Song fingerprinting tools, using FooID
musicmusic
post Aug 8 2008, 15:21
Columns UI developer
I found an old copy of libFooID and decided to try and put it to some use. How is another question..
Anyway I came up with a little component that allows you to calculate FooIDs and save them to the file, as well as compare the FooID of two files. Some downloads below:
FooID binary (put this in your foobar2000 folder)
foobar2000 component version 0.3 (experimental)
foobar2000 component version 0.2 (experimental)
libFooID source
Update: Garf has restored the Foosic homepage now
I am not sure how this is useful.. Maybe finding matches within a set of files would be more useful (?) If someone actually downloads this have fun : P
This post has been edited by musicmusic: Mar 15 2009, 15:31
musicmusic
post Aug 15 2008, 15:16
What about being able to play the tracks directly from the results window (double click) instead? That I will add anyway. Maybe a delete command on the shortcut menu as well.
Otherwise yes I could add a button to flatten the tree into a playlist, but the resultant playlist may be slightly confusing.
- musicmusic   Song fingerprinting tools   Aug 8 2008, 15:21
- - Nemphael   Eager to try this. I've tried to get this work...   Aug 8 2008, 23:22
- - musicmusic   Hello, Check that FooID.dll is in the same folder...   Aug 8 2008, 23:47
- - Nemphael   I doubt it, but would it be possible to compare fi...   Aug 9 2008, 01:40
|- - foosion   QUOTE (Nemphael @ Aug 9 2008, 02:40) I do...   Aug 9 2008, 11:40
|- - hesher   This is genius! Where can i find more informat...   Aug 10 2008, 06:59
- - Nemphael   I've tried running it to compare some files an...   Aug 10 2008, 13:12
|- - 2E7AH   so, this component is only for finding duplicates ...   Sep 1 2008, 02:27
- - musicmusic   QUOTE (hesher @ Aug 10 2008, 06:59) This ...   Aug 10 2008, 23:54
- - musicmusic   Version 0.2 released:'Save fingerprints to fil...   Aug 14 2008, 23:55
- - Nemphael   I tried your new version and like the new mass com...   Aug 15 2008, 11:07
- - Garf   Hey, great that someone found a nice use for libF...   Aug 15 2008, 11:23
|- - nilesr   I was wondering if anyone had a copy of the matchi...   Jan 15 2009, 19:03
|- - Milloflex   Maybe try hosting it on a google app engine and se...   Mar 15 2009, 13:42
|- - Garf   QUOTE (Milloflex @ Mar 15 2009, 13:42) Ma...   Mar 15 2009, 14:02
- - musicmusic   QUOTE (Nemphael @ Aug 15 2008, 11:07) I t...   Aug 15 2008, 12:38
|- - OCedHrt   QUOTE (Garf @ Aug 15 2008, 11:23) Hey, g...   Dec 12 2008, 16:28
|- - Garf   QUOTE (musicmusic @ Aug 15 2008, 12:38) W...   Mar 15 2009, 14:15
- - Nemphael   After trying to remove some duplicates, I have a s...   Aug 15 2008, 15:02
|- - odyssey   QUOTE (Nemphael @ Aug 15 2008, 16:02) Aft...   Oct 19 2008, 23:34
- - musicmusic   What about being able to play the tracks directly ...   Aug 15 2008, 15:16
- - MartDann   I think all of your suggestions could be very usef...   Aug 17 2008, 19:24
|- - sabelosimelane   QUOTE (MartDann @ Aug 17 2008, 19:24) I t...   Feb 24 2009, 11:16
- - mpioner   musicmusic Maybe you can make local version foosic...   Aug 26 2008, 13:36
- - Nemphael   With the ability to generate FooID fingerprint and...   Aug 26 2008, 14:26
- - musicmusic   QUOTE (2E7AH @ Sep 1 2008, 02:27) even if...   Oct 20 2008, 17:06
|- - odyssey   QUOTE (musicmusic @ Oct 20 2008, 18:06) Q...   Oct 20 2008, 20:50
