Comparing Elements of Turntable Construction, Kindly requesting your help in building a turntable comparison chart.
Knowzy
post Aug 19 2008, 03:06
Greetings HydrogenAudio.
USB turntables, as many around here are aware, range in quality from poor to decent. I'm setting out to create comparison charts detailed enough to find the gems in a sea of lightweight plastic and ceramic carts. Once the guide is more presentable, I plan to give HA an exclusive sneak preview.
What follows are the elements I'm considering for chart #3, "Turntable Construction," along with the possible values.
Is there anything else I should be considering? Are there any elements not worth comparing or combinable with other elements? Am I using correct terminology?
I greatly appreciate your informed input.
  • Drive
    • Belt
    • Direct
  • Cartridge Type
    • Ceramic
    • Moving Magnet
    • Moving Coil (no USB TT's feature these)
  • Plinth/Body (really having trouble succinctly comparing this)
    • Lightweight plastic/No isolation
    • Heavy plastic/Rubber
    • Metal/Rubber
    • Wood/Rubber
  • Anti-skate/Counterweight
    • Yes
    • No
  • Edit: Removed tonearm shape, combined counterweight with anti-skate (thanks for setting me straight Axon)
  • Mount Type
    • Half-inch
    • P-Type
    • Edit: Bayonet (thanks Axon)
    • Edit: Universal (thanks Axon)
    • Edit: Proprietary (thanks Axon)
  • Stylus Type Edit: Added more types
    • Conical
    • Elliptical
    • Spherical
    • Linear Contact
    • MicroLine
    • MicroRidge
  • Dustcover
    • Plastic
    • Cloth
    • None
  • Adjustable Feet for Leveling?
    • Yes
    • No
  • Tonearm cue?
    • Yes
    • No
  • Tonearm Auto return?
    • Yes
    • No
  • Edit: Specs (If Available) (Chart #4: Specifications)
    • Wow and Flutter
    • Signal to Noise Ratio
    • Rumble
    • Dimensions
    • Weight
    Edit: Pitch Control (chart #2) (thanks Axon)
    • +/- X%
This post has been edited by Knowzy: Aug 21 2008, 07:03
Axon
post Aug 20 2008, 07:13
Group: Members (Donating)
WmAx's comments are very insightful, but I suspect you and he are not quite seeing eye to eye on price points etc. The DL110 is what, a $130 cartridge? That's more than the cost of some USB turntables. The SL1200 is, somewhat shockingly, still considered a luxurious expense for most of the population. That said, Denon carts (or at least the DL103) have the distinct advantage of having phenomenally rugged suspensions, and are good choices for family-friendly setups, I'd imagine.
I've had a similar mind at some points to make a guide similar to what it sounds like Knowzy is working on. Basically, what people need to know, in decreasing order of importance, is how to choose a turntable that:
  1. Won't f*ck up their records of its own accord. This, most obviously, means avoiding ceramic cartridges (I can't understand why the damn things are still being manufactured!). More subtly, it also means the use of an offset arm instead of a straight arm, an antiskate mechanism, etc. Of course, if it's a P-mount and it's completely misaligned or the VTF or azimuth are way off, that's a big deal too.
  2. Preferrably, sufficiently rugged as to not break if a family member/friend/cleaning maid screws around with it. This favors extremely cartridge suspensions that are particularly rugged - DJ carts and Denon carts come specifically to mind - although the high end Shure has a stylus protection device that allegedly works pretty well too.
  3. Doesn't sound completely obviously bad (low ground hum, acceptable wow/flutter, doesn't skip under reasonable conditions).
  4. Finally, the "finer" points of sound quality - environmental isolation, frequency response, distortion, acoustic resonances, tighter SNR and wow/flutter tolerances, etc. I'd argue that most consumers are not going to be caring about this.
  5. Upgradability: 1/2"/SME mounts, modding potential, counterweight adjustment, etc. Again, not a concern for the lower end tables.
So I guess the executive summary of your article needs to be: For the love of God, buy a turntable with a magnetic cartridge, antiskate, and an offset arm.
I think that alone is going to wipe out >50% of the USB TTs on the market, isn't it?
This post has been edited by Axon: Aug 20 2008, 07:15
RSS Lo-Fi Version Time is now: 1st August 2015 - 11:59
