18 Pages V   1 2 3 > »
FLACCL: CUDA-enabled FLAC encoder by Gregory S. Chudov (prev. FlaCuda), Formerly "lossless codecs and CUDA"
gib
post Jul 13 2008, 05:34
With my recent purchase of a 9000 series nVidia graphics card, I started thinking, has anyone investigated if nVidia's CUDA could be useful for lossless compression? I'm not even remotely close to being a programmer, so I haven't a clue how the code works, but it seems like CUDA is valuable for coding/decoding. I know nVidia is already holding a contest to speed up LAME (which ends in about 2 weeks), so perhaps it could be used to speed up lossless compressors? The fastest modes of several codecs are already blazing fast, approaching the limits of hard drives, but perhaps the high-compression modes could be sped-up through CUDA. Maybe, if the speed-up is enough, developers could even implement more ways to gain compression while still maintaining good encoding rates. It would be pretty cool if compression levels like La's best could be done at 50x or something.
Anyway, my curiosity is large, so just thought I'd ask. :)
Martel
post Jul 13 2008, 09:29
This post has been edited by Martel: Jul 13 2008, 10:53
IE4 Rockbox Clip+ AAC@192; HD 668B/HD 518 Xonar DX FB2k FLAC;
Garf
post Jul 13 2008, 10:00
Server Admin
Group: Admin
QUOTE (Martel @ Jul 13 2008, 10:29) *
If I'm not mistaken, lossless coding usually employs dictionary methods (like LZW/LZMA) which generate a lot of random access and branching operations.
Not at all!
Most lossless audio compressors use large predictive LPC filters. This would be an operation that is well fit to a GPU, if it weren't for a small detail: because of the need to be LOSSLESS, the operations are often integer, not floating point. It would be possible to do it in floating point also, but then there is a need to have PRECISELY defined operations, rounding, precision. Exactly what GPU's dont have.
Despite all the hype, there aren't that many things GPUs are actually good at.
gib
post Jul 14 2008, 03:52
Ah, I see now. Thanks very much for the response, Garf.
Gregory S. Chudo...
post Sep 10 2009, 03:27
Here is good news.
An alfa version of flac encoder for GPU.
I only tested it on GTS 250, so i'm eager to hear from people with other cards.
As all my applications, this requires .NET framework.
And this time of course a CUDA-enabled graphics card.
Source code as usual on SourceForge.
UPD1: A bit more optimized version re-tuned to not so paranoid compression levels.
UPD2: added pipe encoding for use with fb2k (encoder parameters: -5 - -o %d)
UPD3: seeking problem with pipe encoding in fb2k fixed, lower compression levels speed up.
UPD4: general speed improvement
UPD5: wasted_bits/lossyWav support
UPD6: final optimizations
UPD7: rice partitioning on GPU (--gpu-only), multi-core CPU utilization support (--cpu-threads #)
UPD8: default compression level changed to -7, rice partitioning on GPU on by default, memory/IO optimizations
UPD9: bugfix release; UPD91 - fb2k pipe input fix
* Download: Attached File  FlaCuda091.rar ( 97.7K ) Number of downloads: 1679
* Old version: Attached File  FlaCuda06.rar ( 84.9K ) Number of downloads: 1002
This post has been edited by Gregory S. Chudov: Jan 10 2010, 17:30
CUETools 2.1.4
Dr_Colossus
post Sep 10 2009, 05:58
Sounds awesome, care to elaborate on the performance for those of us without a CUDA capable card.
Gregory S. Chudo...
post Sep 10 2009, 06:05
Less impressive than i hoped to, but this is only initial version, and GPUs grow faster each day.
On my GTS 250 it's approximately as fast as my C# encoder (which is fast by the way).
FlaCuda -4 achieves the same compression ratio as reference flac -8 (version 1.2.1 on Core 2 Duo@3Gz) at approximately double-triple speed.
FlaCuda -8 is as slow as flac -8, but gives an extra 0.5% of compression ratio.
Would be nice if someone could thoroughly compare them on a different hardware and post his/her results here.