- - musicmusic   I meant completely different.   Oct 20 2008, 22:25
- - 2E7AH   i've read the posts, but i was playing with th...   Oct 21 2008, 06:31
|- - Nemphael   QUOTE (2E7AH @ Oct 21 2008, 07:31) perhap...   Oct 21 2008, 12:10
- - odyssey   musicmusic: Would you consider an update that impr...   Dec 15 2008, 11:25
- - Nemphael   Will you consider checking one file against a data...   Dec 15 2008, 11:29
- - Garf   I restored the relevant part of http://foosic.org   Jan 16 2009, 00:15
|- - nilesr   QUOTE (Garf @ Jan 15 2009, 17:15) I resto...   Jan 19 2009, 04:21
|- - partneriflight   QUOTE (Garf @ Jan 16 2009, 00:15) I resto...   Nov 24 2009, 19:52
- - musicmusic   My bad, I just had a look and it seems the compile...   Mar 12 2009, 00:22
- - odyssey   musicmusic, did you see this thread? I think it ha...   Mar 12 2009, 12:25
- - musicmusic   0.3 released: -Comparing more than two pre-calcua...   Mar 14 2009, 20:45
- - Nemphael   I still can't believe just how fast it's b...   Mar 15 2009, 14:52
- - MartDann   Wow, incredible fast. Thank you very much for the ...   Mar 15 2009, 15:51
- - odyssey   musicmusic: Thanks for the ability to save a playl...   Mar 20 2009, 13:09
- - odyssey   I was comparing 32320 items in a playlist and afte...   Mar 20 2009, 13:45
- - musicmusic   Do you mean 0xC0000409? That's STATUS_STACK_BU...   Mar 20 2009, 14:19
|- - odyssey   QUOTE (musicmusic @ Mar 20 2009, 14:19) S...   Mar 23 2009, 12:37
- - Nemphael   Transcoding means a change in audio data, which wi...   May 24 2009, 13:41
|- - Patsoe   QUOTE (Nemphael @ May 24 2009, 13:41) Upo...   May 24 2009, 14:54
- - Nemphael   I've tried this on two different computers, so...   May 24 2009, 15:26
- - musicmusic   I confirm, looking into it...   May 24 2009, 16:37
- - 2E7AH   musicmusic, can fingerprint data be somehow interp...   Jul 28 2009, 00:32
- - odyssey   musicmusic: If you try to "Save fingerprints ...   Nov 6 2009, 10:20
- - musicmusic   Do you have a crash log? (Not sure if the crash su...   Nov 6 2009, 13:36
- - odyssey   It crashes hard, not with the crash-handler. I fig...   Nov 14 2009, 15:04
- - musicmusic   QUOTE (odyssey @ Nov 14 2009, 14:04) It c...   Nov 15 2009, 00:00
- - odyssey   I'm a little puzzled about the results (and/or...   Apr 21 2010, 03:04
- - romor   Can I revive this a bit? I realize that develope...   Nov 2 2012, 06:46
- - foosion   Check the definition of the t_fingerprint structur...   Nov 2 2012, 10:27
- - romor   Thanks foosion I did so naive... Can I ask furthe...   Nov 2 2012, 12:40
- - romor   OK, I get that I should group each 4 bytes in this...   Nov 2 2012, 13:41
- - romor   My previous post is not correct. It may make sense...   Nov 3 2012, 11:39
- - foosion   According to the code in spectrum.c the r field co...   Nov 6 2012, 18:04
- - romor   Thanks foosion. I discarded that idea, because of ...   Nov 6 2012, 19:27
- - foosion   I remember that Garf talked on IRC about the finge...   Nov 6 2012, 19:50
- - Garf   I uploaded some Python source that reads and match...   Nov 8 2012, 13:37
- - romor   Thanks Garf. I tried your suggestion, and here is...   Nov 9 2012, 01:45
|- - Garf   QUOTE (romor @ Nov 9 2012, 01:45) So I as...   Nov 12 2012, 22:43
- - ncmaothvez   romor, are you using Garf's (?) fooid library ...   Nov 13 2012, 02:53
- - romor   Thanks ncmaothvez for you input I'm not rewrit...   Nov 13 2012, 03:33
RSS Lo-Fi Version Time is now: 7th July 2015 - 09:03
