia will not allow the cache to be disabled if the cache is larger than 1 meg. Is the this correct?
2. Does the disable cache feature work in XLD?
3. Can the AccurateRip feature be trusted in XLD?
4. Can the the error log report be trusted in XLD?
5. What about using VMware Fusion with XP and EAC. Would this method produce accurate results?
Thank you for answers and help. 500 plus CD's to rip!
This post has been edited by macman4hire: Sep 2 2008, 05:38
macman4hire
post Sep 3 2008, 21:21
Today XLD added an additional feature under the Test before copy preference check box. This new feature located under the Test before copy preference is Only when the track does not exist in Accuraterip DB.
Does any know who the developer is? The developer must read the HA board as this topic was just discussed last night. I hope the developer noticed the topic about the absence of the ability to check if the CD is in the Accuraterip DB before ripping is started. If this feature were to be added it would give the user the option to use the burst rip mode vs. the CDParanoia mode which takes about 3.5 times longer on my hardware. If the users CD condition is fine they could rely on the Accuraterip results to determine if one should rerip using the CDParanoia mode. The developer should be thanked and congratulated on bringing Mac OS X out of the dark ages of DAE.
- macman4hire   Which CD DAE software is the most accurate for Mac OS X?   Sep 1 2008, 22:45
- - Pepzhez   I have spent a lot of time in other forums rigorou...   Sep 2 2008, 06:09
- - Pepzhez   I failed to answer the main question, didn't I...   Sep 2 2008, 06:48
- - macman4hire   Thank you for your answers Pepzhez. The drives I ...   Sep 2 2008, 07:45
- - Tyashki   Um, does any Mac use those? Also, is there a way ...   Sep 2 2008, 10:05
|- - tim.lance   QUOTE (Tyashki @ Sep 2 2008, 04:05) Um, d...   Sep 2 2008, 11:29
|- - Tyashki   QUOTE (tim.lance @ Sep 2 2008, 20:29) QUO...   Sep 3 2008, 13:49
|- - tim.lance   Sorry, no help here and I've checked three dif...   Sep 3 2008, 16:06
- - spoon   Matshita is such an unfortunate name here in the w...   Sep 2 2008, 13:00
- - macman4hire   I ripped this CD and XLD produce this log report p...   Sep 3 2008, 02:37
|- - tim.lance   To have more faith in the rip you might want to ch...   Sep 3 2008, 03:26
- - greynol   For tracks that AR verifies, T&C is a complete...   Sep 3 2008, 03:34
|- - tim.lance   QUOTE (greynol @ Sep 2 2008, 21:34) For t...   Sep 3 2008, 03:43
- - greynol   In EAC my advice is to copy, check AR and then tes...   Sep 3 2008, 03:53
|- - tim.lance   QUOTE (greynol @ Sep 2 2008, 21:53) In EA...   Sep 3 2008, 03:58
- - greynol   I'm interested in what is displayed in the GUI...   Sep 3 2008, 04:01
|- - tim.lance   QUOTE (greynol @ Sep 2 2008, 22:01) I...   Sep 3 2008, 11:24
- - Pepzhez   The only thing displayed in the GUI is a progress ...   Sep 3 2008, 05:01
- - macman4hire   How do you check to see if a CD is in the Accurate...   Sep 3 2008, 06:45
|- - Pepzhez   QUOTE (macman4hire @ Sep 2 2008, 21:45) H...   Sep 3 2008, 07:28
- - spoon   EAC & dBpoweramp will detect if the CD is in A...   Sep 3 2008, 10:49
- - macman4hire   Today XLD added an additional feature under the T...   Sep 3 2008, 21:21
