Song fingerprinting tools, using FooID
musicmusic
post Aug 8 2008, 15:21
Columns UI developer
I found an old copy of libFooID and decided to try and put it to some use. How is another question..
Anyway I came up with a little component that allows you to calculate FooIDs and save them to the file, as well as compare the FooID of two files. Some downloads below:
FooID binary (put this in your foobar2000 folder)
foobar2000 component version 0.3 (experimental)
foobar2000 component version 0.2 (experimental)
libFooID source
Update: Garf has restored the Foosic homepage now
I am not sure how this is useful.. Maybe finding matches within a set of files would be more useful (?) If someone actually downloads this have fun : P
This post has been edited by musicmusic: Mar 15 2009, 15:31
musicmusic
post Aug 8 2008, 23:47
Hello,
Check that FooID.dll is in the same folder as foobar2000.exe. (OK, seems you have solved this now.)
If you run the save command it will save the fingerprint in the FINGERPRINT_FOOID field. But to compare two fingerprints you need to interpret the data, so plain text searching won't achieve anything. So maybe some APIs would be useful if anyone would actually use them tongue.gif
If you save the fingerprints first the compare command will use those instead of recalculating the fingerprint (that command doesn't save them).
Agree on the usefulness of comparing one file against a set or finding matches within a set.. The main obstacles are probably creating the UI for these things wink.gif
- musicmusic   Song fingerprinting tools   Aug 8 2008, 15:21
- - Nemphael   Eager to try this. I've tried to get this work...   Aug 8 2008, 23:22
- - musicmusic   Hello, Check that FooID.dll is in the same folder...   Aug 8 2008, 23:47
- - Nemphael   I doubt it, but would it be possible to compare fi...   Aug 9 2008, 01:40
|- - foosion   QUOTE (Nemphael @ Aug 9 2008, 02:40) I do...   Aug 9 2008, 11:40
|- - hesher   This is genius! Where can i find more informat...   Aug 10 2008, 06:59
- - Nemphael   I've tried running it to compare some files an...   Aug 10 2008, 13:12
|- - 2E7AH   so, this component is only for finding duplicates ...   Sep 1 2008, 02:27
- - musicmusic   QUOTE (hesher @ Aug 10 2008, 06:59) This ...   Aug 10 2008, 23:54
- - musicmusic   Version 0.2 released:'Save fingerprints to fil...   Aug 14 2008, 23:55
- - Nemphael   I tried your new version and like the new mass com...   Aug 15 2008, 11:07
- - Garf   Hey, great that someone found a nice use for libF...   Aug 15 2008, 11:23
|- - nilesr   I was wondering if anyone had a copy of the matchi...   Jan 15 2009, 19:03
|- - Milloflex   Maybe try hosting it on a google app engine and se...   Mar 15 2009, 13:42
|- - Garf   QUOTE (Milloflex @ Mar 15 2009, 13:42) Ma...   Mar 15 2009, 14:02
- - musicmusic   QUOTE (Nemphael @ Aug 15 2008, 11:07) I t...   Aug 15 2008, 12:38
|- - OCedHrt   QUOTE (Garf @ Aug 15 2008, 11:23) Hey, g...   Dec 12 2008, 16:28
|- - Garf   QUOTE (musicmusic @ Aug 15 2008, 12:38) W...   Mar 15 2009, 14:15
- - Nemphael   After trying to remove some duplicates, I have a s...   Aug 15 2008, 15:02
|- - odyssey   QUOTE (Nemphael @ Aug 15 2008, 16:02) Aft...   Oct 19 2008, 23:34
- - musicmusic   What about being able to play the tracks directly ...   Aug 15 2008, 15:16
- - MartDann   I think all of your suggestions could be very usef...   Aug 17 2008, 19:24
|- - sabelosimelane   QUOTE (MartDann @ Aug 17 2008, 19:24) I t...   Feb 24 2009, 11:16
- - mpioner   musicmusic Maybe you can make local version foosic...   Aug 26 2008, 13:36
- - Nemphael   With the ability to generate FooID fingerprint and...   Aug 26 2008, 14:26