This post has been edited by Gregory S. Chudov: Sep 10 2009, 06:17
CUETools 2.1.4
Grunpfnul
post Sep 10 2009, 09:24
No love for ati? *sniff*
Gregory S. Chudo...
post Sep 10 2009, 09:49
There is love, but there's no implementation ^^
But i guess someone else can do it, now that we have a proof-of-concept
CUETools 2.1.4
Case
post Sep 10 2009, 16:30
Group: Developer (Donating)
I ran some tests with my Core i7 940 (stock speed) and GeForce GTX 285. Original wav file was 237368588 bytes in size. Not too impressive results:
FLAC -5 : Elapsed Time : 00:00:08.268 (181929373 bytes)
FLAC -8 : Elapsed Time : 00:00:30.560 (181788832 bytes)
FlaCuda -4 : Elapsed Time : 00:00:09.204 (181892106 bytes)
FlaCuda -5 : Elapsed Time : 00:00:10.904 (181763725 bytes)
FlaCuda -8 : Elapsed Time : 00:00:12.370 (181676614 bytes)
FlaCuda -11: Elapsed Time : 00:00:23.883 (181734405 bytes)
Gregory S. Chudo...
post Sep 10 2009, 20:34
Thank you!
CUETools 2.1.4
Ron Jones
post Sep 10 2009, 20:44
I'm anxious to see how this would perform on the next generation of NVIDIA hardware (GT300), which is supposedly significantly faster in general computational performance than the previous architecture (G200).
Very exciting -- thank you!
thundat00th
post Sep 10 2009, 21:20
QUOTE (Grunpfnul @ Sep 10 2009, 03:24) *
crying.gif as much as i love ati i wish they had as much support for things as nvidia does (they need to get to work on that hardware havok physics)
maybe the "evergreen" release here in a bit will improve things (i hope)
as far as this goes, i would be interested in lossy gpu encoding, and that might work a bit better regarding the inaccurate floating point calculations
ati stream support crying.gif pwease?
This post has been edited by thundat00th: Sep 10 2009, 21:21
My $.02, may not be in the right currency
hlloyge
post Sep 10 2009, 22:42
Here are my test results:
Klaus Shultze - Dreams Deluxe Edition, size 797 MB
Core2Duo 8200, Geforce 9600GT with passive cooling
Encoding with FLAC 1.2.1 in command line, -6, version from Sourceforge, 38 seconds
And this...
PS D:\temp_2> .\CUETools.FlaCuda.exe -6 '.\Klaus Schulze - Dreams Deluxe Edition.wav'
CUETools.FlaCuda, Copyright Đ 2009 Gregory S. Chudov.
This is free software under the GNU GPLv3+ license; There is NO WARRANTY, to
the extent permitted by law. <http://www.gnu.org/licenses/> for details.
Filename : .\Klaus Schulze - Dreams Deluxe Edition.wav
File Info : 44100kHz; 2 channel; 16 bit; 01:19:00.8800000
Results : 61,11x; 499280528 bytes in 00:01:17.5764372 seconds;
Windows 7 32 bit.
(edit) wrote 10 seconds too much for flac encode...
This post has been edited by hlloyge: Sep 10 2009, 22:43
Gregory S. Chudo...
post Sep 10 2009, 23:33
Post #15
What was the file size for flac -6? We should compare the speed at the same compression ratio, e.g. output file size, not at the same compression level, because e.g. -6 for flac is much lower compression than -6 for flacuda. Please, try to compare flacuda -5 vs flac -8, and compare both execution times and file sizes.
Here's a graph i made of Case's results:
This shows x3 speedup of flac -8 compression.
This post has been edited by Gregory S. Chudov: Sep 10 2009, 23:40
CUETools 2.1.4
Wombat
post Sep 11 2009, 00:33
Post #16
Not to shabby. Tried it on a C2D@3600+GTX260
Dream Theater, Awake
Original 793.976.444 Bytes
Flac 1.21 -8 568.604.561 Bytes ~94 sec. encoding time
Flaccuda -8 567.956.198 Bytes ~53 sec.
I donīt have a recent Flake version at hand so i donīt know how much comes from Cuda alone.
Edit:
Flaccuda -6 568.280.716 Bytes ~48 sec.