|- - Kees de Visser   This thread made me curious, so I tried to downloa...   Sep 4 2008, 06:26
- - macman4hire   Click on this link Down Load XLD to down load XLD....   Sep 4 2008, 06:37
|- - Kees de Visser   That link works fine and so does XLD's built-i...   Sep 4 2008, 11:34
|- - tim.lance   QUOTE (Kees de Visser @ Sep 4 2008, 05:34...   Sep 4 2008, 14:04
- - macman4hire   I have created a comparison for three CD rippers t...   Sep 4 2008, 21:37
|- - knucklehead   QUOTE (macman4hire @ Sep 4 2008, 12:37) I...   Sep 4 2008, 23:46
||- - macman4hire   QUOTE (knucklehead @ Sep 4 2008, 16:46) Q...   Sep 5 2008, 22:15
||- - macman4hire   QUOTE (knucklehead @ Sep 4 2008, 16:46) Q...   Sep 13 2008, 00:15
|- - gloog   QUOTE (macman4hire @ Sep 4 2008, 21:37) I...   Jan 2 2009, 19:39
- - macman4hire   Today XLD added a new feature to recognize if a CD...   Sep 4 2008, 23:36
- - macman4hire   Just an update on Mac DAE. Today sbooth the devel...   Sep 5 2008, 21:46
- - macman4hire   Their seems to be some disagreement if the disable...   Sep 5 2008, 22:34
- - knucklehead   QUOTE (macman4hire @ Sep 1 2008, 13:45) 4...   Sep 6 2008, 17:16
|- - ffooky   QUOTE (knucklehead @ Sep 6 2008, 17:16) H...   Sep 6 2008, 17:39
|- - Pepzhez   QUOTE (knucklehead @ Sep 6 2008, 08:16) H...   Sep 6 2008, 23:27
|- - ffooky   QUOTE (Pepzhez @ Sep 6 2008, 23:27) You d...   Sep 6 2008, 23:37
|- - tim.lance   QUOTE (ffooky @ Sep 6 2008, 17:37) QUOTE ...   Sep 6 2008, 23:44
||- - ffooky   QUOTE (tim.lance @ Sep 6 2008, 23:44) Yep...   Sep 7 2008, 00:03
||- - macman4hire   QUOTE (ffooky @ Sep 6 2008, 17:03) QUOTE ...   Sep 7 2008, 00:14
||- - Pepzhez   QUOTE (macman4hire @ Sep 6 2008, 15:14) Q...   Sep 7 2008, 03:57
|- - Pepzhez   QUOTE (ffooky @ Sep 6 2008, 14:37) QUOTE ...   Sep 7 2008, 00:04
|- - knucklehead   QUOTE (Pepzhez @ Sep 6 2008, 15:04) QUOTE...   Sep 7 2008, 01:30
- - greynol   QUOTE (knucklehead @ Sep 6 2008, 09:16) H...   Sep 6 2008, 17:51
|- - knucklehead   Time for new glasses... The 8's were hiding i...   Sep 6 2008, 18:10
- - macman4hire   XLD updated via automatic update today with some i...   Sep 7 2008, 00:03
- - tim.lance   No sh*t. I have never seen such user driven (or an...   Sep 7 2008, 00:11
|- - Pepzhez   QUOTE (tim.lance @ Sep 6 2008, 15:11) Now...   Sep 7 2008, 01:17
- - greynol   Did we determine if the "Only when the track...   Sep 7 2008, 00:50
|- - Pepzhez   QUOTE (greynol @ Sep 6 2008, 15:50) Did w...   Sep 7 2008, 01:04
|- - ffooky   Is it realistically possible for different pressin...   Sep 7 2008, 01:08
- - macman4hire   QUOTE (Pepzhez @ Sep 6 2008, 20:57) I not...   Sep 7 2008, 04:37
- - jhart71   I'm new to XLD - just downloaded and started l...   Sep 13 2008, 14:03
|- - Pepzhez   QUOTE (jhart71 @ Sep 13 2008, 05:03) My q...   Sep 13 2008, 14:22
- - jhart71   I just ripped the same track twice - once with the...   Sep 13 2008, 15:45
- - tim.lance   QUOTE (jhart71 @ Sep 13 2008, 09:45) I ju...   Sep 13 2008, 15:52
- - jhart71   QUOTE (tim.lance @ Sep 13 2008, 09:52) QU...   Sep 13 2008, 16:07
- - tim.lance   QUOTE (jhart71 @ Sep 13 2008, 10:07) You...   Sep 13 2008, 16:25
RSS Lo-Fi Version Time is now: 3rd August 2015 - 11:38