- - musicmusic   QUOTE (2E7AH @ Sep 1 2008, 02:27) even if...   Oct 20 2008, 17:06
|- - odyssey   QUOTE (musicmusic @ Oct 20 2008, 18:06) Q...   Oct 20 2008, 20:50
- - musicmusic   I meant completely different.   Oct 20 2008, 22:25
- - 2E7AH   i've read the posts, but i was playing with th...   Oct 21 2008, 06:31
|- - Nemphael   QUOTE (2E7AH @ Oct 21 2008, 07:31) perhap...   Oct 21 2008, 12:10
- - odyssey   musicmusic: Would you consider an update that impr...   Dec 15 2008, 11:25
- - Nemphael   Will you consider checking one file against a data...   Dec 15 2008, 11:29
- - Garf   I restored the relevant part of http://foosic.org   Jan 16 2009, 00:15
|- - nilesr   QUOTE (Garf @ Jan 15 2009, 17:15) I resto...   Jan 19 2009, 04:21
|- - partneriflight   QUOTE (Garf @ Jan 16 2009, 00:15) I resto...   Nov 24 2009, 19:52
- - musicmusic   My bad, I just had a look and it seems the compile...   Mar 12 2009, 00:22
- - odyssey   musicmusic, did you see this thread? I think it ha...   Mar 12 2009, 12:25
- - musicmusic   0.3 released: -Comparing more than two pre-calcua...   Mar 14 2009, 20:45
- - Nemphael   I still can't believe just how fast it's b...   Mar 15 2009, 14:52
- - MartDann   Wow, incredible fast. Thank you very much for the ...   Mar 15 2009, 15:51
- - odyssey   musicmusic: Thanks for the ability to save a playl...   Mar 20 2009, 13:09
- - odyssey   I was comparing 32320 items in a playlist and afte...   Mar 20 2009, 13:45
- - musicmusic   Do you mean 0xC0000409? That's STATUS_STACK_BU...   Mar 20 2009, 14:19
|- - odyssey   QUOTE (musicmusic @ Mar 20 2009, 14:19) S...   Mar 23 2009, 12:37
- - Nemphael   Transcoding means a change in audio data, which wi...   May 24 2009, 13:41
|- - Patsoe   QUOTE (Nemphael @ May 24 2009, 13:41) Upo...   May 24 2009, 14:54
- - Nemphael   I've tried this on two different computers, so...   May 24 2009, 15:26
- - musicmusic   I confirm, looking into it...   May 24 2009, 16:37
- - 2E7AH   musicmusic, can fingerprint data be somehow interp...   Jul 28 2009, 00:32
- - odyssey   musicmusic: If you try to "Save fingerprints ...   Nov 6 2009, 10:20
- - musicmusic   Do you have a crash log? (Not sure if the crash su...   Nov 6 2009, 13:36
- - odyssey   It crashes hard, not with the crash-handler. I fig...   Nov 14 2009, 15:04
- - musicmusic   QUOTE (odyssey @ Nov 14 2009, 14:04) It c...   Nov 15 2009, 00:00
- - odyssey   I'm a little puzzled about the results (and/or...   Apr 21 2010, 03:04
- - romor   Can I revive this a bit? I realize that develope...   Nov 2 2012, 06:46
- - foosion   Check the definition of the t_fingerprint structur...   Nov 2 2012, 10:27
- - romor   Thanks foosion I did so naive... Can I ask furthe...   Nov 2 2012, 12:40
- - romor   OK, I get that I should group each 4 bytes in this...   Nov 2 2012, 13:41
- - romor   My previous post is not correct. It may make sense...   Nov 3 2012, 11:39
- - foosion   According to the code in spectrum.c the r field co...   Nov 6 2012, 18:04
- - romor   Thanks foosion. I discarded that idea, because of ...   Nov 6 2012, 19:27
- - foosion   I remember that Garf talked on IRC about the finge...   Nov 6 2012, 19:50
- - Garf   I uploaded some Python source that reads and match...   Nov 8 2012, 13:37
- - romor   Thanks Garf. I tried your suggestion, and here is...   Nov 9 2012, 01:45
|- - Garf   QUOTE (romor @ Nov 9 2012, 01:45) So I as...   Nov 12 2012, 22:43
- - ncmaothvez   romor, are you using Garf's (?) fooid library ...   Nov 13 2012, 02:53
- - romor   Thanks ncmaothvez for you input I'm not rewrit...   Nov 13 2012, 03:33
RSS Lo-Fi Version Time is now: 31st July 2015 - 04:52