This post has been edited by Wombat: Sep 11 2009, 00:50
With 24bit audio you can listen to silence much louder
GHammer
post Sep 11 2009, 02:21
Post #17
This is on a 9500 GT
FlaCuda
Filename : Clocks.wav
File Info : 44100kHz; 2 channel; 16 bit; 00:05:07.4670000
Results : 43.10x; 35657424 bytes in 00:00:07.1331000 seconds;
Flac 1.2.1
Clocks.wav: wrote 35796074 bytes, ratio=0.660
2.91 seconds
Both were just run as <executable> Clocks.wav
Gregory S. Chudo...
post Sep 11 2009, 03:24
Post #18
QUOTE (GHammer @ Sep 11 2009, 05:21) *
Flac 1.2.1
2.91 seconds
That's a bit too small file for comparison. And it's better to compare against flac -8. Default flac compression level is very fast, i don't think it can be beaten by FlaCuda, at least yet. FlaCuda is focusing on higher compression.
CUETools 2.1.4
Lucho
post Sep 11 2009, 08:28
Post #19
GPU audio encoding will be useful when OpenCL get adopted by both ATI and Nvidia for now is just "proof of concept"
hlloyge
post Sep 11 2009, 19:52
Post #20
Here I am again, this time, more detailed:
Flac 1.2.1 vs Cuda 01
File: album.wav 643566044
Windows 7, C2Q9400 @ 2.66 GHz, Geforce 9500 GS
flac -8: wrote 405957413 bytes, ratio=0,631 in 99 seconds
cuda -8: 34,98x; 405731414 bytes in 00:01:44.2910429 seconds;
Is there multicore flac encoder? smile.gif that would be a nice thing to test...
Justin Ruggles
post Sep 12 2009, 02:45
Post #21
QUOTE (hlloyge @ Sep 11 2009, 14:52) *
http://softlab-pro-web.technion.ac.il/Proj.../downloads.html
I haven't tested this personally or done anything about trying to adapt the code for inclusion in Flake.
gib
post Sep 12 2009, 06:10
Post #22
Hey, wow. This topic of mine was bumped, and with proof of concept software to boot. Thank you, Gregory!
Here are my results to add to the data (I used flac 1.2.1 -8 and Flacuda01 -8 as suggested):
CPU: Athlon X2 @ 2.35 GHz
GPU: 9600 GSO @ 600 MHz
File 1: 656647868 bytes
Flac: 466183490 in 148 seconds
cuda: 465898530 in 65 seconds
File 2: 654389948 bytes
Flac: 362792762 in 145 seconds
cuda: 360670158 in 63 seconds
More than 2x faster and better compression too. That's pretty impressive.
PatchWorKs
post Sep 12 2009, 09:40
Post #23
Well, I believe that even a small gain is always welcome.
I'm not a developer, so I dunno if possible, but: what about a liboil-like library but for GPGPU encodings, so *any* codec could benefit from GPU computations ?
hlloyge
post Sep 12 2009, 10:32
Post #24
Again: C2D8200, Geforce 9600GT
album.wav to flac -8
original: 578046380
flac: 344489508 in 80 seconds
cuda: 344226134 bytes in 00:00:52.8150209 seconds
Nice.
Gregory S. Chudo...
post Sep 12 2009, 11:33
Post #25
QUOTE (PatchWorKs @ Sep 12 2009, 12:40) *
Not sure. The code i wrote is quite codec specific. The catch is in a relatively slow connection between CPU and GPU. I had to implement practically the whole FLAC algorithm on the device, so that i won't have to transfer intermediate values between host and GPU, only the final result.
FLAC turned out to be very convenient for GPU. Probably the most convenient. One look at e.g. ALAC algorithm was enough to understand it can never get the same benefit.
QUOTE (hlloyge @ Sep 12 2009, 13:32) *
original: 578046380
Nice.
Thank you. And how about FlaCuda -5? It should provide enough compression to beat flac -8.
This post has been edited by Gregory S. Chudov: Sep 12 2009, 11:34
CUETools 2.1.4
RSS Lo-Fi Version Time is now: 2nd February 2015 - 00:27
